Home » Archived » XML Schema Definition (XSD) » Annotation appinfo troubles
Re: Annotation appinfo troubles [message #42416 is a reply to message #42357] |
Wed, 28 April 2004 11:45 |
Valentin,
You'll need to show at least some code to get useful help. (Or better yet, a
small example that reproduces the problem.) Calling
createApplicationInformation will do two things; it will ensure that an
underlying DOM exists by calling updateElement, if neccesarry, and then it will
create the node. So unless calling updateElement is causing a problem,
creating the appinfo should have no impact beyond what you do with it after.
Note that the XSDPrototypicalSchema example creates appinfo and it works
okay...
Valentin Baciu wrote:
> I am trying to add appinfo to an annotation for an xsd:enumeration (used on
> an integer based restricted simple type - let's call it "foo").
> If I use createApplicationInformation to create the appinfo on the
> enumeration, an element declaration based on the type containing the
> enumeration is printed without the type reference:
> <xsd:complexType name="tComplex">
> <xsd:sequence>
> <xsd:element name="baz" type="xsd:string"/>
> <xsd:element name="bar"/>
> <xsd:element name="ttt"/>
> The annotation, appinfo and my custom appinfo child elements are printed
> fine together with the simple type containing the enumeration.
> If I comment out the code that creates the appinfo, the element declaration
> is printed with the proper type:
> <xsd:sequence>
> <xsd:element name="bar" type="tns:foo"/>
> <xsd:element name="ttt" type="xsd:string"/>
> I've tried commenting out the code that adds my own custom "any" content
> under appinfo. The result is the same.
> What is strange is that even elements based on xsd types (for example
> xsd:string) are printed without their type as soon as one call to
> createApplicationInformation is being made..
> Unfortunately, I can't attach the entire code due to dependencies on other
> libraries.
> I am running version 1.1.0. Any suggestions are appreciated.
> Regards,
> Valentin
Re: Annotation appinfo troubles [message #42469 is a reply to message #42416] |
Wed, 28 April 2004 15:55 |
foo bar Messages: 55 Registered: July 2009 |
Member |
Thanks for the reply Ed,
I've created a sample class that illustrates the problem. I'm attaching it.
If you have some time to try it, please make sure you run it under 1.1.0.
Valentin
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:408F994D.29B90297@ca.ibm.com...
> Valentin,
a
will
after.
> okay...
> > Hi,
on
> > <xsd:sequence>
declaration
> > <xsd:sequence>
other
> > libraries.
> > Regards,
> > Valentin
Re: Annotation appinfo troubles [message #42664 is a reply to message #42469] |
Wed, 28 April 2004 20:23 |
Valentin,
Thanks for the sample, I really appreciate that! Please open a bugzilla defect
with this sample code. As a workaround, call schema.updateElement at the end and
it should fix things up.
> Valentin
> > Valentin,
> a
> will
> after.
> > okay...
> > > Hi,
> on
> > > <xsd:sequence>
> declaration
> > > <xsd:sequence>
> other
> > > libraries.
> > > Regards,
> > > Valentin
> AnnotationSample.java Type: unspecified type (application/octet-stream)
> Encoding: x-uuencode
Re: Annotation appinfo troubles [message #42819 is a reply to message #42664] |
Thu, 29 April 2004 15:16 |
Member |
Done, https://bugs.eclipse.org/bugs/show_bug.cgi?id=60438
The workaround worked ;-)
news:409012C6.D483F563@ca.ibm.com...
> Valentin,
defect
end and
it.
1.1.0.
> > Valentin
> > > Valentin,
yet,
> > a
an
then it
> > will
problem,
> > after.
works
> > > okay...
> > > > Hi,
(used
> > on
> > > > <xsd:sequence>
printed
> > declaration
> > > > <xsd:sequence>
content
example
> > other
> > > > libraries.
> > > > Regards,
> > > > Valentin
Re: Annotation appinfo troubles [message #586131 is a reply to message #42357] |
Ed Merks Messages: 33113 Registered: July 2009 |
Valentin,
okay...
> <xsd:sequence>
> <xsd:sequence>
> libraries.
> Regards,
> Valentin
Ed Merks
Re: Annotation appinfo troubles [message #586155 is a reply to message #42416] |
Member |
Valentin
> Valentin,
a
will
after.
> okay...
> > Hi,
on
> > <xsd:sequence>
declaration
> > <xsd:sequence>
other
> > libraries.
> > Regards,
> > Valentin
Re: Annotation appinfo troubles [message #586254 is a reply to message #42469] |
Valentin,
> Valentin
> > Valentin,
> a
> will
> after.
> > okay...
> > > Hi,
> on
> > > <xsd:sequence>
> declaration
> > > <xsd:sequence>
> other
> > > libraries.
> > > Regards,
> > > Valentin
Ed Merks
Re: Annotation appinfo troubles [message #586340 is a reply to message #42664] |
Member |
> Valentin,
defect
end and
it.
1.1.0.
> > Valentin
> > > Valentin,
yet,
> > a
an
then it
> > will
problem,
> > after.
works
> > > okay...
> > > > Hi,
(used
> > on
> > > > <xsd:sequence>
printed
> > declaration
> > > > <xsd:sequence>
content
example
> > other
> > > > libraries.
> > > > Regards,
> > > > Valentin
Current Time: Fri Mar 29 07:43:31 GMT 2024
Powered by FUDForum. Page generated in 0.03405 seconds
