Home » Eclipse Projects » DTP » "No connection" on a database that I am connected to
"No connection" on a database that I am connected to [message #42354] Thu, 28 February 2008 07:58 Go to next message
Jeff Lins is currently offline Jeff LinsFriend
Member
I have been going through the wiki article to set up Derby with DTP for
the first time:
http://wiki.eclipse.org/index.php/Getting_Started_with_DTP
I have everything set up and I can execute the stored procedure talked
about in the article but when I try to execute my own sql as the article
describes, it doesn't work. The sql is:
SELECT * FROM SYS.SYSTABLES;
In the results view, the status field on the left shows as failed and it
says "no current connection" on the status tab to the right. I am
definately connected since I can browse through the database in the Data
Source Explorer and even execute stored procedures successfully. On my
sql file I have specified all the information in the connection profile.
I don't get it. Am I missing something here?
Re: "No connection" on a database that I am connected to [message #42414 is a reply to message #42354] Thu, 28 February 2008 16:01 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
If you right-click on the SQL scrapbook in a blank space, you should see a
"Set Connection" menu item. Also, at the top there is a series of drop-down
lists to select the type of connection profile (Derby), name of th eprofile
(MyProfile), and if it's connected, it'll show "Status: Connected" in that
bar also.
Hope that helps.
--Fitz
"Gigaplex" <gigaplex08@gmail.com> wrote in message
news:fq5plc$g42$1@build.eclipse.org...
>I have been going through the wiki article to set up Derby with DTP for the
>first time:
> Source Explorer and even execute stored procedures successfully. On my sql
Re: "No connection" on a database that I am connected to [message #42436 is a reply to message #42414] Thu, 28 February 2008 17:14 Go to previous messageGo to next message
Member
Yeah, I filled out the stuff at the top and it shows "Status: Connected"
there. That's why I'm so confused by this. I haven't tried right
clicking and using "Set Connection" though so I will give that a shot.
Don't they do the same thing though?
> bar also.
> Hope that helps.
> --Fitz
>> first time:
Re: "No connection" on a database that I am connected to [message #42490 is a reply to message #42436] Fri, 29 February 2008 02:22 Go to previous messageGo to next message
Member
Using the "Set Connection" menu item worked. If I right click on the
connection in the DSE and connect that way, I cannot execute the query
but if I connect through the "Set Connection" menu item, the query will
work. Is this a bug? I can't imagine it's supposed to work that way. It
seems like I should be able to set the connection using the drop down
boxes at the top of the SQL scrap book and never have to use the "Set
Connection" menu item if I don't want to, right?
> Connected" there. That's why I'm so confused by this. I haven't tried
> right clicking and using "Set Connection" though so I will give that a
> shot. Don't they do the same thing though?
>> see a "Set Connection" menu item. Also, at the top there is a series
>> of drop-down lists to select the type of connection profile (Derby),
>> name of th eprofile (MyProfile), and if it's connected, it'll show
>> "Status: Connected" in that bar also.
>> Hope that helps.
>> --Fitz
>>> for the first time:
>>> talked about in the article but when I try to execute my own sql as
>>> the article describes, it doesn't work. The sql is:
>>> and it says "no current connection" on the status tab to the right.
>>> I am definately connected since I can browse through the database in
>>> the Data Source Explorer and even execute stored procedures
>>> successfully. On my sql file I have specified all the information in
Re: "No connection" on a database that I am connected to [message #42529 is a reply to message #42490] Fri, 29 February 2008 04:25 Go to previous message
This certainly sounds like a bug. I'd register it against SQL Tools in DTP
if you could create a Bugzilla entry for it.
news:fq7qbc$468$1@build.eclipse.org...
> connection in the DSE and connect that way, I cannot execute the query but
> if I connect through the "Set Connection" menu item, the query will work.
> Is this a bug? I can't imagine it's supposed to work that way. It seems
> like I should be able to set the connection using the drop down boxes at
> the top of the SQL scrap book and never have to use the "Set Connection"
>> there. That's why I'm so confused by this. I haven't tried right clicking
>> and using "Set Connection" though so I will give that a shot. Don't they
>>> a "Set Connection" menu item. Also, at the top there is a series of
>>> drop-down lists to select the type of connection profile (Derby), name
>>> of th eprofile (MyProfile), and if it's connected, it'll show "Status:
>>> Hope that helps.
>>> --Fitz
>>>> the first time:
>>>> it says "no current connection" on the status tab to the right. I am
>>>> Data Source Explorer and even execute stored procedures successfully.
>>>> On my sql file I have specified all the information in the connection
>>>> profile.
Re: "No connection" on a database that I am connected to [message #590240 is a reply to message #42354] Thu, 28 February 2008 16:01 Go to previous message
Brian Fitzpatrick is currently offline Brian FitzpatrickFriend
bar also.
Hope that helps.
--Fitz
>first time:
Re: "No connection" on a database that I am connected to [message #590249 is a reply to message #42414] Thu, 28 February 2008 17:14 Go to previous message
Member
> bar also.
> Hope that helps.
> --Fitz
>> first time:
Re: "No connection" on a database that I am connected to [message #590269 is a reply to message #42436] Fri, 29 February 2008 02:22 Go to previous message
Member
>> Hope that helps.
>> --Fitz
>>> for the first time:
Re: "No connection" on a database that I am connected to [message #590287 is a reply to message #42490] Fri, 29 February 2008 04:25 Go to previous message
>>> Hope that helps.
>>> --Fitz
>>>> the first time:
>>>> profile.
Previous Topic:Connecting to Sybase via JDBC - Only see Schema under each Table
Next Topic:Connecting to Sybase via JDBC - Only see Schema under each Table
Current Time: Thu Jun 24 13:44:11 GMT 2021
Powered by FUDForum. Page generated in 0.01845 seconds
