Re: Problems copying an XSDSchema [message #42345 is a reply to message #42314] |
Tue, 27 April 2004 22:34 |
Dennis,
The XSD model doesn't have all the right features set to be derived to avoid
generically copying things that should not be copied because they are computed.
Use cloneConcreteComponent if you need to do a copy. But you probably want to
copy the DOM itself anyway. And why not use Resource.save with an output stream
for where you want to save?
Dennis Fuglsang wrote:
> For the purpose of performing a "save as" type operation on an XSDResource I
> create a new resource instance and then attempt to copy the root EObjects
> and then add the copies to the new resource's contents. When executing the
> copy on a XSDResource composed of XSDSimpleTypeDefinition instances I
> encounter an IllegalArgumentException. It appears that the
> XSDSimpleTypeDefinition.patch code is attempting to set a member type
> definition that already exists in the list. My question is should I be able
> to copy a XSDSchema instance and paste it into a new XSDResource ? Are
> there special considerations that need to be taken into account when copying
> an XSDSchema instance?
> Thread [main] (Suspended (exception IllegalArgumentException))
> EObjectEList(BasicEList).set(int, Object) line: 543
> BasicEList$EListIterator.set(Object) line: 1398
> XSDSimpleTypeDefinitionImpl.patch() line: 680
> XSDSchemaImpl(XSDConcreteComponentImpl).patch() line: 513
> XSDSchemaImpl.patch() line: 1494
> XSDSchemaImpl.traverseToRootForPatching() line: 1468
> XSDSchemaImpl.adoptContent(EReference, XSDConcreteComponent) line: 1767
> XSDSchemaImpl(XSDConcreteComponentImpl).eNotify(Notification ) line: 1133
> NotificationChainImpl.dispatch(Notification) line: 115
> NotificationChainImpl.dispatch() line: 103
> EObjectContainmentEList(NotifyingListImpl).addAllUnique(int, Collection)
> line: 342
> EObjectContainmentEList(NotifyingListImpl).addAllUnique(Coll ection) line:
> 294
> EObjectContainmentEList(BasicEList).addAll(Collection) line: 675
> EcoreUtil$Copier.copyContainment(EReference, EObject, EObject) line: 387
> EcoreUtil$Copier.copy(EObject) line: 365
> EcoreUtil$Copier.copyAll(Collection) line: 336
> EcoreUtil.copyAll(Collection) line: 300
> Thanks in advance,
> Dennis Fuglsang
Re: Problems copying an XSDSchema [message #586101 is a reply to message #42314] |
Ed Merks Messages: 33140 Registered: July 2009 |
Dennis,
> line: 342
> 294
> Thanks in advance,
> Dennis Fuglsang
Ed Merks
FUDForum. Page generated in 0.03724 seconds
