Home » Eclipse Projects » Mylyn » Trac Calendar, Schedule
Re: Trac Calendar, Schedule [message #42530 is a reply to message #42501] |
Wed, 06 February 2008 10:27 |
Geraint Hywel Messages: 23 Registered: July 2009 |
Hi Steffen.
Steffen Pingel wrote:
> Please file a bug if you would like to see support for additional plugins
> or custom fields:
> To support common repository configurations I would like to focus
> integration on the most popular (and supported) Trac plug-ins. If there is
> a great demand for synchronizing fields (e.g. due dates which seems very
> sensible) we could also consider adding additional settings in Mylyn.
Understood. I'm still relatively new to Trac, so I can't say with any
certainty which Calendar plugins, if any, are popular in Trac. However,
I'm scoping around TracHacks a bit, so it may become apparent to me in due
course. If and when that occurs, I'll file a bug, as you suggest.
The thought about using custom fields was just me thinking aloud. If there
is no dominant Calendar plug-in for Trac, it would be a relatively easy way
of significantly improving the functionality of Mylyn's Trac connector.
That said, I fully appreciate, and concur with, your desire to support
common repository configurations.
Many thanks for your reply.
G.
Re: Trac Calendar, Schedule [message #43040 is a reply to message #42530] |
Tue, 12 February 2008 14:39 |
>> is a great demand for synchronizing fields (e.g. due dates which seems
>> very sensible) we could also consider adding additional settings in
>> Mylyn.
No luck on existing Trac plug-ins. I raised this issue on the Trac Users'
mailing list, but this also failed to yield a positive outcome:
http://thread.gmane.org/gmane.comp.version-control.subversio n.trac.general/18195
That being the case, I'm inclined to suggest that:
i) The functionality gets added to Mylyn's Trac Connector via custom fields.
ii) Once the names of those custom fields are established, a proposal is
made for a Trac plug-in that would automatically add those fields to a Trac
environment.
If anyone wants to chip in, now would be a good time. Otherwise I'll just
go ahead a file a feature request, as previously suggested.
G.
Re: Trac Calendar, Schedule [message #587507 is a reply to message #42501] |
Hi Steffen.
> or custom fields:
G.
Re: Trac Calendar, Schedule [message #587707 is a reply to message #42530] |
>> Mylyn.
environment.
G.
Current Time: Wed Apr 24 22:03:27 GMT 2024
Powered by FUDForum. Page generated in 0.03376 seconds
