Connection refused on http playback [message #42142] |
Wed, 23 November 2005 19:14 |
Originally posted by: newbie.xxxx.com
I can record a Http session without any problem But when i try to play it
back I get:
!ENTRY org.eclipse.hyades.test.core 4 0 2005-11-23 13:23:34.438
!MESSAGE IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.core.runtime.CoreException
!STACK 1
org.eclipse.core.runtime.CoreException: IWAT4039E The Test Execution
Harness reported the following problems:java.net.ConnectException:
Connection
refusedorg.eclipse.hyades.internal.execution.core.file.Serve rNotAvailableException:
java.net.ConnectException: Connection refused
at
org.eclipse.hyades.test.core.launch.delegates.AbstractLaunch ConfigurationDelegate2.launch(AbstractLaunchConfigurationDel egate2.java:178)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:733)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:931)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!SUBENTRY 1 org.eclipse.hyades.test.core 4 0 2005-11-23 13:23:34.438
problems:java.net.ConnectException: Connection
Port 10002 is opened and tomcat is running on port 80. The capture was
made from my localhost server.
The last few lines of the Agent Controller shows:
<CommonBaseEvent creationTime="2005-11-23T18:47:53.984000Z"
globalInstanceId="AFE383E9648347DFA47479EC29577BE7" msg="Process 2972
exited" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine"
componentIdType="Application" location="192.168.1.101" locationType="IPV4"
processId="2648" subComponent="..\RAServer\util.c"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
Any Idea ??
FUDForum. Page generated in 0.02891 seconds
