Home » Modeling » EMF » calling genmodel dynamic templates stored into plugins
calling genmodel dynamic templates stored into plugins [message #415810] Tue, 08 January 2008 10:16 Go to next message
Cyril Faucher is currently offline Cyril FaucherFriend
Member
In a genmodel file, I have tried to call dynamic templates files that
are stored into my current workspace: it works.
After that, I have tried to call the same dynamic templates files that
are stored into my plugin installation: it does not work.
Is there a workaround to call dynamic templates that are stored into
plugins ?
Cyril.
Cyril Faucher
IRISA-INRIA - Rennes, France
[Breathe life into your metamodels www.kermeta.org]
Re: calling genmodel dynamic templates stored into plugins [message #415819 is a reply to message #415810] Tue, 08 January 2008 13:48 Go to previous messageGo to next message
--------------000605080200050308020302
Cyril,
If you use platform:/plugin/<plugin-ID> in the template path it should
end up in this code path in JETEmitter to look for the compiled
templates in the runtime environment
else if (templateURI.isPlatformPlugin())
final Bundle bundle =
Platform.getBundle(templateURI.segment(1));
if (bundle != null)
// Define a class loader that will look up the class in
the bundle,
// and if it doesn't find it there, will look in the parent.
theClassLoader =
new URLClassLoader(new URL [0], jetEmitter.classLoader)
public Class<?> loadClass(String className) throws
ClassNotFoundException
try
return bundle.loadClass(className);
catch (ClassNotFoundException classNotFoundException)
return super.loadClass(className);
Cyril Faucher wrote:
> plugins ?
> Best regards,
> Cyril.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Cyril,<br>
<br>
If you use platform:/plugin/&lt;plugin-ID&gt; in the template path it
should end up in this code path in JETEmitter to look for the compiled
templates in the runtime environment<br>
<br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; else if (templateURI.isPlatformPlugin())<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; final Bundle bundle =
Platform.getBundle(templateURI.segment(1));<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (bundle != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; // Define a class loader that will look up the class in
the bundle,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; // and if it doesn't find it there, will look in the
parent.<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; //<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; theClassLoader = <br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; new URLClassLoader(new URL [0], jetEmitter.classLoader)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; @Override<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; public Class&lt;?&gt; loadClass(String className)
throws ClassNotFoundException<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; try<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return bundle.loadClass(className);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; catch (ClassNotFoundException
classNotFoundException)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return super.loadClass(className);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; };<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }</small><br>
<br>
<br>
<blockquote cite="mid:flviii$c7c$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
plugins ?
<br>
<br>
<br>
Cyril.
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000605080200050308020302--
Ed Merks
Re: calling genmodel dynamic templates stored into plugins [message #415839 is a reply to message #415819] Wed, 09 January 2008 12:57 Go to previous message
Member
Hi Ed,
Thanks to your reply, for further reasons I have my own "generator"
class, so I have added the missing plugin id like that:
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries , xyz, xyz)
and now it works in deployed mode.
Cyril.
Ed Merks a écrit :
> Cyril,
> if (bundle != null)
> the bundle,
> theClassLoader =
> @Override
> try
>> Hi,
>> plugins ?
>> Best regards,
>> Cyril.
Cyril Faucher
Previous Topic:EMF Change plugin
Next Topic:different behaviour when run from the IDE to when ran the exported product ..
Current Time: Wed Jan 20 06:46:48 GMT 2021
Powered by FUDForum. Page generated in 0.02268 seconds
