Re: Why is .ecore file copied to generated model impl package? [message #414683 is a reply to message #414681] |
Fri, 16 November 2007 12:28 |
h1055071 Messages: 335 Registered: July 2009 |
Ed Merks wrote:
> Phillip,
> If you turn off, initialize by loading and you get the error about
> exceeding the byte code limit for a method, you'll have to turn it back
> on again. The .ecore that's produced isn't just a copy of the one you
> started with. It's produced by the generator and is specialized to
> refer to other packages via the nsURI rather than via their location in
> the models folder; you might not notice that if your model doesn't
> depend on other models, but it's very important.
> Phillip Beauvoir wrote:
>> Ed Merks wrote:
>>> Phillip,
>>> This is controlled by the GenPackage property "Initialize By Loading
>>> " set to true. It's initialized to true for models that are so large
>>> they're likely to result in an XyzPackageImpl that exceeds Java's
>>> byte code limits.
>>>> Hi.
>>>> I have three .ecore and .genmodel files created from 3 XSD Schema
>>>> files. When I generate the model code from one of the .genmodel
>>>> files the corresponding .ecore file is copied to the source
>>>> package's "impl" folder. This does not happen for the other two
>>>> .genmodel's generated model code. Does anybody know why? I would
>>>> like to stop this happening.
>>>> Thanks,
>>>> PB
>> Ed, thanks for the quick answer.
>> Indeed the XSD the model is based on is quite large and the resulting
>> "ImsldV1p0PackageImpl.java" class is big too.
>> How do the two .ecore files stay in synch? Is it copied over anew each
>> time that I generate the model code? What would happen if I turn off
>> "Initialize By Loading"? Is it best to keep it turned on?
>> And thanks for taking the time to be so pro-active on this newsgroup!
>> PB
OK, thanks for that info, Ed. I'll leave it turned on.
BTW - I did a text "diff" beteen the original .ecore file and the
generated one and could only see one difference - an eAnnotations entry
was removed from the generated one. Otherwise they are the same.
PB
Re: Why is .ecore file copied to generated model impl package? [message #414684 is a reply to message #414683] |
Fri, 16 November 2007 12:46 |
Ed Merks Messages: 33137 Registered: July 2009 |
Phillip,
Yep, if there are no dependencies on other models you won't see much
difference. I assume the annotation was related to documentation?
There is a property to control whether documentation annotations end up
in the generated model..
> Ed Merks wrote:
>> Phillip,
>> back on again. The .ecore that's produced isn't just a copy of the
>> one you started with. It's produced by the generator and is
>> specialized to refer to other packages via the nsURI rather than via
>> their location in the models folder; you might not notice that if
>> your model doesn't depend on other models, but it's very important.
>>> Ed Merks wrote:
>>>> Phillip,
>>>> Loading " set to true. It's initialized to true for models that
>>>> are so large they're likely to result in an XyzPackageImpl that
>>>> exceeds Java's byte code limits.
>>>>> Hi.
>>>>> Thanks,
>>>>> PB
>>> resulting "ImsldV1p0PackageImpl.java" class is big too.
>>> each time that I generate the model code? What would happen if I
>>> turn off "Initialize By Loading"? Is it best to keep it turned on?
>>> PB
> entry was removed from the generated one. Otherwise they are the same.
> PB
Ed Merks
Re: Why is .ecore file copied to generated model impl package? [message #414688 is a reply to message #414684] |
Fri, 16 November 2007 12:55 |
Yes, it was.
OK, many thanks for the help, Ed. Just trying to get an understanding
of the process.
Thanks once again.
PB
Ed Merks wrote:
> Phillip,
>> Ed Merks wrote:
>>> Phillip,
>>>> Ed Merks wrote:
>>>>> Phillip,
>>>>>> Hi.
>>>>>> Thanks,
>>>>>> PB
>>>> PB
>> PB
FUDForum. Page generated in 0.02573 seconds
