Home » Eclipse Projects » XML Schema Definition (XSD) » short question on minOccurs and maxOccurs on XSDElementDeclaration
short question on minOccurs and maxOccurs on XSDElementDeclaration [message #41823] Tue, 20 April 2004 11:51 Go to next message
Joachim Lusiardi is currently offline Joachim LusiardiFriend
hello,
i have the following xml schema snippet:
<xs:element name="vorname" type="xs:string" maxOccurs="4"/>
how do i get the maxOccurs from the XSDElementDeclaration?
Or do i have to think it real over?
greets
Joachim Lusiardi
Re: short question on minOccurs and maxOccurs on XSDElementDeclaration [message #41884 is a reply to message #41823] Tue, 20 April 2004 15:05 Go to previous messageGo to next message
Joachim,
The maxOccurs attribute is on the XSDParticle not on the
XSDElementDeclaration.
Joachim Lusiardi wrote:
> hello,
> greets
> Joachim Lusiardi
Re: short question on minOccurs and maxOccurs on XSDElementDeclaration [message #42003 is a reply to message #41884] Tue, 20 April 2004 20:15 Go to previous messageGo to next message
Originally posted by: joachim.lusiardi.web.de
Hello again,
sorry for the question, but a can't find any method to access this
XSDParticle directly. org.eclipse.emf.ecore.EObject.eContainer returns
an XSDParticle if i have min- or maxOccurs set. Wouldn't in be better to
have a method to return the XSDParticle or null if there is no XSDParticle?
Greetz
Joachim
Ed Merks wrote:
> Joachim,
>> hello,
>> greets
>> Joachim Lusiardi
Re: short question on minOccurs and maxOccurs on XSDElementDeclaration [message #42034 is a reply to message #42003] Tue, 20 April 2004 20:39 Go to previous message
Joachim,
In general I do not like to have named "container" references unless there is
only one possible container because many things can be contained in many
different places so you would tend to have a lot of container references where
only one can be non-null at any point in time. An element can be contained by
a schema or by a particle, so there aren't so many for this case, but for
something like a simple type, there are many more possible containers, i.e., a
schema, a simple type, a complex type, an element, an attribute, a redefine...
If xsdElementDeclaration.isGlobal is false xsdElementDeclaration.getContainer()
will be an XSDParticle.
joachim lusiardi wrote:
> Hello again,
> Greetz
> Joachim
> Ed Merks wrote:
> > Joachim,
> >> hello,
> >> greets
> >> Joachim Lusiardi
Re: short question on minOccurs and maxOccurs on XSDElementDeclaration [message #585838 is a reply to message #41823] Tue, 20 April 2004 15:05 Go to previous message
Joachim,
> hello,
> greets
> Joachim Lusiardi
Ed Merks
Re: short question on minOccurs and maxOccurs on XSDElementDeclaration [message #585900 is a reply to message #41884] Tue, 20 April 2004 20:15 Go to previous message
Hello again,
Greetz
Joachim
Ed Merks wrote:
> Joachim,
>> hello,
>> greets
>> Joachim Lusiardi
Re: short question on minOccurs and maxOccurs on XSDElementDeclaration [message #585912 is a reply to message #42003] Tue, 20 April 2004 20:39 Go to previous message
Joachim,
> Hello again,
> Greetz
> Joachim
> Ed Merks wrote:
> > Joachim,
> >> hello,
> >> greets
> >> Joachim Lusiardi
Ed Merks
Previous Topic:Processing complexTypes derived by extension
Next Topic:XsdValidation
Current Time: Thu Jul 29 22:52:55 GMT 2021
Powered by FUDForum. Page generated in 0.02309 seconds
