Home » Modeling » EMF » Ecore + XMI
Ecore + XMI [message #412912] Wed, 12 September 2007 08:00 Go to next message
Youmm P. is currently offline Youmm P.Friend
I feel stupid but I can't find the XMIResourceImpl class but I installed
all EMF plugin from Europa.
I tried "import org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl" but
org.eclipse.emf.ecore.xmi can't be resolved.
Any ideas ?
Re: Ecore + XMI [message #412914 is a reply to message #412912] Wed, 12 September 2007 09:40 Go to previous messageGo to next message
Felix Dorner is currently offline Felix DornerFriend
Youmm P. wrote:
> Hello,
> Any ideas ?
Did you add org.eclipse.emf.ecore.xmi_2.x.x.x.jar (from your emf plugin
installation folder) to the classpath?
Felix
Re: Ecore + XMI [message #412915 is a reply to message #412914] Wed, 12 September 2007 10:17 Go to previous messageGo to next message
OK. Problem solved by specifying the update site of EMF, not the one of
Europa, otherwise I didn't have such a file.
Why Eclipse can't automaticaly handle the import for
org.eclipse.emf.ecore.xmi while it works for org.eclipse.ecore.resource ?
Re: Ecore + XMI [message #412924 is a reply to message #412915] Wed, 12 September 2007 11:57 Go to previous messageGo to next message
Youmm,
Normally only the plugins you add via the Dependencies tab of the
MANIFEST.MF editor will have their classes available for import.
> of Europa, otherwise I didn't have such a file.
Ed Merks
Re: Ecore + XMI [message #1838711 is a reply to message #412914] Thu, 04 March 2021 01:23 Go to previous message
N Rao Bommela is currently offline N Rao BommelaFriend
If any one still experiencing issue with this problem try creating dependencies to your plug in file.
Step 1:
open your plug-in file [usually u find it at bottome of your project files]
Step 2: select dependencies option
step 3: Select Add option and add
step 4: step 3: Select Add option and add
now check your program. I guess your problem is solved.
Thank you
ITS BNR
Previous Topic:[CDO] Oracle DB Adapter for CDO server
Next Topic:Ecore - inherited derived attributes
Current Time: Tue Oct 04 02:58:50 GMT 2022
Powered by FUDForum. Page generated in 0.01972 seconds
