Home » Archived » Hibachi » Problem with toolchain
Problem with toolchain [message #3592] |
Sat, 03 May 2008 19:38  |
Originally posted by: seb.morand.gmail.com
Hi people,
I have problem with my toolchain. No toolchain are available on my installation.
Could someone export his own toolchain and give it to me so that I'll be able to
import mine.
Button add is mysteriously unavailable.
Thanks by advance for help.
Sebastien
Re: Problem with toolchain [message #3625 is a reply to message #3592] |
Wed, 07 May 2008 21:46   |
Originally posted by: trg.world.REMOVETHIS.std.com
"Toolchain" means Ada compiler and tools. That is not delivered with
Hibachi. Assuming you don't have a vendor supported Ada environment (i.e.
Objectada from Aonix, or GNATPro from AdaCore), you can get a gpl'ed version
of GNAT from sourceforge (http://gnuada.sourceforge.net/) or the Libre site
( libre.adacore.com). I think the FSF ada compiler should work too
(ftp://ftp.gnu.org/), but AFAIK it hasn't been tried. I may be wrong, but I
have the impression that the sourceforge distros have more platforms
available than libre.
Once you have installed the Ada compiler/debugger, the button will be usuble
when you are pointing to the correct directory.
BTW, We hope to be able to create a distro that includes an Ada compiler,
but we won't be able to host it on the Eclipse servers, since the compiler
will be gpl'ed, which is incompatable with EPL;
Tom
"Sebastien Morand" <seb.morand@gmail.com> a
Re: Problem with toolchain [message #3658 is a reply to message #3625] |
Thu, 08 May 2008 07:33   |
Actually I found out the problem. There is no compiler type installed.
I'm runinng FreeBSD and I tried to modify the jar file in order that FreeBSD get
the plugin working and it does except that when you add a compiler you have to
choose the compiler type (ObjectAda, Gnat, etc.) ... but this lis is empty so,
I'm unable to add a tool chain.
Is there a way to get the plugin working under FreeBSD ? I know there is no code
issue since it's java ... it's just in the declaration of the features which are
supporting only Solaris, Linux and windows ... what a pity.
Sebastien
> Tom
> "Sebastien Morand" <seb.morand@gmail.com> a écrit dans le message de news:
> fvietl$s4f$1@build.eclipse.org...
> | Hi people,
> installation.
> able to
> | import mine.
> | Sebastien
Re: Problem with toolchain [message #3691 is a reply to message #3658] |
Mon, 12 May 2008 22:20  |
You might be able to use the Linux binary and choose the GNAT toolchain. I'm
not familar with FreeBSD, so I don't know the directory structure of the Ada
installation, but perhaps you may have to add some symbolic links if the
directory structure/executable names are different from Linux gnat
installation.
-Tom
Re: Problem with toolchain [message #565582 is a reply to message #3592] |
Tom
Re: Problem with toolchain [message #565601 is a reply to message #3625] |
Sebastien
> Tom
> | Hi people,
> installation.
> able to
> | import mine.
> | Sebastien
Re: Problem with toolchain [message #565630 is a reply to message #3658] |
installation.
-Tom
Current Time: Tue Jul 05 16:58:51 GMT 2022
Powered by FUDForum. Page generated in 0.02221 seconds
