Home » Archived » Buckminster » Materialzing a custom target platform from multiple repositories
Materialzing a custom target platform from multiple repositories [message #412222] Thu, 30 July 2009 08:56 Go to next message
I now have an example RCP-product build working. Yay! However, I still have
a few things to achieve before I can use buckminster for 'real' builds.
One of those things is having a target platform which consists of multiple
feature from different locations. For example to include the emf runtime as
well as rcp. One idea I had was to create a new feautre project and have the
feature.xml include all the required features of the targetPlatform and then
materialize this.
I tried to test this by modifying my example MailApp but it doesn't work. My
guess is the p2 materilizer is treat the feature as checked into a
repository subversion and is treating it as a regular http server, but
chances are my configuration is wrong :) I am getting the following error.
INFO: import 'com.mialos.tutorial.mailapp.releng/targetPlatform.mspec'
30-Jul-2009 09:36:00
org.apache.commons.httpclient.auth.AuthChallengeProcessor selectAuthScheme
INFO: basic authentication scheme selected
30-Jul-2009 09:36:00 org.apache.commons.httpclient.HttpMethodDirector
processWWWAuthChallenge
INFO: No credentials available for BASIC 'Subversion'@192.168.1.75:80
ERROR [0001] : No repository found at
http://192.168.1.75/svn/sandbox/tutorial/trunk/com.mialos.tu torial.mailapp.targetplatform.
ERROR: No repository found at
ERROR: Errors and Warnings
org.eclipse.core.runtime.CoreException: Errors and Warnings
at
org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:109)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:175)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:144)
Contains: [0001] : No repository found at
INFO: TAG-ID 0001 = Query for
com.mialos.tutorial.mailapp.targetplatform:eclipse.feature
Here is my configuration.
Tas
<md:mspec xmlns:md="http://www.eclipse.org/buckminster/MetaData-1.0"
installLocation="target"
materializer="p2"
name="Target Platform MSPEC"
url="targetPlatform.cquery"/>
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap="mailApp.rmap">
<cq:rootRequest name="com.mialos.tutorial.mailapp.targetplatform"
componentType="eclipse.feature"/>
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
<cq:advisorNode namePattern=".*" useTargetPlatform="false"/>
</cq:componentQuery>
<rmap xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:pmp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
<searchPath name="com.mialos.tutorial">
<provider readerType="svn"
componentTypes="osgi.bundle,eclipse.feature,buckminster" mutable="true"
source="true">
<uri
format="http://192.168.1.75/svn/sandbox/tutorial/trunk/{0}">
<bc:propertyRef key="buckminster.component" />
</uri>
</provider>
</searchPath>
<searchPath name="org.eclipse">
<provider readerType="eclipse.import"
componentTypes="osgi.bundle,eclipse.feature" mutable="false" source="false">
<uri
format=" http://download.eclipse.org/eclipse/updates/3.5?importType=b inary"/>
</provider>
</searchPath>
<locator searchPathRef="com.mialos.tutorial"
pattern="^com\.mialos\.tutorial(\..+)?"/>
<locator searchPathRef="org.eclipse" pattern=".*" />
</rmap>
Re: Materialzing a custom target platform from multiple repositories [message #413435 is a reply to message #412222] Thu, 30 July 2009 09:17 Go to previous messageGo to next message
Hi Tas,
Try using an mspec that excludes the feature from materialization. Like so:
materializer="p2"
url="targetPlatform.cquery">
<mspecNode namePattern="com\.mialos\.tutorial\.mailapp\.targetplatform " exclude="true"/>
</mspec>
An alternative is to let the feature end up in your workspace using an mspec node like:
<mspecNode namePattern="com\.mialos\.tutorial\.mailapp\.targetplatform " materializer="workspace"/>
Thomas Hallgren
Tas Frangoullides wrote:
> have a few things to achieve before I can use buckminster for 'real'
> builds.
> multiple feature from different locations. For example to include the
> emf runtime as well as rcp. One idea I had was to create a new feautre
> project and have the feature.xml include all the required features of
> the targetPlatform and then materialize this.
> work. My guess is the p2 materilizer is treat the feature as checked
> into a repository subversion and is treating it as a regular http
> server, but chances are my configuration is wrong :) I am getting the
> following error.
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Tas
> materializer="p2"
> <cq:componentQuery
> source="true">
> <uri
> </uri>
> </provider>
> </searchPath>
> source="false">
> <uri
> </provider>
> </searchPath>
> </rmap>
Re: Materialzing a custom target platform from multiple repositories [message #415357 is a reply to message #413435] Thu, 30 July 2009 10:05 Go to previous messageGo to next message
Hi Thomas.
Thanks. Excluding the feature worked but materialzing to the workspace
didn't becuase I have specified an installLocation.
ERROR [0001] : Invalid project description.
[0001] : OK
ERROR [0001] :
'target/features/com.mialos.tutorial.mailapp.targetplatform' is not a valid
location. The location is relative to undefined workspace path va
riable 'target'.
Specifying an installLocation in the mspecNode appears to fix this. Is this
OK?
<md:mspecNode namePattern="com\.mialos\.tutorial\.mailapp\.targetplatform "
materializer="workspace" installLocation="${workspace.root}"/>
Tas
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:h4rofm$ndp$1@build.eclipse.org...
> Hi Tas,
> so:
> materializer="p2"
> exclude="true"/>
> </mspec>
> mspec node like:
> Regards,
> Thomas Hallgren
>> Hi,
>> builds.
>> multiple feature from different locations. For example to include the emf
>> project and have the feature.xml include all the required features of the
>> My guess is the p2 materilizer is treat the feature as checked into a
>> error.
>> selectAuthScheme
>> at
>> at
>> at
>> Thanks,
>> Tas
>> <?xml version="1.0" encoding="UTF-8"?>
>> materializer="p2"
>> <cq:componentQuery
>> source="true">
>> <uri
>> </uri>
>> </provider>
>> </searchPath>
>> source="false">
>> <uri
>> </provider>
>> </searchPath>
>> </rmap>
Re: Materialzing a custom target platform from multiple repositories [message #419787 is a reply to message #415357] Thu, 30 July 2009 11:39 Go to previous messageGo to next message
Hi Tas,
This sounds like a bug to me. The workspace materializer should select the workspace as its install location, not use
the default for the target platform. Can you please enter a bugzilla on this?
Thomas Hallgren
> Hi Thomas.
> [0001] : OK
> ERROR [0001] :
> valid location. The location is relative to undefined workspace path va
> riable 'target'.
> this OK?
> <md:mspecNode
> Tas
>> Hi Tas,
>> Like so:
>> materializer="p2"
>> <mspecNode
>> exclude="true"/>
>> </mspec>
>> mspec node like:
>> <mspecNode
>> Regards,
>> Thomas Hallgren
>>> Hi,
>>> still have a few things to achieve before I can use buckminster for
>>> 'real' builds.
>>> feautre project and have the feature.xml include all the required
>>> features of the targetPlatform and then materialize this.
>>> following error.
>>> selectAuthScheme
>>> at
>>> at
>>> at
>>> Thanks,
>>> Tas
>>> materializer="p2"
>>> <cq:componentQuery
>>> source="true">
>>> <uri
>>> </uri>
>>> </provider>
>>> </searchPath>
>>> source="false">
>>> <uri
>>> </provider>
>>> </searchPath>
>>> </rmap>
Re: Materialzing a custom target platform from multiple repositories [message #426693 is a reply to message #419787] Thu, 30 July 2009 13:54 Go to previous message
Ok. I've opened a new bug for it.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=285155
news:h4s0on$5ud$1@build.eclipse.org...
> Hi Tas,
> workspace as its install location, not use the default for the target
> Thomas Hallgren
>> Hi Thomas.
>> [0001] : OK
>> ERROR [0001] :
>> riable 'target'.
>> this OK?
>> <md:mspecNode
>> Thanks,
>> Tas
>>> Hi Tas,
>>> so:
>>> materializer="p2"
>>> <mspecNode
>>> exclude="true"/>
>>> </mspec>
>>> mspec node like:
>>> <mspecNode
>>> Regards,
>>> Thomas Hallgren
>>>> Hi,
>>>> builds.
>>>> following error.
>>>> selectAuthScheme
>>>> at
>>>> at
>>>> at
>>>> Thanks,
>>>> Tas
>>>> materializer="p2"
>>>> <cq:componentQuery
>>>> source="true">
>>>> <uri
>>>> </uri>
>>>> </provider>
>>>> </searchPath>
>>>> source="false">
>>>> <uri
>>>> </provider>
>>>> </searchPath>
>>>> </rmap>
Previous Topic:p2.director application is not available in headless buckminster
Next Topic:Resolving versions to subversion tags
Current Time: Wed Feb 19 03:14:50 GMT 2025
Powered by FUDForum. Page generated in 0.05015 seconds
