Product export uses wrong bundle version [message #41695] |
Fri, 23 January 2009 07:13 |
Hello everybody,
I've build a Eclipse RCP and I want to export it with the export wizard.
I use the BIRT viewer (v2.3.1) in my application which depends on Apache
Axis was not
resolved.
!SUBENTRY 2 HarnessOptimization 2 0 2009-01-23 08:10:51.744
!MESSAGE Missing required bundle org.eclipse.birt.report.viewer_2.3.1.
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-01-23 08:10:51.744
!MESSAGE Bundle update@plugins/org.apache.axis_1.4.0.v200807230600/
was not resolved.
!SUBENTRY 2 org.apache.axis 2 0 2009-01-23 08:10:51.744
!MESSAGE Missing required bundle javax.wsdl_[1.5.1,2.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.birt.report.viewer_2.3.1.v20080908/ [50] was
not resolved.
!SUBENTRY 2 org.eclipse.birt.report.viewer 2 0 2009-01-23 08:10:51.744
!MESSAGE Missing required bundle org.apache.axis_[1.3.0,2.0.0).
Is this a bug or is my installation messed up??
Thanks in advance.
Greetings,
Erik
Re: Product export uses wrong bundle version [message #42156 is a reply to message #41695] |
Fri, 23 January 2009 16:28 |
Andrew Niefer Messages: 990 Registered: July 2009 |
This does look like a bug.
What version of Eclipse are you using? (The version of
org.eclipse.pde.build is most interesting).
If you go look in the plugins folder of your exported product, which
version of javax.wsdl is there?
There is a bug, https://bugs.eclipse.org/bugs/show_bug.cgi?id=252246,
fixed in 3.5M3, where the wrong information could be written to the
configuration bundles.info file, which could cause javax.wsdl to not get
installed even if it is in the plugins directory.
-Andrew
Erik Vonderheid wrote:
> Hello everybody,
> Axis was not
> resolved.
> was not resolved.
> !MESSAGE Bundle
> not resolved.
> Thanks in advance.
> Greetings,
> Erik
Re: Product export uses wrong bundle version [message #42522 is a reply to message #42156] |
Mon, 26 January 2009 13:13 |
I'm using Eclipse 3.4.1 M20080911-1700.
The bundle version is org.eclipse.pde.build_3.4.1.R34x_v20080805.
javax.wsdl_1.4.0.v200806030407.jar is exported.
The two bundles:
javax.wsdl_1.5.1.v200806030408.jar
are available in my eclipse installation.
Erik
"Andrew Niefer" <aniefer@ca.ibm.com> schrieb im Newsbeitrag
news:glcr6s$qm0$1@build.eclipse.org...
> -Andrew
>> Hello everybody,
>> Axis was not
>> resolved.
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
>> Thanks in advance.
>> Greetings,
>> Erik
Re: Product export uses wrong bundle version [message #590379 is a reply to message #41695] |
-Andrew
> Hello everybody,
> Axis was not
> resolved.
> was not resolved.
> !MESSAGE Bundle
> not resolved.
> Thanks in advance.
> Greetings,
> Erik
Re: Product export uses wrong bundle version [message #590532 is a reply to message #42156] |
The two bundles:
Erik
> -Andrew
>> Hello everybody,
>> Axis was not
>> resolved.
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
>> Thanks in advance.
>> Greetings,
>> Erik
FUDForum. Page generated in 0.01546 seconds
