Home » Archived » Test and Performance Tools Platform (TPTP) » Manual Test View? Newbie Question
Manual Test View? Newbie Question [message #41674] |
Tue, 22 November 2005 22:31 |
Originally posted by: ruben.garcia.21csi.com
Hello Team,
I am trying to run the manual example tests and I get to Manual testing
with TPTP>> Running a manual test>> Running the test configuration, and
this part states that the Manual Test View is an independent SWT window
for executing a manual test. Is this in a package with a guide and how
does this automatically come up after I press run on the Run , Create,
Manage and Run configurations window?
Thank you and have a great day!
-Ruben
Re: Manual Test View? Newbie Question [message #41706 is a reply to message #41674] |
Wed, 23 November 2005 02:46 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Ruben,
The documentation for the Manual Test View is located in the TPTP
product documentation that you referencing (Help >> Help Contents >> TPTP
Tester guide >> Manual testing with TPTP >> Running a manual test >> Running
the test configuration.
The Manual Test View is an independent Standard Widget Toolkit (SWT)
window providing an Eclipse look-and-feel user interface for session-based
local and remote manual test execution. Features include test navigation,
test case execution, message sending, rich text (HTML fragments or document)
support in test case descriptions, file attachment support in test case
executions and testing session status. It is packaged with the TPTP
workbench (local execution) and Agent Controller (remote execution). When
executing a test configuration, the manual test is passed to the Manual Test
View on the local or remote machine for execution. Test case execution
events are returned to the TPTP workbench and loaded in the Test model for
viewing in the Test Log view as the user records test case executions.
Did you have a specific question on the execution of the Manual Test
View?
Paul
"Ruben Garcia" <ruben.garcia@21csi.com> wrote in message
news:dm068c$9j7$1@news.eclipse.org...
> Hello Team,
> -Ruben
Re: Manual Test View? Newbie Question [message #41990 is a reply to message #41706] |
Wed, 23 November 2005 15:20 |
Ruben Garcia wrote:
> Ruben Garcia wrote:
> Hello Paul,
> Yes, I think that I have either a setup problem or a configuration
> problem. I can do everything in the walk-thru, up to the point where it
> states that I "Run the test configuration by clicking the Run button at
> the bottom of the Run dialog."
> At this point I do not get the Manual Test View.
> I click Run and the Plug-in Develpoment - exampleManualTest - Eclipse
> SDK window shows 22%, followed by 66% then it ends. I think the test is
> being executed, I just am not seeing the Manual Test View that states I
> should be selecting the Start execution button that the top of the window.
> Do I have some override feature selected that automatically runs the
> test without any more prompting?
> - Ruben
> Paul Slauenwhite wrote:
>> Hi Ruben,
>> Running
>> session-based
>> navigation,
>> document)
>> When
>> Manual Test
>> for
>> View?
>> Paul
>>> Hello Team,
>>> -Ruben
Re: Manual Test View? Newbie Question [message #42775 is a reply to message #41990] |
Thu, 24 November 2005 17:56 |
Hi Ruben,
This appears to be a defect at first glance. Lets try to debug:
1) What platform are you running on?
2) What version and driver of TPTP are you using?
3) Are you using the Agent Controller or Integrated Agent Controller (IAC -
only in TPTP v4.1+)?
4) If the Agent Controller, is it correctly installed as per the
instructions in the <Agent Controller unzip directory>/getting_started.html
file?
Can you post the <Eclipse workspace>/.metadata/.log file?
Since manual test types by definition require manual interaction and the
first point of contact for manual test types is the Manual Test View, there
is no override feature that automatically runs the test without prompting.
Paul
news:dm21ci$ug0$1@news.eclipse.org...
> Ruben Garcia wrote:
> > Ruben Garcia wrote:
> > Hello Paul,
window.
> > - Ruben
> >> Hi Ruben,
TPTP
> >> Running
(SWT)
> >> session-based
> >> navigation,
> >> document)
> >> When
> >> Manual Test
> >> for
Test
> >> View?
> >> Paul
> >>> Hello Team,
testing
and
window
how
Create,
> >>> -Ruben
Re: Manual Test View? Newbie Question [message #43153 is a reply to message #42775] |
Mon, 28 November 2005 16:12 |
> Hi Ruben,
Windows 2000 Professional, Version 5.0.2195 Service Pack 4 Build 2195
Eclipse SDK, Version: 3.2.0 Build id: I20051102-1600
Version: 4.1.0 driver: ?
The Agent Controller:
org.eclipse.tptp.platform.agentcontroller (4.1.0) "TPTP Agent
Controller" [Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user (4.1.0) "Agent
Controller documentation" [Resolved]
> file?
Yes, I followed the getting_started.html file, and I start the RAServer
service manually, prior to starting the eclipse platform.
Will do.
Understood, I may have been looking at it and just did not realize it.
I will repreform the test and capture screen shots to post. Is it
acceptable to post them in a zip file or should I just post them as a .gif?
Thank you once again for taking the time out to help! :)
-Ruben
> Paul
>>Ruben Garcia wrote:
>>>Ruben Garcia wrote:
>>>Hello Paul,
> window.
>>>- Ruben
>>>>Hi Ruben,
> TPTP
>>>>Running
> (SWT)
>>>>session-based
>>>>navigation,
>>>>document)
>>>>When
>>>>Manual Test
>>>>for
> Test
>>>>View?
>>>>Paul
>>>>>Hello Team,
> testing
> and
> window
> how
> Create,
>>>>> -Ruben
Re: Manual Test View? Newbie Question [message #43183 is a reply to message #43153] |
Mon, 28 November 2005 16:14 |
--------------000507080006040003070302
Content-Type: text/plain; charset=us-ascii; format=flowed
Ruben Garcia wrote:
Forgot to post file :)
>> Hi Ruben,
>> (IAC -
>> file?
> Will do.
>> and the
>> there
>> prompting.
> Understood, I may have been looking at it and just did not realize it. I
> -Ruben
>> Paul
>>> Ruben Garcia wrote:
>>>> Ruben Garcia wrote:
>>>> Hello Paul,
>>>> where it
>>>> test is
>> window.
>>>> - Ruben
>>>>> Hi Ruben,
>> TPTP
>>>>> Running
>> (SWT)
>>>>> session-based
>>>>> navigation,
>>>>> document)
>>>>> case
>>>>> When
>>>>> Manual Test
>>>>> execution
>>>>> for
>> Test
>>>>> View?
>>>>> Paul
>>>>>> Hello Team,
>> testing
>> and
>> window
>> how
>> Create,
>>>>>> -Ruben
name=".log"
Content-Disposition: inline;
filename=".log"
!SESSION 2005-11-23 12:06:20.718 -----------------------------------------------
eclipse.buildId=I20051102-1600
java.version=1.5.0_05
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-11-23 12:06:37.609
!MESSAGE While loading class "org.eclipse.hyades.ui.HyadesUIImages", thread "main" timed out waiting (5000ms) for thread "Worker-8" to finish starting bundle "org.eclipse.hyades.ui". To avoid deadlock, thread "main" is proceeding but "org.eclipse.hyades.ui.HyadesUIImages" may not be fully initialized.
!STACK 0
java.lang.Exception: Generated exception.
at org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:108)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.hyades.ui.HyadesUIPlugin$1.run(HyadesUIPlugin.ja va:140)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3213)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2859)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1774)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1738)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:376)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:165)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2005-11-23 12:06:42.750
!MESSAGE While loading class "org.eclipse.hyades.ui.internal.util.ImageManager", thread "main" timed out waiting (5000ms) for thread "Worker-8" to finish starting bundle "org.eclipse.hyades.ui". To avoid deadlock, thread "main" is proceeding but "org.eclipse.hyades.ui.internal.util.ImageManager" may not be fully initialized.
!STACK 0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
at org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
at org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
at org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
at org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
at org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:110)
!ENTRY org.eclipse.hyades.test.core 1 1 2005-11-23 13:40:58.390
!MESSAGE about to load recorder agent: org.eclipse.hyades.execution.recorder.http.remote.SSLProxyRe corder
!MESSAGE load successful
!ENTRY org.eclipse.hyades.test.core 1 1 2005-11-23 13:40:58.406
!MESSAGE about to initialize recorder agent: org.eclipse.hyades.execution.recorder.http.remote.SSLProxyRe corder
!MESSAGE initialization successful
!ENTRY org.eclipse.hyades.test.core 1 1 2005-11-23 13:40:58.421
!MESSAGE about to start SSLProxyServer
!ENTRY org.eclipse.hyades.test.core 1 1 2005-11-23 13:40:59.734
!MESSAGE proxy recorder listening to port1080
!ENTRY org.eclipse.ui.workbench 4 0 2005-11-23 15:02:54.234
!MESSAGE An unexpected exception was thrown.
!STACK 0
at org.eclipse.hyades.test.tools.ui.http.internal.junit.editor. HttpTestCaseDetailPage.dispose(HttpTestCaseDetailPage.java:8 8)
at org.eclipse.hyades.test.ui.internal.editor.form.util.StaticD etailPageProvider.dispose(StaticDetailPageProvider.java:70)
at org.eclipse.hyades.test.ui.internal.editor.form.util.DetailS ection.dispose(DetailSection.java:95)
at org.eclipse.hyades.test.ui.internal.editor.form.base.Abstrac tSectionForm.dispose(AbstractSectionForm.java:142)
at org.eclipse.hyades.test.ui.editor.form.util.EditorForm.dispo se(EditorForm.java:84)
at org.eclipse.hyades.test.tools.ui.common.internal.editor.Test CasesForm.dispose(TestCasesForm.java:75)
at org.eclipse.hyades.test.tools.ui.common.internal.editor.Test SuiteEditorExtension.dispose(TestSuiteEditorExtension.java:4 7)
at org.eclipse.hyades.ui.internal.editor.HyadesEditorPart.dispo se(HyadesEditorPart.java:90)
at org.eclipse.hyades.test.ui.internal.editor.BaseEditorPart.di spose(BaseEditorPart.java:83)
at org.eclipse.ui.internal.WorkbenchPartReference.doDisposePart (WorkbenchPartReference.java:659)
at org.eclipse.ui.internal.EditorReference.doDisposePart(Editor Reference.java:261)
at org.eclipse.ui.internal.WorkbenchPartReference.dispose(Workb enchPartReference.java:628)
at org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1451)
at org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1278)
at org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1262)
at org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1236)
at org.eclipse.ui.internal.WorkbenchPage.closeAllEditors(Workbe nchPage.java:1047)
at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage. java:1499)
at org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(Workbe nchWindow.java:760)
at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1394)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:643)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:624)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:725)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:723)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:108)
at org.eclipse.ui.internal.Workbench$11.run(Workbench.java:599)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:5 96)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:53 3)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:724)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:722)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:697)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:640)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:727)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:67 4)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:159)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:896)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:920)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:905)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:257)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1605)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3144 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1538)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3908 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1698 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:419)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3229 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:17 03)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2854)
!SESSION 2005-11-28 07:34:26.796 -----------------------------------------------
!ENTRY org.eclipse.ui.workbench 4 0 2005-11-28 08:05:00.906
!STACK 0
--------------000507080006040003070302--
Re: Manual Test View? Newbie Question [message #43438 is a reply to message #43183] |
Tue, 29 November 2005 01:39 |
Hi Ruben,
Using the TPTP-4.1.0-200511230100A driver, I cannot seem to reproduce
this problem following the instructions in the TPTP product documentation
(Help >> Help Contents >> TPTP >> Tester guide >> Manual testing with
TPTP ). Can one of you open a defect in the TPTP Bugzilla DB under the
Test.Execution.ManualRunner component with your comments from this thread
and attach your workspace and the <Agent Controller installation
directory>\config\servicelog.log:
http://www.eclipse.org/tptp/ >> Submit Enhancements & Bugs
Paul
news:dmfadk$a9m$2@news.eclipse.org...
> >> Hi Ruben,
> >> (IAC -
> >> file?
> > Will do.
> >> and the
> >> there
> >> prompting.
..gif?
> > -Ruben
> >> Paul
> >>> Ruben Garcia wrote:
> >>>> Ruben Garcia wrote:
> >>>> Hello Paul,
> >>>> where it
at
> >>>> test is
I
> >> window.
> >>>> - Ruben
> >>>>> Hi Ruben,
> >> TPTP
> >>>>> Running
> >> (SWT)
> >>>>> session-based
> >>>>> navigation,
> >>>>> document)
> >>>>> case
> >>>>> When
> >>>>> Manual Test
> >>>>> execution
model
> >>>>> for
executions.
> >> Test
> >>>>> View?
> >>>>> Paul
> >>>>>> Hello Team,
> >> testing
> >> and
> >> window
> >> how
> >> Create,
> >>>>>> -Ruben
> !SESSION 2005-11-23
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
initialized.
> !STACK 0
> at
assLoader.java:108)
> at
oader.java:337)
> at
..java:389)
> at
..java:350)
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
java:226)
> at
> at
initialized.
> !STACK 0
> at
assLoader.java:108)
> at
oader.java:337)
> at
..java:389)
> at
..java:350)
> at
> at
> at
Loader.java:233)
> at
> at
> at
> at
> at
assLoader.java:110)
> at
oader.java:337)
> at
..java:389)
> at
..java:350)
> at
> at
> at
> at
java:226)
> at
> at
> !STACK 0
> at
ilPage.dispose(HttpTestCaseDetailPage.java:88)
> at
> at
> at
> at
va:84)
> at
> at
sion.dispose(TestSuiteEditorExtension.java:47)
> at
art.java:90)
> at
Part.java:83)
> at
ference.java:659)
> at
61)
> at
e.java:628)
> at
> at
a:1278)
> at
> at
> at
7)
> at
60)
> at
> at
> at
> at
:1044)
> at
> at
> at
> at
> at
java:226)
> at
> at
> !SESSION 2005-11-28
> !STACK 0
> at
> at
> at
> at
> at
va:84)
> at
> at
> at
art.java:90)
> at
Part.java:83)
> at
ference.java:659)
> at
61)
> at
e.java:628)
> at
> at
a:1278)
> at
> at
> at
7)
> at
60)
> at
> at
> at
> at
:1044)
> at
> at
> at
> at
> at
java:226)
> at
> at
Re: Manual Test View? Newbie Question [message #43624 is a reply to message #43438] |
Tue, 29 November 2005 16:58 |
Hello Paul,
Thank you very much for your help. It was pointed out to me that
TPTP-4.1.0 works with Eclipse 3.1.0 not 3.2.0 which I incorrectly
installed. My bad :(, I will uninstall and try again. Sorry for the
inconvience.
-Ruben
> Hi Ruben,
> Paul
>>>>Hi Ruben,
>>>>(IAC -
>>>>file?
>>>Will do.
>>>>and the
>>>>there
>>>>prompting.
> .gif?
>>>-Ruben
>>>>Paul
>>>>>Ruben Garcia wrote:
>>>>>>Ruben Garcia wrote:
>>>>>>Hello Paul,
>>>>>>where it
> at
>>>>>>test is
> I
>>>>window.
>>>>>>- Ruben
>>>>>>>Hi Ruben,
>>>>TPTP
>>>>>>>Running
>>>>(SWT)
>>>>>>>session-based
>>>>>>>navigation,
>>>>>>>document)
>>>>>>>case
>>>>>>>When
>>>>>>>Manual Test
>>>>>>>execution
> model
>>>>>>>for
> executions.
>>>>Test
>>>>>>>View?
>>>>>>>Paul
>>>>>>>>Hello Team,
>>>>testing
>>>>and
>>>>window
>>>>how
>>>>Create,
>>>>>>>>-Ruben
>>!SESSION 2005-11-23
> initialized.
>>!STACK 0
>>at
> assLoader.java:108)
>>at
> oader.java:337)
>>at
> .java:389)
>>at
> .java:350)
>>at
>>at
>>at
>>at
> java:226)
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> initialized.
>>!STACK 0
>>at
> assLoader.java:108)
>>at
> oader.java:337)
>>at
> .java:389)
>>at
> .java:350)
>>at
>>at
>>at
> Loader.java:233)
>>at
>>at
>>at
>>at
>>at
> assLoader.java:110)
>>at
> oader.java:337)
>>at
> .java:389)
>>at
> .java:350)
>>at
>>at
>>at
>>at
> java:226)
>>at
>>at
>>!STACK 0
>>at
>>at
>>at
>>at
>>at
> va:84)
>>at
>>at
>>at
> art.java:90)
>>at
> Part.java:83)
>>at
> ference.java:659)
>>at
> 61)
>>at
> e.java:628)
>>at
>>at
> a:1278)
>>at
>>at
>>at
> 7)
>>at
> 60)
>>at
>>at
>>at
>>at
> :1044)
>>at
>>at
>>at
>>at
>>at
> java:226)
>>at
>>at
>>!SESSION 2005-11-28
>>!STACK 0
>>at
>>at
>>at
>>at
>>at
> va:84)
>>at
>>at
>>at
> art.java:90)
>>at
> Part.java:83)
>>at
> ference.java:659)
>>at
> 61)
>>at
> e.java:628)
>>at
>>at
> a:1278)
>>at
>>at
>>at
> 7)
>>at
> 60)
>>at
>>at
>>at
>>at
> :1044)
>>at
>>at
>>at
>>at
>>at
> java:226)
>>at
>>at
Re: Manual Test View? Newbie Question [message #43661 is a reply to message #43624] |
Tue, 29 November 2005 18:26 |
Hi Ruben,
Although TPTP v4.1 does not official support running on Eclipse v3.2,
there are no known issues. Since TPTP v4.2 will officially support running
on Eclipse v3.2, please open defects again TPTP v4.2 for any issues due to
running on Eclipse v3.2.
Paul
news:dmi1cm$fgo$1@news.eclipse.org...
> Hello Paul,
> inconvience.
> -Ruben
> > Hi Ruben,
reproduce
documentation
thread
> > Thanks,
> > Paul
> >>>>Hi Ruben,
> >>>>(IAC -
> >>>>file?
> >>>Will do.
> >>>>and the
> >>>>there
> >>>>prompting.
I
> > .gif?
> >>>-Ruben
> >>>>Paul
> >>>>>Ruben Garcia wrote:
> >>>>>>Ruben Garcia wrote:
> >>>>>>Hello Paul,
> >>>>>>where it
> > at
Eclipse
> >>>>>>test is
states
> > I
> >>>>window.
> >>>>>>- Ruben
> >>>>>>>Hi Ruben,
TPTP
> >>>>TPTP
> >>>>>>>Running
> >>>>(SWT)
> >>>>>>>session-based
> >>>>>>>navigation,
> >>>>>>>document)
> >>>>>>>case
TPTP
execution).
> >>>>>>>When
> >>>>>>>Manual Test
> >>>>>>>execution
> > model
> >>>>>>>for
> > executions.
> >>>>Test
> >>>>>>>View?
> >>>>>>>Paul
> >>>>>>>>Hello Team,
> >>>>testing
configuration,
> >>>>and
> >>>>window
and
> >>>>how
> >>>>Create,
> >>>>>>>>-Ruben
> >>!SESSION 2005-11-23
"main" is
> > initialized.
> >>!STACK 0
> >>at
> > assLoader.java:108)
> >>at
> > oader.java:337)
> >>at
> > .java:389)
> >>at
> > .java:350)
> >>at
> >>at
> >>at
> >>at
> >>at
> > java:226)
> >>at
> >>at
out
but
> > initialized.
> >>!STACK 0
> >>at
> > assLoader.java:108)
> >>at
> > oader.java:337)
> >>at
> > .java:389)
> >>at
> > .java:350)
> >>at
> >>at
> >>at
> > Loader.java:233)
> >>at
> >>at
> >>at
> >>at
> >>at
> > assLoader.java:110)
> >>at
> > oader.java:337)
> >>at
> > .java:389)
> >>at
> > .java:350)
> >>at
> >>at
> >>at
> >>at
> >>at
> > java:226)
> >>at
> >>at
> >>!STACK 0
> >>at
> >>at
> >>at
> >>at
> >>at
> > va:84)
> >>at
> >>at
> >>at
> > art.java:90)
> >>at
> > Part.java:83)
> >>at
> > ference.java:659)
> >>at
> > 61)
> >>at
> > e.java:628)
> >>at
> >>at
> > a:1278)
> >>at
> >>at
> >>at
> > 7)
> >>at
> >>at
> > 60)
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> > :1044)
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> > java:226)
> >>at
> >>at
> >>!SESSION 2005-11-28
> >>!STACK 0
> >>at
> >>at
> >>at
> >>at
> >>at
> > va:84)
> >>at
> >>at
> >>at
> > art.java:90)
> >>at
> > Part.java:83)
> >>at
> > ference.java:659)
> >>at
> > 61)
> >>at
> > e.java:628)
> >>at
> >>at
> > a:1278)
> >>at
> >>at
> >>at
> > 7)
> >>at
> >>at
> > 60)
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> > :1044)
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> >>at
> > java:226)
> >>at
> >>at
Re: Manual Test View? Newbie Question [message #44114 is a reply to message #43661] |
Wed, 30 November 2005 20:31 |
Hi Paul,
Understood, will do.
I will try and get Eclipse v3.1 and TPTP v4.1 up and running first and
then move on to the new v3.2 platform once I am more stable with the
product.
Thank you very much and have a great day!
-Ruben
> Hi Ruben,
> Paul
>>Hello Paul,
>>inconvience.
>>-Ruben
>>>Hi Ruben,
> reproduce
> documentation
> thread
>>>Thanks,
>>>Paul
>>>>>>Hi Ruben,
>>>>>>(IAC -
>>>>>>file?
>>>>>Will do.
>>>>>>and the
>>>>>>there
>>>>>>prompting.
> I
>>>.gif?
>>>>>-Ruben
>>>>>>Paul
>>>>>>>Ruben Garcia wrote:
>>>>>>>>Ruben Garcia wrote:
>>>>>>>>Hello Paul,
>>>>>>>>where it
>>>at
> Eclipse
>>>>>>>>test is
> states
>>>I
>>>>>>window.
>>>>>>>>- Ruben
>>>>>>>>>Hi Ruben,
> TPTP
>>>>>>TPTP
>>>>>>>>>Running
>>>>>>(SWT)
>>>>>>>>>session-based
>>>>>>>>>navigation,
>>>>>>>>>document)
>>>>>>>>>case
> TPTP
> execution).
>>>>>>>>>When
>>>>>>>>>Manual Test
>>>>>>>>>execution
>>>model
>>>>>>>>>for
>>>executions.
>>>>>>Test
>>>>>>>>>View?
>>>>>>>>>Paul
>>>>>>>>>>Hello Team,
>>>>>>testing
> configuration,
>>>>>>and
>>>>>>window
> and
>>>>>>how
>>>>>>Create,
>>>>>>>>>>-Ruben
>>>>!SESSION 2005-11-23
> "main" is
>>>initialized.
>>>>!STACK 0
>>>>at
>>>assLoader.java:108)
>>>>at
>>>oader.java:337)
>>>>at
>>>.java:389)
>>>>at
>>>.java:350)
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>java:226)
>>>>at
>>>>at
> out
> but
>>>initialized.
>>>>!STACK 0
>>>>at
>>>assLoader.java:108)
>>>>at
>>>oader.java:337)
>>>>at
>>>.java:389)
>>>>at
>>>.java:350)
>>>>at
>>>>at
>>>>at
>>>Loader.java:233)
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>assLoader.java:110)
>>>>at
>>>oader.java:337)
>>>>at
>>>.java:389)
>>>>at
>>>.java:350)
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>java:226)
>>>>at
>>>>at
>>>>!STACK 0
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>va:84)
>>>>at
>>>>at
>>>>at
>>>art.java:90)
>>>>at
>>>Part.java:83)
>>>>at
>>>ference.java:659)
>>>>at
>>>61)
>>>>at
>>>e.java:628)
>>>>at
>>>>at
>>>a:1278)
>>>>at
>>>>at
>>>>at
>>>7)
>>>>at
>>>>at
>>>60)
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>:1044)
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>java:226)
>>>>at
>>>>at
>>>>!SESSION 2005-11-28
>>>>!STACK 0
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>va:84)
>>>>at
>>>>at
>>>>at
>>>art.java:90)
>>>>at
>>>Part.java:83)
>>>>at
>>>ference.java:659)
>>>>at
>>>61)
>>>>at
>>>e.java:628)
>>>>at
>>>>at
>>>a:1278)
>>>>at
>>>>at
>>>>at
>>>7)
>>>>at
>>>>at
>>>60)
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>:1044)
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>java:226)
>>>>at
>>>>at
Current Time: Tue Apr 23 06:46:45 GMT 2024
Powered by FUDForum. Page generated in 0.04463 seconds
