Home » Archived » XML Schema Definition (XSD) » Included Schema not resolved in WSDL?
Included Schema not resolved in WSDL? [message #41662] |
Sun, 18 April 2004 06:46 |
Originally posted by: adam.premasys.com
Hi all,
I'm wanting to use the XSD library to parse a wsdl document and gain access
to all of the defined types, both those
embedded in the wsdl document itself, and also those defined in an external
xsd document referenced by an
<include> element. When I write out the names of all of the complex type
definitions I see those defined in the main
document but not those from the external document.
I thought this could be a quirk related to parsing a wsdl document so I
rewrote my test case to use an xsd document with
an included schema and got the same result.
I've included my test case below, perhaps someone can point out where I'm
going wrong with this?
Thanks in advance,
Adam
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "wsdl",
new XSDResourceFactoryImpl());
String uri = "xml/wsdl/Party.wsdl";
ResourceSet resourceSet = new ResourceSetImpl();
XSDResourceImpl xsdSchemaResource = (XSDResourceImpl)
resourceSet.getResource(URI.createDeviceURI(uri), true);
Iterator resources = resourceSet.getResources().iterator();
while (resources.hasNext()) {
Resource res = (Resource) resources.next();
if (res instanceof XSDResourceImpl) {
XSDResourceImpl xsdResource = (XSDResourceImpl) res;
XSDSchema schema = xsdResource.getSchema();
List allTypes = schema.getTypeDefinitions();
for (Iterator iter = allTypes.iterator(); iter.hasNext();) {
XSDTypeDefinition typedef = (XSDTypeDefinition) iter.next();
if (typedef instanceof XSDComplexTypeDefinition) {
String name = typedef.getName();
System.out.println(name);
Re: Included Schema not resolved in WSDL? [message #41693 is a reply to message #41662] |
Sun, 18 April 2004 11:32 |
--------------9C2BAD65159E2D4D0B53DBB2
Content-Type: text/plain; charset=us-ascii
Adam,
Two things I noticed below will cause you problems.
1. The URI of the resource you start with is not absolute, so relative
schemaLocation references within the document will fail to resolve; use
java.io.File to create an absolute or canonical path and then use
URI.createFileURI to create an absolute file schema URI.
2. The getSchema method will access only the one schema, which is fine for a
.xsd document, but a .wsdl document can contain more schemas; iterate over
the getContents of the resource to access them all.
Adam Ratcliffe wrote:
> Hi all,
> Thanks in advance,
> Adam
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Adam,
<p>Two things I noticed below will cause you problems.
<ol>
<li>
The URI of the resource you start with is not absolute, so relative schemaLocation
references within the document will fail to resolve; use java.io.File to
create an absolute or canonical path and then use URI.createFileURI to
create an absolute file schema URI.</li>
<li>
a .xsd document, but a .wsdl document can contain more schemas; iterate
over the getContents of the resource to access them all.</li>
</ol>
<p><br>Adam Ratcliffe wrote:
<blockquote TYPE=CITE>Hi all,
<p>I'm wanting to use the XSD library to parse a wsdl document and gain
access
<br>to all of the defined types, both those
<br>embedded in the wsdl document itself, and also those defined in an
external
<br>xsd document referenced by an
<br><include> element. When I write out the names of all of the complex
type
<br>definitions I see those defined in the main
<br>document but not those from the external document.
<p>I thought this could be a quirk related to parsing a wsdl document so
I
<br>rewrote my test case to use an xsd document with
<br>an included schema and got the same result.
<p>I've included my test case below, perhaps someone can point out where
I'm
<br>going wrong with this?
<p>Thanks in advance,
<br>Adam
<p> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "wsdl",
<br>new XSDResourceFactoryImpl());
<br>String uri = "xml/wsdl/Party.wsdl";
<br>ResourceSet resourceSet = new ResourceSetImpl();
<br>XSDResourceImpl xsdSchemaResource = (XSDResourceImpl)
<br>resourceSet.getResource(URI.createDeviceURI(uri), true);
<p>Iterator resources = resourceSet.getResources().iterator();
<br>while (resources.hasNext()) {
<br> Resource res = (Resource) resources.next();
<br> if (res instanceof XSDResourceImpl) {
<br> XSDResourceImpl xsdResource = (XSDResourceImpl)
res;
<br> XSDSchema schema = xsdResource.getSchema();
<p> List allTypes = schema.getTypeDefinitions();
<br> for (Iterator iter = allTypes.iterator(); iter.hasNext();)
<br> XSDTypeDefinition typedef = (XSDTypeDefinition)
iter.next();
<br> if (typedef instanceof XSDComplexTypeDefinition)
<br> String name = typedef.getName();
<br> System.out.println(name);
<br> }
<br> }
<br> }
<br>}</blockquote>
</html>
--------------9C2BAD65159E2D4D0B53DBB2--
Re: Included Schema not resolved in WSDL? [message #41724 is a reply to message #41693] |
Sun, 18 April 2004 22:05 |
Hi Ed,
Thanks for putting me back on track, in addition to the 2 changes you
suggested I also needed to register a resource factory for 'xsd' documents
in addition to the factory already registered for 'wsdl' documents.
Adam
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:4082673D.4B45E48E@ca.ibm.com...
Adam,
..xsd document, but a .wsdl document can contain more schemas; iterate over
Hi all,
Thanks in advance,
Adam
Re: Included Schema not resolved in WSDL? [message #585758 is a reply to message #41662] |
Ed Merks Messages: 33113 Registered: July 2009 |
Adam,
> Hi all,
> Thanks in advance,
> Adam
<html>
Adam,
<ol>
<li>
<li>
</ol>
access
external
type
I
I'm
<br>Adam
res;
iter.next();
<br> }
<br> }
<br> }
<br>}</blockquote>
</html>
Ed Merks
Re: Included Schema not resolved in WSDL? [message #585774 is a reply to message #41693] |
Adam Ratcliffe Messages: 3 Registered: July 2009 |
Hi Ed,
Adam
Adam,
Hi all,
Thanks in advance,
Adam
Current Time: Thu Mar 28 19:27:58 GMT 2024
Powered by FUDForum. Page generated in 0.01902 seconds
