Re: XDC on Mac OS X [message #3617 is a reply to message #3582] |
Fri, 29 May 2009 14:54   |
Dave Russo Messages: 172 Registered: July 2009 |
Amichi Amar wrote:
> Hello,
> I'd like to use the XDC tools on my Mac and would like to help getting
> the toolset working on OS X.
> Are the sources and instructions on how to build the suite available? I
> understand there is a bootstrap process somewhere as some xdc tools are
> built with xdc.
I working on getting the sources through the eclipse IP process. We
have one of two source trees approved at this point and, while it has
taken a while to get this far, I expect the second tree to go more quickly.
There is a bootstrap to build the RTSC tools because we use the RTSC
tools to build itself.
> If someone could help out a little we could get a good amount of folks
> using Macs working with RTSC.
It is possible to help out now. The RTSC tools include a number of
native executables (e.g., xs, xdc, and xdcpkg, see
http://rtsc.eclipse.org/docs-tip/Command_Line_Tools). One of the first
steps in the bootstrap is build these commands using the RTSC build
engine. In order for this to happen, we need a target and a platform
for OS X.
Part 2 of the RTSC tutorial provides an overview and examples of what is
required, but native targets are often _much_ easier that targets for
embedded platforms. My guess is that there is a gcc compiler for OS X,
so it should be easy to create a target that inherits from
gnu.targets.ITarget. Since it's ok to only support Intel-based Macs (at
least initially), we can probably just use the host.platforms.PC platform.
Once we have an OS X target, we can either put it in the gnu.targets
package or create a new package and maintain it in
http://dev.eclipse.org/svnroot/dsdp/org.eclipse.rtsc/contrib /targets/trunk.
The complete sources to the gnu.targets package are included in any
XDCtools distribution (and will eventually be maintained in our eclipse
SVN repository).
Beyond targets and platforms, there are a few other packages that will
have to be extended to support OS X; e.g., all the graphical tools rely
on SWT (which relies on some native code) but I assume the native code
required for OS X already exists.
Bottom line: a good first step is to create a target and platform that
builds one of the tutorial "hello world" examples
( http://dev.eclipse.org/svnroot/dsdp/org.eclipse.rtsc/trainin g/ec2009/trunk/src/part2/examples/hello)
to run natively on OS X.
> Cheers,
> Amichi
Re: XDC on Mac OS X [message #3738 is a reply to message #3714] |
Mon, 08 June 2009 17:11  |
> There currently isn't a cross compiler from windows to os x so I need to
> build xs, xdc etc from scratch to get them onto os x. Are these sources
> available?
We're working on getting the xdc, xs, sources available; we still need
to get them through the eclipse IP process.
> Otherwise, I could put together a target (simple copy of the Linux86
> target) - but I have no way to test anything out (i.e. can't build
> native code etc).
> So, what to do?
Good question. It's tricky but possible ...
We use the xdc tools on Linux to build Solaris executables _without_ a
Linux-to-Solaris cross compiler. I think we can do the same with OS X.
The way it works is to create a target (like gnu.targets.Sparc) which
can be setup to remotely execute the compiler/linker/archiver on a
different host. Recall that targets simply provide _any_ command
sufficient to convert a .c to a .obj. Without a cross-compiler, the
target supplies a command that simply rsh's to an appropriate host and
does the compile.
When building on Linux, for example, the Linux host will rsh the
compiler command to a specified Solaris host (see the remoteHost config
param of the gnu.targets.ITarget interface
http://rtsc.eclipse.org/cdoc-tip/index.html#gnu/targets/ITar get.html#remote.Host).
The current gnu.targets.ITarget requires a network file system seen by
both hosts.
We even use this technique to build Windows executables from a Linux
host _without_ a cross-compiler(!). This has additional complications
because the file systems are so different between *nix and Windows, but
among *nix hosts the process is fairly easy.
> Amichi
FUDForum. Page generated in 0.01887 seconds
