Home » Eclipse Projects » Plugin Development Environment (PDE) » Where can I find the exported jars ?
Re: Where can I find the exported jars ? [message #41626 is a reply to message #41539] |
Thu, 22 January 2009 18:48 |
Andrew Niefer Messages: 990 Registered: July 2009 |
The build.jars target is not called in the normal run of headless build.
It is more of a convenience target that some people call when
customizing their builds beyond all recognizability.
( I didn't think anyone used it until I broke it once and people started
complaining :) )
In the course of a normal build, bundles are first collected into
folders (gather.bin.parts), and are jarred up later if needed. There
aren't any targets in the customBuildCallbacks that will get called
after jars are created.
To have access to these jars, you will instead need to use
customAssembly.xml (which is comparable to customTargets.xml). It does
not go in individual plugins, but goes in your main builder
configuration. This is new in 3.4, there is a small paragraph on it
here
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/tasks/pde_customization.htm.
The target you will be interested in here is "post.jarUp" (or perhaps
pre.archive), folders will have been jared at this point. The property
${eclipse.base} will be the root of the eclipse install that has been
assembled.
-Andrew
romu wrote:
> Dear all,
> For some of our needs, we must have access to the exported jars just
> before their packaging in the final zips.
> So, I took the customBuildCallbacks.xml template and add some
> instructions in the "post.build.jars" target to try to find where the
> jar of my plugin really is.
> I tried to find it just by running the "dir /S" command within the
> "${build.result.folder}" folder without success.
> So my questions are:
> - did I override the right target? ("post.build.jars")
> - where can I find the exported jar?
> Thanks.
Re: Where can I find the exported jars ? [message #41972 is a reply to message #41626] |
Fri, 23 January 2009 15:22 |
romu Messages: 34 Registered: July 2009 |
Member |
Hi Andrew,
And many thanks for the help.
In don't know if the "build.jars" target is called or not, but the
"post.build.jars" is called indeed, but of course, if there is no jar done
at this point, this is pretty useless.
My problem with the solution of the customAssembly is it is Ganymede
specific. My headless build system is able to build any project of my
company with Eclipse 3.2, 3.3 and 3.4, and, of course, I expect the same
behaviour whatever the Eclipse SDK used to build is.
So I guess I have to find a "home made" solution to fulfill my needs.
Thanks for all, that saved me a lot of searches.
Re: Where can I find the exported jars ? [message #42063 is a reply to message #41972] |
Fri, 23 January 2009 15:44 |
Sorry, you are right, I made a mistake. The "build.jars" target is
called by the headless build. I got it mixed up with "build.update.jar"
which isn't called.
Note that the eclipse you use to actually run the build can be different
from the eclipse that you are targeting and compiling against. There
should be no reason you can't use a Ganymede to build a project
targeting Eclipse 3.2.
-Andrew
romu wrote:
> Hi Andrew,
> done at this point, this is pretty useless.
Re: Where can I find the exported jars ? [message #590177 is a reply to message #41539] |
complaining :) )
here
assembled.
-Andrew
romu wrote:
> Dear all,
> Thanks.
Re: Where can I find the exported jars ? [message #590309 is a reply to message #41626] |
Member |
Hi Andrew,
Re: Where can I find the exported jars ? [message #590339 is a reply to message #41972] |
which isn't called.
-Andrew
romu wrote:
> Hi Andrew,
Current Time: Thu Apr 25 12:48:01 GMT 2024
Powered by FUDForum. Page generated in 0.04905 seconds
