Home » Modeling » EMF » How to use external classes in an ecore model
How to use external classes in an ecore model [message #409382] |
Fri, 18 May 2007 10:27 |
Originally posted by: psentosa.yahoo.com
In my ecore model, a class should have references to classes that are not
(and shouldn't be) part of this model (or any other model) .These classes
are actually kept in another plug-in project.
How can I reference them in my model? Until now I've only seen an .ecore
file that refers to other .ecore-s, but not to classes.
I tried to create classes which are named based on those external classes,
and in their field "Instance Class Name" I put the qualified class name of
the referred classes.
But then I see in the generated code, that those classes are IMPLEMENTed.
(which is not correct, because they're classes). In case it was an external
interface, it will be OK because a new interface, that extends the external
interface is generated, and this will be implemented by the corresponding
class. But what about classes?
The same problem is also for any java libraries that are not yet implemented
as .ecore data type (e.g ArrayList?). Will it be a good approach to create a
data type that has its filed "Instance Class Name" referring to the java
libraries? But than I would have the same problematic result in the
generated code.
Thanks for any idea and suggestions.
Paul
Re: How to use external classes in an ecore model [message #409383 is a reply to message #409382] |
Fri, 18 May 2007 11:20 |
Jacek Pospychala Messages: 159 Registered: July 2009 |
Paul,
EDataType's are designed for this purpose. When you create EDataType and
set it Instance Class name to e.g. ArrayList, only appropriate feature
id will be defined in package. If you mark it also serializable, then
generated factory implementation will additionally have convertToString
and createFromString methods.
EMF actually has already a versatile set of etypes implementing
java.util Collections interfaces, starting from BasicEList, that you may
want to use.
To use them in your ecore, set lower and upper bounds, so EMF will
automatically select apropriate list for you.
Hope this helps
Paul Sentosa wrote:
> generated code.
> Regards
> Paul
Re: How to use external classes in an ecore model [message #409384 is a reply to message #409383] |
Fri, 18 May 2007 12:01 |
Jacek,
thanks for your answer.
I tried to follow your suggestion: create a datatype called ArrayList, set
its Instance Class Name to java.util.ArrayList.
But then when I tried to get the .genmodel file, I got the following error
report:
java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EDataTypeImpl
at
org.eclipse.emf.ecore.impl.EReferenceImpl.getEReferenceType( EReferenceImpl.j
ava:268)
at org.eclipse.emf.ecore.impl.EReferenceImpl.eGet(EReferenceImp l.java:358)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:967)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:959)
how can I get this correct?
And should this approach also work for external class -case I mentioned
before?
I created a DataType called OwnClass representing the class
own.package.OwnClass, a class kept in a certain external package..
Doing this, I could get the .genmodel file, but not the generated code, due
to this error:
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenTypedElementI mpl.getTypeGenPa
ckage(GenTypedElementImpl.java:80)
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl$D ependencyHelper.
<init>(GenPackageImpl.java:2050)
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.p repareCache(GenP
ackageImpl.java:2777)
and also, one further question: in case I could make this work, how should I
make a DataType as a reference in my class?
Thanks for further explanation
Paul
"Jacek Pospychala" <jacek.pospychala@pl.ibm.com> schrieb im Newsbeitrag
news:f2k25q$vtp$1@build.eclipse.org...
> Paul,
> want to use.
> Hope this helps
> Paul Sentosa wrote:
> > Hi,
not
classes
classes,
of
IMPLEMENTed.
external
external
corresponding
implemented
create a
> > generated code.
> > Regards
> > Paul
Re: How to use external classes in an ecore model [message #409387 is a reply to message #409384] |
Fri, 18 May 2007 14:03 |
Marcelo Paternostro Messages: 602 Registered: July 2009 |
Hi Paul,
DataTypes, like primitive types, can only be used as the type of
attributes. I believe the first error is happening because you've
defined the feature as a reference.
Regarding the NPE... Are you using EMF 2.3.0? In this version we are
providing a very complete EcoreValidation that would spot problems in
your Ecore model as soon as you open the GenModel editor. Even if you
are currently tied to an earlier version, I would recommend you to have
a separate Eclipse with 2.3.0 installed just to double check your
models. Believe me... It can save you lots of debugging/newsgroup time ;-)
Marcelo
Paul Sentosa wrote:
> Jacek,
> report:
> at
> ava:268)
> at
> at
> before?
> to this error:
> at
> at
> at
> Regards
> Paul
>> Paul,
>> want to use.
>> Hope this helps
>> Paul Sentosa wrote:
>>> Hi,
> not
> classes
> classes,
> of
> IMPLEMENTed.
> external
> external
> corresponding
> implemented
> create a
>>> generated code.
>>> Regards
>>> Paul
Re: How to use external classes in an ecore model [message #409391 is a reply to message #409387] |
Fri, 18 May 2007 14:54 |
Hi Marcelo,
No, I haven't even used the ArrayList; I just defined it first to find out
how the generated code of it looks like, but I got those error report.
And here is also the problem:
In my generated code later, I'd like to have following line generated:
ArrayList children = new ArrayList();
RefererredClass rc;
So as you can see, both are references and not part of the model I defined.
Regarding NPE, yes, I used Eclipse 3.3M4 and its corresponding EMF version.
Any other idea?
Many thanks in advance!
Paul
"Marcelo Paternostro" <marcelop@ca.ibm.com> schrieb im Newsbeitrag
news:f2kbnt$an2$1@build.eclipse.org...
> Hi Paul,
> Cheers,
> Marcelo
> Paul Sentosa wrote:
> > Jacek,
set
error
> > report:
> > at
> > ava:268)
> > at
> > at
> > at
> > before?
due
> > to this error:
> > at
> > at
> > at
should I
> > Regards
> > Paul
> >> Paul,
and
may
> >> want to use.
> >> Hope this helps
> >> Paul Sentosa wrote:
> >>> Hi,
> > not
> > classes
..ecore
> > classes,
name
> > of
> > IMPLEMENTed.
> > external
> > external
> > corresponding
> > implemented
> > create a
java
> >>> generated code.
> >>> Regards
> >>> Paul
Re: How to use external classes in an ecore model [message #409392 is a reply to message #409391] |
Fri, 18 May 2007 15:24 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------050300010109020109030205
Paul,
It's very clear that you have an EReference with an eType that's an
EDataType and the validation support should spot that (when, for
example, you right click and invoke "Validate" from the root package)
but I'm not sure it was complete in M4. I'd suggest using M7. Your
second problem sounds like a feature with no type at all. Again,
validation should report that. I can't imagine that it would be a good
idea to use ArrayList in your APIs. You're sure that a multi-valued
feature (upperBound set to -1) would not be more appropriate?
Paul Sentosa wrote:
> Hi Marcelo,
> RefererredClass rc;
> Any other idea?
> Regards
> Paul
>> Hi Paul,
>> Cheers,
>> Marcelo
>> Paul Sentosa wrote:
>>> Jacek,
> set
> error
>>> report:
>>> at
>>> ava:268)
>>> at
>>> at
>>> at
>>> before?
> due
>>> to this error:
>>> at
>>> at
>>> at
> should I
>>> Regards
>>> Paul
>>>> Paul,
> and
> may
>>>> want to use.
>>>> Hope this helps
>>>> Paul Sentosa wrote:
>>>>> Hi,
>>> not
>>> classes
> .ecore
>>> classes,
> name
>>> of
>>> IMPLEMENTed.
>>> external
>>> external
>>> corresponding
>>> implemented
>>> create a
> java
>>>>> generated code.
>>>>> Regards
>>>>> Paul
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Paul,<br>
<br>
good idea to use ArrayList in your APIs. You're sure that a
multi-valued feature (upperBound set to -1) would not be more
appropriate?<br>
<br>
<br>
Paul Sentosa wrote:
<blockquote cite="midf2kenh$6e1$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Marcelo,
RefererredClass rc;
Any other idea?
Paul
"Marcelo Paternostro" <a class="moz-txt-link-rfc2396E" href="mailto:marcelop@ca.ibm.com"><marcelop@ca.ibm.com></a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:f2kbnt$an2$1@build.eclipse.org">news:f2kbnt$an2$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi Paul,
</pre>
</blockquote>
<pre wrap=""><!---->;-)
</pre>
<pre wrap="">Cheers,
Marcelo
Paul Sentosa wrote:
</pre>
<pre wrap="">Jacek,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->set
</pre>
<pre wrap="">its Instance Class Name to java.util.ArrayList.
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->error
</pre>
<pre wrap="">report:
at
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.ecore.impl.EReferenceImpl.getEReferenceType( EReferenceImpl.j
</pre>
<pre wrap="">ava:268)
at
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.ecore.impl.EReferenceImpl.eGet(EReferenceImp l.java:358)
</pre>
<pre wrap=""> at
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:967)
</pre>
<pre wrap=""> at
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:959)
</pre>
<pre wrap="">....
before?
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->due
</pre>
<pre wrap="">to this error:
at
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.codegen.ecore.genmodel.impl.GenTypedElementI mpl.getTypeGenPa
</pre>
<pre wrap="">ckage(GenTypedElementImpl.java:80)
at
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl$D ependencyHelper.
</pre>
<pre wrap=""><init>(GenPackageImpl.java:2050)
at
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.p repareCache(GenP
</pre>
<pre wrap="">ackageImpl.java:2777)
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->should I
</pre>
<pre wrap="">make a DataType as a reference in my class?
Paul
"Jacek Pospychala" <a class="moz-txt-link-rfc2396E" href="mailto:jacek.pospychala@pl.ibm.com"><jacek.pospychala@pl.ibm.com></a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:f2k25q$vtp$1@build.eclipse.org">news:f2k25q$vtp$1@build.eclipse.org</a>...
</pre>
<pre wrap="">Paul,
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->and
</pre>
<pre wrap="">set it Instance Class name to e.g. ArrayList, only appropriate feature
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->may
</pre>
<pre wrap="">want to use.
Hope this helps
Paul Sentosa wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
<pre wrap="">not
</pre>
<pre wrap="">(and shouldn't be) part of this model (or any other model) .These
</pre>
</blockquote>
</blockquote>
<pre wrap="">classes
</pre>
<pre wrap="">are actually kept in another plug-in project.
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->.ecore
</pre>
<pre wrap="">file that refers to other .ecore-s, but not to classes.
</pre>
</blockquote>
</blockquote>
<pre wrap="">classes,
</pre>
<pre wrap="">and in their field "Instance Class Name" I put the qualified class
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->name
</pre>
<pre wrap="">of
</pre>
<pre wrap="">the referred classes.
</pre>
</blockquote>
</blockquote>
<pre wrap="">IMPLEMENTed.
</pre>
<pre wrap="">(which is not correct, because they're classes). In case it was an
</pre>
</blockquote>
</blockquote>
<pre wrap="">external
</pre>
<pre wrap="">interface, it will be OK because a new interface, that extends the
</pre>
</blockquote>
</blockquote>
</pre>
<pre wrap="">interface is generated, and this will be implemented by the
</pre>
</blockquote>
</blockquote>
<pre wrap="">corresponding
</pre>
<pre wrap="">class. But what about classes?
</pre>
</blockquote>
</blockquote>
<pre wrap="">implemented
</pre>
<pre wrap="">as .ecore data type (e.g ArrayList?). Will it be a good approach to
</pre>
</blockquote>
</blockquote>
<pre wrap="">create a
</pre>
<pre wrap="">data type that has its filed "Instance Class Name" referring to the
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->java
</pre>
<pre wrap="">libraries? But than I would have the same problematic result in the
generated code.
Paul
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------050300010109020109030205--
Ed Merks
Re: How to use external classes in an ecore model [message #409417 is a reply to message #409392] |
Mon, 21 May 2007 16:44 |
------=_NextPart_000_000A_01C79BD8.1AC3CFB0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
thanks everyone for the answers and sorry for this late reply.
Yes, I was editing the model arbitrarily and didn't notice one reference =
I made before. Sorry about this.
Another question, and hope the last one, regarding referring an external =
class. So far I used those classes only as return type or parameter, so =
it wasn't problem at all defining them as a datatype. Now, I just =
realize that one of the classes in the model should EXTEND an external =
class, which means, I can't define this referred external class using a =
new data type. Instead, this class must somehow be recognized as an =
EClass object (but it shouldn't part of any ecore model). Hope I've =
described this clearly.
Any suggestions how I can solve this kind of problem?
Paul
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag =
news:f2kgep$lk4$1@build.eclipse.org...
Paul,
It's very clear that you have an EReference with an eType that's an =
EDataType and the validation support should spot that (when, for =
example, you right click and invoke "Validate" from the root package) =
but I'm not sure it was complete in M4. I'd suggest using M7. Your =
second problem sounds like a feature with no type at all. Again, =
validation should report that. I can't imagine that it would be a good =
idea to use ArrayList in your APIs. You're sure that a multi-valued =
Paul Sentosa wrote:=20
Hi Marcelo,
No, I haven't even used the ArrayList; I just defined it first to find =
out
ArrayList children =3D new ArrayList();
RefererredClass rc;
So as you can see, both are references and not part of the model I =
defined.
Regarding NPE, yes, I used Eclipse 3.3M4 and its corresponding EMF =
version.
Any other idea?
Paul
Hi Paul,
Marcelo
Paul Sentosa wrote:
Jacek,
set
error
report:
at
org.eclipse.emf.ecore.impl.EReferenceImpl.getEReferenceType( EReferenceImp=
l.j
ava:268)
at
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:96=
7)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:95=
9)
before?
due
to this error:
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenTypedElementI mpl.getTypeGe=
nPa
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl$D ependencyHelp=
er.
at
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.p repareCache(G=
enP
should I
Paul
Paul,
and
may
want to use.
Hope this helps
not
classes
.ecore
classes,
name
of
IMPLEMENTed.
external
external
corresponding
implemented
as .ecore data type (e.g ArrayList?). Will it be a good approach =
to
create a
data type that has its filed "Instance Class Name" referring to =
the
java
generated code.
Paul
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2800.1561" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>thanks everyone for the answers and =
sorry for this=20
late reply.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Yes, I was editing the model =
arbitrarily and didn't=20
notice one reference I made before. Sorry about this.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Another question, and hope the last =
one, regarding=20
referring an external class. So far I used those classes only as return =
type or=20
parameter, so it wasn't problem at all defining them as a datatype. Now, =
I just=20
realize that </FONT><FONT face=3DArial size=3D2>one of the classes in =
the model=20
should EXTEND an external class, which means, I can't define this =
referred=20
external class using a new data type. Instead, this =
class must=20
somehow be recognized as an EClass object (but it shouldn't part of any =
ecore=20
model). Hope I've described this clearly.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Any suggestions how I can solve this =
kind of=20
problem?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Many thanks in advance</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Paul</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
schrieb im Newsbeitrag <A=20
href=3D"news:f2kgep$lk4$1@build.eclipse.org">news:f2kgep$lk4$1@build.ecli=
pse.org</A>...</DIV>Paul,<BR><BR>It's=20
EDataType and=20
the validation support should spot that (when, for example, you right =
click=20
and invoke "Validate" from the root package) but I'm not sure it was =
complete=20
in M4. I'd suggest using M7. Your second problem sounds =
like a=20
feature with no type at all. Again, validation should report=20
that. I can't imagine that it would be a good idea to use=20
ArrayList in your APIs. You're sure that a multi-valued feature=20
(upperBound set to -1) would not be more appropriate?<BR><BR><BR>Paul =
Sentosa=20
wrote:=20
<BLOCKQUOTE cite=3Dmidf2kenh$6e1$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi Marcelo,
out
RefererredClass rc;
defined.
version.
Any other idea?
Paul
"Marcelo Paternostro" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:marcelop@ca.ibm.com"><marcelop@ca.ibm.com></A> =
<A class=3Dmoz-txt-link-freetext =
href=3D"news:f2kbnt$an2$1@build.eclipse.org">news:f2kbnt$an2$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi Paul,
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->;-)
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Cheers,
Marcelo
Paul Sentosa wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Jacek,
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->set
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">its Instance Class Name =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->error
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">report:
at
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE =
wrap=3D""><!---->org.eclipse.emf.ecore.impl.EReferenceImpl.getEReferenceT=
ype(EReferenceImpl.j
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">ava:268)
at
wrap=3D""><!---->org.eclipse.emf.ecore.impl.EReferenceImpl.eGet(EReferenc=
eImpl.java:358)
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D""> at
wrap=3D""><!---->org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEO=
bjectImpl.java:967)
</PRE>
bjectImpl.java:959)
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">....
before?
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->due
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">to this error:
at
wrap=3D""><!---->org.eclipse.emf.codegen.ecore.genmodel.impl.GenTypedElem=
entImpl.getTypeGenPa
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE =
wrap=3D"">ckage(GenTypedElementImpl.java:80)
at
wrap=3D""><!---->org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageIm=
pl$DependencyHelper.
</PRE>
wrap=3D""><init>(GenPackageImpl.java:2050)
at
pl.prepareCache(GenP
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">ackageImpl.java:2777)
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->should I
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">make a DataType as a =
Paul
"Jacek Pospychala" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:jacek.pospychala@pl.ibm.com"><jacek.pospychala@pl.ibm.c=
om></A> schrieb im Newsbeitrag
href=3D"news:f2k25q$vtp$1@build.eclipse.org">news:f2k25q$vtp$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Paul,
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE><PRE =
wrap=3D""><!---->and
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">set it Instance Class =
wrap=3D""><!---->may
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">want to use.
Hope this helps
Paul Sentosa wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">not
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">(and shouldn't be) =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">classes
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">are actually kept in =
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ><PRE =
wrap=3D""><!---->.ecore
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">file that refers to =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">classes,
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">and in their field =
wrap=3D""><!---->name
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">of
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">the referred classes.
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">IMPLEMENTed.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">(which is not =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">external
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">interface, it will be =
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">interface is =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">corresponding
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">class. But what about =
classes?
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">implemented
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">as .ecore data type =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">create a
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">data type that has =
wrap=3D""><!---->java
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">libraries? But than I =
generated code.
Paul
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""> =
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000A_01C79BD8.1AC3CFB0--
Re: How to use external classes in an ecore model [message #409420 is a reply to message #409417] |
Mon, 21 May 2007 22:14 |
--------------040201060805070605020509
Paul,
It it's an interface, you can define an EClass with that external
interface name set as the instanceClassName as well as isInterface and
isAbstract set to true. If it's literally a class and not an interface,
then you are out of luck unless you do some hand coding since instances
of EClasses must implement EObject/InternalEObject and that' normally
done by extending EObjectImpl or minimally by extending
BasicEObjectImpl. Since you can extend only one class, extending some
other class will force you to copy all of the logic in
BasicEObjectImpl/EObjectImpl into your derived class.
Paul Sentosa wrote:
> external class. So far I used those classes only as return type or
> Now, I just realize that one of the classes in the model should EXTEND
> an external class, which means, I can't define this referred external
> class using a new data type. Instead, this class must somehow be
> recognized as an EClass object (but it shouldn't part of any ecore
> Regards
> Paul
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> schrieb im
> Newsbeitrag news:f2kgep$lk4$1@build.eclipse.org...
> Paul,
> an EDataType and the validation support should spot that (when,
> for example, you right click and invoke "Validate" from the root
> package) but I'm not sure it was complete in M4. I'd suggest
> using M7. Your second problem sounds like a feature with no type
> at all. Again, validation should report that. I can't imagine
> that it would be a good idea to use ArrayList in your APIs.
> You're sure that a multi-valued feature (upperBound set to -1)
> Paul Sentosa wrote:
>> Hi Marcelo,
>> RefererredClass rc;
>> Any other idea?
>> Regards
>> Paul
>>> Hi Paul,
>>> Cheers,
>>> Marcelo
>>> Paul Sentosa wrote:
>>>> Jacek,
>> set
>> error
>>>> report:
>>>> at
>>>> ava:268)
>>>> at
>>>> at
>>>> at
>>>> before?
>> due
>>>> to this error:
>>>> at
>>>> at
>>>> at
>> should I
>>>> Regards
>>>> Paul
>>>>> Paul,
>> and
>> may
>>>>> want to use.
>>>>> Hope this helps
>>>>> Paul Sentosa wrote:
>>>>>> Hi,
>>>> not
>>>> classes
>> .ecore
>>>> classes,
>> name
>>>> of
>>>> IMPLEMENTed.
>>>> external
>>>> external
>>>> corresponding
>>>> implemented
>>>> create a
>> java
>>>>>> generated code.
>>>>>> Regards
>>>>>> Paul
<html>
<head>
</head>
Paul,<br>
<br>
interface, then you are out of luck unless you do some hand coding
since instances of EClasses must implement EObject/InternalEObject and
that' normally done by extending EObjectImpl or minimally by extending
BasicEObjectImpl/EObjectImpl into your derived class.<br>
<br>
<br>
Paul Sentosa wrote:
<blockquote cite="midf2sia1$5m4$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2800.1561" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Hi,</font></div>
<div> </div>
<div><font face="Arial" size="2">thanks everyone for the answers and
sorry for this late reply.</font></div>
<div><font face="Arial" size="2">Yes, I was editing the model
arbitrarily and didn't notice one reference I made before. Sorry about
this.</font></div>
<div> </div>
<div><font face="Arial" size="2">Another question, and hope the last
one, regarding referring an external class. So far I used those classes
only as return type or parameter, so it wasn't problem at all defining
them as a datatype. Now, I just realize that </font><font face="Arial"
size="2">one of the classes in the model should EXTEND an external
described this clearly.</font></div>
<div><font face="Arial" size="2">Any suggestions how I can solve this
kind of problem?</font></div>
<div> </div>
<div><font face="Arial" size="2">Many thanks in advance</font></div>
<div><font face="Arial" size="2">Regards</font></div>
<div><font face="Arial" size="2">Paul</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>>
schrieb im Newsbeitrag <a href="news:f2kgep$lk4$1@build.eclipse.org">news:f2kgep$lk4$1@build.eclipse.org</a>...</div>
Paul,<br>
<br>
appropriate?<br>
<br>
<br>
RefererredClass rc;
Any other idea?
Paul
</pre>
</pre>
</blockquote>
</pre>
Marcelo
Paul Sentosa wrote:
</pre>
<pre wrap="">Jacek,
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
at
</pre>
</blockquote>
</blockquote>
</pre>
at
</pre>
</blockquote>
</blockquote>
</pre>
<pre wrap=""> at
</pre>
</blockquote>
</blockquote>
</pre>
<pre wrap=""> at
</pre>
</blockquote>
</blockquote>
</pre>
<pre wrap="">....
before?
</pre>
</blockquote>
</blockquote>
</pre>
at
</pre>
</blockquote>
</blockquote>
</pre>
at
</pre>
</blockquote>
</blockquote>
</pre>
at
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
Paul
</pre>
<pre wrap="">Paul,
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
Hope this helps
Paul Sentosa wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
<pre wrap="">not
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
<pre wrap="">of
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
generated code.
Paul
</pre>
</blockquote>
</blockquote>
<pre wrap=""> </pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------040201060805070605020509--
Ed Merks
Re: How to use external classes in an ecore model [message #1772477 is a reply to message #409382] |
Mon, 11 September 2017 09:14 |
Abdelrahman Fouda Messages: 1 Registered: September 2017 |
Hi all,
I have tried using an edatatype and initialize its instance class with the type I need to link to. However, when I tried to link to my class in a different model, it saves the tostring of the class like in the following example
<tasks description="" id="p1.tsk4" label="1" type="place" time="10">
<requiredCapabilityDescriptor>cod.gen.impl.CapabilityDescriptorImpl@78483404 (description: , id: cap2, label: ) (parent: null)</requiredCapabilityDescriptor>
<involvedResource>cod.gen.impl.ResourceDescriptorImpl@2839ac4c (description: null, id: null, label: null) (cad: null, material: null, pointySurface: <unset>, sharpEdges: <unset>, thumbnail: null, weight: <unset>) (changeCost: null, generic: <unset>, investCost: null, manufacturer: null)</involvedResource>
</tasks>
in this example I am linking to two different external classes CapabilityDescriptorImpl and ResourceDescriptorImpl. As you can see the tostring is stored which is inconvenient in terms of storage and readability, also I am not so sure about the consistency handling in such case (I mean deleting, editing of the referenced instance). According to the thread the tostring is written because I chose the data type to be serializable, I have tried making it non serializable, but that did not work .
So I have tried another approach using an eReference, which minimised the string to save to become
<requiredCapabilityDescriptor xsi:type="CoD:CapabilityDescriptor" description="" id="cap2" label=""/>
<involvedResource xsi:type="CoD:ResourceDescriptor"/>
</tasks>
which is much better in terms of readability and storage, but I really doubt it is an actual reference it does not contain any thing that can refer to the original instance. Actually, I am sure it is not referring to the original object as it does not show any econtainer. And again with the consistency issues.
My last option -that I can think of- is storing the URI of the referenced object but in this case I will have to manage all the consistency issues myself.
So my question is "is there a better way to achieve this external class referencing?"
Current Time: Thu Apr 25 19:35:34 GMT 2024
Powered by FUDForum. Page generated in 0.04084 seconds
