Home » Eclipse Projects » Nebula » Custom data model for cells in grid
Custom data model for cells in grid [message #41367] |
Wed, 24 October 2007 12:46 |
Originally posted by: svo.ciklum.net
Hi!
As far as I see, we are bound to String when using Grid (even through
GridViewer), cause GridItem uses text as cell values. Is there any way
to set custom objects as cell values? This is important for our project,
as we are using different datatypes in cells.
Stanislav
Re: Custom data model for cells in grid [message #41430 is a reply to message #41398] |
Wed, 24 October 2007 14:16 |
Yes, I understand the architecture. But can we draw custom content using
label providers with GridViewer?
Stanislav
> What is a "Object", with Viewers normally the LabelProvider makes a
> String/Image presentation from the model-object, what else can you
> display to the user?
> Tom
> Stanislav Vodetskyi schrieb:
>> Hi!
>> project, as we are using different datatypes in cells.
>> Regards,
>> Stanislav
Re: Custom data model for cells in grid [message #41460 is a reply to message #41430] |
Wed, 24 October 2007 14:58 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
I suppose you need to create your own cell renderer. For SWT-Tables we
provide LabelProviders who use OwnerDraw at least from Viewers-Point of
view we could invent something like this also for GridViewer but I don't
know enough about the internals of the Grid-implementation.
Tom
> Regards,
> Stanislav
>> Tom
>>> Hi!
>>> way to set custom objects as cell values? This is important for our
>>> Regards,
>>> Stanislav
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Custom data model for cells in grid [message #41562 is a reply to message #41460] |
Wed, 24 October 2007 15:25 |
Chris Gross Messages: 253 Registered: July 2009 |
As Tom said you could write your own cell renderer. I'd be interested
to see a screenshot of what you are trying to achieve.
-Chris
Tom Schindl wrote:
> Tom
>> using label providers with GridViewer?
>> Regards,
>> Stanislav
>>> Tom
>>>> Hi!
>>>> through GridViewer), cause GridItem uses text as cell values. Is
>>>> there any way to set custom objects as cell values? This is
>>>> important for our project, as we are using different datatypes in
>>>> cells.
>>>> Regards,
>>>> Stanislav
Re: Custom data model for cells in grid [message #41659 is a reply to message #41562] |
Wed, 24 October 2007 16:24 |
Thanks for quick response!
We would try using OwnerDraw. I'll send you the screenshot as soon as we
achieve some solid results :)
We actually want to use combo-box as editor, and need renderer to look
like combo too - that leads to the need for custom drawing. Perhaps you
can advise some easier way? :)
Stanislav
> Regards,
> -Chris
> Tom Schindl wrote:
>> Hi,
>> of view we could invent something like this also for GridViewer but I
>> don't know enough about the internals of the Grid-implementation.
>> Tom
>>> Regards,
>>> Stanislav
>>>> Tom
>>>>> Hi!
>>>>> cells.
>>>>> Regards,
>>>>> Stanislav
Re: Custom data model for cells in grid [message #42525 is a reply to message #41690] |
Mon, 29 October 2007 20:16 |
Originally posted by: svo.maconomy.dk
----------------14973145151600932445
Content-Type: image/png; name="kopete020.png"
Content-Disposition: inline; filename="kopete020.png"
iVBORw0KGgoAAAANSUhEUgAAABYAAAAWCAYAAADEtGw7AAAABGdBTUEAAK/I NwWK6QAAABl0
RVh0U29mdHdhcmUAQWRvYmUgSW1hZ2VSZWFkeXHJZTwAAAS/SURBVHjaYmTA AS6lMDj8Z2CI
Z/gPpP8zKADZDEAaghkYHgDpA0A80WwRwwVs+gECiBFd4HIq2JD5QE0OHDwM DHyiDAw8ivoM
DKwCYHmQBZ9vHGR4/5KB4etHMB9kQaLlEoYHyOYABBAjmqEBIEOBBgpIGcgy cFuXMTBI+zAw
sAlgOunJZoZPJ2cwPDxwjOHLR4YPIMOtlzFsgEkDBBAjmqHrBSUYGCT9sxmY dfMZiAF/Hu1i
eLCwkuHlvc8g5wfaLIcYDhBAjEjePw80VEAmupKBQc4Hw4C/374wMLKLMDAx /8A0/eMthttT
chle3v3yAWiOod0KhgcAAcQEDTew9yW9w4BeNwOa8goF/3p9iuH5unCGT5fm YciBMY8Ag2JC
GQMXH4PA/38M80FmAgQQEzD2DUARJaUvxMCs7gT020sM/PpgP8OvLx8YmDnY scqDMIuIGIOS
hwXIkQ77QxkMAAKIBcjI5+BjYOA2tQPa/hLDlz/fvWT49vIRAyMwVXBL8qGo eXXpFgOnlB0D
r8gLYBJ5xSAgy8zADYznz+8Y8gECiAXkWj4poCphKYYfzy4wsHDzAjEPXPPn u6cZfv9mYBDV
0WVgYgJ6+w9E/NnJMwxPT5xikDJ+w8AreBzogk9gcWF5BoZPbxkcAAIIZLAC jwowsf55wfDt
2Q2Gv/+lGUR1+eAG80gBLWHUZhDRgagBR+T37wzPTl9g+P2LgYGTCxSZQEPZ IeoF5IBxdo5B
ASCAQEHBwMAEVPH3BQMj03eGz/evMIhqKcEN5hAAYX6wPMQLzxjeXnzA8OML AwOXmByDkCgw
X/xECjtWSO4ECCAWcBZl/gV2DRvPL4YvL14wfHnCzMAjwY4a2P/+MjB8AUXU D4Zv34F6WPgY
1GxAPrsCdy2ywQABBDaYgQlo5Z/nDBz8fGDvPT3zgkHdg40Bnof//QPKA9Uw M4CxDDCHy5jy
M7AwXsFM06wQLQABxAQkH3x+CtT4/zsDM/NLBkEtB4Z3j/8yPLsEdBYDEDMC MfNPiKugGOhY
BhaOxyhiMPzuMdjFDwACiAlUSr2/BQpMCJY24wWnglsHGRie32LAqhkffnkV bPABgABi+gcs
+r4+B8brE4gEO+8hBlnHMIY/QMMvb2JgOLWYgeHtE+yGvH7EwHBmDQPDw4vC ENcC4/HTU3Dw
TQQIIHBZcSKGYT+nFIODVh7Qi1ygANJkuLPXkOHmpmXg4AVhYFZlEFKGhjkQ vL4NoaUMVBhM
4rkYGP9dYjjZCTT4EcMBr00MjgABBIoOhmRdhoO/PjMk/P7CwCFkAjL4DYOQ 6g8g9mH49ZmT
4ePTJ2DDv70F4negoksIaKAOg36kNIO6zzNgVn/AcHUh0LJLDB+Asp5LbzJ8 AAggeLF5NApY
bP5nWC9mw8CgGAN1OThVKADTsBHD7y9sDF/ffGYQkAfawPgGqOAKOHL/fGVg uA4sdp7sB6sO
BLoWXGwCBBBKQX84AlLQc8szCCjFAXORFv6y+B3Q7Otzgd6/B3ZpIsxQEAAI IIyq6WA4sGz+
D6yagKUU0AIGERNMC0AGvjwJNPA+JAVADUWpmgACiBGXa0BFH1BTPjDVOAC5 CvCKFKkyBcW+
5ybslSlAgAEAaOLXpbt84FkAAAAASUVORK5CYII=
I've been playing with GridCellRenderer for some time, and couldn't
make it work under windows. I'm posting a snippet here, that works
perfectly on Mac OS X.
It also illustrates windows problems perfectly.
The class we need is ComboCellRenderer. I left some comments in the
code, to point out main problems.
- we have to hide snapshot shell from user. That is done by setting
it's location to [-100,-100] - works perfectly on mac, but not on
windows. On windows XP, when trying to get the snapshot from a shell,
located beyond the screen, we get blank area.
-in the computeSize() method we need to know the size of the cell - to
fit our combobox. This can be achieved, but requires some tricky
loopback.
To make it work on windows (if you run the snippet "as is" it will fall
into infinite loop under win xp) you need to replace renderer's
constructor with the following:
public ComboCellRenderer(Grid grid) {
this.grid = grid;
shell = new Shell(grid.getShell(), SWT.NO_TRIM);
// or use:
// shell = new Shell(grid.getDisplay(), SWT.NO_TRIM);
combo = new Combo(shell, SWT.DROP_DOWN);
combo.setLocation(0, 0);
// hide the snapshot shell from user - will not work under win xp
// platform.
// will have to find some other way round this on windows.
// shell.setLocation(-100, -100);
shell.open();
// shell.setVisible(false);
It will not work on mac properly with this constructor, neither with
grid.getShell() (falling into infinite loop) nor with grid.getDisplay()
(a little better, but still not good).
As you can see, shell's setLocation() method is commented - otherwise,
nothing will be drawn in a cell. I also had to comment
shell.setVisible(false) to make it work. It is not critical at all, and
can be commented on mac too, but I like when it's present
Finally, you can pass either grid.getShell() to the shell constructor,
or grid.getDisplay(). In the latter case, if you move a window over
that shell, it won't be visible.
So, as you can see, the main difficulty is that we cannot hide the
snapshot shell from user on windows XP, plus there is minor difficulty
with getting cell size. Would like to hear your thoughts on how to
achieve it. Thanks in advance
In fact, what we really need and dream of is a cell renderer, that can
take Control as an argument and paint it on screen - like it is done in
Swing
, because right now we will have to reimplement all basic cell
rendering, as DefaultCellRenderer cannot be extended. Are you planning
to implement something like this in near future?
the snippet:
package snippets;
import java.util.ArrayList;
import java.util.Random;
import org.eclipse.jface.viewers.ArrayContentProvider;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.nebula.jface.gridviewer.GridTableViewer;
import org.eclipse.nebula.jface.gridviewer.GridViewerColumn;
import org.eclipse.nebula.widgets.grid.Grid;
import org.eclipse.nebula.widgets.grid.GridCellRenderer;
import org.eclipse.nebula.widgets.grid.GridItem;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
* Snippet for demonstrating combo box rendering.
* @author svo
public class SnippetComboRenderer {
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
shell.setLocation(100, 100);
shell.setSize(400, 400);
// create composite
final Composite composite = new Composite(shell, SWT.NONE);
composite.setLayout(new FillLayout());
//create table viewer
final GridTableViewer tableViewer = new GridTableViewer(composite);
final GridViewerColumn column = new GridViewerColumn(tableViewer, SWT.NONE);
column.getColumn().setText("Column1");
column.getColumn().setWidth(200);
column.getColumn().setCellRenderer(new
ComboCellRenderer(tableViewer.getGrid()));
tableViewer.setLabelProvider(new TableLabelProvider());
tableViewer.setContentProvider(new ArrayContentProvider());
tableViewer.getGrid().setCellSelectionEnabled(true);
tableViewer.setInput(new TableInput(
Content-Type: image/png; name="kopete008.png"
Content-Disposition: inline; filename="kopete008.png"
RVh0U29mdHdhcmUAQWRvYmUgSW1hZ2VSZWFkeXHJZTwAAAZLSURBVHjaYmTA AtQtNigost8y
cBHa6S/P/sBBheuuwn+QBJD4D8EXgPgAkDnRbBHDA2xmAAQQIzJH1WyNAJCa LywtEGBuKs7A
xcnM8Pn1O4Yrx04xZBuvY/CwYGb4//sDw4cbFxnev2Rg+PENbMkEoAWNlksY PiCbBRBAKAYr
Gy+dr2allmBuJcMgK8LGICPMyiAFxBwsjAzz5hxm+PLpA8OkLhcGhl9AM55u YXi9q4vhwanH
DH9+g30QaL0M4XqAAGKGMbbGSCVsfO/e8ENanuHLj38MX77/Zfjy8x/DNyD+ x8DIYGulwHDr
5jOGm9dvMZgaiTAw8KswcBvFM4hI/WP4ePO0xK8fDAGJOgwL519h+AEyDyCA wAZfTmVQuPdV
av36Hx4cz//yMrz99Jfh0/d/DF/BFkAMB7ENjBQZpk3azBAfJg4Mg29gzCKh yyCiIs7w4eIR
gZ8/GSyABi8EmQkQQGCDM40Z1osKfNNY+dCBgUlKAmjoH4bX7/8wvHzzh+Hx s98MT9/8Znj1
4Q8DIxMjw+O7jxm05d4xSIj9Yzh57jPDk6efGOQ0ZRl4eb4wPDt/WyFRm+Hh gqsMFwACiPFS
CoMDMPD3K7uqMmRsiWY4w+LI8J1dgOHd5z8MX78Cg+EHEwPDTyD+BwkyoQ8H GRw1GRgevFdi
kFEUYBDhZWC4c/sZgzzPdQa/f9MZhP+8euC4ikERIIBYgIbGc/AxMHAbGDO0 avxjcE3ezSDn
HMIgwM3O8BZo+Lsvfxi+f/3D8B9kwS8mhg93TjG8NspliAhXAkeutDAbg5SQ GcPPzy4MpWUi
DEZvJivsC7nlABBAzBmGDBPEtNkEuA2tGfh5vjHY6H5iWDn7LAMTMweDpIIs AwcrEwMzCwPD
n7/fGP6cW8IgKKnJwKdvAA7zrz//g2lQHLBxsDOEh5kxLDoM8sGThwABxHg+ ieG/ip8oA4+J
LcO/37/B3n3/hZlhzvIfDNsPsTBceiLN8PvvfwY9sTsMpqbSDItuRjN8E5Jg EOVnYZAXZWOQ
A2ERVgYZaPLkZf3NEOYQcwEggEBBwcDG/4uB4e8Lhl/vPjF8eyvEIKz+h6E8 nYGhJOU/w9+/
byAJnpGR4fajNwyrW38w/GD7w/D0/V+Gtx+BkfvyF8MdflYGMQEWBi15DgYl SXYGSS1DA4AA
YgFlUQaWP0C/vmD4/+cHw5dHLxmElHnhiZyZCZrQ//xk0BI4wyD/z5KBT1CO 4cNPRqDP/jA8
egvET38yMPxmYtj6/xODuDALw6c3nAwAAcQEMvjnl+9Ajc8ZWDj+Mnx+8Zrh x+tnYD4Y/wbi
n0+A+CnQAb8Z6qJXMPy7eZlBWYKdQVGcjUFUhJmBTQBoCM9fBgbW/wwv3wEj +9nlTwABxJym
z5DAKfFfgEfqDzCSvjK8eaDA8Pn5GwZhlT8gZwLDAIiZgJpYGMBYRf41A9// uwyb1nMwyKkB
0y8fFwMbK7BkYP4PjIuvDP+urmUQ+nZlNkAAMafqMxj8/sZgIGYJ0fjrtwLD y8svGJg4GBh4
ZRjgBiJjA61XDL6WJxku7rnAcPvMc4Y/Hz8w/Lh9ikHwzlKGUIGDDJUmV8sB AojxVBwwg/xn
2K8BjCw+ZVCy0mc4NeUBw68vHxnkrRkYFB0YcIJvb4H28CL4VxczMLw8zfDA cyODIkAAMQHL
0wOgsvXBJqAMO1Ah10UGvZQUhv/MfAw39wCzZDdQwxYGhjcPGRheP4DgO0cY GA5NYWDY08PJ
8OeXGgMb0PCf78CGgorRRpAlAAEELjaPRzOACvLzohYMAiqJIFE+hk/P0hgu zN/I8P7BbYZ/
wOz87x/CZaycnAxSBsoM+lE/GFi57zD8AZZHJ5sZGD49ZDjgtYnBEaQGIIDg 5fHRKIYEoG3z
xWyABX4aVPCfK8PHB0IMr6/+ZPj9BRSJrxlENNkZRLWAqYj5CtAB3xm+v2Jg ONcFNPQ+uCw2
BBoMLvABAgiloD8cATScgaGfW45BQCmegUFAiwEveLqPgeH6XGCK/MJwAcgN BBoKL+gBAogR
XfHBcAYDoMv7gdiBW4GBQcIemETlUdW8PMnA8AqIv72CVE1AoUaYS2EAIIAY cblmXyiDA7Dy
jP/3H0yDK9P/yJUpA8MBoPhEz03YK1OAAAMA77NeQD9zzicAAAAASUVORK5C YII=
tableViewer.getGrid().setLinesVisible(true);
tableViewer.getGrid().setHeaderVisible(true);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
@SuppressWarnings("serial")
static class TableInput extends ArrayList<String[]> {
private final String[] values = {"Noise", "Electronic", "Experimental",
"Industrial"};
public TableInput(final int size) {
final Random random = new Random();
for (int i = 0; i<size; i++) {
add(new String[] {values[random.nextInt(values.length-1)]});
static class TableLabelProvider extends LabelProvider implements
ITableLabelProvider{
public Image getColumnImage(Object element, int columnIndex) {
return null;
public String getColumnText(Object element, int columnIndex) {
final String[] row = (String[]) element;
return row[columnIndex];
static class ComboCellRenderer extends GridCellRenderer {
private final Grid grid;
private final Combo combo;
private final Shell shell;
this.grid = grid;
combo = new Combo(shell,SWT.DROP_DOWN);
//hide the snapshot shell from user - will not work under win xp platform.
//will have to find some other way round this on windows.
shell.open();
public boolean notify(int event, Point point, Object value) {
return false;
public Point computeSize(GC gc, int hint, int hint2, Object value) {
final Point rendererSize = getSize();
//renderer size is [0,0]. Need to get to know cell size somehow.
//we can get it from grid, but this kind of loopback is not very good
looking (plus, it won't always return correct item height)
//but it works, in fact
final Point comboSize = combo.computeSize(hint, hint2);
final Point gridCellSize = new
Point(grid.getColumn(getColumn()).getWidth(),
Math.max(grid.getItemHeight(),comboSize.y));
combo.setSize(gridCellSize);
return combo.getSize();
public void paint(GC gc, Object value) {
final GridItem item = (GridItem) value;
System.out.println(item.getText(getColumn()));
combo.setItems(new String[] {item.getText(getColumn())});
combo.select(0);
shell.setSize(combo.getSize());
gc.drawImage(takeSnapshot(), getBounds().x, getBounds().y);
private Image takeSnapshot() {
shell.setVisible(true);
final Image image = new Image(shell.getDisplay(), getBounds().width,
getBounds().height);
final GC gc = new GC(combo);
gc.copyArea(image, 0, 0);
gc.dispose();
return image;
Stanislav
>That's fairly easy make a screenshot on the fly from the Combo and set
>the icon onto cell
I'm doing this with Checkboxes and it works
>fairly well [1].
>Please don't mix things:
>- OwnerDraw is specific to SWT-Tables/Trees you won't have any luck
> using it with Grid
>- CellRenders are the Grid-way of drawing custom things into
> a cell
>Tom
>[1]http://tom-eclipse-dev.blogspot.com/2007_01_01_archive.html
----------------14973145151600932445--
Re: Custom data model for cells in grid [message #42587 is a reply to message #42556] |
Tue, 30 October 2007 09:58 |
Thanks, strangely I didn't notice it myself. One more thing - it would
be cool, if we could draw snapshot of the focused combobox - right now
it's grayed, cause we take snapshot of the background window. Setting
focus directly in the paint method is not good. Is there any way to
force component look like it is active?
Also still don't know how to hide snapshot shell on windows xp.
Thanks in advance :)
Stanislav
Tom Schindl wrote:
> just one note you are leaking resources like hell because you are not
> disposing images you create.
> Tom
Re: Custom data model for cells in grid [message #585475 is a reply to message #41430] |
Tom
> Regards,
> Stanislav
>> Tom
>>> Hi!
>>> Regards,
>>> Stanislav
Re: Custom data model for cells in grid [message #585548 is a reply to message #41460] |
Chris Gross Messages: 471 Registered: July 2009 |
-Chris
Tom Schindl wrote:
> Tom
>> Regards,
>> Stanislav
>>> Tom
>>>> Hi!
>>>> cells.
>>>> Regards,
>>>> Stanislav
Re: Custom data model for cells in grid [message #585585 is a reply to message #41562] |
blutkind Messages: 25 Registered: July 2009 |
Stanislav
> Regards,
> -Chris
> Tom Schindl wrote:
>> Hi,
>> Tom
>>> Regards,
>>> Stanislav
>>>> Tom
>>>>> Hi!
>>>>> cells.
>>>>> Regards,
>>>>> Stanislav
Re: Custom data model for cells in grid [message #586009 is a reply to message #41690] |
loopback.
this.grid = grid;
// or use:
// platform.
shell.open();
Swing
the snippet:
package snippets;
* @author svo
// create composite
shell.open();
display.sleep();
display.dispose();
"Industrial"};
return null;
this.grid = grid;
shell.open();
return false;
combo.select(0);
gc.dispose();
return image;
Stanislav
>the icon onto cell
>fairly well [1].
> using it with Grid
> a cell
>Tom
Current Time: Thu Apr 25 09:12:26 GMT 2024
Powered by FUDForum. Page generated in 0.04459 seconds
