Home » Modeling » EMF » resource resolve() issues
resource resolve() issues [message #407714] |
Mon, 12 March 2007 15:01 |
Originally posted by: pkelly03.gmail.com
I have a model that looks like the following :
<mrd:RepositoryModel xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" >
<classification xsi:type="mrd:RepositoryModelClassification"/>
<solution xsi:type="mrd:RepositoryModelContents">
<artifact xsi:type="mdp:_Artifact" >
<artifact name="IFW System of Record Model">
<reference><element href="design/XX.ldm#_5w9gHczQEduQo_D6tiKB0g"/>
</artifact>
</artifact>
The problem is when I load the resource in my ResourceSet it goes and
loads the <reference> element (design/XX.ldm) and opens it in the editor
window. I don't want this happening, its can be very time consuming
depending on the number of artifacts and clutters up the editor area.
What I want is to return the resource from the resource set without
loading all the hrefs.
I tried setting the loadOnDemand to false - but it just returns a null
for the resource (fair enough). I then tried getting the contents from
an IFile and loading the resource that way (using the
OPTION_DEFER_IDREF_RESOLUTION load option).
file = ResourcesPlugin.getWorkspace().getRoot().getFile(new
Path(platformResourcePath.toString()));
InputStream is = file.getContents();
options.put(XMLResource.OPTION_DEFER_IDREF_RESOLUTION,Boolea n.TRUE);
resource.load(is, options);
This worked fine - but when I add it to the resourceset,
RepositoryPlugin.INSTANCE.getEditingDomain().getResourceSet( ).getResources().add(resource);
it repeats the exercise of resolving all hrefs listed and opening each
one in the editor window.
I wondering is there a way to turn off the resolve of all hrefs on a
resource load?
I seen the following in XMLHelper.setResource that might turn it off
depending on the URI type.
deresolve = resourceURI != null && !resourceURI.isRelative() &&
resourceURI.isHierarchical();
Any help much appreciated,
Paul
Re: resource resolve() issues [message #407720 is a reply to message #407714] |
Mon, 12 March 2007 15:22 |
Ed Merks Messages: 33140 Registered: July 2009 |
Paul,
Comments below.
Paul Kelly wrote:
> xmlns:xmi="http://www.omg.org/XMI"
> <reference><element
> </artifact>
> </artifact>
> editor window. I don't want this happening, its can be very time
> consuming depending on the number of artifacts and clutters up the
> editor area.
That's want happens when you load, but once you start accessing the
data, it needs to resolve the proxies to do that. You can call
eGet(feature, false) or for multi-valued features cast to InternalEList
and call basicGet.
This just affects how IDREFS are resolved and you are dealing with cross
document references.
Proxies should not be resolved just because you've added the object to
the resource set. (But there may well be adapters do this under the
covers, like the ECrossReferenceAdapter; but it can be specialized not
to do that by overriding resolve() to return false.)
> resource load?
It should not happen purely because of a load. It only happens as a
result of looking at the data.
This has to do with resolving or deresolving URIs to make them absolute
or relative and is not directly related to proxy resolution.
> Cheers,
> Paul
Ed Merks
Re: resource resolve() issues [message #407721 is a reply to message #407720] |
Mon, 12 March 2007 15:36 |
Thanks for the update Ed,
I see the ResourceSet does have a CrossReferenceAdapter attached to it and it is set to true like you say.
Any idea how to detach the current crossReferenceAdapter and add a new one with resolve set to false?
Sorry to be a nuisance.
Paul
Ed Merks wrote:
> Paul,
> Comments below.
> Paul Kelly wrote:
>> Hi,
>> <reference><element
>> </artifact>
>> </artifact>
>> editor area.
> and call basicGet.
>> resource load?
>> Cheers,
>> Paul
Re: resource resolve() issues [message #407722 is a reply to message #407721] |
Mon, 12 March 2007 16:58 |
Paul,
Probably you should figure out where this is created and see how to
specialize that code to create your own derived version. I.e., set a
breakpoint in the constructor and see when it is invoked.
> Cheers,
> Paul
> Ed Merks wrote:
>> Paul,
>> Comments below.
>> Paul Kelly wrote:
>>> Hi,
>>> <reference><element
>>> </artifact>
>>> </artifact>
>>> and loads the <reference> element (design/XX.ldm) and opens it in
>>> the editor window. I don't want this happening, its can be very time
>>> editor area.
>> InternalEList and call basicGet.
>>> null for the resource (fair enough). I then tried getting the
>>> contents from an IFile and loading the resource that way (using the
>> cross document references.
>>> each one in the editor window.
>> to the resource set. (But there may well be adapters do this under
>> the covers, like the ECrossReferenceAdapter; but it can be
>> specialized not to do that by overriding resolve() to return false.)
>>> resource load?
>> absolute or relative and is not directly related to proxy resolution.
>>> Cheers,
>>> Paul
Ed Merks
Current Time: Thu Apr 25 07:18:41 GMT 2024
Powered by FUDForum. Page generated in 0.02818 seconds
