Re: Grid : When Headers meet Footers [message #41841 is a reply to message #41515] |
Thu, 25 October 2007 10:30 |
Defert Philippe Messages: 62 Registered: July 2009 |
Member |
Hi Chris,
In first solution you loose the most important effect :-), the scroll
between header and footer like this
http://home.tampabay.rr.com/bmerkey/examples/nonscroll-table -header.html
in second solution, you can't use the contentprovider to do the summary
and you must manage the layout of additional component.
What changes would be necessary to add these features to grid and
gridviewer?
Philippe
Chris Gross a écrit :
> Hi Philippe,
> The Grid currently doesn't have any footers. You could put a summary
> row at the end of the table and color it different, or you could put the
> summary information outside and underneath the table.
> Regards,
> -Chris
> Defert Philippe wrote:
>> Hi Grid team,
>> Is it possible to add columnFooter like as TFOOT from html table ?
>> If yes, is it possible to have vertical scroll between columnheader and
>> columnfooter ?
>> Is it possible to add RowFooter ?
>> If yes, is it possible to have horizontal scroll between rowheader and
>> rowfooter ?
>> Why need footers ?
>> when you need to do some aggregation on column or row, You need to
>> display clear information in specified areas with different behaviors
>> than the body of grid.
>> best regards
>> Philippe
Re: Grid : When Headers meet Footers [message #585681 is a reply to message #41515] |
Member |
Hi Chris,
gridviewer?
Philippe
> Hi Philippe,
> Regards,
> -Chris
>> Hi Grid team,
>> columnfooter ?
>> rowfooter ?
>> Why need footers ?
>> best regards
>> Philippe
FUDForum. Page generated in 0.03599 seconds
