Home » Eclipse Projects » Standard Widget Toolkit (SWT) » problems with TableViewer
problems with TableViewer [message #406095] Tue, 06 January 2004 20:56 Go to next message
Brian Fernandes is currently offline Brian FernandesFriend
Member
Hi Guys,
I'm using a TableViewer for one of my views but I am unclear of how to
achieve the following.
I have 3 columns in my table. Consider a single row of the table. The color
of the cell in the first column must bet set corresponding to the text in
the cell in the second column. Currently I am using a ColorCellEditor in the
first column but the cell editor is displayed only when I click the cell
(obviously). When you use this cellEditor to pick a color, I also manage to
change the background color of the TableItem. - this has 2 issues
1) the color of the entire row is changed, not a single cell
2) the color can be set only you manually change the color.
I use a Label provider to set the text in the second column - this would be
a good time to set the color of the tables cells as well; but here I don't
have a TabelItem Reference - I only have the Object provided by the
ContentProvider and an index.
So in what method should I change the background color of the cells ? - so
that as soon as a row is populated with textual data, it's color is set
accordingly ?
I have also set the third column to be a CheckboxCellEditor but the checkbox
isn't being displayed. Any simple mistakes which I could have made ?
Brian.
Re: problems with TableViewer [message #406106 is a reply to message #406095] Wed, 07 January 2004 01:51 Go to previous messageGo to next message
Michael Xia is currently offline Michael XiaFriend
Brian,
Are you using 2.1? In 3.0, you could use TableItem.setBackground(int,
Color) to set individual cell's background color.
Michael
Brian Fernandes wrote:
> Hi Guys,
> accordingly ?
> Brian.
Re: problems with TableViewer [message #406116 is a reply to message #406106] Wed, 07 January 2004 05:17 Go to previous messageGo to next message
Member
Great - I am using 3 so I can color individual cells.
But I still have a problem here ..
My view is linked to an editor and I am notified of editor changes with the
IPartListener Interface.
When my editor is activated, I call setInput which in turn calls
getElements[] and the LabelProvider provides the new labels for the table.
Now according to a label in a row, I have to set the color of a cell in that
row - where do I do this ?
Or do I use the list of tableItem list to getText and according set the
color ? In what method do I do this ?
Thanks again,
Brian.
Re: problems with TableViewer [message #409981 is a reply to message #406106] Thu, 15 January 2004 06:38 Go to previous messageGo to next message
Member
I managed to set the background color of the cell using the
ColorCellEditor - but I'm having the following issues with this.
If the table style is set to SWT.FULL_SELECTION, then if I click a row of
the table, the entire rows background color becomes the selection color, and
the color I set is not visible... this is not too big a deal, becuse the
selection is not shown if you deselect the view.
If I don't use SWT.FULL_SELECTION , then the color cell editor does not work
as expected. I have to first select the appropriate row of the table by
clicking a cell in the first column and then only can I click the
colorCellEditor.
SWT.HIDE_SELECTION does not have any effect when SWT.FULL_SELECTION is on.
Any thing I can do to disable the selection from changing the background
color ?
Brian.
"Michael Xia" <yun@rti.com> wrote in message
news:btfone$54k$1@eclipse.org...
> Brian,
> Michael
> > Hi Guys,
color
in
the
to
be
don't
so
> > accordingly ?
checkbox
> > Thanks,
> > Brian.
Re: problems with TableViewer [message #449915 is a reply to message #406095] Mon, 31 January 2005 13:04 Go to previous message
Originally posted by: hoeggerand.post.ch
Brian Fernandes schrieb:
> Hi Guys,
> accordingly ?
> Brian.
Hi Brian
When you attach your own provider class implements ITableLabelProvider,
ITableColorProvider to a TableViewer. The methods Color
getForeground(Object element, int columnIndex); and
Color getBackground(Object element, int columnIndex);
are called for each cell in your table. Once you have had a look at the
implementation of the TableViewer you'll find this hack as internal
class TableColorAndFontCollector.
snipplet:
TableViewer tv = new TableViewer(new Table(parent),SWT.FULL_SELECTION);
tv.setLabelProvider(new P_NonSenseProvider());
// somewhere else
class P_NonSenseProvider implements ITableLabelProvider,
ITableColorProvider{
public Image getColumnImage(Object element, int columnIndex)
{ return null; }
public String getColumnText(Object element, int columnIndex)
{ return null; }
public void addListener(ILabelProviderListener listener)
public void dispose()
public boolean isLabelProperty(Object element, String property)
{ return false; }
public void removeListener(ILabelProviderListener listener)
// methods of the ColorProvider
public Color getBackground(Object element, int columnIndex)
{ return null; }
public Color getForeground(Object element, int columnIndex)
{ return null; }
Hope it helps...
Previous Topic:flexible space between menus
Next Topic:Cell editors not working.
Current Time: Wed Dec 11 16:38:36 GMT 2019
Powered by FUDForum. Page generated in 0.01443 seconds
