Home » Modeling » EMF » emf generated editor using transactional editing domain
emf generated editor using transactional editing domain [message #405466] Wed, 22 November 2006 02:28 Go to next message
Vlad Ciubotariu is currently offline Vlad CiubotariuFriend
On the gmf list someone else made the emf editor work with a given
transactional editing domain.
I thought one has to manipulate a model through transactional commands,
however I'm pretty sure the emf editor doesn't do that. How does it work?
thanks for your help,
Vlad
Re: emf generated editor using transactional editing domain [message #405471 is a reply to message #405466] Wed, 22 November 2006 11:00 Go to previous messageGo to next message
--------------040400090208060800070701
Vlad,
I think you'd want to use it in combination with
TransactionalCommandStackImpl which creates transactions as you execute
a command.
public void execute(Command command, Map options) throws
InterruptedException, RollbackException {
if ((command != null) && command.canExecute()) {
InternalTransaction tx = createTransaction(command,
options);
Vlad Ciubotariu wrote:
> Vlad
<html>
<head>
http-equiv="Content-Type">
</head>
Vlad,<br>
<br>
a command.<br>
<blockquote>
Ed Merks
Re: emf generated editor using transactional editing domain [message #405513 is a reply to message #405471] Thu, 23 November 2006 23:59 Go to previous message
Thanks a lot for the info.
vlad
On Wed, 22 Nov 2006 06:00:39 -0500, Ed Merks wrote:
> Vlad,
> a command.
> options);
>> Hi,
>> Vlad
> <html>
> <head>
> </head>
> Vlad,<br>
> <br>
> a command.<br>
> <blockquote>    public void execute(Command command, Map options)
> throws InterruptedException, RollbackException {<br>
>         if ((command != null) &amp;&amp; command.canExecute()) {<br>
> options);<br>
>             <br>
> </blockquote>
> <br>
> <blockquote cite="midpan.2006.11.22.02.28.39.725096@uwaterloo.ca"
> type="cite">
> <pre wrap="">Hi,
> Vlad
> </pre>
> </blockquote>
> <br>
> </body>
> </html>
Previous Topic:EAnnotation contents lost due to EPackage generation
Next Topic:Question about saving model
Current Time: Tue Apr 16 14:41:19 GMT 2024
Powered by FUDForum. Page generated in 0.01895 seconds
