Home » Modeling » EMF » getTypeDefinition returns null for element declared in included schema
getTypeDefinition returns null for element declared in included schema [message #405202] Wed, 08 November 2006 14:06 Go to next message
A call to getTypeDefinition() on an XSDElementDeclaration element
returns null if that element is declared in an external schema
included in the main schema.
For example if I have the schema file listed below and I walk the
schema, elements, when I come to the ElementDeclaration for ref=qa:ref1"
XSDElementDeclaration elementDecl = (XSDElementDeclaration)node;
XSDTypeDefinition type = elementDecl.getTypeDefinition()
the call to getTypeDefinition() returns an XSDComplexTypeDefinition
which is what I expect and I can walk the children of that element.
If, however, the identical declaration of element 'ref" exists in
the included file (test2.xsd) the same call to elementDecl.getTypeDefinition()
returns null.
I made sure that the declaration of element 'ref' was commented out in the
second case of course.
Is there something extra I have to do to ensure I can reference externally
included elements in my xsd xshema model?
Gary
<xs:schema
targetNamespace="http://www.test.com/qa/"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:po="http://example.com/po"
xmlns:qa="http://www.test.com/qa/"
elementFormDefault="unqualified"
attributeFormDefault="unqualified">
<!-- <xs:include schemaLocation="C:/Tmp/workspace/Test/test2.xsd"/> -->
<xs:element name="main">
<xs:complexType>
<xs:sequence>
<xs:element name="main1" type="xs:string"/>
<xs:element name="main2" type="xs:string"/>
<xs:element ref="qa:ref"/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="ref">
<xs:complexType>
<xs:sequence>
<xs:element name="ref1" type="xs:string"/>
<xs:element name="ref2" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
Re: getTypeDefinition returns null for element declared in included schema [message #405203 is a reply to message #405202] Wed, 08 November 2006 14:26 Go to previous messageGo to next message
Gary,
Depending which methods you call to reach the element declaration you
may well be looking at an element declaration reference,
XSDElementDeclaration.isElementDeclarationReference() is true, and in
that case you'll want to get the resolved one,
XSDElementDeclaration.getResolveElementDeclaration(), and call
getTypeDefinition for that. If you are walking the particle structure,
use getTerm to get at the term because this will return the resolved
element declaration, rather than getContent, which will return an
element declaration reference if the source has a ref=. Similarly for
a model group, use getParticles rather than getContents. In other
words, walk the logical structure (the "infoset properties" in the
Javadoc) unless you want to look closely as the physical structure (the
"concrete references" in the Javadoc).
> returns null.
> Gary
> <xs:schema
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
Re: getTypeDefinition returns null for element declared in included schema [message #405204 is a reply to message #405203] Wed, 08 November 2006 15:04 Go to previous messageGo to next message
Thanks for the reply.
In this case I do use both getTerm() and getParticles() to
walk the structure. I call getResolveElementDeclaration() on
every element if isElementDeclarationReference() is true for that element.
To be sure, I called isElementDeclarationReference() on that specific
elementDeclaration which returned false.
Would there be another reason I can not get the Type? The code I am
using is code you sent me back in Nov 2005. If you have time I could
send it back as an eclipse project.
"Ed Merks" <merks@ca.ibm.com> wrote in message news:eitb24$6qa$1@utils.eclipse.org...
Gary,
> returns null.
> Gary
> <xs:schema
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
Re: getTypeDefinition returns null for element declared in included schema [message #405206 is a reply to message #405204] Wed, 08 November 2006 16:29 Go to previous message
--------------050002050208080500090406
Gary,
The sample appears correct in the editor:
If you want to send me a project that I can easily run to reproduce the
problem, I'll have a look at that.
> Thanks
> Gary,
>> returns null.
>> Thanks,
>> Gary
>> <xs:schema
>> <xs:complexType>
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> </xs:element>
>> <xs:complexType>
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> </xs:element>
>> </xs:schema>
Content-Type: multipart/related;
boundary="------------000602020106080805050100"
--------------000602020106080805050100
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
The sample appears correct in the editor:<br>
<blockquote><img src="cid:part1.05070503.05000302@ca.ibm.com" alt=""><br>
</blockquote>
problem, I'll have a look at that.&nbsp; <br>
<br>
<br>
Gary J wrote:
<blockquote cite="mideitd86$np1$1@utils.eclipse.org" type="cite">
<pre wrap="">Thanks for the reply.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message <a class="moz-txt-link-freetext" href="news:eitb24$6qa$1@utils.eclipse.org">news:eitb24$6qa$1@utils.eclipse.org</a>...
Gary,
Gary J wrote:
</pre>
<blockquote type="cite">
<pre wrap="">A call to getTypeDefinition() on an XSDElementDeclaration element
returns null.
Gary
&lt;xs:schema
targetNamespace=<a class="moz-txt-link-rfc2396E" href="http://www.test.com/qa/">"http://www.test.com/qa/"</a>
xmlns:xs=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>
xmlns:po=<a class="moz-txt-link-rfc2396E" href="http://example.com/po">"http://example.com/po"</a>
xmlns:qa=<a class="moz-txt-link-rfc2396E" href="http://www.test.com/qa/">"http://www.test.com/qa/"</a>
attributeFormDefault="unqualified"&gt;
&lt;!-- &lt;xs:include schemaLocation="C:/Tmp/workspace/Test/test2.xsd"/&gt; --&gt;
&lt;xs:element name="main"&gt;
&lt;xs:complexType&gt;
&lt;xs:sequence&gt;
&lt;xs:element name="main1" type="xs:string"/&gt;
&lt;xs:element name="main2" type="xs:string"/&gt;
&lt;xs:element ref="qa:ref"/&gt;
&lt;/xs:sequence&gt;
&lt;/xs:complexType&gt;
&lt;/xs:element&gt;
&lt;xs:element name="ref"&gt;
&lt;xs:sequence&gt;
&lt;xs:element name="ref1" type="xs:string"/&gt;
&lt;xs:element name="ref2" type="xs:string"/&gt;
&lt;/xs:element&gt;
&lt;/xs:schema&gt;
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot-28.jpg"
Content-ID: <part1.05070503.05000302@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot-28.jpg"
/9j/4AAQSkZJRgABAQIAJQAlAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAJCAxsDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD0qWc5hjhXzJp22xKTgE4z yewxzV59LtrX
C6jr/kzsN2xDFGuPYOCce+az/Dn/ACEdH/68X/lHWlr02oRS6mdKGb0WluY+ ATjzJN2M8Z25
xnvipSbaS6jbsm2SW+iWt3GZLbWrqZAcFo2hYA+mQlS/8I0n/QTvvyi/+IrJ 0C6M93Bdi9uZ
Zprt7adJ4VidQsbMEkVflLDA+YY4Puc6XijxMnhhLS4uIJ3tX895XijV+Ire SbZy6kMRGSDh
h8pB27gQ0mm1JaoV00miT/hGk/6Cd9+UX/xFH/CNJ/0E778ov/iKj1bxZBpe sR6SmnX17fSe
VsitvKG7zFnYcyOo4FtITk91xnPGfp3jFL7xXPZJ57rJaW5isgi+ZFKJ7mK4 ZjnG1DEoZtxX
KgKWLqGLIDU/4RpP+gnfflF/8RR/wjSf9BO+/KL/AOIq5qesW+keU94k4gky POjiMiq/G1CF
y258kLgHLALncyK2W3jOyjur2GWzu40023E+pyloiLHMRl2yKJC7Hb3jV1J4 BOGwWQFj/hGk
/wCgnfflF/8AEUf8I0n/AEE778ov/iKr6JrWoal4q1W0u7C70+C3srSSK2uj CW3O9wGcGJ3G
CEQYJ/hPAzk2fFEZ/syO5M1wsVtMJZYbed4ZLhSGURqyEHcSylV/iZVXjOQW QFG88M6iH32W
rsy8fup40BPr84U4/wC+aymiuYLgW15d3NtcHlVbyiHHqp28/wA/UVr3lnen U9NtrnVbhpWm
DwzIWgj2RlWZHVWxLLIMgg4XarsqrtIboLyzgv7V7e4TfG34EHsQexHrRYdz jfss3/QQuf8A
vmP/AOIo+yzf9BC5/wC+Y/8A4ip5oZ9NuhaXbb1b/UT4wJB6H0Yfr1Hs+oGV fss3/QQuf++Y
/wD4ij7LN/0ELn/vmP8A+Iq1RQMq/ZZv+ghc/wDfMf8A8RR9lm/6CFz/AN8x /wDxFWqKAKv2
Wb/oIXP/AHzH/wDEUfZZv+ghc/8AfMf/AMRVqigCr9lm/wCghc/98x//ABFH 2Wb/AKCFz/3z
H/8AEVaooAq/ZZv+ghc/98x//EUfZZv+ghc/98x//EVaooAq/ZZv+ghc/wDf Mf8A8RR9lm/6
CFz/AN8x/wDxFWqKAKv2Wb/oIXP/AHzH/wDEUfZZv+ghc/8AfMf/AMRVqigC r9lm/wCghc/9
8x//ABFH2Wb/AKCFz/3zH/8AEVaooAq/ZZv+ghc/98x//EUfZZv+ghc/98x/ /EVaooAq/ZZv
+ghc/wDfMf8A8RR9lm/6CFz/AN8x/wDxFWqKAKv2Wb/oIXP/AHzH/wDEUfZZ v+ghc/8AfMf/
AMRVqigCr9lm/wCghc/98x//ABFH2Wb/AKCFz/3zH/8AEVaooAq/ZZv+ghc/ 98x//EUfZZv+
ghc/98x//EVaooAq/ZZv+ghc/wDfMf8A8RR9lm/6CFz/AN8x/wDxFWqKAKv2 Wb/oIXP/AHzH
/wDEUfZZv+ghc/8AfMf/AMRVqigCr9lm/wCghc/98x//ABFH2Wb/AKCFz/3z H/8AEVaooAq/
ZZv+ghc/98x//EUfZZv+ghc/98x//EVaooAq/ZZv+ghc/wDfMf8A8RR9lm/6 CFz/AN8x/wDx
FWqKAKv2Wb/oIXP/AHzH/wDEUfZZv+ghc/8AfMf/AMRVqigCr9lm/wCghc/9 8x//ABFH2Wb/
AKCFz/3zH/8AEVaooAq/ZZv+ghc/98x//EUfZZv+ghc/98x//EVaooAq/ZZv +ghc/wDfMf8A
8RR9lm/6CFz/AN8x/wDxFWqKAKv2Wb/oIXP/AHzH/wDEUfZZv+ghc/8AfMf/ AMRVqigCr9lm
/wCghc/98x//ABFH2Wb/AKCFz/3zH/8AEVaooAq/ZZv+ghc/98x//EUfZZv+ ghc/98x//EVa
ooAq/ZZv+ghc/wDfMf8A8RR9lm/6CFz/AN8x/wDxFWqKAMq6urSxlEV3r4t5 Cu4JLJChI9cF
enBotbq0vpTFaa+LiQLuKRSQuQPXAXpyKtm2uEvpLuz1O6s5JYkikESxMGCl iv30bn526UC2
uHvo7u81O6vJIonijEqxKFDFS33EXn5F60xEF00djEJbvWXt4y20PK0SAn0y V68Gq0ep6dNK
kUXiWJ5HYKqLNASxPQAbeTV65to7zWNDglaVUe8fJhmaJuLeY8MhBHTsat+J tDtLPR1nim1B
nS8tMCbUZ5V5uIxyruQevcUJBcrRTyxzi2uSrSMpZHQYDgYzxk4IyPz/AAEq 5njupzcC2srM
E3E+ze3A3MFHsvOSD1GAecRXX/HzY/8AXc/+i3q1Ckdz4SvbWWdYI5RdRtK3 SMF3BY8jgZz1
pwSbVxSbSdhbS30+9uxaxanq6zFDIFmtPKyoIBILwgHBZfzrQ/4R6P8A6Cd9 /wCQv/jdctNM
knmXP9r22sSRw+ULbT2eKQK8sW590bu+F2gnaOma3fD4WK38wWd/atNFFIwu 7p5uSuSo3uWB
Ukg5C5963qU4RV1/X5P8DClVnJ2l/X5r8S5/wj0f/QTvv/IX/wAbo/4R6P8A 6Cd9/wCQv/jd
Ydz4l1FLK/12L7KNH09p1ltnjY3EqwMySur7tqnKNtQq24KMsu87F1zxvFp/ hm51K1hdpw17
BAsqgr51uk7Eths7CbduhzyOnOMTc2/+Eej/AOgnff8AkL/43R/wj0f/AEE7 7/yF/wDG65W/
8cz6VrM8l/b3VtZpZxzGzeKKSVSEvpH+ZJNoJW2THzMOAMAsSL978QLDS7eQ 6naXVhdK0ara
3MkCs4cOVYSeZ5QB8qX7zg/JjGSu4A2/+Eej/wCgnff+Qv8A43R/wj0f/QTv v/IX/wAbpuja
7aa7pUGo2T7oJdwHIOGVirDKkg4YEZUkHGQSMGql5FNL4jtzHeXCSXEOyBY5 GKQMm5md4shX
RgyoScEHYAQWDKaARXPh/VoXZ7fUjcx8kRlUjcDsAdpDH67R/SlHHI8jxG/u kmjOJInWLcn1
G39eh7VpWcU0XiO4Ml5cPJbw7J1kkYJOz7WV0iyVRFCsgIySd4JJUs17ULWO /iXLeXNHkxSg
ZKn+oPcd/qAQmgMP7LN/0ELn/vmP/wCIo+yzf9BC5/75j/8AiKljkbzGhmQR 3Ef3kzkEdmB7
g+v4dRUtSMq/ZZv+ghc/98x//EUfZZv+ghc/98x//EVaooGVfss3/QQuf++Y /wD4ij7LN/0E
Ln/vmP8A+Iq1RQBV+yzf9BC5/wC+Y/8A4ij7LN/0ELn/AL5j/wDiKtUUAVfs s3/QQuf++Y//
AIij7LN/0ELn/vmP/wCIq1RQBV+yzf8AQQuf++Y//iKPss3/AEELn/vmP/4i rVFAFX7LN/0E
Ln/vmP8A+Io+yzf9BC5/75j/APiKtVS1KUC0mt1WR5pYX2JHGzk8Y7A45I6+ tROahFyY4x5n
ZCRL5+fJ1aWTb12eUcfktSfZZv8AoIXP/fMf/wARV7XrpY7u1uHWTyY4Zt7p GzBeUPOAccA/
lUdTSqqd9dhyjYq/ZZv+ghc/98x//EU3yJAf+QlP+Uf/AMRVzcqHdIrsgGSE xk+3WtpbwKoV
QAoGAAOlakHO+HP+Qjo//Xi/8o62NY0i6vry4K21pcWtxbxxOk87RkFWc5GE P94YOQQRWR4d
ISewlK7jHpruBnH/ADyrf/tz/p2/8f8A/rVadrMTV9ChpuhXlnd2pFtawQR3 D3ErLdyTSSM0
bLklkBJ+Yck9BVrxDoC+IpdPt7pY20+F5nuVLMGlDwSQeWMYwCszktnI2gAH dldOyu/tkJk2
bMNtxnPp/jUwkzM0ePuqGz9c/wCFO7erElbRHPWvg+KLW4tYu9X1LULyJ42R 7jyVACJOgXEc
ajGLmQ+udvOBgkXgrTYJru4jnu1uJ38xJg677eTzp5g8Z28HdcyLg5BX5WBB bd0lFAGPP4dt
7uBLe8u764gWWaby3uCMu7l1O5cN+7yRHg/LhT95EZad74MstXuo5tZvLvU0 it5II4p1iQJ5
kXlSMGjjV8upbI3bctkAbV26ms6xb6Hpz3t0k7xrniGItzgn5m+7GvHLuVQf xMBVixe8ks42
v4IILo53xwTGVF5OMMVUnjH8I9OetAGfpOgnTNRu7+fVb7Ubq6iihZ7sQjak ZkKgCKNB1lbr
ntVnVNLGpC1Iu7i1ltpvOilg2Fg2xkPDqwIw7dqrR6+I/D2n6pqNhfW0l1FG 72sNpNcSQuyb
ijLGhYY5BJUcjsTij/hJbD+zvt32fVfJ83ydv9k3XmbsZz5fl79uP4sbc8Zz xQAyTwvZZiFt
LcWsSzRzzRQspW4eNw6tIWBJbKjLAhm/iJwMbdU9N1ODVbdp7eO7RFcoRdWk tu2cA8LIqkjn
rjHX0NR6zrFvoenPe3STvGueIYi3OCfmb7sa8cu5VB/EwFAFm8s4L+1e3uE3 xt+BB7EHsR61
yt1bXekcXYM1qM7bpATgf9NAB8v16fStXUtY1LSPD66peadaZgcPfpFeMywW 4J3yoxjBkKr8
xTapOCAScZp/8JRfyeF/7bt9G8+OeXNmsUsknmWxP7uZwkTSLuGDsVHI3Luw NxRNXAqxSxzo
HikSRD/EjAin1FYT/wDCRaPqepSeHYU1S1d0it4Lp4pLhhErKrs6RSRliwGJ FHGG5UqTeGiN
JocNzHpbR6m8SO9nPq0ypG5xuQyruzt55CnOO2c0uUdytRVCe4tU8F6P4jt9 Hubj7f8AYy9o
uqSq6C4KKAhJ2uwaRRhigPJyKPOg2fY/7Jb+2f7Q/s/yP7Wn+z+Z9n+0583G 7b5Xfy87+MY+
alyjuX6Ks6To63cU51LSLnT5I5fLRRqckolUKpLqQ3CliwGQGIUEhSdoy/Ms n8J6Fr0WmylN
SeyEsLanMDCtyyJlTzvKtIvB25GeR0Jyhct0VQeaAXN1Yx6SzX66qdNtkbVp xFJ/owuQ7vgl
P3eRgK3zADODuFO51a2s7S5E+g3i6hFqY01LdNQuZld/s63BfMSu+zaWxhCe FLBMtsOULm3R
S+G7Wz1zTpJ7nS9QsZopTEyS3F0ivwGDJ5ojcrhsZKL8wYDIAJk1/T7bSNLa 6tNMvL2QOF8t
bu5IUH+JhHvcjt8iMckZAXcynKFyKisixvUvLCP/AIkrR6jPqBsbe3fVrlEJ EBnLSF0WSL5V
fAaLJ+Uj5XDVcugdO0S4v77w5eRzx3tvaRW0WrM5uBI8Ue9G3AAbpG2h9pIU Ftm7CnKFy3RW
RfalZ6fYSLNo9y+qpqA0828F/dTRGQwC4yGRDIV8o9RFkNxjb89Rx6g8sOm+ X4YvPPvL2SxK
TajdW4DiFpVdfNRGaLCsGYqpBVtqycZOULm3RWAPEGmT6ctxbaHqAmuIra4t IZr+YtJDMJCj
MsRkfdiCQ7UWQhdjHaN/l3LDUdNu9ElvZNKvIbiDU7fTp4GvLpAGmeFQy+YE fAWdT8yLkggc
YYnKFzTopdWt9Ms2gtrCBry/uLv7GkT6nNGiSeU0xEjAsU/dqSPlJO5eADkZ /nQbPsf9kt/b
P9of2f5H9rT/AGfzPs/2nPm43bfK7+XnfxjHzUcoXL9FUL5207SZLi88PXMV 2bsW1vANVmlE
48sM0i+UHkK5EgAWNnwoZlRdxSmmqQ3Hh+S+ttDl+2QanBp09tc6ld26q0pj CspeMOR++jzu
jX+LGQAWOULm3RVn+wZf7H83+zov7T/59/7YuPJ+9/z12bvu8/c68e9ZaSWV z4c8P6haabK1
5riRG3t5dTmSNGaBpyHkGSAFRwCEOTjgAkg5QuW6KzLq6js9LuJ20OWa8stT t9Pu7aDV5SMz
eVtMLttDnE8fDiMZ3c4AJLm4W3025caJLJqFneizuYIr+9mjBMSyhkaKJ3I2 umd0agEkZ4G4
5QuadFQaRB/aejtdtolzHcC7SHyPt15H+7LIHkzPHEx2qzNgKQduAcnAsSWl rbT6XDdaZcwy
X+oTWgH9pSttREmkSThudywqdvGN/JyOTlC4lFaN/oNrb6dczWdlc3d1HE7w 2/2+WPzXAJVN
xbC5OBk9M1Tms9PsPDQ1XU7C8gnW3WSWyiv5JXEpA/cod4DuWIRcfeJGOtHK FyKitWDw7ZNb
xNcQyxzlAZEjv5nVWxyAxIJGe+Bn0Fcu11HJpHhe/stDluDryKBEdXlQwO8D TLknhkARtzcE
AZVXJ20coXNOisD+3rGbTEvrXw9qDrJ9gmSCTVGSV7e7kMUbDDlfM3qTsLAb SpLgkquxE+mR
aTqtzqVjcxXWly+RPb2uoTTCWQxpIiQsxQuzCWNQCqkudozwScoXJ6KZrtmN H0S1vItMWe7k
uLe3lgbV7hERpXWPKvtJYB3XqoyMnrwcey1W21IyCx0pZRPex2mnSHWLlUuA 1t9qDyZTdEPJ
I4Ac7jtOAN1HKFzborMurqOz0u4nbQ5Zryy1O30+7toNXlIzN5W0wu20OcTx 8OIxndzgAm5f
wpougtqWr6UySLdwQeTY6pc3OUkljj3D5FYsN5OwKc4AByeDlC5PRWRbXFzN 4XXW28OM0c+x
rVbbV7uffExOJXCxeYqkbSAqO3zjcqAMVjTUh/wj8mpv4elaSLU4LF7WPV7h ZCspjUMFlWNl
fdKvySCPI+bdtKknKFzborMuby2tNNuTJpErapbXosXtotTuZIy5iWYFGVTK 48thkLESDnI2
KXEdjqVnqFhGsOj3Kaq+oHTxbz391DEJBAbjJZ0EgXyh1MWS3GNvz0coXNei szUrkaTpqy33
hy8ivJr0WdrAmo3E6zYiMjSZhDuE+SUD92WO1SyoCdtiwuNNl8NXmrahpOqW j2jlDb+fdBrh
sKVEIlEbuWLKgBVcvlRngk5QuW6K1YPDtk1vE1xDLHOUBkSO/mdVbHIDEgkZ 74GfQVy91qOm
weEND1qPSryW41hITBareXUgRnhMxDGMO5AVG5WM84yAMkHKFzTorMjull8N TakvhvVBdRXH
kNA096qEYB8xcx+cyfMFyISd2eNoLiul+8nh+TUF0FRcJqcFgbeTWbqPiUxq rnfGJEO6Vfle
NTtG4ZBXccoXNuipZ7Cy0zw/LqOrWcsc8SEtbWeozTb2zhEjLFC7sdoAwMsw Az1NfXbMaPol
reRaYs93JcW9vLA2r3CIjSuseVfaSwDuvVRkZPXgnKFx9FVNa8nQdGsprvSZ ZNSu7j7PHbWu
oXc8Yba75LIhkI2Rk8RHnA6ZYV47pZfDU2pL4b1QXUVx5DQNPeqhGAfMXMfn MnzBciEndnja
C4OULmnRWIl+8nh+TUF0FRcJqcFgbeTWbqPiUxqrnfGJEO6VfleNTtG4ZBXd 0n9mWFjo/wBt
1qFrSReJEt9QuJ1yWwqoflZ2bKgKFyWOACcZOULlair1vots+nxz3NhcW87n /UHUJWKAthQz
BsbsEZAyAcgFgAxh+w6T/dk/8DriiwXKF1Z2t9EIru2huIw24JLGHAPrg9+T VaPQtHhlSWLS
rFJEYMrrboCpHQg44NWL6bSbLUNPtBaTyteSOoZb+cBAqFsnJ56Af55teRpn /Ppc/wDgfN/j
RYCndf8AHzY/9dz/AOi3pBE954bvrONlDzfaY1LHgFncDP51Yu7OzSOxubeK aN/tZjIe5kkG
PKc9GOKl0GyN5bTfvdmyeX+HOcyP/hTTaaaE0mrMomLVr2/Se6litBHBJEsl rL5jgs0Z6PHj
omOh61fs45rbf5uoXN3uxjzljG36bFXr756Vq/2If+fn/wAc/wDr0f2If+fn /wAc/wDr1c6k
pbmcKcYbHNz6FbTTyD7VcpYTMXuNOUp5EzE5YsCu4BjyyqwVjncDufdVufCV jeTbZ7y8fT/N
nm/s/cgi3zJIsh3BfM586Q/f4LcYAAHQPbOLiaGKK5m8lgjOixgZKhv4nB6M O1SWVpFfCQJc
MksTbZInQbkPvhiMHHUHH5GsVJN2NrdTl7/wdZ6qHbUNRv7iZ4PIeZjErMuy 4jzhUC523UnQ
fwr75vahoVtf6k2pC6ube9CxLFNCUJiMfmgFQylSSs8incCMEYAIzXSf2If+ fn/xz/69H9iH
/n5/8c/+vV6i0M2zT7HapB5805XJaWd9zuxOST2HJPAAA6AAAAVriwjuL6W4 e5nEc8SQz2wK
+XMqFiobjdjLtkAgEcEEZB2/7EP/AD8/+Of/AF6P7EP/AD8/+Of/AF6LMNDE t7CO3vorhLmc
xwRPDBbEr5cKuVLBeN2MouASQBwABgDQ873q3/Yh/wCfn/xz/wCvR/Yh/wCf n/xz/wCvRZho
Zd5Ct2ikNsmTmOQDJU/1B7j+uCKBvBbnZfBYG7PuJjb6MQOevB54/Guj/sQ/ 8/P/AI5/9ej+
xD/z8/8Ajn/16VmFzHBBAIOQaKu/8Ijag5jlaEdxDujB/BWApf8AhE4f+fy5 /wC/0n/xdHKw
uUaKvf8ACJw/8/lz/wB/pP8A4uj/AIROH/n8uf8Av9J/8XRysLlGir3/AAic P/P5c/8Af6T/
AOLo/wCETh/5/Ln/AL/Sf/F0crC5Roq9/wAInD/z+XP/AH+k/wDi6P8AhE4f +fy5/wC/0n/x
dHKwuUaKvf8ACJw/8/lz/wB/pP8A4uj/AIROH/n8uf8Av9J/8XRysLlGmSxC VR8zKyncjr1U
+o/zzyDwa0f+ETh/5/Ln/v8ASf8AxdH/AAicP/P5c/8Af6T/AOLpOF1ZgpW1 Rl4ubhl+1mPb
GQVSMnDsP4jn9F5x1yTjE1Xv+ETh/wCfy5/7/Sf/ABdH/CJw/wDP5c/9/pP/ AIuop0Y01yxR
UpuTuygw3KR6jFS/aH/55r/31/8AWq1/wicP/P5c/wDf6T/4uj/hE4f+fy5/ 7/Sf/F1pYm5k
6D/y6/8AYKk/9pVYqvoP/Lr/ANgqT/2lVihgjd0X/jzf/rof5Cri/wDH5L/1 zT+bVT0X/jzf
/rof5Cri/wDH5L/1zT+bVS2EyaiiimIKp6bpVjo9u1tp1tHa25cuIIvljQkA HYnRAcZIUAEk
nqSSalqtjpFus9/cxwI7iOMNy0rkEhEUcu5wcKoJPYGs+bxBPY6WNR1HRru1 gNwsbr5kTvbx
HAM02G2qinJO1nwuGOPmCgGxBCttbxQIZCkaBFMkjOxAGOWYksfckk96krm5 /GdlbeH5dbls
7tbMXBhhd2iRbhc4Eyu0gRYmwSrOy7vlxksgaTSvFkGr+Hr3WbbTr5obXzNs SeVM9zsQMfJM
TskmSdow33gVOCDQB0FFc/qvi+w0Xw9ZaxqEU9st55YitrgxwSB2QvscyMqI wVWzuYcrgEkg
GTQ/Edt4q0a5utHmjSWN2gPmFJ1il2hhkxOUcYZT8r98ZBBAAJB4W0ZLOGzi s/ItIbtLyO2g
leKJJUIK4RSFC7gG2Y2lvmILEmo5fCOjzW/kGO7RBeyX6mK+njZJ5AwdkZXB UHe+VUhfmPHN
Z48b22n+BdE8Qax5aS6lbwMI43SJWlki8wqGldUUABj8zjpjJJAMdv8AEXTL y1s57Oxvrv7V
dvYhbQwz+XcLF5qxlkkKncnO5SUXneyYOADcTw9piaNd6SYJJLS8R0ufNnkk kmDrtbfIzF2O
3CglsgAAYAGJBotkmhw6NEs8FjDEkMawXMkToiYCgSKwccADrz3zk1z9x8Sv D8GnfbS8/lye
SbcTKtv9oSUOUdWmZFVT5U2N5XPl8Ahk3SRfEHSp/D/9swW93cW6XsdjcLa+ XcNA7lQpPluw
kH7yPiIufnAxkMAAXB4L0RdDh0UJfCwhlSaKMalc5jZMbAreZuCrtUhQdoIB AyM1I3hHR2e9
kMd35l7cC6lkF9OHWUKV3xtvzEdp2fJtyvy/d4qnf+Mja6O15Dol9NdRahBY XFiZIVkgeVow
uW3lDlZYyNrHl1BK/MV6CxuJbuzjnmsp7KRs5gnKF0wSOSjMvPXgnr68UAU4 /D+nw6XNp8X2
tIpn3yyrezCd245abf5hOFVclvugL0GKjs/C+k2OhnRYYZzYfLsjlu5ZTFtx t8tmYsm3apXa
RtIBGDzUmva5D4esI724tbueBriKB/ssYkaPzHCKxXO5huZRhAzcjANZ9z4z srLRrnULuzu4
JLW4FtcWsrRK0MhVXAeQyeSoKOjBjJj5gud5C0ASQ+CtBt4rmOC1ni+0SrPI 8d5Mr+aq7PNV
w+5ZGXIZ1IZ8ncWyaIfBWg28VzHBazxfaJVnkeO8mV/NVdnmq4fcsjLkM6kM +TuLZNZ9v8Rd
MvLWzns7G+u/tV29iFtDDP5dwsXmrGWSQqdyc7lJRed7Jg4Lj4leH4NO+2l5 /Lk8k24mVbf7
Qkoco6tMyKqnypsbyufL4BDJuAOk03TINKt2gt5Lt0Zy5N1dy3DZwBw0jMQO OmcdfU1Hq2i2
WtxQR3qz/wCjy+dC8FzJA6PtZMh42Vvuuw6965//AIWPoreHv7ZjG+Fbv7HI n220XZJs348x
phE3ykH5HY84xkMASeLb3WvCFzqXhW1gkv1u4rWJLiaO5jBaSMMzm2kfCqrl jzkAZIx1ANj/
AIRfSf7O+xeTPt83z/P+1y/aPMxt3+fu8zdt+TO7Oz5fu8VHN4R0e40sadJH dmD7Qt0zi+nE
skq42u8ofe5G1cbmONiY+6uMuHxXqmn4Gt6PPI17qt1Z6cthD8xjj3eV5odg QziN2Dj5AuGY
oOakf4h6KNLl1CNLt4FSGWMvGIBLFLuCS7pSiohMcgBkKZKjGd8e8A0G8I6O z3shju/MvbgX
Usgvpw6yhSu+Nt+YjtOz5NuV+X7vFC+EtKD2Ts2pSPZXBubdptUuZCshUKSd 0h3DbkbTkYZh
j5mzHpPi2117Q59T0m1nvWgl8mS1gmgd9/ynAcSeU3yurcOfT7wK1GfFsNr4 O0jxBcW93cwX
yWu9rW3G5PP2hWMW9mxudRtQu3Ixu60ASQ+CtBt7OO2htZ0WKKKGKRbyYSxJ GZCgSTfvXAlk
Xgj5WK/d4qM+A/D32e4t1truOO4uIrqYRahcJvmjA2yEq4O/IDFurMoZssAR HqXiDVLnw5eS
6Bp+zW4LuG0a0v03iF3eLJk8liCojlEhKscDryCBJp+qeI/sF9d3mjx3BTU5 4re2tW8qY2qO
URyJSFZyV3feVSjBgc4UgFiPwjo8VlNarHdkS3H2ppmvp2nEuwR71mL+Yp2K E4YfLkdCQZP+
EX0n+zvsXkz7fN8/z/tcv2jzMbd/n7vM3bfkzuzs+X7vFXNN1Wx1e3aewuY5 0RzHIF4aJwAS
jqeUcZGVYAjuBVygDH/4RfSf7O+xeTPt83z/AD/tcv2jzMbd/n7vM3bfkzuz s+X7vFR2vhDQ
7O3vreC0kWO+dJLgG4lbdKoGJQS2VlyqsZFw5YBiSwBrcooAy4/D+nw6XNp8 X2tIpn3yyrez
Cd245abf5hOFVclvugL0GKrweEdHttGi0mGO7W0hcPBm+nMkBC7R5chffGNu VwrAYLDoxzuU
UAYc3hHR7jSxp0kd2YPtC3TOL6cSySrja7yh97kbVxuY42Jj7q4uafotlpd5 f3Vqs4mv5RNc
GS5kkDOBjIVmIXgAfKBwqjooxoUUAFV76xt9Rs5LW6j8yF8EgMVIIIKsrDBV gQCGBBBAIIIq
xRQBlp4e0xNGu9JMEklpeI6XPmzySSTB12tvkZi7HbhQS2QAAMADB/YFitlp NjEskdnpbxtB
bhtyMI0Kxq+7JYKSrjPIZEbORWpRQBHPCtzbywOZAkiFGMcjIwBGOGUgqfcE Edqx4vCOjw2+
j28cd2sWjvvsVF9P+7OMc/P84CkqA2QFJUcEityigDj9U8A2sugppeiz/wBn Y+yxmWZp7hhD
bytLHGp81WXDscMGyFOBjCldhPDOnRRWsUYnEcF2LxxJM0puJApVTK0hZpNv yMuTlTFHggKB
WxRQBXvrG31GzktbqPzIXwSAxUgggqysMFWBAIYEEEAggis//hFtGXTvsMVn 5EIl85TbyvFJ
G+NoKSIQyYT5BtIwnyDC/LWxRQBhzeEdHuNLGnSR3Zg+0LdM4vpxLJKuNrvK H3uRtXG5jjYm
Puriw/h/T5bC0spvtcsFpcJcxebezOxkR96l2LlnAbBCsSOBxwMalFAHPyeC 9Ek3/JfJuu2v
R5epXKeXM3mbmTbIPLz5smQuAd3I4FV9a8Hi98OHSNKu/sXmXcVzNcT+dcSy GN1cZk81ZN2Y
0G7fkKuBjCleoooAx/8AhF9J/s77F5M+3zfP8/7XL9o8zG3f5+7zN235M7s7 Pl+7xVeHwVoN
vFcxwWs8X2iVZ5HjvJlfzVXZ5quH3LIy5DOpDPk7i2TXQUUAY/8Awi+k/wBn fYvJn2+b5/n/
AGuX7R5mNu/z93mbtvyZ3Z2fL93ihPDVlHFawia+kht7sXey5vJLgSOFIUMZ SxKqdrgAjDor
DkVsUUARzwrc28sDmQJIhRjHIyMARjhlIKn3BBHastPC+kx6Ha6NHDOlnaY+ zbbuUSw4yBsl
3eYvBK8N90lfu8VsUUAYcnhLSprKG0lbUnSG4+0xSNqlyZUk2FMrL5m8DazD aDjk8c1Yj8Pa
ZHpc2nCCR4Jn8yR5Z5Hldxja5lZi+9dq7W3ZXYuCNoxqUUAY6eGdOiitYoxO I4LsXjiSZpTc
SBSqmVpCzSbfkZcnKmKPBAUCtC+sbfUbOS1uo/MhfBIDFSCCCrKwwVYEAhgQ QQCCCKsUUAY/
/CL6T/Z32LyZ9vm+f5/2uX7R5mNu/wA/d5m7b8md2dny/d4qOTwlpU1lDaSt qTpDcfaYpG1S
5MqSbCmVl8zeBtZhtBxyeOa3KKAMuPw9pkelzacIJHgmfzJHlnkeV3GNrmVm L712rtbdldi4
I2jFeTwjo8tlDatHdgRXH2pZlvp1nMuwx72mD+Yx2MU5Y/LgdAANyigDNtNL tNG0uOyskkWB
Z9/7yV5WLPLvYlnJYksxOST1rzHxPqfjWDWrSPw74fS6sIWD3MktxEn2gEfc XLZUDP3iM7gO
MA7vU9WjuZdMmSzuEt7j5Skrx+YEwwOduRnj1OPXiuN/sDxCOviSD3/4lo/+ L9j+XbDbZY0U
NRdpde8NSPE8LM8zGNyCyEwtwcEjI9iR71v1l/8ACN6kuoWl/f6zHci0ZmWN bPyySylOu8+p
7Z4+uNSpYx11/wAg+x/6/wA/+iXq54T/AOPa6/67yf8Aox6p3X/IPsf+v8/+ iXq54T/49rr/
AK7yf+jHqkJmdpmm3L22nbPDWgzWTwQF7mW4ImIKLvby/IIJznA388ZIzxua G1z/AGFpoWKI
p9miwTKQcbU7bfdu/YepxN/YWj/9Aqx/8B0/wq9HGkUaxxoqIgCqqjAAHQAV QjhPGEMFxaX4
uLqGCOHU4pP9JiZ4HPkIAsu3opz1PGcd8Va8GzQTwaRLBZrah7K4Hlhiw+WW McM3JXuvoCAO
K2r3Slje8v11G8gD/vpEjMO3KoF4LqccKOpx9KntNIFrfC7e+urmRY2jUSiM ABipP3VHPyih
tOHLbqKz5uYwfH+uX/h6ystQsvIZY/tbGOUSfM6Wc8qHKuoK5jIKsGzuBG0q DRrfiHWIvF9v
oGmvYw+f9nxPc27zbd8d67fKsiZ/49UA5GNzdeMbupRaf9v0+7v7xIjaO8lv HJKqKZChTfzy
SFd1xnHzkkEhSKFhaeDdKffp1voNm4cPut0hjO4Kyg/Ljna7jPozDuaai30D mSOZ0nxJeTeN
bhpY4ImlitrG4u2U+SrQ3l9Fwucq0pTCBjtUtgszbVk6jX/EX9k2cOoW0tjc Wple2kR5th8w
EjdvGQFjKOZBtJVFd/8AlmVbU/snTdlyn9n2my6RkuF8lcTKzOxD8fMC0khI Pd2Pc1JFYWcE
qyxWkEci+ZtdIwCPMYPJg/7TAMfUjJ5pDOP1rxXrHh25uX1KKBbW3tJHgC2j 41KSO2aZ9kqy
MLfBVhskViQpKs2TtuaDHqUXjrW11S7tLmf+zLEq9rbNAoXzbvgq0jknOec9 xxxzuWehaPp9
4byy0qxtroxLAZobdEcxqAFTcBnaAqgDoNo9KNM0LR9E83+ydKsbDzseZ9kt 0i34zjO0DOMn
r6mgDQooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDiNB/5d f+wVJ/7SqxVf
Qf8Al1/7BUn/ALSqxUMpG7ov/Hm//XQ/yFXF/wCPyX/rmn82qnov/Hm//XQ/ yFXF/wCPyX/r
mn82qlsJk1FFFMRHPBDdW8tvcRRzQSoUkjkUMrqRggg8EEcYrHm8MQzaWNMb UdSNl9oWV4pZ
xMZIxgmB3kDO0TEHcCSSGK5CfLW5RQBz6+FjBp0dlZa7qtnHDdvcQGBof3KM GAgCtGVMK7jt
VgduFwcKMWIPD6QaTqNn/aF81xqG83F+HVJy5jEYdSihVZUVANqj7oJBOSdi o554bW3luLiW
OGCJC8kkjBVRQMkkngADnNAGXP4fSfSdOs/7QvluNP2G3vy6vOHEZjLsXUqz MjODuU/eJABw
RJHpV4mlzWjeINSknd9y3rR2/mxjj5VAiCY4PVSfmPPTEY8S2S2cN3PDfW1v PdpaQPPZyIXd
yFUlMbo1LnZmQLz7MpIfFGkizmuhNO0cV29lhLSVnkmQkOsaBd0mNrZKBh8j HOFOACnaeD4r
TQbDS01fUmOnOrWF23k+bbBYzEFXEexhsZ1+dWPzk5yARI3hiaafTJrnxFqt xJp9211GXS2G
8lDHtbbCPl2s44wfnPOQu2xB4o0m40nUdTE08drpu/7WZ7SWF4tsYkOUdQ33 GU8DnPFSP4h0
xNGtNWE8klpeIj23lQSSSTB13LsjVS7HbliAuQAScAHABj2ngGysre0WDU9S FzZW8Fva3ZMR
khWETKhA8vYTsuJEO5Txg/eG6rl74Ym1DR10+68RarIy3cd0LnZbCQGNldF4 h27Q6q33ckjB
OOKkj8X6HNZTXcN3JKkVx9leOK3leXztgcxiILvLqpyygErtbdja2I5vGug2 8VtJPdTxfaJW
gjSSzmV/NVd/lMhTcsjLgqjAM+RtDZFAB/wicDf2v5uo30v9pXcd783lD7NN Hs8to8IPu+VF
w+4HyxkHLbtTTbBtPt2jkvru9ldy7z3TKWY4AGAoVFAAAwqgdSckknLl8ceG orNrw6vA1oss
cTXMYZ4lMhIRi6gqIywZfMJ2BlZSdykDQtdVi1TTp7jTB5s0e5BDcq9uyyAZ CyKy748gqeVz
tYMAQRkAj17RRr1hHaNf3dkEuIrgSWoj3Fo3DoDvRhgMqt0/hA6ZBz28HxG6 vbsavqS3Nxei
+ilHk5tZREYcxjy8EGL5MOH4GeG+arFn4ntJfCula5dpJANQt4ZY7eJHnkLO m/YiopZyBknC
9FJwADiQeKNJNnDdGadY5btLLD2kqvHM5ARZEK7o87lwXCj51OcMMgGXB4Ei t9Wi1Bdf1lnS
9F+0cjQusk/k+SzEmLcAyZG1SFXPyhcLgtPANlZW9osGp6kLmyt4Le1uyYjJ CsImVCB5ewnZ
cSIdynjB+8N1aEuuXN7b7/DtjHqDx3slnObqV7SOIxhg7BjGxcB1CfIpGSef lOMvTPG07aHb
a1rulfYLC9itZLSSzeW9MjT5wjKkQZGHyDoVJkUAk8UAdJptlPY27RXGp3eo OXLCW6WJWAwP
lHlogxxnpnk89MXK5+48a6DafbDdXU9vHZXaWdzNNZzJHFK/3dzlNoU5U787 QGQk4Zc2P+Eo
0n+zvtvnT7fN8jyPskv2jzMbtnkbfM3bfnxtzs+b7vNAEmqaKNUv9Kuzf3du dOuDcJHCI9sr
FChD7kY42u6/KR98nqARj2ngGysre0WDU9SFzZW8Fva3ZMRkhWETKhA8vYTs uJEO5Txg/eG6
tT/hJbJ9O+3QQ308KS+VOkVnIZrc4yN8JHmjOV4Ck4dWxtyw1IJ4bq3iuLeW OaCVA8ckbBld
SMggjggjnNAGHY+FjpsWqC113VVm1GVJ5J3aGR0lCqrMu6MgbgigqQVXogQY FV18Fqnhez0B
de1UW9nLBJBNi38xFhKmNP8AVbSoZFbkbiRySMiuoooAy9L0UaXf6rdi/u7g 6jcC4eOYR7Ym
CBAE2opxtRF+Yn7gPUkmxqWnLqdutvJc3cMW8M4tZ2haQAHCl1w6jOD8pUna ASQSDcooAjgg
htbeK3t4o4YIkCRxxqFVFAwAAOAAOMVJRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAEN1/x7 P7YP6/59PqOt
Z3T2x+GP5ent07Y+TRuv+PZ/bB/X/Pp9R1rO6e2Pwx/L09unbHyJjRDdcWz9 ug9O/wCHp+nT
jCZtaV1xbP26D07/AIen6dOMJm1DGh11/wAg+x/6/wA/+iXq54T/AOPa6/67 yf8Aox6p3X/I
Psf+v8/+iXq54T/49rr/AK7yf+jHqkJnQ0UUVQjndWklXVZiljqd+Egh2wWF 2ISu5pcsd0sa
n7qjqT04607SZ50u7j/QdSi3W8b/AGS6uVlkjO6YZz5jL82xejHqM45xoX+n QTebdFp0nEW3
fFLKOBkjKxsC2CTx15qa10+3s5JJIvNLyBVZpZnkJAzgZYnH3j+dAFC+uZY9 XgaOFvNFldFE
bB3FXix0Pfj357GuL0HxFqmseHtak1G+inK6ezvAEO6CT5wQSI1C9MbSWYbc 55rvNQ0n7ddW
9yl9dWk0KPGGg8s7lcqSCHVu6LVGfw/JfW9xaTa7qrROpikUxwKGBXnB8rng 9R/MV0U5wUbP
+tTnnGbbt/Whf13U/wCxPD2p6t5PnfYbSW58rdt37ELbc4OM4xnBrDh8YzQ6 ibbWLK0soo7h
rOe4S9LpHMLc3WcsifuvJGS5wQ2RtwN9dJf2NvqenXNheR+Za3UTwzJuI3Iw IYZHIyCelU5/
DmkXUsslxYxzGW4NzIshLK8hg+zklScEGL5duMd8Z5rnOg4u6+Jc9vbyPcaT PBdWe+eSAGWN
JY/st1KoJnt0flrZgdqgD5Tub5krsNJ1a8utRu9N1Kygtb62iiuCLa5M8bRy GRV+ZkQ7sxPk
bcY28nJApt4D8PSicXFtd3JnTZI11qFxMxXy5Y8BnckDbPMMD++T1AI3Esbe PUZr9Y8XU0Uc
Mj7j8yIXKjHTgyP+fsKALFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAcRo
P/Lr/wBgqT/2lViq+g/8uv8A2CpP/aVWKhlI3dF/483/AOuh/kKuL/x+S/8A XNP5tVPRf+PN
/wDrof5Cri/8fkv/AFzT+bVS2EyaiiimIKKKKACqepaVY6vbrBf20c6I4kjL cNE4BAdGHKOM
nDKQR2Iq5RQBz99oGo3+hyaRca19ogmlC3Es9qvmzWpx5kJKFFDN8y71UYU9 Nw31Tk8J33/C
NQ6FHqGmyWcFx+6gvdL+0RG0AIigkQyAsUOwiQEE+WuQTknrKKAOf0rw7caR 4evbCzvoLW6u
PMaGS1tBHb2jlAqmKAswVQQHKljudnPG7Aku9FvrrTdJzqcbatprrMt5LbZj ll8p4nZ4lZeC
sjkBWGDjkgYO5WXB4k0W5t4rmHVLRrea4FrBOZQI55SMhI3PEh6j5SeQw6qQ ACncaHql3a2k
0+rwPqtpdm6gl+x4t0JiaIr5QfcV2Ox5kzvOc7cJVNfCmpf2jZag2rWhuE1M 6jeYsWCTN9nF
sFjHm5jHlZ6l/m54Hy1uPrujx2d1eSarYpa2kpguZmuECQyAgFHbOFbJAwee RRa67o99p0+o
2eq2NxYwbvOuYbhHjj2jc25gcDAIJz0FAHD3/hDWdG8NW8OnN/at/FFpVonk 26RqiWdw0okZ
ZJl3ZUhSoYZYdQG+XrLLR9SsbLUZItRtDq1/cC4luGs28gMEjjwsXmbsbI16 yH5iT0+UaE2r
abbaWNUn1C0i08ori7eZViKtjad5OMHIwc85FV4/EugzaXNqkWt6a+nwvslu 1ukMSNxwz5wD
8y8E9x60Ac//AMILNP4Q0nRNQvNNvn0l4zaNPppaB1SExATQmQ7ztZjkMvzb Tjgg2I/CEyeG
ptESTRrS3urjN4mnaUbdJrcgCSPaJTtd1G0yZJAPABAI3P7d0f8Asf8Atf8A tWx/sz/n9+0J
5P3tv387fvcdevFRp4l0GR0RNb01nd4kVRdISzSruiA55LqMqP4hyM0AR6Pp N5o2hvpkV7A6
w749PZrY4t4ekUbjfmTYMDdlSwAzzljnjQZdP+HUOgXAn1OS2tEtUewRIJjs wsckfmvtWRMK
4Ytwy5HOBWw+u6PHZ3V5JqtilraSmC5ma4QJDICAUds4VskDB55FCa7o8lna 3keq2L2t3KIL
aZbhCk0hJARGzhmyCMDng0AcnqWl64ngG2W306SfxBdXtrqF4qtE3lzCaOZ8 7pEDogTy1G/O
1UXdgbhcvvA/9p2En2+4sbu/k1Aag5nsPMtGkEAtwDAXyVEYBx5md43Zx8td B/buj/2P/a/9
q2P9mf8AP79oTyfvbfv52/e469eKG13R006TUW1WxWxi2eZcm4QRpvCsuWzg ZDoR6hl9RQBl
6b4bu9N0ZtPtLvTdMMlwZZJdG0tLb5doHCO0i7yQMsQ3y8YBww2NN0qx0i3a Cwto4EdzJIV5
aVyAC7seXc4GWYknuTVeTxJosWlw6o2qWh02V9i3qyhoAeR80g+VRlSuSQN2 F6kA6lABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAQ3X/Hs/tg/r/n0+o61ndPbH4Y/l6e3 Ttj5NC7OLc4B
JJUAD1JH+e31HWswSDj7g/7apx09/wDDoOnG1MaGXXFs/boPTv8Ah6fp04wm bUuo6pBbS2ln
JnzbxmSIIVYDau45weBhcflxjG2KoY0Ouv8AkH2P/X+f/RL1c8J/8e11/wBd 5P8A0Y9U7r/k
H2P/AF/n/wBEvVzwn/x7XX/XeT/0Y9UhM6GiiiqEV79d+nXK7d2YmG3buzwe MbWz/wB8n6Hp
ViqupMi6VeNIVCCByxYZGNpznhv5H6HpVqgCjq0ssViDBK0TvPDHvUAkBpFU 4yCOhPauft9W
jlmzZ3mtiQzwmQXmkvbJIGkSM5Z4EycEDAOePQV017aLe2xhaSSP50cPHjcp VgwIyCOoHUVV
fSpJSgn1S8lRJEk2MsQBKsGGcID1A70AVPENxFc6P5eyQq9xbgiSFlBUzRZB yPRsY+o7HGNY
2Ok2urarBqsemMFnVLWBYk8zB+YYUKGPDoO/Kmus1CxTUbJraSSSMFlcPHjc rKwYEZBHUDqD
WXcaC80YgufEGoukp2iOVbchyOcYMXPQn8K1U2oNJ2ZlKN53auJosVnDrl+L CKOK2e0tpEWN
doO4y849SMVFc+MIoNWudOj0jUrmWG4FojReSFnnMKzmNN0gIIiYsSwVflIB JwDpaXo6aY8s
guri4eREj3TBBtRN21QEVRgbj2qH/hG7P+1f7R8yfzv7Q/tDbuG3zPsv2bHT 7uznHXd3xxUS
d3qXBWRnzePtEh1HSLUy5j1WKGW1n82JdwlO2P8AdM4mOTgZEZAzyQA2K+je PINRtbWV9Pvv
s7fZYpdQ8uJIRNPFE6Ls81pBkzxrwGALctgFqkt/ANlaW9naWup6lDZ272kk lspiK3ElsIxG
7loywOIYgQhUHb0BJJsaf4K03TdGGlwz3bQC4s7jc7qW3WywLGOFxgi2TPHd sYyMSUdJRXPl
fEmpRTWN/Y2Nha3ETxPd2GrSPPDuUgNGDbqNwOMHIx15xg2L658SR3ki2Gla VPajGySfU5In
bgZyogYDnP8AEfXjpQBl+HvGYvtB0e91qzk0x76yNyZ5mjW3O2NJGKsJG2gq zsqthtsUhIG3
mS08bQXM4V9G1W2t1lt7eW5uEiVYZpkiZI3TzDIGzNGpwhAY8nAJBP4QQ6Tp 2jJL5+mW92jF
LoKWgtkjIWCIheVOFjbfuLRvKCxzRH4Tll17VL291Gc2NzqEN7HYRbPLZooo QjOSm8MJIQ2F
faQq5BywIAeG/H2ieKdRkstOl3SCIzxHzYn82IEAttR2aP7yfLIEb5umQ2Oo rH0bw+mibI4t
QvprWGIQWtrM6+XbRDGFUKoLYCqA0hdgBwfmbdsUAFFFFABRRRQAUUUUAFFF FABRRRQBxGg/
8uv/AGCpP/aVWKr6D/y6/wDYKk/9pVYqGUjd0X/jzf8A66H+Qq4v/H5L/wBc 0/m1U9F/483/
AOuh/kKuL/x+S/8AXNP5tVLYTJqKKKYgooooAKKKKACiiigDP1nR7fXNOeyu nnSNs8wylecE
fMv3ZF55RwyH+JSKy9U03XtT8Ptplw2myTy3CJJdxF4dkOQxliQhyk6n7nzE BlV9w+4OkooA
4tvD2sx+GrXS1tNNuXtL1ykrahPbyyw4fE3nRpvS4YsPMIBDbpOfnwLmm6Df 2fhnV7V4rGS7
vfMeO2uppLqEExKgSaZwJJlJXJLDIVtg+VFrqKKAOX1LR9TuPDOkWcVhpTXV t5fnxRXM1nHF
iJlP2aWNS8eGIA45Qsp61lyeDNQl0iHcYxdRan9vW2XU7hSR5Bg2NehfOY/M X3FScYj+6AR3
Ec8MzzJFLG7wvslVWBKNtDYb0O1lOD2IPepKAOLtvDOoWtpbXNvY2kOoW2pm +MMurXF0tyTb
tb5eeSMupCtwNrD92BxuJGfo+l3uoW/im1NpHZ3n9uwaki/ZJYLeVoxbuVV2 UbwZIHVpVByT
5m3DBT6JRQB5/ceEtfvpLy5vfsJmbVU1OGO0v57bdm0+zNEZUXem0YO9c+Zg gqgbAkuvCeoT
eE7jTotI03z7rU7e6uobvV7i7SdI2iY7pJYixLCFY9pXAHOT909xPMttbyzu JCkaF2EcbOxA
GeFUEsfYAk9qjsL631PTra/s5PMtbqJJoX2kbkYAqcHkZBHWgDk20DXv7Yvd TWHTS6awNRs4
jduBMv2Q2pWRvK/dnbh+A/Py8feo1Dwre6hpsMgstNs7yPU21BrWwupbZZWa J4m3XMahy53l
y4QZwEIIy57SigDl9J0jVtM0meKytrGxvrq782aWe/uNSGPLVd5MgR3bCKm3 coA+bJxtOxo2
j2+h6cllavO8a45mlLc4A+VfuxrxwiBUH8KgVoVHNPDbIHnljiQuqBnYKCzM FUc9yxAA7kgU
ASUUUUAFFFFABRRRQAUVn63reneHNHn1bVrj7PYwbfMl2M+3cwUcKCTyQOBR pWt6drf23+zr
jzvsN3JZXHyMuyZMbl5AzjI5GR70AaFFFFABRUcEy3NvFOgkCSIHUSRsjAEZ 5VgCp9iAR3qO
+v7PTLOS8v7uC0tY8b5p5BGi5IAyx4GSQPxoAsUVj3vinRtP8Lr4lurzy9Ia KOYXHlOcpIVC
HaBu53L24zzVjStb07W/tv8AZ1x532G7ksrj5GXZMmNy8gZxkcjI96ANCio5 p4bZA88scSF1
QM7BQWZgqjnuWIAHckCpKACiiigAoorP1vW9O8OaPPq2rXH2exg2+ZLsZ9u5 go4UEnkgcCgD
QorP0rW9O1v7b/Z1x532G7ksrj5GXZMmNy8gZxkcjI960KACiiigAoqOaeG2 QPPLHEhdUDOw
UFmYKo57liAB3JAqSgAooqOCZbm3inQSBJEDqJI2RgCM8qwBU+xAI70ASUUV n63reneHNHn1
bVrj7PYwbfMl2M+3cwUcKCTyQOBQBoUVn6Vrena39t/s64877DdyWVx8jLsm TG5eQM4yORke
9Gn6zZ6jZ291G/lx3UskVt5pAM+0vho+fmVlQupHVMN0oA0KKKKACiiigAoo ooAKKKKAIbn/
AFS/9dE/9CFctXU3P+qX/ron/oQrlqmRSMPV/wDkZfD3/XWf/wBEtW5WHq// ACMvh7/rrP8A
+iWrcqQHXX/IPsf+v8/+iXq54T/49rr/AK7yf+jHqndf8g+x/wCv8/8Aol6u eE/+Pa6/67yf
+jHqkJnQ0UUVQivfts065bdtxEx3btuODzncuP8AvofUdasVXv22adctu24i Y7t23HB5zuXH
/fQ+o61YoAKKKKACuTu/E1raz7dR8S6HpkiyymKC7fY5RXeMMczLuB2ntjI9 RXWVlw2OpWwk
S3vrQRNLJIoktWZhvctgkSDP3vSgB1jqaNaM17c2yTJJKj4OwYR3AOCSRkRs evY+lUl8X6az
amoS5J04sJtsW4fLvzyucfcb72O3rWrp9q9naeVJKsrmSSRmVNoJdyxwMnH3 vWrVUmuqJab2
Zzc3jfSoNHh1N0uvIlcop8sYyN38Wdp+4ejE9K2NS1S00m3Wa7eQB3CRpFE8 skjYJwiICzHA
JIAOApPQE1crH8SaM+uadHbRGxSRJRKsl3atN5ZAIDR7JI2SQZ4dWyOcc8gk 09kEU1uwHijS
TeQ2pmnWSXYMvaSqkbOAUjkcrtjkO5cI5VvnUYywzXj8a6DJdJbrdThpdphk azmWOYNLHErR
yFNsil5YxuUkYcHOOay4fh7bW+tw34ltLoq8Eslzf2CXF8zwoiKVuGOFBESk /ITlnIZSQVpn
wRqgv9JsjfwSaZpmntDYzLbbXheOe0kgE2ZD5ufs43bRHna33dwxJR1F34o0 mznmt3mnluIZ
fJeC2tJZ5AwRHJ2RqWKhZY8sBtBdQTk4qOLxfoc9/wDY4buSQ74089LeU2+6 RFeMeeF8rLCR
MDdyXUDkgVz918PZtQupdR1G60a/1CS4klxd6QZbVVeKCM4iaXIcfZkw2/oz jHII1IfBqW2n
XFlFe4jl1CyvFPkKu0WwtgE2ptX5vs38IUDfwuByAXB4u0drd7hJLt4g6pGy WM7faCwJHkYT
9+Nqs2Y9w2jd05rUsb631GzjurWTzIXyASpUggkMrKcFWBBBUgEEEEAiuTm8 CzXOg2Oj3V5p
t3aaW8Z06O600yoFSN4gLhTJiU7HzlfLwwDYx8tdJomlpoujwWEYgCx7iRb2 6wRgsxYhI14V
ck4HJx1LHLEA0KKKKACiiigAooooAKKKKACiiigDiNB/5df+wVJ/7SqxVfQf +XX/ALBUn/tK
rFQykbui/wDHm/8A10P8hVxf+PyX/rmn82qnov8Ax5v/ANdD/IVcX/j8l/65 p/NqpbCZNRRR
TEFFFFABRRRQAUUUUAFFFFABWfrOn3Gp6c9ta6jPYSHP7yED5hgja38QU55K Mj8fK6nmtCig
Di9R0ee48J2+lweF7SzuoL2M2gsniaCxfdvF3HkIWCEklNoLMGXBVixz5fD9 z/wh39lz+HLu
ed9Tke+ktZLTddt8zG8McpMTiRtv7qQfJuG0fu0NeiUUAcPofhs6Z4I16x/s Lcl75zppzvDb
y3AMKpskMGIY2YqVBjwAu0n59xo1zw9dah4I0HT4NOntoLXyTdaVBJBO4jWF lEIM4MUuxzGc
vwdm4fMFruKKAOT8L2Uvhzw1crBpOsuRcF47Gc2SPghAfKWFlhROrYypJ3nk tzhvoOr6h8N/
D2k3Wl31u2m+RFfWataSPdIluU+QSM8LL5hRsSY+4SAGC59EnnhtbeW4uJY4 YIkLySSMFVFA
ySSeAAOc0QTw3VvFcW8sc0EqB45I2DK6kZBBHBBHOaAPM4fCA2aBbt4b1Wa1 g1WWWdbtrGP7
PA9uY2VVgdVELOys0ag79sm4HIDU08IeIbjRrSO8tNS8v7PZPqVs1xb3E13c ItykpxMzxOdz
WzZkONiIBho1VfXKKAPM5/C8q+CF0+30HWZnXWLe6jt5pLKGW3RHjZ3hMDpH ECqyAbCG3yMT
94tVi48LSXul63pbeGo00+31i2vdNtJVgMTwx+T5qQoGIQv5c/DBAfP+Yjc+ PRKKAMvQIhBp
awx6JHo1ujkQWa+WCi9SWWPKKSxY4Vm4wSQSVGX490yXVdBt4INKn1CZNQtZ wtvKkUkSpKru
6OzptbYHUFWDZfsMkdRRQB5vd+Hb+aw1bS4vD88GjpqqzW9rD9lIe38gIRDE 7GH/AFymQrKo
GHLAeZjbl2HhHUVvNOsdQ8MXc+n2+sNcRSGWzVYbOW18toisTRgAyndJGibG w3Muct65RQB5
GnhDxDcaNaR3lpqXl/Z7J9StmuLe4mu7hFuUlOJmeJzua2bMhxsRAMNGqr0G m+B7W/8ACraT
dwalZwLem4jhvrbTpdnyBcRxpG8KIck8KG3Fj/Ec95RQBz+keD9M0jR20xR5 1ubtLzHkQ2+J
EZGQ4gSNTho1PIJOMEkcVl+I/C9tcX/hyGDQZLy0h1O4ubuRJEHlpMkvmBi7 hmR5JVZkXIZV
YEEYU9ZfX9nplnJeX93BaWseN808gjRckAZY8DJIH40Wt/Z33n/Y7uC48iVo JvJkD+XIv3kb
HRhkZB5FAHl8HhTXpdDhhvtOvpEktLI6hBJcw3E89yn2hZnAldoZGJNsf3uR 5artAeNAux4b
0W703w9rel6t4bnv7A3aTWdjJ9jdZImSP5AimOJGV1Z2XCruJKtIfmPoFFAH m82j6ld/C/Qd
JufDN81/p0uno0S3FusiCAxmSWKQTDblVkRSGD5boASa3NCjvNDHiCKDw5dx 2Md6r6baW7W6
q8RjjRvKXzAqDeskhDbc788sSB1EE8N1bxXFvLHNBKgeOSNgyupGQQRwQRzm o76/s9Ms5Ly/
u4LS1jxvmnkEaLkgDLHgZJA/GgDn/CumSy+BtH0nWtKntZtPitY2imlQ7pIB Gyupidvl3oCM
kE7eRg89BZ2Nvp8DQ2sflxtLJMRuJy8jtI559WZj7Z44qObVtNttLGqT6haR aeUVxdvMqxFW
xtO8nGDkYOecipLW/s77z/sd3BceRK0E3kyB/LkX7yNjowyMg8igDH8ZaGmv 6Ctu9hBfNBd2
90IJkVt4jlVnVd3G5kDoMkA78EgEmsfW9I0y7+H88F9o2laFaWkq3Flb6gYV gikVgyeaEyiK
8hZWCMSUc8hmIHcUUAeR61baDB4BfxPdWtpBJrmsWWpp5bJby7TNGUCSErsl 8jezHfw7zMGC
kmtS+8K393oEkEOmT2WmNqouho0AtS6W4txH5Yjfdbcz/vtpJHO7/WcV6RRQ Bwem+B7W/wDC
raTdwalZwLem4jhvrbTpdnyBcRxpG8KIck8KG3Fj/Ec7mkeD9M0jR20xR51u btLzHkQ2+JEZ
GQ4gSNTho1PIJOMEkcV0FV76/s9Ms5Ly/u4LS1jxvmnkEaLkgDLHgZJA/GgD n/EmgpJoMdhp
ml+dO2oC5gm3KfsM7ymQ3fzsM7GZm2DO7OzG0nGHL4fuf+EO/sufw5dzzvqc j30lrJabrtvm
Y3hjlJicSNt/dSD5Nw2j92hrvLW/s77z/sd3BceRK0E3kyB/LkX7yNjowyMg 8irFAHD6H4bO
meCNesf7C3Je+c6ac7w28twDCqbJDBiGNmKlQY8ALtJ+fcak1jSJLjwLo2lr 4euzGqQJLYWt
zBK1oqxHAP2j91OFYKmHz1Dj5lBrtKKAPN4PAyt4LurF9BgKnVYNQis7mK3E sixmHeGWP9ws
jrHIgCbVKsu4gs5q5rujyX3gy1srTwfJbJDqdvNb2NrLBFLbxpKrySAq6pE5 AlA8tyfnByNz
Be8ooA5uPS9Lh8JzQReC40t5n3y6Ktvagu24DLLv8on5VbJboB3GK5ubR9Su /hfoOk3Phm+a
/wBOl09GiW4t1kQQGMySxSCYbcqsiKQwfLdACTXpFRwTw3VvFcW8sc0EqB45 I2DK6kZBBHBB
HOaAPN7+w/su01H7dokdt4Ys9YW4WxmltY7e4tjb+VtRGkEaj7RibbJsGSGG X4q54E0nS9Rt
ddu002CKzutVgntTDP5qmOGKBogsinBWORWGxSURg6KSo59AqvfX9nplnJeX 93BaWseN808g
jRckAZY8DJIH40AY+r2L2ujrpGjxzwNqV26PPCzZthKzyzy7+SjY8zYeQJGj GMVY1iwRtDTS
7XQbHULc7IlsrkrHbIi8jcNrYUbQAFRudvAGWGha39nfef8AY7uC48iVoJvJ kD+XIv3kbHRh
kZB5FFnfW+oQNNayeZGsskJO0jDxu0bjn0ZWHvjjigCvo2n3GmacltdajPfy DH7yYD5RgDav
8RUY4Ls78/M7HmtCiigAooooAKKKKACiiigCG5/1S/8AXRP/AEIVy1dFq17b adp0l5eTJDbx
MjPI5wANwrgf+Ex8Pf8AQVg/X/CpkNBq/wDyMvh7/rrP/wCiWrcrlJta03Vv E+hLYXkc7Ryz
Fgp5AMTV1dSxjrr/AJB9j/1/n/0S9XPCf/Htdf8AXeT/ANGPVO6/5B9j/wBf 5/8ARL1c8J/8
e11/13k/9GPVITOhoooqhFe/Xfp1yu3dmJht27s8HjG1s/8AfJ+h6VYqvfrv 065XbuzEw27d
2eDxja2f++T9D0qxQAUUUUAFFFFABRRRQBXsF2adbLt24iUbdu3HA4xtXH/f I+g6VBqckqyW
MMU7wefcFGdApOBG7fxAjqo7UtlZW32O2ZrWIOI0JJiAIIC/7K4+4vYfdHAw AKmq2sludOl0
/TzKILrfJFb7EO3yXjB+YqOMoOvQe1VDcmexjaZ4os9W1mXTLTVtRMqeYA5W 32sUIDDAUsvX
jcozg4ziun0qd7rR7K4lbdJLbxuzYxklQTXK6Xpc+kXs1xa6Rr4ikaRxatd2 5hRnILEL5nPI
7k4ycV02iW81roGnW9wmyeK1iSRcg4YKARkcda1qqKXumVJyb1IrPxLoOovA ljrem3Tzu6Qr
BdI5kZFDOFweSqkEgdAQTQfEWlObhLa/tLqW2uIra4ihuYy0LvIIwHBYbTuz weTggAnAPL2X
grUrbTrK3ee0LwWWiW7EO2C1ncNLKR8vQqcL6nrjrVP/AIQfX59YtLu7ngka 38vzLmTUp5jc
st3azM4hZNlvlbd/kjJUFlXooIwNztLPxJoupW91PpuqWmoJapvmFhKLhlGC R8seSSdpwAMn
HGasaTqUOs6NY6pbrIsF7bx3EayABgrqGAOCRnB9TXP6T4d1LSbfw6ym0mn0 nQpNPdDKyrJM
Rb7cNtJCZhbJxkZHymtTwpp95pHhLSdMvxALqytI7ZzBIXRtihQwJVTyADjH Gcc4yQDQF/Zt
Zw3gu4DazbPKmEg2SbyAm1uh3FlAx1yMdar32u6PpkUkt/qtjaRxyiB3nuEj CyFQ4QknhipD
Y64OelVxYXn/AAiUOnG00oXRtEt5YBGfsa5UK4VOrRgbsIcbgApK5yOfufCm sQ2dhb6ZLBDe
WXnQ2+r/AGt1mSOQozSSQmNo55GIJcOQGZd4KM/yAHWXOrabZW9zcXeoWkEF q4S4klmVVhYh
SA5JwpIdCAf7w9RWfY+L9B1C/u7KHU7Tz7d4htadP3qyJE0bphssjGZFB7sc DPGaet6Jf3qT
yW1lYm6TUFurOaK8ktJEItxH5rssbh5AS67WUoU2hs4wc+fwhqlxZ3mnXstj qVvfXdjeXdxO
NhleE2yyoYQpXa6W7N97q+3bgbqANyTxh4egBe71rTbWIuFhlmvYVWcGNJNy Hf02yJ1weQcY
Kk3LrXdHsdRg0681Wxt76fb5NtNcIkkm47V2qTk5IIGOprHsfDd5beO7zXHk gNrN5+1Ax3jf
FZIMjGOtrJnnuvqccnb6HrOg2+meGY7SO9NxcaXd3FxGJwsP2cWySAN5RiIx alvmkRjuwFJ2
7gD1SiiigAooooA4jQf+XX/sFSf+0qsVn2E7W2nfaFZVaLRJ3BfGAQIzzllG PqwHuOtcf/wl
niBfvyaYMfe/0SQYx1+9KMY2yfexjb823bN5LjSc1oDkkeu6L/x5v/10P8hV xf8Aj8l/65p/
Nq5vwDf32o6FPNqHkeatyyDyInjGAq54Yk5Dbh6jGGCsGUb8khjvHwBzGvX6 tRytPlC+ly3R
Vb7Q/otH2h/RafIyeZFmiq32h/RaPtD+i0cjDmRZoqt9of0Wj7Q/otHIw5kW aKrfaH9Fo+0P
6LRyMOZFmiq32h/RaPtD+i0cjDmRZrP1mHVJ9OdNIuoLe65+aaPdkYPCnkI2 cYcq4HdG6VP9
of0WvP8A4m/EHVvBf9l/2db2Uv2vzfM+0I7Y2bMY2sP7xqoUpTlyoTmkrs0b 2IQ+F1TTNO1y
x1T+0IzFHK80sjXOV2tcyo7+Zb7dodi7AINoIdVUU5Xux4O8q4m8QQ6hNqci X0sdrdzqso3M
2xUZZRa/KBGYmXrGGzmQHzr/AIX14p/58NH/AO/Mv/xyj/hfXin/AJ8NH/78 y/8Axyt/qVUn
20D1HQ7e6t/BGvfaZdcmV/OaGWMzrdOnkqMwRzs0sTbgwVXY5YFhhXUA1xNT k8EaCunz6rBC
fJ+2yXMM0t4sPktjzFgZZTJ5nlbvLYHOScruFeXf8L68U/8APho//fmX/wCO Uf8AC+vFP/Ph
o/8A35l/+OUfUqoe2geu+F7p9M8NXM99e6lfxRXB2btKvEljUhBtWOUyTSDc S24lsbiBgLgc
/G2qTfC/wzaWY1Kw+yJb22qbtPuhKipbkELHGY5mHm+UN0R9ckqHFcF/wvrx T/z4aP8A9+Zf
/jlH/C+vFP8Az4aP/wB+Zf8A45R9Sqh7aB3MMF66aBbPq3iOaN9VljlkgsL+ 28u2a3IKSeaX
cqZSmJXbK722MgQlaaS+LbzRrRprvWUint7K41Kaaxn8xJStysypHD5UoAkj tRtiI4w5yHdn
5L/hfXin/nw0f/vzL/8AHKP+F9eKf+fDR/8AvzL/APHKPqVUPbQO9n+3w+CF 2ar4gnnTWLcw
y2um3sU8EW+MygpL5kkqBPNbMm9CWCgfKqiS+sZtT0fWtL8vXHtdL1u0mtjI 10sjWyNC0pSQ
4efDC5IwznITb/yzrz7/AIX14p/58NH/AO/Mv/xyj/hfXin/AJ8NH/78y/8A xyj6lVD20D3X
QJIH0tVtIdSjtkcrE2omXzZB1LfviZcZJA34Py8DbtJy/HrTpoNu1rLqsVwN QtSsmmRyySIv
mr5hKorBlEfmcOrKTgYJwK8e/wCF9eKf+fDR/wDvzL/8co/4X14p/wCfDR/+ /Mv/AMco+pVQ
9tA9Bu5dRNhq2l2ra5FZWmqrGlxJBeSutsYASQwKzzr9oDj93JkblJPlDa2X YPq895p2mX03
ieJI9YZFnhtbyNXsZLXPzuzSYBmIGZHMkeTjysYXkv8AhfXin/nw0f8A78y/ /HKP+F9eKf8A
nw0f/vzL/wDHKPqVUPbQOtSXxbeaNaNNd6ykU9vZXGpTTWM/mJKVuVmVI4fK lAEkdqNsRHGH
OQ7s/Qabo2pav4Va0j1673x3pdJbqz1C0ZE2DMY3XCTONxLbmkYclQPlG3zL /hfXin/nw0f/
AL8y/wDxyj/hfXin/nw0f/vzL/8AHKPqVUPbQPYbbweJfDkuja3d/wBoQy3c dw2fOcMEeNwj
C4lmJUmPBGQCCeAck5es6FBpd/odpp76zAl9rFzcX8unrL86TJIz+c0a7QN7 QoHbDKoyrLtL
DzL/AIX14p/58NH/AO/Mv/xyj/hfXin/AJ8NH/78y/8Axyj6lVD20DsYJ/E9 3ocJu59cC3Fp
ZT308lpMrwzn7QswEUIjlKho7ddkJTGVkJZWk8zY8N3Fz/wj2t2XiD+3Db21 2ht5I7a9jme3
dI2UoQ7zH595I3s6g4YIPkHm3/C+vFP/AD4aP/35l/8AjlH/AAvrxT/z4aP/ AN+Zf/jlH1Kq
HtoHoM1/fXPwv0FmfxHBq1vLp8VxJDZ3IuVdTH57MpQ+YuzzMllZGPHzHAqw urTaWmp2yadq
t0LPVVh02e80+6uvs6NbjdNuKmSVQ/2hcqTneq7kRgw82/4X14p/58NH/wC/ Mv8A8co/4X14
p/58NH/78y//AByj6lVD20D2Gx0XS9e8HR6fLa3wsZLszyR38Hly3DpcmVmk jZeFkdSxXavy
vgBeANjSNGs9EguYrNMfabua8mcgbnklcuxJAGcZCjPO1VGTivBv+F9eKf8A nw0f/vzL/wDH
KP8AhfXin/nw0f8A78y//HKPqVUPbQPZfHGlnVfDqIEu38i9tbl1tZZEfy45 0aQjyyGYhA5C
jJyAVG4LVO+sG1fwXJFo6a5C1rKJrVZ7y4t57vYQ7Rl3cSqr5eLMmNudwBAQ nyqX46eLoHCT
aXpUbFVcK9vKCVYBlPMnQggg9wRXaeAPGd18RrPWLPxDpmlzWsHk/uRAWR9x Y/MrswOCikVM
8LUjHmY1Vi3Ylv1l/wCERuvEkOqazbpqOsWd1aGC7mmaG2a4jjXy4yWDCRGe TyimP3qoVOxa
kvk1qTQJFsJ9Vg0k6qNkk8N3LcrZ/ZxnKhluj/pOf4g2OeY+K6+60rSr7ToN OvNJ0+4sYNvk
201srxx7RtXapGBgEgY6CtD7Q/otYcjK5kcZpujalq/hVrSPXrvfHel0lurP ULRkTYMxjdcJ
M43EtuaRhyVA+UbdS28HiXw5Lo2t3f8AaEMt3HcNnznDBHjcIwuJZiVJjwRk AgngHJO/9of0
Wj7Q/otHIw5kcxrOjRaJoLxaOl8NQudVN5C9sHw91LKXzcGIDNuM7X3f8s1A BLBay5Xux4O8
q4m8QQ6hNqciX0sdrdzqso3M2xUZZRa/KBGYmXrGGzmQHu/tD+i0faH9Fo5G HMjkNDt7q38E
a99pl1yZX85oZYzOt06eSozBHOzSxNuDBVdjlgWGFdQJNYeUeBdGiim8QQ+c kCGVrWae5UCI
t/pKwMsoPygMUZTvKg5UsD1f2h/RaPtD+i0cjDmR54NDu73wRcx3DazcpHrF tdxu013FK8Eb
wmQpFI5nQALLiNmZi670+8gGhrs3/FGWv9lDxPbCLU7cQTLHdSXRTzVMrsjB 5GQIZRtmXBKj
CkFM9n9of0Wj7Q/otHIw5kYkcOkxeE5nU+IDYSvvbdJftdg7gvygnz1GVHAw MZPQknm5r++u
fhfoLM/iODVreXT4riSGzuRcq6mPz2ZSh8xdnmZLKyMePmOBXf8A2h/RaPtD +i0cjDmRwjTX
am904jxB/Y1lrASVxHdmdrQ2x/1cuPOlH2odUZiF/wCmdSeH9Ht/Edr4kstS fVZ7IarbiKDU
5S7CGKK3mjQxvkBWJOdwEjK37w7846++httTs5LO/s7a7tZMb4Z4hIjYIIyp 4OCAfwosYbbT
LOOzsLO2tLWPOyGCIRouSScKOBkkn8aORhzIyL2zTw3o8thoh8rUtZ1CXypi ilhPMzyPKeMN
5aB2Ab7yxKmckVY1XTNOsvD1lpsWlX11DbeXDZQWErJNHtQgFZt6+XhAwLF1 yCVyS21tf7Q/
otH2h/RaORhzIg0aHVINORNXuoLi64+aGPbgYHDHgO2c5cKgPZF6VoVW+0P6 LR9of0WjkYcy
LNFVvtD+i0faH9Fo5GHMizRVb7Q/otH2h/RaORhzIs0VW+0P6LR9of0WjkYc yH3X/Hs/tg/r
/n0+o61ndPbH4Y/l6e3Ttj5LU0zPEwIGOufT/P4fUdaq9PbH4Y/l6e3Ttj5I krMpO5DdcWz9
ug9O/wCHp+nTjCZtaV1xbP26D07/AIen6dOMJm1DKQ66/wCQfY/9f5/9EvVz wn/x7XX/AF3k
/wDRj1Tuv+QfY/8AX+f/AES9XPCf/Htdf9d5P/Rj1SEzoaKKKoRV1JUbSrxZ ApQwOGDHAxtO
c8r/ADH1HWrVV79tmnXLbtuImO7dtxwec7lx/wB9D6jrVigAooooAKKKKACi iigCrpqoulWa
xhQggQKFORjaMY5b+Z+p60zULieF7SK3aJHuJjHukQuAAjt0BH931pLKCOWz tpjJKxaNGyJ2
IPCn++wP3R3Ocnk7jmjrAFg2lzJHdyxR3eZPLWSdlHkSIDgbjjO38Tk8kmqg ruxM3ZXILXXv
tt+9jbatZyTrvwPsEoVyhAcK5faxBIztJxW1p1y15pdpdOFDTQpIQvTJUHj8 64TQ9MstC1e4
vIvtzxSPI6odBlEoLkHDS+XuIHOAMdec4rrtAnjj0fS7CaRI75bCJ3tnbEqj aASVPIGePrWt
aMYrQzouU2a1RzTLAgdxIQXVPkjZzlmCjhQTjJ5PQDJOACa8s034eXNpa6S6 aULW7s7LSlDW
04iKTGUrft8jD52hChn6sAACSKoWXgHW7PWGuLWxv4p55Ybm/e4uYWtJLlLu BxJGqSCWRFX7
QwEx3Ebc/Ma5m5djrjGk1rJp+mn33v8AgevX19b6dZyXV1J5cKYBIUsSSQFV VGSzEkAKASSQ
ACTUem6paatbtNaPIQjlJElieKSNsA4dHAZTgggEDIYHoQa8y0zStf8AAmlW F3aeHrXzF0wW
0sOmQbpZZ2Nvhp0XAleMC4O/eA2SAUL89z4Nuba+0Bb62tbyIXLmR5rx4nmu WwAZGMTMueNu
3jbs2hVVVFCknp1CdGcFzbx7rb+vLc6CiufXT8eBrPTxoe1ktII0037X/wAe 7AKFHn5yPLIB
8xcsNm5QWwDy+reGNSn060gbSf7S1OKWXzZbtLeewvJWEYFzcRu4kHAwvl/N FhkUNGFD0ZHp
FV7e+t7ue7hgk3yWkohnG0jY5RZAOevyup49fXNcn4l0WS+tNQWPRbuQyaml x5cLwTx32LdF
DzRTuqmIEBSgIbMaupB+YY7eDLvZeQzaFaLe3lxpsrX2mlIUhhia0WWCN9yy oF8iR1AGMBcH
fxQB6RHMsrzIokBifY26NlBO0N8pIwwww5GRnI6ggSV5/D4GguPG1xLqGg2M +iL5/wBmjmii
eNMwWEabYznb/qJlHHAX0Izzb2clpcaLp2vWEd/4onuNJnhuXngmuLaKM24m X5n87G+K4cmN
WTDsxPL4APZKKKKACiiigDz21fy9Jd9+zbodwd27bj5Y+c7lx9dy/Uda88/1 f+xs/wCA7cf9
84x5f+xjy/8Aln5f+iekaXE09pHCj+W8mjTKr/N8pIiGflIP5EH0Irl08D6g m3Gs2vy46WDL
02dNsox9wdMY+XGPLi2bUZxiveZM4tvQ7P4aps8OXA2bf9LYfd29ERcfdXpj GO2NuI8eUnSz
/wDH43/XNf5tWL4F0ibRtEmt5rmK4ZrjcHjtxCANiLjGT/d9cAYUAKoA3Wi8 y8fnGI17e7VD
kue6Cz5bEVFWPs3+3+lH2b/b/Sq5kTysr0VY+zf7f6UfZv8Ab/SjmQcrK9FW Ps3+3+lH2b/b
/SjmQcrK9FWPs3+3+lH2b/b/AEo5kHKyvRVj7N/t/pR9m/2/0o5kHKyvXk/x mi06a+8OJqlz
NBb/AOkfNEm7JzDwx6ouM5YK5HZG6V7B9m/2/wBK4zx98OP+E4/s/wD4mv2L 7H5n/Lv5m/ft
/wBoYxt/WtaNSMZptkyi2tDw600x7zxG1re6HZx2X2GR2eydpIrSEZLXSyI7 ebsbcSGZskGM
YO0Lai8PQt4q+zR+Hbm6sYNPSeL7OkkjXcZ2qt15fmKzBywOxHXZnnOxg3af 8M9/9TR/5T//
ALZR/wAM9/8AU0f+U/8A+2V2PEUv5/wZl7OXY4HWNMtI/F+i2dpoe3zvKEun M8lvJK5lYbJF
d3MLMu0D5z8pV+N2AaPo9jceL9atb3TJkNr5pg0uHddOZBKq+UAro0u1S5yr g/Ju5AIPff8A
DPf/AFNH/lP/APtlH/DPf/U0f+U//wC2UfWKVrc/5h7OXY861zSprfxPZw6D pGsWd60SzJbt
aSQyiRSx3RIXkcKAoOSxO4MeBgDbutBjl+JniRdX068cmW4urO1W2d3u83AU FIw8bSLtLt8r
j7hPIBB6r/hnv/qaP/Kf/wDbKP8Ahnv/AKmj/wAp/wD9so+sUv5/wYezl2OV l0HT421udfCW
pFLTTY7vy7q3ntvLlE4X5V8xz5RTcW3MWPlvtZMcW38HaJaardQvp1+zWk93 bQWjK08t4Ymt
yr+WrRMxKTyPhGUBUU/Nhi+//wAM9/8AU0f+U/8A+2Uf8M9/9TR/5T//ALZU +3p/z/mPkl/K
clD4dsbjxg1knhfVTC2lTzyWktvLbSI6o5R4l3yEAssaguXBZm45UBlnpdva appN5ceHYRFr
GkXUkNpOs3lGcLKsaxZbcWbbDgbmOZQVwSmOw/4Z7/6mj/yn/wD2yj/hnv8A 6mj/AMp//wBs
p+3pfz/mHs5djyLW7S4tNRK3OmJpkjqG+xqXzEOnKuzOpON2GOcEEcEVo+C9 Lj1fWp7WbSpt
SiFjcSGOAuJEKxsyMpXOGLhVG4MMvjaSRXpn/DPf/U0f+U//AO2Uf8M9/wDU 0f8AlP8A/tlW
8VScbc35k+yne9jhNJ0y0vfEl3b6n4eeyntbTdHpdvBPI80hdP8Alk8okY7H Z8K68Ju5AIOj
p+i24+JGk2lv4UvJIJfJe5tdQsZo1iUzBWlWPzHOwKACZGZclsjGAOq/4Z7/ AOpo/wDKf/8A
bKP+Ge/+po/8p/8A9sqHXpP7f5lKnLscJf6k8niRZ/GekXNufsmyOG4jupmP zkhsS3KPj74+
/t/2c5Iqx+I7HQ/FFvq/h228rybaVEHktFtldHQPh5Zs43KeuDjGB1Pov/DP f/U0f+U//wC2
Uf8ADPf/AFNH/lP/APtlNV6Gzl+YvZz7HA218/iu+3TWH26bTdIgttP07LHz zGY0YYj2u3DT
S4ByMckqprU/sDTBqOlwyaB5c76bJdzWUUktxLJMbhozGIxIpbYqk+WGR0AY uzlCG6r/AIZ7
/wCpo/8AKf8A/bKu33wRu9RtbK2ufFMJisovKgEekRxlUznBKuC3OT8xPJY9 Scp16X2ZWXzG
qcuqPO9d8NwWXiXw8bPSJpLfUthNk5MCvKJmjaAMZJDG2AoYFyyljnb90QaJ osd7431fTZvD
00sUUV6TYwTO8lsUVyirIucsHCoGYMCW6EkV33/DPf8A1NH/AJT/AP7ZR/wz 3/1NH/lP/wDt
lP6xStbn/Bi9nK+xwmk6ZaXviS7t9T8PPZT2tpuj0u3gnkeaQun/ACyeUSMd js+FdeE3cgEH
R0/RbcfEjSbS38KXkkEvkvc2uoWM0axKZgrSrH5jnYFABMjMuS2RjAHVf8M9 /wDU0f8AlP8A
/tlH/DPf/U0f+U//AO2UnXpP7f5jVOXY4S88T+INH8YW2s6jptzZalBaSRwJ cNOWG9JEWT/S
GckBnJx907ccZJqk163izV7A6hvh03TNPhhlKEZjt4UAbDYxudshd38cirnp XpH/AAz3/wBT
R/5T/wD7ZT4/gDLEkqR+LHRZV2SKtiQHXIbB/e8jKqceoHpT9vQWqevoxezn 2PLbK7vNZ8QX
V3/Z9hciVS0sFy3lW8MYICgOXXylU7FXDr/CmSDtPqvwZi06G+8RppdzNPb/ AOj/ADSptwcz
cKerrjGGKoT3RelQ/wDDPf8A1NH/AJT/AP7ZXZ+Afhx/wg/9of8AE1+2/bPL /wCXfy9mzd/t
HOd36VFavSlBqL/Mcack9UdXRVj7N/t/pR9m/wBv9K4eZG3KyvRVj7N/t/pR 9m/2/wBKOZBy
sr0VY+zf7f6UfZv9v9KOZBysr0VY+zf7f6UfZv8Ab/SjmQcrK9FWPs3+3+lH 2b/b/SjmQcrK
9FWPs3+3+lH2b/b/AEo5kHKyvRVj7N/t/pR9m/2/0o5kHKyvRVj7N/t/pR9m /wBv9KOZBysr
0VY+zf7f6UfZv9v9KOZBysr0VY+zf7f6UfZv9v8ASjmQcrK9FWPs3+3+lH2b /b/SjmQcrK9F
WPs3+3+lH2b/AG/0o5kHKyrJ9w+3P+f8j6jrUPT2x+GP5ent07Y+S5PBshZt 2cc9P8/0+o61
T6e2Pwx/L09unbHyZzd2XFWRDdcWz9ug9O/4en6dOMJm1pXXFs/boPTv+Hp+ nTjCZtZMtDrr
/kH2P/X+f/RL1c8J/wDHtdf9d5P/AEY9U7r/AJB9j/1/n/0S9XPCf/Htdf8A XeT/ANGPVITO
hoooqhFe/DNp1yqmQMYmAMZIYHB6EAkH6An2NWKr3679OuV27sxMNu3dng8Y 2tn/AL5P0PSr
FABRRRQAUUUUAFFFFAHPXGrXFvBY6Xp8c0+qSJAWaWF5EhjYkNJKx2dkfgkM WA4rB1+98SaN
JKsWpXOpXRjE0dpaRwwll3SF9gMUhwoEY+Y8k4yWZVO9otiI9X1l0uJg0U8N sMbceWkMTqoX
GFGXk4UD77e2Ga9HYWUmnzak1s8c1wIZpryOPBQQyEKTtAxvGfqxxwcUqUee XvHVXqqhFQgl
sm20m7tLutEr/qzG0Kw0y5tntpNO0XUr6KW4Ekl4Y/tMiJO6B3AjJJIUZY9T knmuis4LGy0M
X2l6fa2DXMUcjCCJVznBAOAM43H865DQhp2l6yZrjW9Ae1g84WrRXW11VyDt EYYRp3yQCWwK
6uwbf4G05v71lAf/AB1a2q0YwV0jkhi6tX3ZTbXqR/2pef8APb/x0f4Uf2pe f89v/HR/hXlk
FzfRXFvCBq76nJpM39pRztdeWJvMt1eSJchW2b5WAgIyMBSMrWt4ae9Mccd3 LqkscWqMttJ9
nmhDR/Ztx80TFpDHvLgFmPzhMYAAHPqWd7/al5/z2/8AHR/hWJPqDTazN9gu 5k1OILJLsEgg
Yjb8smB5e8oVHILhSrAYC1xUlnrUfh3w+Li/1RVktPMvpHiuZ5RcFIgilYHS RQAJB/dyMtly
Grd8K6ddQ3uqXuoG8+2SSQqzSsUSTFrbhn8tWMe7erAsucYIDECk1dal06ko O8f68n5Hotrq
mbhLLUEitL98mOIS71mGM5jYhS2B1GAR3GCpOjWT4g/d2tncrxNDf23lt6b5 Vibj3SRx+Oeo
BrWqot3sx1IxcVOKte/3r9LNfiFFFFUYhRRRQAUUUUAFFFFAHEaD/wAuv/YK k/8AaVWKr6D/
AMuv/YKk/wDaVWKhlI3dF/483/66H+Qq4v8Ax+S/9c0/m1U9F/483/66H+Qq 4v8Ax+S/9c0/
m1UthMmooopiCiiigAooooAKKKKAM/WdQuNM057m106e/kGf3cJHyjBO5v4i oxyEV35+VGPF
ZcettZ+E5tY/tK012SV9ts1kFjgmlZhFHFGQX2hpNqlmZsMzEkKML0lU5NKs ZbqG6a2jE8Vx
9qV1+UmXyjFvbH3j5bFec8Y9BgAw7pLzwj4Qge1nguJraVZr0yQnfes8m6YR KGG2aR3YovK7
mCAAEEV11/XbjwvHqFqti99e3bra2vlgSRRgsfKaN5UElwoRt674wpD4z5eH 6i6sLO+8j7Za
QXHkSrPD50Yfy5F+6656MMnBHIqnP4a0G6t5be40TTZoJbg3UkclqjK8xGDI QRguRxu60AY+
k61rU/hzXZtQk0221OweRF+0RmCKAiBJF8/EkgA+fcSkjDYR0bcosXuravH4 V024sm0261S7
SIZt3DxSsULsYFeSMSDAJAMi/JlsnbtbYh0nTbbSzpcGn2kWnlGQ2iQqsRVs 7hsAxg5ORjnJ
qO60LR77ToNOvNKsbixg2+TbTW6PHHtG1dqkYGASBjoKAOP/AOEs8Sx6X5D2 UE2tS6r9gSGK
2VWhH2b7R88ZuNjNtB+7Pja6nO4FK0Itb8S/YLC1vbGCw1O+1BrSGaeJWTYI Hm8wwxzNj/Vt
Ht83/bz/AAV0H9haP/Y/9kf2VY/2Z/z5fZ08n7277mNv3uenXmo4/DWgw6XN pcWiaamnzPvl
tFtUETtxyyYwT8q8kdh6UAcvB4o15k1GV7jRpUsNds9KYW8LsJFdoUlbd5ny vun+7g7CjKS/
3gXfjDVwb+106K01C7Gutpds9tGGCqLYXDblaZQ7rh4z+8TkZxkbD0Gl+FrL SxqsIkkuLPUX
Beymii8iJRGIgiKqL8nloiYbPCDuSTYPhrQTb3FudE03yLhIknj+yptlWMAR hhjBCgAKD0xx
igDn59d8V2vhhby4020t9QTU7e2EV0oRbmKWSOPIEcsnkndJjO6T7hO35gBJ /wAJDrHmf2Rv
sf7T/tX+zftn2d/J/wCPT7Xv8nzN33f3ePM6/Nn+Gtj/AIRPw3/Z39nf8I/p X2HzfP8As32K
Py/Mxt37cY3Y4z1xUjeGtBZL1G0TTSl+4e8U2qYuGDFgZOPnIYk5OeTmgDn9 S8QeI9OtFtlh
0291SfUxYwix/eeWotzMWkjkkjAchGOzzBtWRfmfHz2I9T1z/hGpr3Wrm08P XFrcY+03scXk
TRkAAyIszbBucqAJs7kU5wxStz+wtH/sf+yP7Ksf7M/58vs6eT97d9zG373P TrzRY6Fo+mRR
xWGlWNpHHKZ0SC3SMLIVKFwAOGKkrnrg46UAGjahcanpyXN1p09hIcfu5iPm GAdy/wAQU54D
qj8fMinitCiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAhuv8Aj2f2wf1/z6fU dazuntj8Mfy9
Pbp2x8mjdf8AHs/tg/r/AJ9PqOtZ3T2x+GP5ent07Y+RMaIbri2ft0Hp3/D0 /TpxhM2tK64t
n7dB6d/w9P06cYTNqGNDrr/kH2P/AF/n/wBEvVzwn/x7XX/XeT/0Y9U7r/kH 2P8A1/n/ANEv
Vzwn/wAe11/13k/9GPVITOhoooqhGbrF9Zw2dxbT3ltDNJA2xJXTJyCB8rkA 8+vBq1a39ne7
/sl3BcbMbvKkD7c9M4+hrk/Gc18tvrcGlanaWOoTaYqwmdtrSHE4Cxt5ibH3 FcOSQvcGtLSJ
7m6v7kjU9Pu7hbaJZJ7aEiIndPgBfMYjGVz8xzg9MjABr3V99muIoEtpp5JF ZwsRUYClQSdz
D+8Kgn1aS2t5J5tLvFijUu7bojgDk/x1W1DzjrNtCJVWWSyu9jgFdvzw7e55 GRz/AC6VxWha
Hf6F4c1uS/tpYZjp7rJIbiJlncBzuCooJ653OSx3Y7V0Qppxu/61MJ1Gm0eo UVj+LL640zwb
rl/ZyeXdWun3E0L7QdrrGxU4PBwQOtcf4m1nxLpGrQ2Ues2MTJaLPFJdOsAv rhpJN0SRCGV5
VULGBHGyyAOAXdmDDnNz0CG/s7i8ubOG7gkurXb9ohSQF4twyu5RyuRyM9as Vy/ge3lj0/UZ
3vZ5Y5dVv9kDhAkOLycHaQoY56ncW9sDiuooAxo3bTNfu/NjZbK/aKRLgkFR cFfLMZ5yoKpH
tyMFiRnJVa2aZLFHPC8M0ayRSKVdHGVYHggg9RWND4ajspbg6XqF1psE8gka 2tYoBGrbVXID
RkjIUd+uajWO2p03hVV5PlaS72dtPNrTy+43KjuIFuIGickK2M469c1z97Fr NlqGm29nrjTt
cTP5q3lrHJtjWNjuxGIyF3bAT6snI5DXvJ8Qp832/S5cc+X9ikj3+27zW259 dpx1welHPfoE
sOopPnWvr3t28hT4fsWnSchjMisiyHbuVSQSAccAlVz9B6U/+xbb+/L+Y/wq P+2LmH/j80W/
iReJJodk6Z9VVGMjAnp8gPOSBzg/4SOx/wCeGqf+Cq5/+N0c0eovq1Z/DG/p r+VyT+xbb+/L
+Y/wo/sW2/vy/mP8Kj/4SOx/54ap/wCCq5/+N0f8JHY/88NU/wDBVc//ABuj mh3D6tX/AJH9
zDxH/wAgyH/r/s//AEpirWrDjuBruqIohuo7Gy2T5ntpIvPlO8BcSKMhMBuh +YocjbzuUR1b
aCqnCEact1dv52/yv8woooqznCiiigAooooAKKKKAOI0H/l1/wCwVJ/7SqxV fQf+XX/sFSf+
0qsVDKRu6L/x5v8A9dD/ACFXF/4/Jf8Armn82qnov/Hm/wD10P8AIVcX/j8l /wCuafzaqWwm
TUUUUxBRRRQAVn6zrFvoenPe3STvGueIYi3OCfmb7sa8cu5VB/EwFaFFAGO+ p3mlaHdalrcM
CyR5ZLWxYyk9AsaswXzJHbhRtXJdVwSNzU5LrUvDHhOG8vljvpYX+0apIbhg sEbMXmeLKksk
e47UODsUAEkAG4nhjS4IrWC1g+y2ltdi7W0h+WAuFIA8v7oUMRIAoH7xQ/3s k3NR0u01VLdL
xJHSC4juUVZXQeZG25C20jcAwB2nIyAccCgDD/4Si/k8L/23b6N58c8ubNYp ZJPMtif3czhI
mkXcMHYqORuXdgbikmjeItS1bQdTvRo8a31o7pDZrcsDMwjV1DebHG8RYtjD oOMNyrAmxL4R
0ea38gx3aIL2S/UxX08bJPIGDsjK4Kg73yqkL8x45qwnh7TE0a70kwSSWl4j pc+bPJJJMHXa
2+RmLsduFBLZAAAwAMAFe71q+tdN0nOmRrq2pOsK2ctziOKXynldXlVW4Cxu AVU5OOADkV5P
EGrwwwxT6FHBqF1e/Y7SKW9BilxCZWkMiqxVP3coXKbjtXKruO3Qfw9pj6Na aSIJI7SzREtv
KnkjkhCLtXZIrB1O3KkhskEg5BOY/wDhF9J/s77F5M+3zfP8/wC1y/aPMxt3 +fu8zdt+TO7O
z5fu8UAY83i/VIrm2sl0KCW+bUG02eOO/wDkjl+zfaEZWaMbo9h+Y4Vlwdqy cZr/APCwpZtM
S+tdBndZPsEyQSXCJK9vdyGKNhjK+ZvUnYWA2lSXBJVdxfCOjq9lII7vzLK4 N1FIb6cu0pUL
vkbfmU7Rs+fdhfl+7xWXqngG1l0FNL0Wf+zsfZYzLM09wwht5WljjU+arLh2 OGDZCnAxhSoB
saZqNxrFrqVpOn2C/tJTazNbSiZY3aJJFaNnQbsLKh+ZB8wIwQMnDj8X3Nh4 A8M6nPbyX+pa
pb26hVjfDytAZWZhFG7AYRz8qHnHAGSOgj8P6fDpc2nxfa0imffLKt7MJ3bj lpt/mE4VVyW+
6AvQYqvB4R0e20aLSYY7tbSFw8Gb6cyQELtHlyF98Y25XCsBgsOjHIBnx+L7 0+GptZm0SSBL
O423yzmWEJbgBpJ4vMiV5AqtnaUQko4XOBusW0+p+KtGtr21vZNGt5bgzQy2 vlzSXVptby2P
mxkRl8o+NrEAAEgk7bg8Mab9jhtZDfTQw3aXiCfULiU+ahBXLM5JUFQdhJXI zjNWLbRbKzs7
y1t1njhvJZZpQtzJkPKSXKNuzHkkn5CMEkjBNAHH6Xq3iLTfA1h4knvv7b+2 2llLLDetHapa
eYP3su+KI/uxvQkMPlVGbcelaF14v1S2g1G6XQoLi1tNVh06MwX+XuQ7rGWT dGq7leRUKlsb
lkBYbPm2P7Bis/C/9haSIIrdIvIjS/R7yMRk8oys4Zl2kqAWwBgdBisvUPB9 zc+CLHw7b6pH
DLC8Ek948Dlp3jcSM/ySIyu8i7i24nlucncACO+8bT6fYSLNpW/VU1AaebeB 5ZojIYBcZDJE
ZCvlHqIshuMbfnq5put6zrOjNdWmlR215BcGOS2vhPDHOu0HMbvErgfMPmMX JRlxgh6uf8Iv
pP8AZ32LyZ9vm+f5/wBrl+0eZjbv8/d5m7b8md2dny/d4o/4RfSX07+z7mGe 9tDL5zQ393Ld
K7YwA3ms25R1CnKhgGA3AGgCxo2sW+uacl7apOkbY4miK84B+VvuyLzw6FkP 8LEVoUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFAEF3k2+AQCWUZI6ZYVjC7jGP3j8f9MgPT/a 9v5egxtXP+qX
/ron/oQryXxP4N1HWtatL3T/ABNqmmQFgt5BBdSBWQDgxjOFbgA8Y53YyCGl jR1Wqay0Go6X
YxKHS8kkWRmTaVCxlhjB7lR7Y7dMT1gajEsGveGoULlY3mUF3LsQIWHLEkk+ 5OTW/UsY66/5
B9j/ANf5/wDRL1c8J/8AHtdf9d5P/Rj1Tuv+QfY/9f5/9EvVzwn/AMe11/13 k/8ARj1SEzoa
KKKoQUUUUAVL3S9P1LZ9usba68vOzz4VfbnrjI46D8qq/wDCMeH/APoB6Z/4 CR/4Vq0VSlJa
JkuMXq0FFFFSUFFFFABRRRQBk6f/AKTr2rXEnL20iWcQ7KnlpKSPQs0mDjqE TjjNa1ZOhfvf
7Tven2m/l+T+75WIOvfPk7vbdjnGTrVMNrm+J0qcvZJfNJX/ABuFFFFUYBRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFAHEaD/y6/wDYKk/9pVYqvoP/AC6/9gqT/wBpVYqGUi3a 6hLaRGONUIJ3
fMD/AI1Zh1OV5JZX2KAgzhCehx6j+9WXU0P+quP+uY/9CWlcC8deiWdIDMgm dWdYzGNzKCAS
Bv5ALLn6j1qlZ+Jri617VLIpEsFlDC6v5ZLMXLZyN2McD9fXjh7Hwxqdl8UL zxBNevd2F1YN
CnmEBrdt6ERgDHy4DEED1zzy23pH/I0+JP8Ar2tf5tTuI67+2P8Aa/8AIP8A 9nR/bH+1/wCQ
f/s6x6KLsdjUh1RokKvcSTEuzbngUEAsSF+VgMAHA74AySckyf2x/tf+Qf8A 7Oseii7Cxsf2
x/tf+Qf/ALOj+2P9r/yD/wDZ1j0UXYWNj+2P9r/yD/8AZ0f2x/tf+Qf/ALOs eii7Cxsf2x/t
f+Qf/s6P7Y/2v/IP/wBnWPRRdhY2P7Y/2v8AyD/9nR/bH+1/5B/+zrHoouws bH9sf7X/AJB/
+zo/tj/a/wDIP/2dY9FF2FjY/tj/AGv/ACD/APZ0f2x/tf8AkH/7Oseii7Cx sf2x/tf+Qf8A
7Oj+2P8Aa/8AIP8A9nWPRRdhY2P7Y/2v/IP/ANnR/bH+1/5B/wDs6x6KLsLG x/bH+1/5B/8A
s6P7Y/2v/IP/ANnWPRRdhY2P7Y/2v/IP/wBnR/bH+1/5B/8As6x6KLsLGx/b H+1/5B/+zo/t
j/a/8g//AGdY9FF2FjY/tj/a/wDIP/2dH9sf7X/kH/7Oseii7Cxsf2x/tf8A kH/7Oj+2P9r/
AMg//Z1j0UXYWNj+2P8Aa/8AIP8A9nR/bH+1/wCQf/s6x6KLsLGx/bH+1/5B /wDs6P7Y/wBr
/wAg/wD2dY9FF2FjY/tj/a/8g/8A2dH9sf7X/kH/AOzrHoouwsbH9sf7X/kH /wCzo/tj/a/8
g/8A2dY9FF2FjY/tj/a/8g//AGdH9sf7X/kH/wCzrHoouwsbH9sf7X/kH/7O j+2P9r/yD/8A
Z1j0UXYWNj+2P9r/AMg//Z0f2x/tf+Qf/s6x6KLsLGx/bH+1/wCQf/s6P7Y/ 2v8AyD/9nWPR
RdhY2P7Y/wBr/wAg/wD2dH9sf7X/AJB/+zrHoouwsbH9sf7X/kH/AOzqjYeI 7i913U7Hy4hD
aRwsr7SGYuHJzzjA2jv2PblatZ+gceLvEB/6ZWnP4SH+nr27Y3KJhY7A3snP yoPwPHX/AD26
HpztDeyc/Kg/A8df89uh6c7a/T2x+GP5ent07Y+Q6e2Pwx/L09unbHyO4iwb 2Tn5UH4Hjr/n
t0PTnaG9k5+VB+B46/57dD0521+ntj8Mfy9Pbp2x8h09sfhj+Xp7dO2PkLgW Deyc/Kg/A8df
89uh6c7Q3snPyoPwPHX/AD26Hpztr9PbH4Y/l6e3Ttj5Dp7Y/DH8vT26dsfI XAsG9k5+VB+B
46/57dD052hvZOflQfgeOv8Ant0PTnbX6e2Pwx/L09unbHyHT2x+GP5ent07 Y+QuBYN7LlVA
QFmC8gnGTj1H+R9QtM69Es6QGZBM6s6xmMbmUEAkDfyAWXP1HrUg4kj7fvEH p/EPp6fp04wn
m3i7wxqev+KPDV3Y3r2MOnNPJNdRkb1z5eFUHqWAYcgrjOc/dJcDrPEOu3Ms 2n6VbzNCL+R1
e4jULJGEQv8AJksMkgDJHAzjnBGR/wAI5L/0MGs/9/k/+Io1f/kZfD3/AF1n /wDRLVuUmxmN
b+HVh1C2vJdT1C6e3LNGs8iMoJUqeig9D61s0UUhjrr/AJB9j/1/n/0S9XPC f/Htdf8AXeT/
ANGPVO6/5B9j/wBf5/8ARL1c8J/8e11/13k/9GPVIlnQ0UUVQgooooAKKKKA CiiigAooooAK
ztcuprXSpGt38ueWSO3jkwD5bSyLGHweDtL7sd8Y4zWjWTrPzX+hxNzG9+d6 Ho22CV1yO+GV
WHoVB6ipnsbYdJ1E3stfu1/Q0LW1hsrOC0t02QQRrHGuSdqqMAZPPQVNRRVG TbbuwooooEFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAcX4aQS3FjG2cNpjqce5irov7Ftv78v 5j/CsDwt/wAf
mnf9g5v5xVQ8epo8eoi6vJ9Dvr6O0zDomqQpPJcYLFVtlLAxySHKFgr7isfy /LgpLQZ139i2
39+X8x/hVPUPC8d8iomqajZgZ3fZnRS/1JQ9P89q5HVPEuuKNRXTdTkm1rfq ER0eOGJ2tIo4
5zbziML5uXMdvy5ZG8/gfMmLF54sn1nxnbaZ4c8RWjWEr20Uk1qIrgIWiv3k APID4hiIzkAg
EqQSrFkK5rf8IFH/ANDHr3/f+P8A+N1Tv/A0WnafqV/b69rQn+zl3YyxfP5a sVBPl5xyf8gV
VvvEeoR2eszQ65GusQ3DwnSZHhRbO2F0sQuSPLaRAISJd770G/dtK4WtDR9Q vtR8C6xJfX9p
f7EnSG6tZfOWRPKB5kEUaOQxYZRABgKcsrUwOe/4RnVP+hp1D/vlaP8AhGdU /wChp1D/AL5W
Previous Topic:Converting domain model with generics into ecore problem
Next Topic:Extension points not being generated
Current Time: Sun Nov 02 05:13:27 EST 2025
Powered by FUDForum. Page generated in 0.04660 seconds
