Re: Adding Error Log View and writing to Problem View [message #403507 is a reply to message #403505] |
Sun, 02 January 2005 15:11 |
Originally posted by: daniel.megert.gmx.net
Michael Scott wrote:
>I would like to add the Error Log View to my RCP application so that I can
>display logged IStatus objects. I have not found how to activate it.
It's in org.eclipse.pde.runtime.
> I did
>find how to add the Problems view but have not found how to write to it.
You have to create markers of type IMarker.PROBLEM.
HTH
Dani
> I
>would like pointers to documentation containing such information.
>Thanks,
>Mike.
Re: Adding Error Log View and writing to Problem View [message #403736 is a reply to message #403719] |
Tue, 04 January 2005 08:10 |
>Daniel,
>Thanks for your help. I placed an addView("org.eclipse.pde.runtime.LogView")
>statement in my perspective factory class and the Error Log came right up.
>My writes to the plugin log show up fine. I looked up the IMarker interface
>in the eclipse help and it describes what I need. I also used such criteria
>to find and purchase the book "eclipse Building Commercial Quality
>Plug-ins". I found it has a chapter on Markers and another on the Properties
>view, which would have been my next question.
There's also a good article on eclipse.org called "Mark My Words".
Dani
>Thanks again,
>Mike.
>"Daniel Megert" <daniel.megert@gmx.net> wrote in message
>news:cr92uf$d8a$1@www.eclipse.org...
>can
>>>I did
>>HTH
>>Dani
>>>I
>>>Thanks,
>>>Mike.
Re: Adding Error Log View and writing to Problem View [message #403937 is a reply to message #403507] |
Tue, 04 January 2005 13:40 |
Originally posted by: ramim.kauhajoki.fi
Could you show me the code how you opened the Error Log-view. Somehow my
code didn't work. Here's what I tried:
layout.addView("org.eclipse.pde.runtime.LogView",
IPageLayout.BOTTOM,
new Float(0.40).floatValue(),
IPageLayout.ID_EDITOR_AREA);
And the result was:
Could not create view: org.eclipse.pde.runtime.LogView
I guess because this is trying to locate the View from my plugin.xml-file
which is not listed in there...??...
- noon -
>> I did
> HTH
> Dani
>> I
>>Thanks,
>>Mike.
Re: Adding Error Log View and writing to Problem View [message #403953 is a reply to message #403937] |
Wed, 05 January 2005 02:53 |
Michael Scott Messages: 7 Registered: July 2009 |
I created a folder and placed it there along with the Problem and Property
Sheet views. I do not have the view listed in my plugin.xml file either. I
do, however, have it listed in my runtime-workbench plugin list. Hope this
helps.
Mike.
public void createInitialLayout(IPageLayout layout) {
// Get the editor area.
String editorArea = layout.getEditorArea();
// Bottom: Task area with Logs and Properties
IFolderLayout bottom = layout.createFolder("Bottom", IPageLayout.BOTTOM,
0.66f,
editorArea);
bottom.addView(IPageLayout.ID_PROBLEM_VIEW);
bottom.addView(IPageLayout.ID_PROP_SHEET);
bottom.addView("org.eclipse.pde.runtime.LogView");
"noon" <ramim@kauhajoki.fi> wrote in message
news:cre6bn$90h$1@www.eclipse.org...
> IPageLayout.BOTTOM,
> And the result was:
> - noon -
can
> >> I did
> > HTH
> > Dani
> >> I
> >>Thanks,
> >>Mike.
FUDForum. Page generated in 0.01876 seconds
