Home » Eclipse Projects » XML Schema Definition (XSD) » URI converting - set resource base
URI converting - set resource base [message #40810] Fri, 09 April 2004 10:49 Go to next message
Christian Stein is currently offline Christian SteinFriend
Hello NewsGroup (aka Ed...)!
is it possible to set a resource base which is prepended
to all *relative* schemaLocation tag values that *do not*
start with "./"?
The simple solution
map.put(URI.createURI("./"), URI.createURI("./my/folder/"));
does not always work here, as some schemaLocations just
contain the simple file name. A possible solution could be a
directory change to where the root schema is located. But,
AFAIK, you can't change users' current directory "user.dir"...
Christian
Current directory: /
Green example "/my/folder/main1.xsd":
<xs:schema targetNamespace="MAINSPACE" ...>
<xs:import namespace="IMPORTSPACE" schemaLocation="./import.xsd"/>
</xs:schema>
Not working example "/my/folder/main2.xsd":
<xs:import namespace="IMPORTSPACE" schemaLocation="import.xsd"/>
</xs:schema>
Re: URI converting - set resource base [message #40844 is a reply to message #40810] Fri, 09 April 2004 12:34 Go to previous messageGo to next message
On Fri, 09 Apr 2004 12:49:38 +0200, Christian Stein <sormuras@web.de>
> start with "./"?
> The simple solution
I use this work-around(?) for now:
// String name = "main2.xsd";
// String name = "folder/textmain2.xsd";
// String name = "/my/folder/textmain2.xsd";
String name = "my/folder/textmain2.xsd";
java.io.File file = new java.io.File(name).getAbsoluteFile();
System.setProperty("user.dir", file.getParent());
set.getResource(URI.createURI(file.getName()), true);
This only works, because XSD uses System.getProperty("user.dir") or
a similiar "magic". As long it does, that's ok for me...
Sorry for bothering,
Christian
Still learning Java basics after 6 years... ;)
Re: URI converting - set resource base [message #40969 is a reply to message #40844] Mon, 12 April 2004 10:52 Go to previous message
Christian,
I'm not sure exactly what you are doing, but you can always override the
resource set's URI converter's normalize method to do additional funky
stuff. Just be aware that relative schema locations within documents,
i.e., in an include's or import's schemaLocation, typically need to be
resolved against the absolute location of the containing schema and if
that location isn't an absolute URI, resolve isn't well defined. It's
really best to ensure that each resource URI is absolute.
If you want things to be "relocatable" I would suggest something like:
map.put(URI.createURI("pathmap://base-location/",
"c:/actual-location/");
and using absolute URI's of the form "pathmap://base-location/..." for
the resources...
> > start with "./"?
> > The simple solution
> Christian
Re: URI converting - set resource base [message #585272 is a reply to message #40810] Fri, 09 April 2004 12:34 Go to previous message
> start with "./"?
> The simple solution
Christian
Re: URI converting - set resource base [message #585352 is a reply to message #40844] Mon, 12 April 2004 10:52 Go to previous message
Christian,
and using absolute URI's of the form "pathmap://base-location/.." for
the resources...
> > start with "./"?
> > The simple solution
> Christian
Ed Merks
Previous Topic:redefine
Next Topic:Settable properties for XSDSimpleTypeDefinition
Current Time: Wed Dec 02 22:58:26 GMT 2020
Powered by FUDForum. Page generated in 0.02019 seconds
