Home » Modeling » EMF » DeleteCommand on top level resource contents
DeleteCommand on top level resource contents [message #401427] Mon, 29 May 2006 22:11 Go to next message
Baybora Aksoy is currently offline Baybora AksoyFriend
I am trying to make DeleteCommand ( RemoveCommand ) executable on resource
contents. My editor shows a list of top level eobjects in the resource. When
I right-click on an object, I see "delete" command grayed-out. I think, if
the parent is not an EObject, it becomes an Unexecutable command. Is there a
way to enable this command on top level eobjects.
thanks,
Bora
Re: DeleteCommand on top level resource contents [message #401430 is a reply to message #401427] Tue, 30 May 2006 01:04 Go to previous messageGo to next message
Bora,
You could specialize the ResourceItemProvider to do this.
Baybora Aksoy wrote:
> thanks,
> Bora
Ed Merks
Re: DeleteCommand on top level resource contents [message #401509 is a reply to message #401430] Sat, 03 June 2006 20:19 Go to previous messageGo to next message
Thanks Ed,
that was my original solution. Is there a specific reason, why emf doesn't
allow this command on resources? If not, do you plan to provide a
ResourceItemProvider that supports it?
thanks again,
Bora
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:e5g5le$l5l$2@utils.eclipse.org...
> Bora,
>> Hi,
>> resource contents. My editor shows a list of top level eobjects in the
>> resource. When I right-click on an object, I see "delete" command
>> grayed-out. I think, if the parent is not an EObject, it becomes an
>> Unexecutable command. Is there a way to enable this command on top level
>> eobjects.
>> thanks,
>> Bora
Re: DeleteCommand on top level resource contents [message #401511 is a reply to message #401509] Sun, 04 June 2006 11:56 Go to previous message
--------------050505020400050102080306
Bora,
If you allow a delete, it means you likely will end up with an empty
resource. Then there would be the expectation that you could create a
new object, but since the root can allow any EObject, it's hard to offer
useful suggestions without offering to create any type of EObject
possible. We could make it easier by having the command support
factored in to the resource item provider but not yet enabled...
> Thanks Ed,
> thanks again,
> Bora
>> Bora,
>>> Hi,
>>> eobjects.
>>> thanks,
>>> Bora
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Bora,<br>
<br>
resource.&nbsp; Then there would be the expectation that you could create a
offer useful suggestions without offering to create any type of EObject
possible.&nbsp; We could make it easier by having the command support
factored in to the resource item provider but not yet enabled...<br>
<br>
<br>
<blockquote cite="mide5sqf1$j9t$1@utils.eclipse.org" type="cite">
<pre wrap="">Thanks Ed,
thanks again,
Bora
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:e5g5le$l5l$2@utils.eclipse.org">news:e5g5le$l5l$2@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Bora,
</pre>
<pre wrap="">Hi,
eobjects.
thanks,
Bora
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------050505020400050102080306--
Ed Merks
Previous Topic:Advice for bulk edits to a model
Next Topic:Problems creating an EMF model from an XML Schema document
Current Time: Mon Nov 29 12:47:39 GMT 2021
Powered by FUDForum. Page generated in 0.02509 seconds
