Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #40696 is a reply to message #40634] |
Fri, 11 January 2008 02:01 |
Originally posted by: rob.elves.eclipse.org
There was a dependency issue that could lead to this miss-configuration,
especially when using the "Search for updates..." vs "Search for new
features..." option. This has been resolved on the following bug report:
214301: [update] could not load tasklist hyperlink detector extension
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214301
To get your installation back in order, select Help (menu) > Software
Updates > Find and Install..., select the "Search for new features to
install" option, choose the Mylyn update site, and from the available
updates ensure you select the "Mylyn Focused UI" feature.
-Rob
Francois Cottet wrote:
> Hi all,
> Since my Mylyn 2.2 update I have a recurrent error pop-up:
> The 'org.eclipse.mylyn.java.hyperlink.detector.stack' extension from
> plug-in 'org.eclipse.mylyn.java.ui' to the
> 'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
> failed to load the hyperlink detector.
> Plug-in org.eclipse.mylyn.java.ui was unable to load class
> org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDe tector.
> An error occurred while automatically activating bundle
> org.eclipse.mylyn.java.ui (799).
> The mylyn update was made today by the automatic eclipse install/update
> feature.
> I paste the log file of the workspace below, hoping this can help to
> figure out what's missing.
> And thanks to everyone making Mylyn such a great tool. I think it
> improved the way to work for many of us.
> Best regards,
> Francois
> !MESSAGE Plug-in org.eclipse.mylyn.java.ui was unable to load class
> !STACK 0
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
> at
> ... continuing OSGI classes
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> at
> org.eclipse.mylyn.internal.tasks.ui.util.TasksUiExtensionRea der.readHyperlinkDetector(TasksUiExtensionReader.java:296)
> at
> org.eclipse.mylyn.internal.tasks.ui.util.TasksUiExtensionRea der.initStartupExtensions(TasksUiExtensionReader.java:183)
> at
> org.eclipse.mylyn.tasks.ui.TasksUiPlugin.start(TasksUiPlugin .java:433)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
> at java.security.AccessController.doPrivileged(Native Method)
> ... many more
> Caused by: org.osgi.framework.BundleException: The activator
> org.eclipse.mylyn.internal.java.ui.JavaUiBridgePlugin for bundle
> org.eclipse.mylyn.java.ui is invalid
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
> ... 85 more
> Caused by: java.lang.NoClassDefFoundError:
> org/eclipse/mylyn/internal/context/ui/AbstractContextUiPlugi n
> at java.lang.ClassLoader.defineClass1(Native Method)
> at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
> ... more OSGI loader classes
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #40850 is a reply to message #40696] |
Fri, 11 January 2008 03:48 |
Francois Cottet Messages: 19 Registered: July 2009 |
Thanks Rob.
Yes it seems to be the real reason underneath this error since i had
exactly the same scenario (doing a simple update rather than installing
a new mylyn version).
As indicated in a previsou message, reinstalling subversive and its
mylyn component fixed it as well (by installing the correct "Mylyn
Focused UI" feature).
Francois
> Regards,
> -Rob
>> Hi all,
>> point failed to load the hyperlink detector.
>> install/update feature.
>> Best regards,
>> Francois
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... many more
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 85 more
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #586804 is a reply to message #40634] |
Robert Elves Messages: 87 Registered: July 2009 |
Member |
-Rob
> Hi all,
> feature.
> Best regards,
> Francois
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> ... many more
> at
> at
> at
> at
> at
> at
> ... 85 more
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #586876 is a reply to message #40696] |
Thanks Rob.
Francois
> Regards,
> -Rob
>> Hi all,
>> Best regards,
>> Francois
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... many more
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 85 more
FUDForum. Page generated in 0.03381 seconds
