Home » Eclipse Projects » Mylyn » Internationalization of Labels, Messages etc.
Re: Internationalization of Labels, Messages etc. [message #40881 is a reply to message #40543] |
Fri, 11 January 2008 09:29 |
Christian Stellwag Messages: 48 Registered: July 2009 Location: Munich |
Member |
Hello Maarten,
how is that done concretely?
Should I create a new task/bug only?
Do I have to address it to someone?
How do I gather votes for it?
Christian
Am 09.01.2008, 11:25 Uhr, schrieb Maarten Meijer <mm105@xs4all.nl>:
> OK Christian,
> I think you should open a bug for this on bugs.eclipse.org and try an
> gather votes.
> Maarten
> Christian Stellwag wrote:
>> Thank you Maarten for your answer.
>> A lot to read in this bug.
>> But as far as I understood that only relates to localization of
>> bugzilla (e.g. germzilla) and the co-work of Mylyn with localized error
>> messages coming from bugzilla and digesting them correctly within Mylyn.
>> That is not what I was thinking about.
>> I thought about localizing the Mylyn-UI within Eclipse itself, i.e.
>> externalizing all UI-Strings and -messages into properties-files so
>> that I or any other person could write their own translations.
>> Please look at language packs for Eclipse 3.2.1 at IBM for example:
>> http://update.eclipse.org/downloads/drops/L-3.2.1_Language_P acks-200609210945/index.php
>> that do the same for Eclipse IDE, workbench or RCP.
>> cheers, Chris
Operas work. Efficiency strikes, Christian
Re: Internationalization of Labels, Messages etc. [message #40944 is a reply to message #40881] |
Fri, 11 January 2008 14:49 |
maarten meijer Messages: 146 Registered: July 2009 |
go to https://bugs.eclipse.org/bugs/enter_bug_wizard.cgi and either
login or register first, then login.
Create a new bug selecting Mylyn as product and bugzilla as component.
Then enter the description of what you want.
Votes gathering is something to do via blogs or here or friends, etc.
Maarten
> Hello Maarten,
> Christian
>> OK Christian,
>> gather votes.
>> Maarten
>>> error messages coming from bugzilla and digesting them correctly
>>> within Mylyn.
>>> cheers, Chris
> --Operas work. Efficiency strikes, Christian
Re: Internationalization of Labels, Messages etc. [message #41069 is a reply to message #40944] |
Sat, 12 January 2008 00:24 |
Originally posted by: beatmik.acm.org
Christian,
Please do file this bug. While we have had a lot of interest in
ensuring that Mylyn correctly supports internationalized Strings coming
from task repositories, we have not had much interest in the
internationalization of the UI. However, this is definitely something
that we feel we need to do at some point. If you were interested in
contributing a language bundle, that could serve us as a good driver for
externalizing the Strings we use.
The following bugs is related, but you should still file a new one.
212317: externalize plugin.xml strings
https://bugs.eclipse.org/bugs/show_bug.cgi?id=212317
Mik
> Maarten
>> Hello Maarten,
>> Christian
>>> OK Christian,
>>> gather votes.
>>> Maarten
>>>> within Mylyn.
>>>> cheers, Chris
Re: Internationalization of Labels, Messages etc. [message #41855 is a reply to message #41069] |
Sun, 27 January 2008 00:05 |
Werner Keil Messages: 1087 Registered: July 2009 |
Mik,
This is probably a good thread to point you to the Eclipse Babel Project.
If you were to internationalize parts of Mylyn, please note, that quite
a number of plugins and projects are already localized there:
http://www.eclipse.org/babel/
and
http://www.eclipse.org/projects/project_summary.php?projecti d=technology.babel
Beside usage of Babel for projects like Mylyn, we also discussed a
possibility to make use of Mylyn on the other hand for Translation tools
within Babel. Do you think, tasks like translation could also be
maintained and made accessible via Mylyn?
E.g. by highlighting the artifacts a translator needs and showing such
tasks similar to enhancements or other work items.
There is also a potentially interesting post in the Babel newsgroup by a
developer who's working on what he calls an Agile Translation Tool, but
it is currently not part of Babel. However, some of the goals and
features he describes there (like translations being approved or
completed) show similarities to other (Agile) Project Management tools
and their frontends including Mylyn.
Please tell us your thoughts on that. If you think it fits better there,
of course also in the Babel group or mailing lists.
Werner
Mik Kersten wrote:
> Christian,
> Mik
>> Maarten
>>> Hello Maarten,
>>> Christian
>>>> OK Christian,
>>>> an gather votes.
>>>> Maarten
>>>>> within Mylyn.
>>>>> i.e. externalizing all UI-Strings and -messages into
>>>>> properties-files so that I or any other person could write their
>>>>> own translations.
>>>>> cheers, Chris
Re: Internationalization of Labels, Messages etc. [message #42133 is a reply to message #41947] |
Thu, 31 January 2008 05:03 |
Hello Chris,
Thanks a lot for the interest.
Babel is quite matured in some areas and the translation parts are to my
knowledge going to be official part of Ganymede already.
The 'missing' sources in CVS might seem misleading. I have not checked
the code recently (as I am attending committer telco almost weekly but
quite busy in my current day project) but it could also be an option to
use SVN now on one hand.
On the other hand the probably more interesting and advanced part is a
kind of "Content Repository" which is indeed to become the de facto
standard for all Eclipse Resources from now on.
Please check the project page or get in touch with the Spec Leads (Kit
or Chris) if you have any further questions.
Of course, if there are extension points allowing that similar to e.g.
Bugzilla, using Mylyn in some of the Client parts of Babel could also be
very interesting. Translation and Localization may not have been widely
recognized as a key part of the Application Lifecycle, but a Globalized
World and Markets make it more and more important, also to commercial
products. And many like Borland already use Mylyn anyway.
Werner
> Hello Werner,
> I had a look at Babel-project website and that really caught my
> interest. If Babel was used for Internationalization of Mylyn, it would
> be of particular interest of how far this project is currently matured?
> Can you please give me a hint. What is the current status of the
> project? And what are the plans (schedule) for a release?
> Can I have a look on the current proceedings? I didn't find the link to
> source-code (CVS) or whatever place where I can get it.
> Thank you very much,
> Christian
Re: Internationalization of Labels, Messages etc. [message #43127 is a reply to message #41855] |
Tue, 12 February 2008 21:32 |
Hi Werner,
All this sounds great and I would love to see Mylyn available in other
languages for 3.0. Regarding using Mylyn as a tool for the
translations, yes, I definitely think that it would be useful,
especially if the corresponding tasks are already in Bugzilla.
To support Babel efforts, do we need to do anything other than the
following:
215116: externalize Mylyn UI Strings, Labels, Messages to support
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215116
Mik
Werner Keil wrote:
> Mik,
> and
> Werner
Re: Internationalization of Labels, Messages etc. [message #586887 is a reply to message #40543] |
Member |
Hello Maarten,
Christian
> OK Christian,
> gather votes.
> Maarten
>> cheers, Chris
Re: Internationalization of Labels, Messages etc. [message #586913 is a reply to message #40881] |
Maarten
> Hello Maarten,
> Christian
>> OK Christian,
>> gather votes.
>> Maarten
>>> within Mylyn.
>>> cheers, Chris
Re: Internationalization of Labels, Messages etc. [message #586963 is a reply to message #40944] |
Mik Kersten Messages: 287 Registered: July 2009 |
Christian,
Mik
> Maarten
>> Hello Maarten,
>> Christian
>>> OK Christian,
>>> gather votes.
>>> Maarten
>>>> within Mylyn.
>>>> cheers, Chris
Re: Internationalization of Labels, Messages etc. [message #587215 is a reply to message #41069] |
Mik,
and
Werner
Mik Kersten wrote:
> Christian,
> Mik
>> Maarten
>>> Hello Maarten,
>>> Christian
>>>> OK Christian,
>>>> an gather votes.
>>>> Maarten
>>>>> within Mylyn.
>>>>> own translations.
>>>>> cheers, Chris
Re: Internationalization of Labels, Messages etc. [message #587321 is a reply to message #41947] |
Hello Chris,
Werner
> Hello Werner,
> Christian
Re: Internationalization of Labels, Messages etc. [message #587743 is a reply to message #41855] |
Hi Werner,
following:
Mik
Werner Keil wrote:
> Mik,
> and
> Werner
Current Time: Tue Apr 23 06:17:08 GMT 2024
Powered by FUDForum. Page generated in 0.05267 seconds
