Re: Task Synchronization [message #41038 is a reply to message #40266] |
Sat, 12 January 2008 00:21 |
Originally posted by: beatmik.acm.org
Hi Chris,
Please send this question to the mylyn-integrators list.
http://www.eclipse.org/mylyn/community/
Mik
Chris wrote:
> using Mylyn for my tasks in a DB-based application, I wrote my own
> connector and TaskEditor for it following the instructions on Mylyn
> Integrator Reference and looking at TracConnector. I tried to avoid
> TaskData (and -Handler) because I always have DB-connection open.
> Now I'm stuck with the following problems (I will describe only briefly
> the cirumstances in order to keep it short):
> 1) Calling TaskList.notifyTaskChanged(), some attribute changes in
> TaskEditor are not reflected in TaskList (Summary is, Priority-! is not).
> ? How can I asure/force these changes to be shown in TaskList, do I have
> to set some dirty-attribute?
> 2) When changing task attributes in TaskListView with context menue
> (e.g. Schedule->...) these changes are kept local but not
> forwarded/stored into Database. When opening TaskEditor, task is read
> from DB again and changes get lost. ? Is Synchronization only one-way
> DB->local?
> Do I have to store these changes manually? Where do I best hook my code
> (e.g. as ChangeListener in TaskList?)
> Or do I get this automatically if I implement TaskDataHandler and use
> TaskData?
> btw: updateOfflineState (AbstractRepositoryConnector) mentioned in
> Mylyn_Integrator_Reference section Implementing core extension points
> doesn't exist (anymore).
> I would be very thankful for any Tipp that improves my understanding of
> Mylyn and helps me solving these issues.
> Chris
FUDForum. Page generated in 0.01821 seconds
