newest integration build and Eclipse 2.2M1: not able to open genmodel editor [message #395345] |
Tue, 30 August 2005 16:07 |
Originally posted by: philipp.kutter.org
Does anyone have the same problem? I get the error
java.lang.ClassNotFoundException:
org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1248)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:243)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:239)
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:252)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:837)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:533)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:355)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 5)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:141)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:387)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1131)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1084)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 91)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:441)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:110 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:60)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:214)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:204)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:753)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:665)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:628)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2323)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2258)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2250)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2236)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2231)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:279)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:271)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:178)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:868)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3137)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2765)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1734)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1698)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Best, Philipp
Re: newest integration build and Eclipse 2.2M1: not able to open genmodel editor [message #395351 is a reply to message #395346] |
Tue, 30 August 2005 19:53 |
Hi, Ed.
You are completly right. After reloading and regenerating
a dozend EMF projects, I forgot that one...
Sorry,
Best,
Philipp
Ed Merks wrote:
> Philipp,
> Maybe you have to run with -clean after updating your installation?
>> at
>> at
>> at
>> at java.lang.ClassLoader.loadClass(Unknown Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> Best, Philipp
FUDForum. Page generated in 0.05318 seconds
