Home » Modeling » EMF » missing emf icons for product export
Re: missing emf icons for product export [message #395206 is a reply to message #395202] |
Mon, 22 August 2005 21:48 |
Ed Merks Messages: 33141 Registered: July 2009 |
Michael,
EMF expects the folder to be called "icons". When it generates icons
for plugins, that what it uses. Is that a typo? Perhaps you have two
folders with slightly different names and you're either getting from one
folder or the other folder but not both folders?
Michael Illgner wrote:
> Ed Merks wrote:
>> Michael,
>> Is this maybe related to
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=107519? Loading icons
>> for RCP should be no different than loading icons regularly. When
>> you say the icons are in the plugin jar, do you mean you have a
>> jarred plugin, i.e, the whole plugin is a jar?
> Yes,
> the product export generated most plugins as single jars.
> After changing/overriding EMFPlugin.dogetImage() to use an URL from
> the Bundle (Bundle.getEntry("icon/MyIcon.gif")) our custom images got
> loaded, but the icon for the popup menu (little triangle) is still
> missing and I cannot reproduce this with the rcp mail template
> application..., some other icons are missing too, like the icon for
> the "Help Contents" menu.
Ed Merks
Re: missing emf icons for product export [message #395454 is a reply to message #395451] |
Thu, 08 September 2005 14:06 |
--------------090001060100040507060504
Michael,
Your problem is kind of a mystery to me. Clearly all this works for all
our own plugins and this is the first time I've seen an issue like this
in years of it working like this. It's probably worth while to look at
how your plugin structure differs from the ones for which all this works
correctly. Since the base URL is computed by
getBundle().getEntry("/")
what you show and what we already do should produce the same result.
(You have been running with -clean to be sure configuration changes are
picked up, right?)
How things are exported depends on how you've declared your jar in the
plugin.xml/MANIFEST.MF and (I believe) on the build.properties file.
> Ed Merks wrote:
>> Michael,
>> two folders with slightly different names and you're either getting
>> from one folder or the other folder but not both folders?
> Hi Ed,
> Sorry for the late answer,
> the problem seems to be still there, let me recall it
> We have a so called model plugin with all stuff related to EMF.
> All works fine when we start out application from eclipse, but after
> the product export the icons and resource texts are missing (not found).
> The model plugin gets exported to a single jar (btw. how can we change
> this ?)
> When we override the method EMFPlugin.dogetImage() in our model plugin
> class to use the bundle URL like
> protected Object doGetImage(String key) throws IOException {
> URL url = Platform.getBundle(PLUGIN_ID).getEntry("icons/" + key
> + ".gif");
> InputStream inputStream = url.openStream();
> inputStream.close();
> return url;
> we get our icons back, a similar method has to be changed for resource
> texts. Is this a bug ?
> BTW.
> We are using EMF 2.1
> Michael
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Michael,<br>
<br>
all our own plugins and this is the first time I've seen an issue like
this in years of it working like this. It's probably worth while to
look at how your plugin structure differs from the ones for which all
this works correctly. Since the base URL is computed by <br>
<blockquote>getBundle().getEntry("/")<br>
</blockquote>
picked up, right?)<br>
<br>
plugin.xml/MANIFEST.MF and (I believe) on the build.properties file.<br>
<br>
<br>
<blockquote cite="middfov0s$9iv$1@news.eclipse.org" type="cite">Ed
Merks wrote:
<br>
<blockquote type="cite">Michael,
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
Hi Ed,
<br>
<br>
<br>
<br>
found).
<br>
this ?)
<br>
<br>
<br>
<br>
URL url = Platform.getBundle(PLUGIN_ID).getEntry("icons/" + key +
".gif");
<br>
<br>
<br>
return url;
<br>
<br>
<br>
<br>
<br>
BTW.
<br>
<br>
<br>
Michael
<br>
</blockquote>
<br>
</body>
</html>
--------------090001060100040507060504--
Ed Merks
Current Time: Thu Apr 25 16:05:36 GMT 2024
Powered by FUDForum. Page generated in 0.04082 seconds
