Re: How to get the position in the XML file where a validation error occures? [message #392935 is a reply to message #392934] |
Wed, 18 May 2005 10:12 |
Ed Merks Messages: 33141 Registered: July 2009 |
Michael,
No, not directly. An in memory model instance may not even have come
from an XML file or may have been just created and never been saved to
an XML file yet. I know some folks have written code to associate line
numbers while parsing (since the XMLHandler can know about the line
number at the point that it creates each object). That would be an
interesting load option which could be used if you immediately validate
the model to give feedback in terms of line numbers. I could imagine
recording line numbers while saving too. I suppose line number tracking
would be an interesting feature request...
Michael Scharf wrote:
> we are using models in an makefile based build process.
> This calls a java program that uses emf to read some xml files.
> Normally the model validation is done in the UI. However,
> some command-line customers are using emacs/vi to edit
> the xml files directlt. The java program is using EMF to
> validate xml file.
> Is there a way to spit out the position in the XML file
> where the validation error occured?
> This would also be interesting for a multi page editor
> that shows a page with the xml code.
> Michael
Ed Merks
FUDForum. Page generated in 0.03460 seconds
