Re: Changes in mutable objects not detected [message #467871 is a reply to message #390598] |
Mon, 03 August 2009 09:06  |
Sabine Heider Messages: 8 Registered: July 2009 |
Hi James!
You wrote:
> For dates you can set the persistence property,
> "eclipselink.temporal.mutable"="true"
Thanks, that's what I was looking for - and it works as expected.
> For the byte array you can mark the mapping as mutable using @Mutable.
I tried this out and it worked for a byte[] array. However, I tested it
also on the other array types that are supported according to the JPA
spec, i.e. Byte[], char[] and Character[], and it failed on all of them.
That's not limiting me, actually, as I have only a use case for the
byte[] array (I haven't seen the other array types in real-life
applications so far). Still, I wanted to mention it.
It would be much nicer, though, to have a global switch like the one for
the temporal types. It would be more consistent and would reduce the
effort when porting _many_ applications.
Sabine
FUDForum. Page generated in 0.02181 seconds
