Home » Eclipse Projects » EclipseLink » Generics and Eclipselink
Generics and Eclipselink [message #389737] Thu, 25 June 2009 12:19 Go to next message
Enrico is currently offline EnricoFriend
Member
Hi all. I am new in EclipseLink, so I hope my question wiil be not too
dummy :-)
I would like to know if there is an easy way to use generics and
eclipselink jpa in order to implement DAO for generics object. I know for
example that using Hibernate there is an HibernateDaoSupport that allow to
handle this. Is this possible using also eclipselink?
To be more clear, i would like to have something similar to
http://blog.grumblesmurf.org/2007/10/generics-makes-daos-eas y.html
but using eclipselink ORM.
Best Regards,
Enrico
Re: Generics and Eclipselink [message #389745 is a reply to message #389737] Thu, 25 June 2009 14:19 Go to previous message
James Sutherland is currently offline James SutherlandFriend
Should be pretty simple to do this.
Something like:
public abstract class BaseDAOJPA<T>
implements BaseDAO<T> {
public void save(T object) {
getEntityManager().merge(object);
public T get(Serializable id) {
return getEntityManager().find(getModelClass(), id);
public void remove(T object) {
getEntityManager().remove(object);
public void remove(Serializable id) {
remove(get(id));
@SuppressWarnings("unchecked")
public List<T> loadAll() {
return getEntityManager().createQuery("Select o from " +
getModelClass().getSimpleName() + " o");
protected abstract Class<T> getModelClass();
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog : Twitter
Previous Topic:remove not removing
Next Topic:Order of persit operations not preserved?
Current Time: Fri May 29 16:33:25 GMT 2020
Powered by FUDForum. Page generated in 0.01459 seconds
