Home » Modeling » EMF » failed to read genmodel
failed to read genmodel [message #389593] Mon, 29 November 2004 14:34 Go to next message
Originally posted by: roger.wegner.web.de
I want to read library.genmodel programmatically and tried to read it
similar to reading library.ecore. The following succeeds:
Resource.Factory.Registry .put("ecore", new
XMIResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
this.resource =
resourceSet.getResource(URI.createURI("file:///D:/.../library.ecore"),
true);
But when I change this to
Resource.Factory.Registry .put("genmodel", new
this.resource =
resourceSet.getResource(URI.createURI("file:///D:/.../library.genmodel"),
true);
I receive an exception like:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'http://www.eclipse.org/emf/2002/GenModel' not found.
(file:///D:/.../library.genmodel, 7, 111)
Maybe the above approach is completely wrong. Can anybody give some hints?
Thanx,
Roger
Re: failed to read genmodel [message #389594 is a reply to message #389593] Mon, 29 November 2004 14:51 Go to previous messageGo to next message
Roger,
It sounds like you are trying to use the org.eclipse.emf.codegen.ecore
plugin while running stand alone, but that plugin is not designed to run
standalone, so you may not be able to get it to work. Accessing
GenModel.eINSTANCE before you try to parse will help. (Check out the
FAQ about running standalone.)
Roger Wegner wrote:
> new XMIResourceFactoryImpl());
> this.resource =
> true);
> this.resource =
> true);
> hints?
> Thanx,
> Roger
Re: failed to read genmodel [message #389597 is a reply to message #389594] Mon, 29 November 2004 15:54 Go to previous messageGo to next message
I try to generate some hibernate stuff (mapping files and other things)
with JET and hope to be able to use a GenModel instance similarly to
EMF's Class.javajet without depending on eclipse and/or it's plugins
(eclipse or plugin jar files in the classpath are ok for me).
It seems that GenModel and all those GenXXX classes provide the most
complete and convenient means to access all (or almost all) model
information for generating the mentioned things.
Do you think this is a feasible approach? Are there better alternatives?
Roger
Ed Merks wrote:
> Roger,
> Roger Wegner wrote:
>> Hi,
>> this.resource =
>> true);
>> this.resource =
>> true);
>> hints?
>> Thanx,
>> Roger
Re: failed to read genmodel [message #389598 is a reply to message #389597] Mon, 29 November 2004 17:44 Go to previous messageGo to next message
Roger,
Since the plugins aren't designed to run standalone, I think it will
probably not work.
Can't you just treat eclipse as a really big executable? ;-) I.e.,
can't you run it headless to provide a command line utility the way we
do for all our command line support?
> things) with JET and hope to be able to use a GenModel instance
> similarly to EMF's Class.javajet without depending on eclipse and/or
> it's plugins (eclipse or plugin jar files in the classpath are ok for
> me).
> Roger
> Ed Merks wrote:
>> Roger,
>> org.eclipse.emf.codegen.ecore plugin while running stand alone, but
>> that plugin is not designed to run standalone, so you may not be able
>> to get it to work. Accessing GenModel.eINSTANCE before you try to
>> parse will help. (Check out the FAQ about running standalone.)
>> Roger Wegner wrote:
>>> Hi,
>>> it similar to reading library.ecore. The following succeeds:
>>> this.resource =
>>> true);
>>> .put("genmodel", new XMIResourceFactoryImpl());
>>> this.resource =
>>> true);
>>> hints?
>>> Thanx,
>>> Roger
Re: failed to read genmodel [message #1856529 is a reply to message #389594] Wed, 14 December 2022 04:01 Go to previous messageGo to next message
Do you have pointers as to where I can find the FAQ about running standalone ?
Thanks.
Re: failed to read genmodel [message #1856533 is a reply to message #1856529] Wed, 14 December 2022 05:34 Go to previous message
To answer my own question, this is part of a bigger FAQ:
https://wiki.eclipse.org/EMF/FAQ#How_do_I_use_EMF_in_standalone_applications_.28such_as_an_ordinary_main.29.3F
HTH.
Previous Topic:load model from xmi file
Next Topic:modifying xmi model file
Current Time: Tue Apr 29 18:39:55 EDT 2025
Powered by FUDForum. Page generated in 0.07490 seconds
