Home » Eclipse Projects » EclipseLink » Trying to persist @Lob field throws NullPointerException
Re: Trying to persist @Lob field throws NullPointerException [message #389407 is a reply to message #389406] |
Fri, 05 June 2009 07:47 |
Torben Putkonen Messages: 34 Registered: July 2009 |
Member |
Here is a stack trace with changed class and package names. EclipseLink
1.1.1.
[EL Finer]: 2009-06-05
10:35:55.79--ServerSession(31945752)--Thread(Thread[RMICallH andler-5,5,HTTPThreadGroup])--client
acquired
10:35:55.79--UnitOfWork(26864146)--Thread(Thread[RMICallHand ler-5,5,HTTPThreadGroup])--TX
binding to tx mgr, status=STATUS_ACTIVE
[EL Finest]: 2009-06-05
10:35:55.79--UnitOfWork(26864146)--Thread(Thread[RMICallHand ler-5,5,HTTPThreadGroup])--PERSIST
operation called on: com.mypackage.entities.MyTable@1d66fa5.
10:35:55.791--ClientSession(20705522)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--Execute
query ValueReadQuery(sql="SELECT MY_IDSEQ.NEXTVAL FROM DUAL")
10:35:55.791--ServerSession(31945752)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--reconnecting
to external connection pool
[EL Fine]: 2009-06-05
10:35:55.792--ServerSession(31945752)--Connection(25739042)- -Thread(Thread[RMICallHandler-5,5,HTTPThreadGroup])--SELECT
10:35:55.793--ServerSession(31945752)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--sequencing
preallocation for MY_IDSEQ: objects: 50 , first: 1,451, last: 1,500
10:35:55.794--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--assign
sequence to the object (1,451 -> com.mypackage.entities.MyTable@1d66fa5)
10:35:55.794--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--TX
beforeCompletion callback, status=STATUS_ACTIVE
10:35:55.794--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--begin
unit of work commit
10:35:55.794--ClientSession(20705522)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--TX
beginTransaction, status=STATUS_ACTIVE
10:35:55.795--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--Execute
query InsertObjectQuery(com.mypackage.entities.MyTable@1d66fa5)
10:35:55.798--ClientSession(20705522)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--reconnecting
10:35:55.798--ClientSession(20705522)--Connection(12293884)- -Thread(Thread[RMICallHandler-5,5,HTTPThreadGroup])--INSERT
INTO MY_TABLE (ID, CONTENT) VALUES (?, ?)
bind => [1451, ]
10:35:55.844--ClientSession(20705522)--Connection(12293884)- -Thread(Thread[RMICallHandler-5,5,HTTPThreadGroup])--SELECT
CONTENT FROM MY_TABLE WHERE (ID = ?) FOR UPDATE
bind => [1451]
[EL Warning]: 2009-06-05
10:35:55.904--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--java.lang.NullPointerException
at
oracle.oc4j.sql.spi.ConnectionHandle.oc4j_getCachedObject(Co nnectionHandle.java:549)
at oracle_jdbc_driver_T4CConnection_Proxy.prepareStatement()
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.prepareStatement(DatabaseAccessor.java:1354)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.prepareStatement(DatabaseAccessor.java:1303)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseCall .prepareStatement(DatabaseCall.java:646)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.basicExecuteCall(DatabaseAccessor.java:551)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.executeCall(DatabaseAccessor.java:501)
at
org.eclipse.persistence.internal.helper.LOBValueWriter.build AndExecuteCall(LOBValueWriter.java:71)
at
org.eclipse.persistence.internal.helper.LOBValueWriter.build AndExecuteSelectCalls(LOBValueWriter.java:182)
at
org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.flushSelectCalls(DatabaseAccessor.java:135)
at
org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.insertObject(DatasourceCallQueryMechanism.java:350 )
at
org.eclipse.persistence.internal.queries.StatementQueryMecha nism.insertObject(StatementQueryMechanism.java:162)
at
org.eclipse.persistence.internal.queries.StatementQueryMecha nism.insertObject(StatementQueryMechanism.java:177)
at
org.eclipse.persistence.internal.queries.DatabaseQueryMechan ism.insertObjectForWrite(DatabaseQueryMechanism.java:461)
at
org.eclipse.persistence.queries.InsertObjectQuery.executeCom mit(InsertObjectQuery.java:80)
at
org.eclipse.persistence.queries.InsertObjectQuery.executeCom mitWithChangeSet(InsertObjectQuery.java:90)
at
org.eclipse.persistence.internal.queries.DatabaseQueryMechan ism.executeWriteWithChangeSet(DatabaseQueryMechanism.java:28 6)
at
org.eclipse.persistence.queries.WriteObjectQuery.executeData baseQuery(WriteObjectQuery.java:58)
at
org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:664)
at
org.eclipse.persistence.queries.DatabaseQuery.executeInUnitO fWork(DatabaseQuery.java:583)
at
org.eclipse.persistence.queries.ObjectLevelModifyQuery.execu teInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery. java:109)
at
org.eclipse.persistence.queries.ObjectLevelModifyQuery.execu teInUnitOfWork(ObjectLevelModifyQuery.java:86)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2755)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1181)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1165)
at
org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1125)
at
org.eclipse.persistence.internal.sessions.CommitManager.comm itNewObjectsForClassWithChangeSet(CommitManager.java:195)
at
org.eclipse.persistence.internal.sessions.CommitManager.comm itAllObjectsWithChangeSet(CommitManager.java:103)
at
org.eclipse.persistence.internal.sessions.AbstractSession.wr iteAllObjectsWithChangeSet(AbstractSession.java:3175)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitToDatabase(UnitOfWorkImpl.java:1298)
at
org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:468)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1398)
at
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.iss ueSQLbeforeCompletion(UnitOfWorkImpl.java:3022)
at
org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.issueSQLbeforeCompletion(RepeatableWriteUnitOfWork.j ava:224)
at
org.eclipse.persistence.transaction.AbstractSynchronizationL istener.beforeCompletion(AbstractSynchronizationListener.jav a:157)
at
org.eclipse.persistence.transaction.JTASynchronizationListen er.beforeCompletion(JTASynchronizationListener.java:68)
at
com.evermind.server.ApplicationServerTransaction.callBeforeC ompletion(ApplicationServerTransaction.java:1066)
at
com.evermind.server.ApplicationServerTransaction.doCommit(Ap plicationServerTransaction.java:275)
at
com.evermind.server.ApplicationServerTransaction.commit(Appl icationServerTransaction.java:162)
at
com.evermind.server.ApplicationServerTransactionManager.comm it(ApplicationServerTransactionManager.java:472)
at com.mypackage.MyBean.doTheDeed(MyBean.java:104)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
com.evermind.server.ejb.interceptor.joinpoint.EJBJoinPointIm pl.invoke(EJBJoinPointImpl.java:35)
at
com.evermind.server.ejb.interceptor.InvocationContextImpl.pr oceed(InvocationContextImpl.java:119)
at
com.evermind.server.ejb.interceptor.system.SetContextActionI nterceptor.invoke(SetContextActionInterceptor.java:44)
at
at
com.evermind.server.ejb.interceptor.system.DMSInterceptor.in voke(DMSInterceptor.java:52)
at
at
com.evermind.server.ejb.interceptor.system.TxBeanManagedInte rceptor.invoke(TxBeanManagedInterceptor.java:53)
at
at
at
at
com.evermind.server.ejb.InvocationContextPool.invoke(Invocat ionContextPool.java:55)
at
com.evermind.server.ejb.StatelessSessionEJBObject.OC4J_invok eMethod(StatelessSessionEJBObject.java:87)
at
OrganizationUpdater_RemoteProxy_1d98pf4.updateOrganizations( Unknown Source)
at
at
at com.evermind.server.rmi.RmiMethodCall.run(RmiMethodCall.java :53)
at
com.evermind.util.ReleasableResourcePooledExecutor$MyWorker. run(ReleasableResourcePooledExecutor.java:303)
at java.lang.Thread.run(Thread.java:595)
10:35:55.906--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--java.lang.NullPointerException
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
10:35:55.907--UnitOfWork(26864146)--Thread(Thread[RMICallHan dler-5,5,HTTPThreadGroup])--java.lang.NullPointerException
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at MyBean_RemoteProxy_1d98pf4.doTheDeed(Unknown Source)
at
at
at
10:35:55.91--UnitOfWork(26864146)--Thread(Thread[RMICallHand ler-5,5,HTTPThreadGroup])--TX
afterCompletion callback, status=ROLLEDBACK
10:35:55.91--UnitOfWork(26864146)--Thread(Thread[RMICallHand ler-5,5,HTTPThreadGroup])--release
unit of work
10:35:55.911--ClientSession(20705522)--Thread(Thread[RMICall Handler-5,5,HTTPThreadGroup])--client
released
Re: Trying to persist @Lob field throws NullPointerException [message #389417 is a reply to message #389406] |
Tue, 09 June 2009 13:49 |
The null pointer is occurring in the JDBC driver. The issue seems to be
related to EclipseLink Oracle thin JDBC driver Lob support. In order to
workaround the drivers 4k size limit, we insert an empty Lob and then
select it back to populate it. This requires access to Oracle JDBC
specific syntax so we unwrap the DataSource connection to get the real
JDBC connection instance. This seems to be related to the issue.
What version of OC4J are you using? Are you setting your ServerPlatform
to OC4J in your persistence.xml? What database platform are you using,
Oracle or Oracle9Platform? Are you using the thin or OCI driver?
If you Lob works without the @Lob annotation (maybe up to 4k?), then you
could probably just use the OraclePlatform instead of the Oracle9Platform
to avoid the issue. You might also look into the unwrap method in your
ServerPlatform.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog : Twitter
Current Time: Wed Apr 24 23:55:29 GMT 2024
Powered by FUDForum. Page generated in 0.03130 seconds
