Home » Modeling » EMF » about loadResource issue
about loadResource issue [message #388713] |
Wed, 20 October 2004 11:12 |
Originally posted by: tranfy.hotmail.com
We have a project developed in eclipse 2.1 and background model
generated by emf 1.1. Now we migrate the project to eclipse 3.0
environment and still use the inital model. But in our development
environment, there are eclipse 3.0 ,gef 3.0 and emf 2.0. That is to say,
we use emf 2.0 to access our model generated by emf 1.1 and get the model
properties.
In our program ,there is a statement
Resource resource =
editingDomain.loadResource(
URI
.createPlatformResourceURI(
modelFile.getFile().getFullPath().toString())
.toString());
In eclipse 2.1 ,emf 1.1 and gef 2.1 environment ,the above code can
successfully run and get the correct resource. But in eclipse 3.0 ,emf 2.0
and gef3.0 environment , the resource got from above code is null.
I can get little docs about resource modification of emf1.1 migrated to
emf2.0.
Can you show me how to get the resource correctly ?
Thank you advance!
Re: about loadResource issue [message #388717 is a reply to message #388713] |
Wed, 20 October 2004 12:03 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------050803020508050308080804
Demi,
The loadResource method is implemented like this:
public Resource loadResource(String fileNameURI)
try
Resource resource =
resourceSet.getResource(URI.createURI(fileNameURI), true);
return resource;
catch (Exception exception)
EMFEditPlugin.INSTANCE.log(exception);
return null;
So if you are seeing null, there will be a logged exception. Without
seeing what that exception is, I can't offer any useful advice (because
it should just continue to work as before).
>properties.
> Resource resource =
> URI
> .toString());
>emf2.0.
> Thank you advance!
<html>
<head>
http-equiv="Content-Type">
</head>
Demi,<br>
<br>
The loadResource method is implemented like this:<br>
<blockquote>
Ed Merks
Re: about loadResource issue [message #388736 is a reply to message #388717] |
Thu, 21 October 2004 01:17 |
Hi Ed,
In our com.viador.datatype.impl package ,which extends EFactoryImpl, there
is a method named createColorFromString as follows:
public Color createColorFromString(EDataType eDataType, String
initialValue) {
return (Color)super.createFromString(eDataType, initialValue);
The exception is like that:
at
org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFa ctoryImpl.java:369)
at
com.viador.datatype.impl.DatatypeFactoryImpl.createColorFrom String(DatatypeFactoryImpl.java:130)
at
com.viador.datatype.impl.DatatypeFactoryImpl.createFromStrin g(DatatypeFactoryImpl.java:64)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createFromStrin g(XMLHelperImpl.java:1090)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:768)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:1695)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:1754)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:147)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:1339)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1265)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1202)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1041)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:441)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:65)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:424)
at
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startElement(SAXWr apper.java:75)
at org.apache.crimson.parser.Parser2.maybeElement(Parser2.java: 1674)
Ed Merks wrote:
> Demi,
> try
> Resource resource =
> return resource;
> return null;
> >properties.
> > Resource resource =
> > URI
> > .toString());
> >emf2.0.
> > Thank you advance!
Re: about loadResource issue [message #388743 is a reply to message #388736] |
Thu, 21 October 2004 10:52 |
--------------080302020808050103030302
Demi,
I would have expected you to have an override for creating a Color from
a String. It doesn't look like any of the reflective algorithms can be
successful, and there is a (new) bug in the code when it tries to throw
an exception at the end of the method (because it just can't do it
reflectively). It would be far more efficient to write the explicit
code to do the conversion.
Please open a bugzilla showing this stack trace, and we'll fix the null
pointer problem, but note that I don't think that will actually fix your
problem it will just fail more gracefully.
Demi wrote:
>Hi Ed,
>initialValue) {
>java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>Ed Merks wrote:
>>Demi,
>> try
>> Resource resource =
>> return resource;
>> return null;
>>>properties.
>>> Resource resource =
>>> URI
>>> .toString());
>>>emf2.0.
>>>Thank you advance!
<html>
<head>
<title></title>
</head>
Demi,<br>
<br>
a String.
Ed Merks
Current Time: Thu Apr 25 15:59:56 GMT 2024
Powered by FUDForum. Page generated in 0.02720 seconds
