Home » Archived » Buckminster » relative paths to RMAP in CQUERY?
relative paths to RMAP in CQUERY? [message #387391] Fri, 03 July 2009 14:26 Go to next message
What is the base location for a relative path in CQUERY for resourceMap
file uri?
I am confused, because when I specify the uri as a simple file name, I
expect the Buckminster would pick it up from the same folder as .cquery
file itself. However - this does not seem to be the case.
Re: relative paths to RMAP in CQUERY? [message #387392 is a reply to message #387391] Fri, 03 July 2009 15:43 Go to previous messageGo to next message
Roland Tepp wrote:
> file uri?
That would be the location used when obtaining the CQUERY.
It should be. How did you open the CQUERY? I can see one case where it would not work and that is if
you type in a URL in the File Dialog on a Windows box. The reason that doesn't work is that Windows
first downloads the file and then passes the location of the temporary file to Buckminster. That
location is of course no good but unfortunately there's no way of telling that windows changed it.
If you however use the "File" -> "Open a Component Query..." or the headless import command, there
should be no such problem.
HTH,
Thomas Hallgren
Re: relative paths to RMAP in CQUERY? [message #387395 is a reply to message #387392] Mon, 06 July 2009 08:53 Go to previous messageGo to next message
3.07.2009 18:43, Thomas Hallgren kirjutas:
> Roland Tepp wrote:
>> Hi,
>> resourceMap file uri?
>> .cquery file itself. However - this does not seem to be the case.
> would not work and that is if you type in a URL in the File Dialog on a
> Windows box. The reason that doesn't work is that Windows first
> Buckminster. That location is of course no good but unfortunately
> headless import command, there should be no such problem.
> HTH,
> Thomas Hallgren
well.. I pressed the "Materialize to Wizard" button in the CQUERY editor...
Re: relative paths to RMAP in CQUERY? [message #387396 is a reply to message #387395] Mon, 06 July 2009 09:30 Go to previous messageGo to next message
>> Roland Tepp wrote:
>>> Hi,
>> HTH,
>> Thomas Hallgren
My question was, how did you open the CQUERY editor? The base URL is determined at that time.
Thomas Hallgren
Re: relative paths to RMAP in CQUERY? [message #387397 is a reply to message #387396] Mon, 06 July 2009 11:10 Go to previous messageGo to next message
from within the workspace.
> Regards,
> Thomas Hallgren
Re: relative paths to RMAP in CQUERY? [message #387398 is a reply to message #387396] Mon, 06 July 2009 11:11 Go to previous messageGo to next message
Oh yes,
I tried to (re)open the same file with File->Open... and then it worked
just fine...
>>> HTH,
>>> Thomas Hallgren
>> editor...
> Regards,
> Thomas Hallgren
Re: relative paths to RMAP in CQUERY? [message #387399 is a reply to message #387398] Mon, 06 July 2009 11:35 Go to previous messageGo to next message
Hi Roland,
I seem to recall that Buckminster had a bug some time back that caused files opened from the workspace to have an
incorrect base. It's been fixed since though. Can you please tell me what version you are using?
Thomas Hallgren
Roland Tepp wrote:
> Oh yes,
> just fine...
>>>> HTH,
>>>> Thomas Hallgren
>>> editor...
>> Regards,
>> Thomas Hallgren
Re: relative paths to RMAP in CQUERY? [message #387400 is a reply to message #387399] Mon, 06 July 2009 11:57 Go to previous messageGo to next message
The version of the Buckminster feature is 1.1.350.r10382
(downloaded with Yoxos Install Manager)
6.07.2009 14:35, Thomas Hallgren kirjutas:
> Hi Roland,
> files opened from the workspace to have an incorrect base. It's been
> Regards,
> Thomas Hallgren
> Roland Tepp wrote:
>> Oh yes,
>> worked just fine...
>>>>> HTH,
>>>>> Thomas Hallgren
>>>> editor...
>>> Regards,
>>> Thomas Hallgren
Re: relative paths to RMAP in CQUERY? [message #387401 is a reply to message #387400] Mon, 06 July 2009 12:06 Go to previous messageGo to next message
OK, very odd in that case. That version shouldn't have that problem. You just double-click on a cquery to open it? Can
you please enable DEBUG logging (Window -> Preferences -> Buckminster -> "Console Log level" -> DEBUG). With debug on,
you should see a text saying "CQUERY Context URL set to ..." in the console window. I'm interested in what it says when
you have the problem.
Thomas Hallgren
>> Hi Roland,
>> Regards,
>> Thomas Hallgren
>> Roland Tepp wrote:
>>> Oh yes,
>>> worked just fine...
>>>>>> HTH,
>>>>>> Thomas Hallgren
>>>>> editor...
>>>> Regards,
>>>> Thomas Hallgren
Re: relative paths to RMAP in CQUERY? [message #387643 is a reply to message #387401] Mon, 06 July 2009 14:28 Go to previous message
6.07.2009 15:06, Thomas Hallgren kirjutas:
> just double-click on a cquery to open it? Can you please enable DEBUG
> DEBUG). With debug on, you should see a text saying "CQUERY Context URL
The path is okay now ... I don't know what changed, but it seems to work
now...
.... trying on a brand new workspace...
.... works ... It might have been a typo on my part...
Previous Topic:The Bucky Book 0.2 rough cut is available
Next Topic:Buckminster 3.5 install issues
Current Time: Fri Feb 14 22:43:11 GMT 2025
Powered by FUDForum. Page generated in 0.03521 seconds
