Home » Archived » XML Schema Definition (XSD) » redefine
redefine [message #39443] |
Tue, 23 March 2004 23:20 |
Originally posted by: jtaylor.nextance.com
If I understand the W3C spec correctly, a redefined complexType should be
used everywhere in place of the original type. For example, if I use the
redefined complexType as a base type for another type, the derived type
should now include the additional elements introduced by the redefined
type. This is not the behavior I'm seeing in Eclipse XSD. When I get the
base type, using complexTypeDefinition.getBaseType(), I continue to get
the original definition instead of the redefined one. References to the
type within the schema that has the redefine do point to the new redefined
type, though. Is this intentional? Should I use a different mechanism to
get the base type? Or is this a bug?
James
Re: redefine [message #39474 is a reply to message #39443] |
Wed, 24 March 2004 00:00 |
James,
I'm not sure I can really answer the details of your questions without clear
references to particular components in actual schema documents, i.e., a
sample. Perhaps it helps to explain that redefinition is accomplished by
making a clone of the schema being redefined and then modifying that copy
according to the redefinition. The original schema is not touched; it may be
redefined many times in many different ways. The schema containing the
redefine will see only the copy, not the original. Which version you get will
depend very much on where you ask, so you need to be specific...
James Taylor wrote:
> Hello,
> James
Re: redefine [message #39505 is a reply to message #39474] |
Wed, 24 March 2004 00:38 |
Ed,
Thanks for the reply. My sample is below. In v4.xsd, I would have
expected that the "marriedPeople" element would contain the "generation"
element since it is redefined to include this in v2.xsd. The
"singlePeople" element does include the "generation" element as expected.
James
v1.xsd:
<xs:schema targetNamespace="http://namespaces.nextance.com/nex/test"
xmlns:test="http://namespaces.nextance.com/nex/test"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="unqualified" attributeFormDefault="unqualified">
<xs:complexType name="personName">
<xs:sequence>
<xs:element name="title" type="xs:string" minOccurs="0"/>
<xs:element name="forename" type="xs:string" minOccurs="0"
maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
<xs:element name="addressee" type="test:personName"/>
</xs:schema>
v2.xsd:
<xs:redefine schemaLocation="v1.xsd">
<xs:complexContent>
<xs:extension base="test:personName">
<xs:sequence>
<xs:element name="generation" type="xs:string" minOccurs="0"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:redefine>
<xs:element name="author" type="test:personName"/>
</xs:schema>
v3.xsd:
<xs:include schemaLocation="v1.xsd"/>
<xs:complexType name="marriedPersonName">
<xs:complexContent>
<xs:sequence>
<xs:element name="maidenName" type="xs:string" minOccurs="0"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:element name="marriedPerson" type="test:marriedPersonName"/>
</xs:schema>
v4.xsd:
<xs:include schemaLocation="v2.xsd"/>
<xs:include schemaLocation="v3.xsd"/>
<xs:complexType name="people">
<xs:sequence>
<xs:element name="marriedPeople" type="test:marriedPersonName"
<xs:element name="singlePeople" type="test:personName"
</xs:sequence>
</xs:complexType>
<xs:element name="directory" type="test:people"/>
</xs:schema>
Ed Merks wrote:
> James,
> James Taylor wrote:
> > Hello,
> > Thanks,
> > James
Re: redefine [message #39536 is a reply to message #39505] |
Wed, 24 March 2004 12:57 |
James,
The v4.xsd schema isn't valid because its includes both a redefined version of
personName and addressee, via its include of v2.xsd's redefinition of v1.xsd, as
well as the original version of personName and addressee, via its include of
v3.xsd's include of v1.xsd without redefinition. The v3.xsd schema needs to
include v2.xsd not v1.xsd for this example to be valid. The bottom line is that
v1.xsd is not modified by virtue of the redefine in v2.xsd; only v2.xsd sees that
redefinition directly and any schema importing or including v2.xsd will see that
redefinition indirectly; but v3.xsd sees only the original v1.xsd and knows nothing
of v2.xsd. When we get to v4.xsd, the result is name collision.
James Taylor wrote:
> Ed,
> James
> v1.xsd:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> v2.xsd:
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:redefine>
> </xs:schema>
> v3.xsd:
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
> v4.xsd:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Ed Merks wrote:
> > James,
> > James Taylor wrote:
> > > Hello,
> > > Thanks,
> > > James
Re: redefine [message #39780 is a reply to message #39536] |
Thu, 25 March 2004 02:09 |
Ed,
Thank you for the explanation. It's not clear to me how "pervasive" the
W3C spec
( http://www.w3.org/TR/2001/REC-xmlschema-1-20010502/#modify-s chema) meant
a redefine to be when they state:
The modifications have a pervasive impact, that is, only the redefined
components are used, even when referenced from other incorporated
components, whether redefined themselves or not.
Given that later in the spec they imply that multiple redefines of the
same type that conflict are not legal, I assume they meant that the
redefined type should "pervade" everywhere, including in my example of
v4.xsd.
James
Ed Merks wrote:
> James,
of
v1.xsd, as
that
that
that
nothing
> James Taylor wrote:
> > Ed,
> > Thanks,
> > James
> > v1.xsd:
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > v2.xsd:
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:redefine>
> > </xs:schema>
> > v3.xsd:
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:schema>
> > v4.xsd:
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > Ed Merks wrote:
> > > James,
clear
may be
will
> > > James Taylor wrote:
> > > > Hello,
be
the
the
the
redefined
mechanism to
> > > > Thanks,
> > > > James
Re: redefine [message #39811 is a reply to message #39780] |
Thu, 25 March 2004 11:37 |
James,
All the components of the schema mentioned in the redefine are incorporated (i.e.,
cloned) and the redefinitions are pervasively applied to all the components in that
clone. Note that if the schema being redefined has a null target namespace, it may
be redefined in multiple schemas each with a different namespace and each in a
different way; in this case, during incorporation, the namespace of the clone is
modified to match the namespace of the redefining schema and the other redefinition
modifications are applied as well. In any event, the original schema remains
untouched so that it can and will be reused in its pristine form when referenced
directly.
James Taylor wrote:
> Ed,
> W3C spec
> v4.xsd.
> James
> Ed Merks wrote:
> > James,
> of
> v1.xsd, as
> that
> that
> that
> nothing
> > James Taylor wrote:
> > > Ed,
> > > Thanks,
> > > James
> > > v1.xsd:
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > v2.xsd:
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > </xs:schema>
> > > v3.xsd:
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:schema>
> > > v4.xsd:
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > Ed Merks wrote:
> > > > James,
> clear
> may be
> will
> > > > James Taylor wrote:
> > > > > Hello,
> be
> the
> the
> the
> redefined
> mechanism to
> > > > > Thanks,
> > > > > James
Re: redefine [message #39904 is a reply to message #39811] |
Thu, 25 March 2004 23:50 |
Ed,
Here's a smaller more realistic example that illustrates an issue:
File A defines Employee type
File B includes File A and defines Department type
File C includes File B, redefines Employee from File A and defines Company
type
This is a common use case for redefine in which a type in a nested include
needs to be redefined. With Eclipse XSD, the redefine does not affect the
Employee type within the Department type and affects the Employee type
within the Company type only if the include of File B precedes the
redefine of File A. This does not seem like the correct behavior.
I've included the XSD files below. Thanks,
James
Employee.xsd:
<xs:schema targetNamespace="http://namespaces.nextance.com/test"
xmlns:test="http://namespaces.nextance.com/test"
<xs:complexType name="Employee">
<xs:sequence>
<xs:element name="name" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
Department.xsd:
<xs:include schemaLocation="Employee.xsd"/>
<xs:complexType name="Department">
<xs:sequence>
<xs:element name="employee" type="test:Employee"
<xs:element name="manager" type="test:Employee"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
Company.xsd:
<xs:include schemaLocation="Department.xsd"/>
<xs:redefine schemaLocation="Employee.xsd">
<xs:complexContent>
<xs:extension base="test:Employee">
<xs:sequence>
<xs:element name="ranking" type="xs:int"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:redefine>
<xs:complexType name="Company">
<xs:sequence>
<xs:element name="department" type="test:Department"
<xs:element name="president" type="test:Employee"/>
</xs:sequence>
</xs:complexType>
<xs:element name="fortune500" type="test:Company" maxOccurs="500"/>
</xs:schema>
Ed Merks wrote:
> James,
(i.e.,
in that
it may
in a
clone is
redefinition
referenced
> directly.
> James Taylor wrote:
> > Ed,
> > W3C spec
> > v4.xsd.
> > James
> > Ed Merks wrote:
> > > James,
version
> > of
> > v1.xsd, as
include of
needs to
is
> > that
sees
> > that
see
> > that
knows
> > nothing
> > > James Taylor wrote:
> > > > Ed,
"generation"
expected.
> > > > Thanks,
> > > > James
> > > > v1.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > v2.xsd:
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > </xs:schema>
> > > > v3.xsd:
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > v4.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Ed Merks wrote:
> > > > > James,
without
> > clear
i.e., a
accomplished by
copy
it
> > may be
the
get
> > will
> > > > > James Taylor wrote:
> > > > > > Hello,
should
> > be
use
> > the
type
redefined
get
> > the
to get
to
> > the
> > redefined
> > mechanism to
> > > > > > Thanks,
> > > > > > James
Re: redefine [message #39976 is a reply to message #39904] |
Fri, 26 March 2004 18:27 |
--------------CEEB91C322B38F5CBD2D5836
Content-Type: text/plain; charset=us-ascii
James,
As I was fixing the Company.xsd to make it valid:
<xs:redefine schemaLocation="Department.xsd">
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:redefine>
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:element name="fortune500" type="test:Company"/>
</xs:schema>
I discovered that there is a bug that causes the transitive includes/redefines of a
cloned included/redefined schema to be omitted so I opened
https://bugs.eclipse.org/bugs/show_bug.cgi?id=56328 and have fixed that particular
problem. So, to my way of thinking, the above sample is the correct way to express
what you intended.
Consider the following slightly modified example where Employee.xsd has no
namespace:
<xs:schema
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
and Department.xsd is still the same (but the include is changing the null
namespace of the included schema to match that of the including schema):
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
In this case, a Company.xsd can validly access both the original version of
Employee as well as a redefined version.
<xs:import schemaLocation="Employee.xsd"/>
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:redefine>
<xs:sequence>
<xs:element name="dummy" type="Employee"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
The semantics view for this shows that everyone is using the redefined type, except
the junk element, which is using the original:
[Image]
This stuff is all really much too complicated for human minds to handle (and I
think there are still lurking bugs in the implementation, but I don't have any more
time to spend to look at this further).
James Taylor wrote:
> Ed,
> type
> James
> Employee.xsd:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Department.xsd:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Company.xsd:
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:redefine>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Ed Merks wrote:
> > James,
> (i.e.,
> in that
> it may
> in a
> clone is
> redefinition
> referenced
> > directly.
> > James Taylor wrote:
> > > Ed,
> > > W3C spec
> > > v4.xsd.
> > > James
> > > Ed Merks wrote:
> > > > James,
> version
> > > of
> > > v1.xsd, as
> include of
> needs to
> is
> > > that
> sees
> > > that
> see
> > > that
> knows
> > > nothing
> > > > James Taylor wrote:
> > > > > Ed,
> "generation"
> expected.
> > > > > Thanks,
> > > > > James
> > > > > v1.xsd:
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > v2.xsd:
> > > > > <xs:complexContent>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:extension>
> > > > > </xs:complexType>
> > > > > </xs:redefine>
> > > > > </xs:schema>
> > > > > v3.xsd:
> > > > > <xs:complexContent>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:extension>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > v4.xsd:
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > Ed Merks wrote:
> > > > > > James,
> without
> > > clear
> i.e., a
> accomplished by
> copy
> it
> > > may be
> the
> get
> > > will
> > > > > > James Taylor wrote:
> > > > > > > Hello,
> should
> > > be
> use
> > > the
> type
> redefined
> get
> > > the
> to get
> to
> > > the
> > > redefined
> > > mechanism to
> > > > > > > Thanks,
> > > > > > > James
Content-Type: multipart/related;
boundary="------------57AEC190E1D3D8E73CCE5127"
--------------57AEC190E1D3D8E73CCE5127
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
James,
<p>As I was fixing the Company.xsd to make it valid:
<blockquote><font size=-1><xs:schema targetNamespace="<A HREF="http://namespaces.nextance.com/test">http://namespaces.nextance.com/test</A>"</font>
<br><font size=-1>xmlns:test="<A HREF="http://namespaces.nextance.com/test">http://namespaces.nextance.com/test</A>"</font>
<br><font size=-1>xmlns:xs="<A HREF="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</A>"</font>
<br><font size=-1>elementFormDefault="unqualified" attributeFormDefault="unqualified"></font><font size=-1></font>
<p><font size=-1> <xs:redefine schemaLocation="Department.xsd"></font>
<br><font size=-1> <xs:complexType name="Employee"></font>
<br><font size=-1> <xs:complexContent></font>
<br><font size=-1> <xs:extension
base="test:Employee"></font>
<br><font size=-1>
<xs:sequence></font>
<br><font size=-1>
<xs:element name="ranking" type="xs:int"/></font>
<br><font size=-1>
</xs:sequence></font>
<br><font size=-1> </xs:extension></font>
<br><font size=-1> </xs:complexContent></font>
<br><font size=-1> </xs:complexType></font>
<br><font size=-1> </xs:redefine></font><font size=-1></font>
<p><font size=-1> <xs:complexType name="Company"></font>
<br><font size=-1> <xs:sequence></font>
<br><font size=-1> <xs:element name="department"
type="test:Department" maxOccurs="unbounded"/></font>
<br><font size=-1> <xs:element name="president"
type="test:Employee"/></font>
<br><font size=-1> </xs:sequence></font>
<br><font size=-1> </xs:complexType></font><font size=-1></font>
<p><font size=-1> <xs:element name="fortune500" type="test:Company"/></font><font size=-1></font>
<p><font size=-1></xs:schema></font></blockquote>
of a cloned included/redefined schema to be omitted so I opened <a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=56328">https://bugs.eclipse.org/bugs/show_bug.cgi?id=56328</a>
and have fixed that particular problem. So, to my way of thinking, the
above sample is the correct way to express what you intended.
<p>Consider the following slightly modified example where Employee.xsd
has no namespace:
<blockquote><font size=-1><xs:schema</font>
<br><font size=-1> <xs:element name="name"
type="xs:string"/></font>
<br><font size=-1></xs:schema></font></blockquote>
<br><font size=-1> <xs:include schemaLocation="Employee.xsd"/></font><font size=-1></font>
<p><font size=-1> <xs:complexType name="Department"></font>
<br><font size=-1> <xs:element name="employee"
type="test:Employee" maxOccurs="unbounded"/></font>
<br><font size=-1> <xs:element name="manager"
of Employee as well as a redefined version.
<p><font size=-1> <xs:import schemaLocation="Employee.xsd"/></font><font size=-1></font>
<br><font size=-1>
<br><font size=-1>
<br><font size=-1>
<br><font size=-1> <xs:element name="dummy"
type="Employee"/></font>
type, except the junk element, which is using the original:
<blockquote><img SRC="cid:part1.40647602.566D4349@ca.ibm.com" height=771 width=263></blockquote>
(and I think there are still lurking bugs in the implementation, but I
don't have any more time to spend to look at this further).
<br>
<p>James Taylor wrote:
<blockquote TYPE=CITE>Ed,
<p>Here's a smaller more realistic example that illustrates an issue:
<p>File A defines Employee type
<br>File B includes File A and defines Department type
<br>File C includes File B, redefines Employee from File A and defines
Company
<br>type
<p>This is a common use case for redefine in which a type in a nested include
<br>needs to be redefined. With Eclipse XSD, the redefine does not
affect the
<br>Employee type within the Department type and affects the Employee type
<br>within the Company type only if the include of File B precedes the
<br>redefine of File A. This does not seem like the correct behavior.
<p>I've included the XSD files below. Thanks,
<p> James
<p>Employee.xsd:
<br><xs:schema targetNamespace="<a href="http://namespaces.nextance.com/test">http://namespaces.nextance.com/test</a>"
<br>xmlns:test="<a href="http://namespaces.nextance.com/test">http://namespaces.nextance.com/test</a>"
<br>xmlns:xs="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>elementFormDefault="unqualified" attributeFormDefault="unqualified">
<br> <xs:complexType name="Employee">
<br> <xs:sequence>
<br> <xs:element name="name" type="xs:string"/>
<br> </xs:sequence>
<br> </xs:complexType>
<br></xs:schema>
<p>Department.xsd:
<br> <xs:include schemaLocation="Employee.xsd"/>
<p> <xs:complexType name="Department">
<br> <xs:sequence>
<br> <xs:element name="employee" type="test:Employee"
<br>maxOccurs="unbounded"/>
<br> <xs:element name="manager" type="test:Employee"/>
<br> </xs:sequence>
<br></xs:schema>
<p>Company.xsd:
<p> <xs:include schemaLocation="Department.xsd"/>
<p> <xs:redefine schemaLocation="Employee.xsd">
<br> <xs:complexContent>
<br> <xs:extension base="test:Employee">
<br> <xs:sequence>
<br>
<br> </xs:sequence>
<br> </xs:extension>
<br> </xs:complexContent>
<br> </xs:redefine>
<p> <xs:complexType name="Company">
<br> <xs:sequence>
<br> <xs:element name="department" type="test:Department"
<br> <xs:element name="president" type="test:Employee"/>
<br> </xs:sequence>
<p> <xs:element name="fortune500" type="test:Company" maxOccurs="500"/>
<p></xs:schema>
<p>Ed Merks wrote:
<p>> James,
<p>> All the components of the schema mentioned in the redefine are incorporated
<br>(i.e.,
<br>> cloned) and the redefinitions are pervasively applied to all the
components
<br>in that
<br>> clone. Note that if the schema being redefined has a null target
namespace,
<br>it may
<br>> be redefined in multiple schemas each with a different namespace
and each
<br>in a
<br>> different way; in this case, during incorporation, the namespace
of the
<br>clone is
<br>> modified to match the namespace of the redefining schema and the
other
<br>redefinition
<br>> modifications are applied as well. In any event, the original
schema remains
<br>> untouched so that it can and will be reused in its pristine form
when
<br>referenced
<br>> directly.
<p>> James Taylor wrote:
<p>> > Ed,
<br>> >
<br>> > Thank you for the explanation. It's not clear to me how "pervasive"
the
<br>> > W3C spec
<br>> > (<a href=" http://www.w3.org/TR/2001/REC-xmlschema-1-20010502/#modify-s chema"> http://www.w3.org/TR/2001/REC-xmlschema-1-20010502/#modify-s chema</a>)
meant
<br>> > a redefine to be when they state:
<br>> >
<br>> > The modifications have a pervasive impact,
<br>> > components are used, even when referenced
<br>> > components, whether redefined themselves
or not.
<br>> >
<br>> > Given that later in the spec they imply that multiple redefines
of the
<br>> > same type that conflict are not legal, I assume they meant that
the
<br>> > redefined type should "pervade" everywhere, including in my example
of
<br>> > v4.xsd.
<br>> >
<br>> > James
<br>> >
<br>> > Ed Merks wrote:
<br>> >
<br>> > > James,
<br>> >
<br>> > > The v4.xsd schema isn't valid because its includes both a redefined
<br>version
<br>> > of
<br>> > > personName and addressee, via its include of v2.xsd's redefinition
of
<br>> > v1.xsd, as
<br>> > > well as the original version of personName and addressee, via
its
<br>include of
<br>> > > v3.xsd's include of v1.xsd without redefinition. The v3.xsd
schema
<br>needs to
<br>> > > include v2.xsd not v1.xsd for this example to be valid.
The bottom line
<br>is
<br>> > that
<br>> > > v1.xsd is not modified by virtue of the redefine in v2.xsd; only
v2.xsd
<br>sees
<br>> > that
<br>> > > redefinition directly and any schema importing or including v2.xsd
will
<br>see
<br>> > that
<br>> > > redefinition indirectly; but v3.xsd sees only the original v1.xsd
and
<br>knows
<br>> > nothing
<br>> > > of v2.xsd. When we get to v4.xsd, the result is name collision.
<br>> >
<br>> > > James Taylor wrote:
<br>> >
<br>> > > > Ed,
<br>> > > >
<br>> > > > Thanks for the reply. My sample is below. In v4.xsd,
I would have
<br>> > > > expected that the "marriedPeople" element would contain the
<br>"generation"
<br>> > > > element since it is redefined to include this in v2.xsd.
The
<br>> > > > "singlePeople" element does include the "generation" element
as
<br>expected.
<br>> > > >
<br>> > > > Thanks,
<br>> > > >
<br>> > > > James
<br>> > > >
<br>> > > > v1.xsd:
<br>> > > > <xs:schema targetNamespace="<a href="http://namespaces.nextance.com/nex/test">http://namespaces.nextance.com/nex/test</a>"
<br>> > > > xmlns:test="<a href="http://namespaces.nextance.com/nex/test">http://namespaces.nextance.com/nex/test</a>"
<br>> > > > xmlns:xs="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>> > > > elementFormDefault="unqualified" attributeFormDefault="unqualified">
<br>> > > > <xs:complexType name="personName">
<br>> > > > <xs:sequence>
<br>> > > > <xs:element name="title" type="xs:string"
minOccurs="0"/>
<br>> > > > <xs:element name="forename" type="xs:string"
minOccurs="0"
<br>> > > > maxOccurs="unbounded"/>
<br>> > > > </xs:sequence>
<br>> > > > </xs:complexType>
<br>> > > >
<br>> > > > <xs:element name="addressee" type="test:personName"/>
<br>> > > > </xs:schema>
<br>> > > >
<br>> > > > v2.xsd:
<br>> > > > <xs:redefine schemaLocation="v1.xsd">
<br>> > > > <xs:complexContent>
<br>> > > > <xs:extension base="test:personName">
<br>> > > > <xs:element name="generation"
<br>> > > > </xs:extension>
<br>> > > > </xs:complexContent>
<br>> > > > </xs:redefine>
<br>> > > >
<br>> > > > <xs:element name="author" type="test:personName"/>
<br>> > > >
<br>> > > > v3.xsd:
<br>> > > > <xs:include schemaLocation="v1.xsd"/>
<br>> > > >
<br>> > > > <xs:complexType name="marriedPersonName">
<br>> > > > <xs:element name="maidenName"
<br>> > > >
<br>> > > > <xs:element name="marriedPerson" type="test:marriedPersonName"/>
<br>> > > >
<br>> > > >
<br>> > > > v4.xsd:
<br>> > > > <xs:include schemaLocation="v2.xsd"/>
<br>> > > > <xs:include schemaLocation="v3.xsd"/>
<br>> > > >
<br>> > > > <xs:complexType name="people">
<br>> > > > <xs:element name="marriedPeople"
<br>> > > > <xs:element name="singlePeople"
<br>> > > > <xs:element name="directory" type="test:people"/>
<br>> > > >
<br>> > > > Ed Merks wrote:
<br>> > > >
<br>> > > > > James,
<br>> > > >
<br>> > > > > I'm not sure I can really answer the details of your questions
<br>without
<br>> > clear
<br>> > > > > references to particular components in actual schema documents,
<br>i.e., a
<br>> > > > > sample. Perhaps it helps to explain that redefinition
is
<br>accomplished by
<br>> > > > > making a clone of the schema being redefined and then modifying
that
<br>copy
<br>> > > > > according to the redefinition. The original schema
is not touched;
<br>it
<br>> > may be
<br>> > > > > redefined many times in many different ways. The schema containing
<br>the
<br>> > > > > redefine will see only the copy, not the original. Which
version you
<br>get
<br>> > will
<br>> > > > > depend very much on where you ask, so you need to be specific...
<br>> > > >
<br>> > > > > James Taylor wrote:
<br>> > > >
<br>> > > > > > Hello,
<br>> > > > > > If I understand the W3C spec correctly, a redefined complexType
<br>should
<br>> > be
<br>> > > > > > used everywhere in place of the original type. For
example, if I
<br>use
<br>> > the
<br>> > > > > > redefined complexType as a base type for another type,
the derived
<br>type
<br>> > > > > > should now include the additional elements introduced by
the
<br>redefined
<br>> > > > > > type. This is not the behavior I'm seeing in Eclipse
XSD. When I
<br>get
<br>> > the
<br>> > > > > > base type, using complexTypeDefinition.getBaseType(), I
continue
<br>to get
<br>> > > > > > the original definition instead of the redefined one.
References
<br>to
<br>> > the
<br>> > > > > > type within the schema that has the redefine do point to
the new
<br>> > redefined
<br>> > > > > > type, though. Is this intentional? Should I
use a different
<br>> > mechanism to
<br>> > > > > > get the base type? Or is this a bug?
<br>> > > > > >
<br>> > > > > > Thanks,
<br>> > > > > >
<br>> > > > > > James</blockquote>
</html>
Content-Type: image/jpeg
Content-ID: <part1.40647602.566D4349@ca.ibm.com>
Content-Disposition: inline; filename="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\nsmailC1.jpeg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDACAWGBwYFCAcGhwkIiAmMFA0MCws MGJGSjpQdGZ6
eHJmcG6AkLicgIiuim5woNqirr7EztDOfJri8uDI8LjKzsb/2wBDASIkJDAq MF40NF7GhHCE
xsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbG xsbGxsb/wAAR
CAMDAQcDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhB
Re: redefine [message #40038 is a reply to message #39976] |
Mon, 29 March 2004 22:56 |
Ed,
Thanks for fixing the bug you found and sorry about the error in
Company.xsd. I sent a question to the W3C regarding redefines because I
don't think the spec is as clear as it could be, and the answers I
received clarify things:
http://lists.w3.org/Archives/Public/xmlschema-dev/2004Mar/00 54.html
I understand the revised example you've shown below is an alternative,
however, it still should work the way I expressed it. The reason this is
an important issue for us here at my company is that our schemas can
become large with many levels of nesting. Being forced to redefine every
encompassing type for all occurrences of a type becomes cumbersome and
potentially error prone if an occurrence is missed. It can also prevents
being able to redefine a type nested inside of element declaration with an
anonymous type.
I'll volunteer to fix it if that helps.
James
Ed Merks wrote:
> James,
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:redefine>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
particular
express
> what you intended.
> namespace:
> <xs:schema
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:redefine>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
except
> [Image]
I
any more
> James Taylor wrote:
> > Ed,
> > type
> > James
> > Employee.xsd:
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > Department.xsd:
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > Company.xsd:
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:redefine>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > Ed Merks wrote:
> > > James,
incorporated
> > (i.e.,
components
> > in that
namespace,
> > it may
each
> > in a
> > clone is
> > redefinition
remains
> > referenced
> > > directly.
> > > James Taylor wrote:
> > > > Ed,
the
> > > > W3C spec
meant
redefined
> > > > v4.xsd.
> > > > James
> > > > Ed Merks wrote:
> > > > > James,
> > version
> > > > of
> > > > v1.xsd, as
> > include of
> > needs to
line
> > is
> > > > that
v2.xsd
> > sees
> > > > that
will
> > see
> > > > that
> > knows
> > > > nothing
> > > > > James Taylor wrote:
> > > > > > Ed,
> > "generation"
> > expected.
> > > > > > Thanks,
> > > > > > James
> > > > > > v1.xsd:
> > > > > > <xs:schema
> > > > > > <xs:sequence>
> > > > > > </xs:sequence>
> > > > > > </xs:complexType>
> > > > > > </xs:schema>
> > > > > > v2.xsd:
> > > > > > <xs:schema
> > > > > > <xs:complexContent>
> > > > > > <xs:sequence>
minOccurs="0"/>
> > > > > > </xs:sequence>
> > > > > > </xs:extension>
> > > > > > </xs:complexType>
> > > > > > </xs:redefine>
> > > > > > </xs:schema>
> > > > > > v3.xsd:
> > > > > > <xs:schema
> > > > > > <xs:complexContent>
> > > > > > <xs:sequence>
minOccurs="0"/>
> > > > > > </xs:sequence>
> > > > > > </xs:extension>
> > > > > > </xs:complexType>
> > > > > > </xs:schema>
> > > > > > v4.xsd:
> > > > > > <xs:schema
> > > > > > <xs:sequence>
> > > > > > </xs:sequence>
> > > > > > </xs:complexType>
> > > > > > </xs:schema>
> > > > > > Ed Merks wrote:
> > > > > > > James,
> > without
> > > > clear
> > i.e., a
> > accomplished by
that
> > copy
touched;
> > it
> > > > may be
containing
> > the
you
> > get
> > > > will
> > > > > > > James Taylor wrote:
> > > > > > > > Hello,
> > should
> > > > be
if I
> > use
> > > > the
derived
> > type
> > redefined
When I
> > get
> > > > the
continue
> > to get
References
> > to
> > > > the
new
> > > > redefined
> > > > mechanism to
> > > > > > > > Thanks,
> > > > > > > > James
Re: redefine [message #40108 is a reply to message #40038] |
Tue, 30 March 2004 11:28 |
--------------CB5C521ADEF6460EF290FC80
James,
I think you need to show the example I showed below to get a clear answer to the
complete question. Multiple different redefines would normally cause a name
conflict, but not for the example below because the redefines are in different
namespaces and hence are redefining different abstract components. Unless someone
says the sample below is invalid and can point to some constraint in the spec that
would justify an error message for this case, then I will continue to consider the
case valid and will not make changes that would make that case stop working.
The case you show, modified as suggested in the answer to your question at the
schema forum, does work correctly now. Do you have cases without redundant (and
I'm still convinced, invalid) includes that don't work correctly?
James Taylor wrote:
> Ed,
> anonymous type.
> James
> Ed Merks wrote:
> > James,
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:redefine>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> particular
> express
> > what you intended.
> > namespace:
> > <xs:schema
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:redefine>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> except
> > [Image]
> I
> any more
> > James Taylor wrote:
> > > Ed,
> > > type
> > > James
> > > Employee.xsd:
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > Department.xsd:
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > Company.xsd:
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > Ed Merks wrote:
> > > > James,
> incorporated
> > > (i.e.,
> components
> > > in that
> namespace,
> > > it may
> each
> > > in a
> > > clone is
> > > redefinition
> remains
> > > referenced
> > > > directly.
> > > > James Taylor wrote:
> > > > > Ed,
> the
> > > > > W3C spec
> meant
> redefined
> > > > > v4.xsd.
> > > > > James
> > > > > Ed Merks wrote:
> > > > > > James,
> > > version
> > > > > of
> > > > > v1.xsd, as
> > > include of
> > > needs to
> line
> > > is
> > > > > that
> v2.xsd
> > > sees
> > > > > that
> will
> > > see
> > > > > that
> > > knows
> > > > > nothing
> > > > > > James Taylor wrote:
> > > > > > > Ed,
> > > "generation"
> > > expected.
> > > > > > > Thanks,
> > > > > > > James
> > > > > > > v1.xsd:
> > > > > > > <xs:schema
> > > > > > > <xs:sequence>
> > > > > > > </xs:sequence>
> > > > > > > </xs:complexType>
> > > > > > > </xs:schema>
> > > > > > > v2.xsd:
> > > > > > > <xs:schema
> > > > > > > <xs:complexContent>
> > > > > > > <xs:sequence>
> minOccurs="0"/>
> > > > > > > </xs:sequence>
> > > > > > > </xs:extension>
> > > > > > > </xs:complexType>
> > > > > > > </xs:redefine>
> > > > > > > </xs:schema>
> > > > > > > v3.xsd:
> > > > > > > <xs:schema
> > > > > > > <xs:complexContent>
> > > > > > > <xs:sequence>
> minOccurs="0"/>
> > > > > > > </xs:sequence>
> > > > > > > </xs:extension>
> > > > > > > </xs:complexType>
> > > > > > > </xs:schema>
> > > > > > > v4.xsd:
> > > > > > > <xs:schema
> > > > > > > <xs:sequence>
> > > > > > > </xs:sequence>
> > > > > > > </xs:complexType>
> > > > > > > </xs:schema>
> > > > > > > Ed Merks wrote:
> > > > > > > > James,
> > > without
> > > > > clear
> > > i.e., a
> > > accomplished by
> that
> > > copy
> touched;
> > > it
> > > > > may be
> containing
> > > the
> you
> > > get
> > > > > will
> > > > > > > > James Taylor wrote:
> > > > > > > > > Hello,
> > > should
> > > > > be
> if I
> > > use
> > > > > the
> derived
> > > type
> > > redefined
> When I
> > > get
> > > > > the
> continue
> > > to get
> References
> > > to
> > > > > the
> new
> > > > > redefined
> > > > > mechanism to
> > > > > > > > > Thanks,
> > > > > > > > > James
<html>
James,
<p>I think you need to show the example I showed below to get a clear answer
to the complete question. Multiple different redefines would normally
cause a name conflict, but not for the example below because the redefines
are in different namespaces and hence are redefining different abstract
components. Unless someone says the sample below is invalid <b>and</b>
can point to some constraint in the spec that would justify an error message
for this case, then I will continue to consider the case valid and will
<p>The case you show, modified as suggested in the answer to your question
at the schema forum, does work correctly now. Do you have cases without
redundant (and I'm still convinced, invalid) includes that don't work correctly?
<br>
<p>Thanks for fixing the bug you found and sorry about the error in
<br>Company.xsd. I sent a question to the W3C regarding redefines
because I
<br>don't think the spec is as clear as it could be, and the answers I
<br>received clarify things:
<p><a href=" http://lists.w3.org/Archives/Public/xmlschema-dev/2004Mar/00 54.html"> http://lists.w3.org/Archives/Public/xmlschema-dev/2004Mar/00 54.html</a>
<p>I understand the revised example you've shown below is an alternative,
<br>however, it still should work the way I expressed it. The reason
this is
<br>an important issue for us here at my company is that our schemas can
<br>become large with many levels of nesting. Being forced to redefine
every
<br>encompassing type for all occurrences of a type becomes cumbersome
and
<br>potentially error prone if an occurrence is missed. It can also
prevents
<br>being able to redefine a type nested inside of element declaration
with an
<br>anonymous type.
<p>I'll volunteer to fix it if that helps.
<p> James
<p>Ed Merks wrote:
<br>> James,
<p>> As I was fixing the Company.xsd to make it valid:
<p>> <xs:schema targetNamespace="<a href="http://namespaces.nextance.com/test">http://namespaces.nextance.com/test</a>"
<br>> xmlns:test="<a href="http://namespaces.nextance.com/test">http://namespaces.nextance.com/test</a>"
<br>> xmlns:xs="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>> elementFormDefault="unqualified" attributeFormDefault="unqualified">
<p>> <xs:redefine schemaLocation="Department.xsd">
<br>> <xs:complexType
name="Employee">
<br>>
<xs:complexContent>
<br>>
<br>>
<xs:sequence>
<br>>
<br>>
</xs:sequence>
<br>>
</xs:extension>
<br>>
<br>> </xs:complexType>
<br>> </xs:redefine>
<p>> <xs:complexType name="Company">
<br>> <xs:sequence>
<br>>
<br>> maxOccurs="unbounded"/>
<br>>
<br>> </xs:sequence>
<p>> <xs:element name="fortune500"
<p>> </xs:schema>
<p>> I discovered that there is a bug that causes the transitive
<br>includes/redefines of a
<br>> cloned included/redefined schema to be omitted so I opened
<br>> <a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=56328">https://bugs.eclipse.org/bugs/show_bug.cgi?id=56328</a>
and have fixed that
<br>particular
<br>> problem. So, to my way of thinking, the above sample is the correct
way to
<br>express
<br>> what you intended.
<p>> Consider the following slightly modified example where Employee.xsd
has no
<br>> namespace:
<p>> <xs:schema
<br>> <xs:complexType name="Employee">
<br>> <xs:sequence>
<br>>
<br>> </xs:schema>
<p>> and Department.xsd is still the same (but the include is changing
the null
<br>> namespace of the included schema to match that of the including schema):
<br>> <xs:include schemaLocation="Employee.xsd"/>
<p>> <xs:complexType name="Department">
<br>> <xs:sequence>
<br>>
<br>>
<br>> </xs:schema>
<p>> In this case, a Company.xsd can validly access both the original version
of
<br>> Employee as well as a redefined version.
<p>> <xs:import schemaLocation="Employee.xsd"/>
name="Employee">
<br>>
<xs:complexContent>
<br>>
<br>>
<xs:sequence>
<br>>
<br>>
</xs:sequence>
<br>>
</xs:extension>
<br>>
<br>> <xs:sequence>
<br>>
<br>>
<br>>
<p>> </xs:schema>
<p>> The semantics view for this shows that everyone is using the redefined
type,
<br>except
<br>> the junk element, which is using the original:
<p>> [Image]
<p>> This stuff is all really much too complicated for human minds to handle
(and
<br>I
<br>> think there are still lurking bugs in the implementation, but I don't
have
<br>any more
<br>> time to spend to look at this further).
<p>> > Ed,
<br>> >
<br>> > Here's a smaller more realistic example that illustrates an issue:
<br>> >
<br>> > File A defines Employee type
<br>> > File B includes File A and defines Department type
<br>> > File C includes File B, redefines Employee from File A and defines
Company
<br>> > type
<br>> >
<br>> > This is a common use case for redefine in which a type in a nested
include
<br>> > needs to be redefined. With Eclipse XSD, the redefine does
not affect the
<br>> > Employee type within the Department type and affects the Employee
type
<br>> > within the Company type only if the include of File B precedes
the
<br>> > redefine of File A. This does not seem like the correct behavior.
<br>> >
<br>> > I've included the XSD files below. Thanks,
<br>> >
<br>> > James
<br>> >
<br>> > Employee.xsd:
<br>> > <xs:schema targetNamespace="<a href="http://namespaces.nextance.com/test">http://namespaces.nextance.com/test</a>"
<br>> > xmlns:test="<a href="http://namespaces.nextance.com/test">http://namespaces.nextance.com/test</a>"
<br>> > xmlns:xs="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>> > elementFormDefault="unqualified" attributeFormDefault="unqualified">
<br>> > <xs:complexType name="Employee">
<br>> > <xs:sequence>
<br>> > <xs:element name="name"
type="xs:string"/>
<br>> > </xs:sequence>
<br>> > </xs:complexType>
<br>> > </xs:schema>
<br>> >
<br>> > Department.xsd:
<br>> > <xs:include schemaLocation="Employee.xsd"/>
<br>> >
<br>> > <xs:complexType name="Department">
<br>> > <xs:element name="employee"
<br>> > maxOccurs="unbounded"/>
<br>> > <xs:element name="manager"
<br>> >
<br>> > Company.xsd:
<br>> >
<br>> > <xs:include schemaLocation="Department.xsd"/>
<br>> >
<br>> > <xs:redefine schemaLocation="Employee.xsd">
<br>> > <xs:complexContent>
<br>> > <xs:extension
<br>> >
<br>> > </xs:extension>
<br>> > </xs:complexContent>
<br>> > </xs:redefine>
<br>> >
<br>> > <xs:complexType name="Company">
<br>> > <xs:element name="department"
<br>> > <xs:element name="president"
<br>> >
<br>> > <xs:element name="fortune500" type="test:Company"
maxOccurs="500"/>
<br>> >
<br>> >
<br>> >
<br>> > > James,
<br>> >
<br>> > > All the components of the schema mentioned in the redefine are
<br>incorporated
<br>> > (i.e.,
<br>> > > cloned) and the redefinitions are pervasively applied to all
the
<br>components
<br>> > in that
<br>> > > clone. Note that if the schema being redefined has a null
target
<br>namespace,
<br>> > it may
<br>> > > be redefined in multiple schemas each with a different
namespace and
<br>each
<br>> > in a
<br>> > > different way; in this case, during incorporation, the namespace
of the
<br>> > clone is
<br>> > > modified to match the namespace of the redefining schema and
the other
<br>> > redefinition
<br>> > > modifications are applied as well. In any event, the original
schema
<br>remains
<br>> > > untouched so that it can and will be reused in its pristine form
when
<br>> > referenced
<br>> > > directly.
<br>> >
<br>> >
<br>> > > > Ed,
<br>> > > >
<br>> > > > Thank you for the explanation. It's not clear to me how
"pervasive"
<br>the
<br>> > > > W3C spec
<br>> > > > (<a href=" http://www.w3.org/TR/2001/REC-xmlschema-1-20010502/#modify-s chema"> http://www.w3.org/TR/2001/REC-xmlschema-1-20010502/#modify-s chema</a>)
<br>meant
<br>> > > > a redefine to be when they state:
<br>> > > >
<br>> > > > The modifications have a pervasive
<br>redefined
<br>> > > > components are used, even when referenced
<br>> > > > components, whether redefined themselves
or not.
<br>> > > >
<br>> > > > Given that later in the spec they imply that multiple redefines
of the
<br>> > > > same type that conflict are not legal, I assume they meant
that the
<br>> > > > redefined type should "pervade" everywhere, including in my
example of
<br>> > > > v4.xsd.
<br>> > > >
<br>> > > > James
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > > > The v4.xsd schema isn't valid because its includes both a
redefined
<br>> > version
<br>> > > > of
<br>> > > > > personName and addressee, via its include of v2.xsd's redefinition
of
<br>> > > > v1.xsd, as
<br>> > > > > well as the original version of personName and addressee,
via its
<br>> > include of
<br>> > > > > v3.xsd's include of v1.xsd without redefinition. The
v3.xsd schema
<br>> > needs to
<br>> > > > > include v2.xsd not v1.xsd for this example to be valid.
The bottom
<br>line
<br>> > is
<br>> > > > that
<br>> > > > > v1.xsd is not modified by virtue of the redefine in v2.xsd;
only
<br>v2.xsd
<br>> > sees
<br>> > > > that
<br>> > > > > redefinition directly and any schema importing or including
v2.xsd
<br>will
<br>> > see
<br>> > > > that
<br>> > > > > redefinition indirectly; but v3.xsd sees only the original
v1.xsd and
<br>> > knows
<br>> > > > nothing
<br>> > > > > of v2.xsd. When we get to v4.xsd, the result is name
collision.
<br>> > > >
<br>> > > >
<br>> > > > > > Ed,
<br>> > > > > >
<br>> > > > > > Thanks for the reply. My sample is below. In
<br>> > > > > > expected that the "marriedPeople" element would contain
the
<br>> > "generation"
<br>> > > > > > element since it is redefined to include this in v2.xsd.
The
<br>> > > > > > "singlePeople" element does include the "generation" element
as
<br>> > expected.
<br>> > > > > >
<br>> > > > > >
<br>> > > > > >
<br>> > > > > > v1.xsd:
<br>> > > > > > <xs:schema
<br>targetNamespace="<a href="http://namespaces.nextance.com/nex/test">http://namespaces.nextance.com/
Re: redefine [message #40269 is a reply to message #40108] |
Wed, 31 March 2004 00:16 |
Ed,
I got the latest XSD from CVS and everything works fine. Thanks again for
the bug fix -- I didn't realize it fixed my test case. I agree with you
that your example should work as well, since there are really two Employee
types one with no namespace and the other with a namespace. I tried it
with the W3C schema validator (XSV) against a test instance and it worked
fine.
James
Ed Merks wrote:
> James,
the
different
someone
spec that
consider the
the
(and
> James Taylor wrote:
> > Ed,
> > anonymous type.
> > James
> > Ed Merks wrote:
> > > James,
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > particular
to
> > express
> > > what you intended.
no
> > > namespace:
> > > <xs:schema
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
null
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
of
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
type,
> > except
> > > [Image]
(and
> > I
have
> > any more
> > > James Taylor wrote:
> > > > Ed,
Company
> > > > type
include
the
> > > > James
> > > > Employee.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Department.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Company.xsd:
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Ed Merks wrote:
> > > > > James,
> > incorporated
> > > > (i.e.,
> > components
> > > > in that
> > namespace,
> > > > it may
> > each
> > > > in a
the
> > > > clone is
other
> > > > redefinition
> > remains
> > > > referenced
> > > > > directly.
> > > > > James Taylor wrote:
> > > > > > Ed,
"pervasive"
> > the
> > > > > > W3C spec
> > meant
> > redefined
incorporated
the
example of
> > > > > > v4.xsd.
> > > > > > James
> > > > > > Ed Merks wrote:
> > > > > > > James,
redefined
> > > > version
> > > > > > of
redefinition of
> > > > > > v1.xsd, as
> > > > include of
schema
> > > > needs to
bottom
> > line
> > > > is
> > > > > > that
> > v2.xsd
> > > > sees
> > > > > > that
v2.xsd
> > will
> > > > see
> > > > > > that
v1.xsd and
> > > > knows
> > > > > > nothing
> > > > > > > James Taylor wrote:
> > > > > > > > Ed,
have
> > > > "generation"
> > > > expected.
> > > > > > > > Thanks,
> > > > > > > > James
> > > > > > > > v1.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:sequence>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > v2.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:complexContent>
> > > > > > > > <xs:sequence>
> > minOccurs="0"/>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:extension>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:redefine>
> > > > > > > > </xs:schema>
> > > > > > > > v3.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:complexContent>
> > > > > > > > <xs:sequence>
> > minOccurs="0"/>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:extension>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > v4.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:sequence>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > Ed Merks wrote:
> > > > > > > > > James,
questions
> > > > without
> > > > > > clear
documents,
> > > > i.e., a
> > > > accomplished by
modifying
> > that
> > > > copy
> > touched;
> > > > it
> > > > > > may be
> > containing
> > > > the
version
> > you
> > > > get
> > > > > > will
specific...
> > > > > > > > > James Taylor wrote:
> > > > > > > > > > Hello,
complexType
> > > > should
> > > > > > be
example,
> > if I
> > > > use
> > > > > > the
> > derived
> > > > type
the
> > > > redefined
> > When I
> > > > get
> > > > > > the
> > continue
> > > > to get
> > References
> > > > to
> > > > > > the
the
> > new
> > > > > > redefined
different
> > > > > > mechanism to
> > > > > > > > > > Thanks,
> > > > > > > > > > James
Re: redefine [message #40755 is a reply to message #40108] |
Fri, 09 April 2004 03:00 |
Ed,
I believe I found a redefine bug. Complex types that are derived from
types that are redefined continue to pick up the old type definition when
these types are included. For example, in the case I showed below, if
there was a Manager complexType with an Employee base type, the Manager
type when used in the Company.xsd does not pick up the new "rank" element
from the redefinition.
Let me know if you'd rather I just file a bug that post this here. Thanks,
James
Ed Merks wrote:
> James,
the
different
someone
spec that
consider the
the
(and
> James Taylor wrote:
> > Ed,
> > anonymous type.
> > James
> > Ed Merks wrote:
> > > James,
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > particular
to
> > express
> > > what you intended.
no
> > > namespace:
> > > <xs:schema
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
null
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
of
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
type,
> > except
> > > [Image]
(and
> > I
have
> > any more
> > > James Taylor wrote:
> > > > Ed,
Company
> > > > type
include
the
> > > > James
> > > > Employee.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Department.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Company.xsd:
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Ed Merks wrote:
> > > > > James,
> > incorporated
> > > > (i.e.,
> > components
> > > > in that
> > namespace,
> > > > it may
> > each
> > > > in a
the
> > > > clone is
other
> > > > redefinition
> > remains
> > > > referenced
> > > > > directly.
> > > > > James Taylor wrote:
> > > > > > Ed,
"pervasive"
> > the
> > > > > > W3C spec
> > meant
> > redefined
incorporated
the
example of
> > > > > > v4.xsd.
> > > > > > James
> > > > > > Ed Merks wrote:
> > > > > > > James,
redefined
> > > > version
> > > > > > of
redefinition of
> > > > > > v1.xsd, as
> > > > include of
schema
> > > > needs to
bottom
> > line
> > > > is
> > > > > > that
> > v2.xsd
> > > > sees
> > > > > > that
v2.xsd
> > will
> > > > see
> > > > > > that
v1.xsd and
> > > > knows
> > > > > > nothing
> > > > > > > James Taylor wrote:
> > > > > > > > Ed,
have
> > > > "generation"
> > > > expected.
> > > > > > > > Thanks,
> > > > > > > > James
> > > > > > > > v1.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:sequence>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > v2.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:complexContent>
> > > > > > > > <xs:sequence>
> > minOccurs="0"/>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:extension>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:redefine>
> > > > > > > > </xs:schema>
> > > > > > > > v3.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:complexContent>
> > > > > > > > <xs:sequence>
> > minOccurs="0"/>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:extension>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > v4.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:sequence>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > Ed Merks wrote:
> > > > > > > > > James,
questions
> > > > without
> > > > > > clear
documents,
> > > > i.e., a
> > > > accomplished by
modifying
> > that
> > > > copy
> > touched;
> > > > it
> > > > > > may be
> > containing
> > > > the
version
> > you
> > > > get
> > > > > > will
specific...
> > > > > > > > > James Taylor wrote:
> > > > > > > > > > Hello,
complexType
> > > > should
> > > > > > be
example,
> > if I
> > > > use
> > > > > > the
> > derived
> > > > type
the
> > > > redefined
> > When I
> > > > get
> > > > > > the
> > continue
> > > > to get
> > References
> > > > to
> > > > > > the
the
> > new
> > > > > > redefined
different
> > > > > > mechanism to
> > > > > > > > > > Thanks,
> > > > > > > > > > James
Re: redefine [message #40939 is a reply to message #40755] |
Mon, 12 April 2004 10:44 |
James,
Please open a bugzilla defect with a sample that illustrates the problem. I
believe that if you redefine a schema document that is composed by including other
schema documents, that the indirectly included documents won't see all the
redefinitions, so I suspect that the problem is avoidable if you put all the
contents into a single schema and redefine that schema.
James Taylor wrote:
> Ed,
> James
> Ed Merks wrote:
> > James,
> the
> different
> someone
> spec that
> consider the
> the
> (and
> > James Taylor wrote:
> > > Ed,
> > > anonymous type.
> > > James
> > > Ed Merks wrote:
> > > > James,
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > particular
> to
> > > express
> > > > what you intended.
> no
> > > > namespace:
> > > > <xs:schema
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> null
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> of
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> type,
> > > except
> > > > [Image]
> (and
> > > I
> have
> > > any more
> > > > James Taylor wrote:
> > > > > Ed,
> Company
> > > > > type
> include
> the
> > > > > James
> > > > > Employee.xsd:
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > Department.xsd:
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > Company.xsd:
> > > > > <xs:complexContent>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:extension>
> > > > > </xs:complexType>
> > > > > </xs:redefine>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > Ed Merks wrote:
> > > > > > James,
> > > incorporated
> > > > > (i.e.,
> > > components
> > > > > in that
> > > namespace,
> > > > > it may
> > > each
> > > > > in a
> the
> > > > > clone is
> other
> > > > > redefinition
> > > remains
> > > > > referenced
> > > > > > directly.
> > > > > > James Taylor wrote:
> > > > > > > Ed,
> "pervasive"
> > > the
> > > > > > > W3C spec
> > > meant
> > > redefined
> incorporated
> the
> example of
> > > > > > > v4.xsd.
> > > > > > > James
> > > > > > > Ed Merks wrote:
> > > > > > > > James,
> redefined
> > > > > version
> > > > > > > of
> redefinition of
> > > > > > > v1.xsd, as
> > > > > include of
> schema
> > > > > needs to
> bottom
> > > line
> > > > > is
> > > > > > > that
> > > v2.xsd
> > > > > sees
> > > > > > > that
> v2.xsd
> > > will
> > > > > see
> > > > > > > that
> v1.xsd and
> > > > > knows
> > > > > > > nothing
> > > > > > > > James Taylor wrote:
> > > > > > > > > Ed,
> have
> > > > > "generation"
> > > > > expected.
> > > > > > > > > Thanks,
> > > > > > > > > James
> > > > > > > > > v1.xsd:
> > > > > > > > > <xs:schema
> > > > > > > > > <xs:sequence>
> > > > > > > > > </xs:sequence>
> > > > > > > > > </xs:complexType>
> > > > > > > > > </xs:schema>
> > > > > > > > > v2.xsd:
> > > > > > > > > <xs:schema
> > > > > > > > > <xs:complexContent>
> > > > > > > > > <xs:sequence>
> > > minOccurs="0"/>
> > > > > > > > > </xs:sequence>
> > > > > > > > > </xs:extension>
> > > > > > > > > </xs:complexType>
> > > > > > > > > </xs:redefine>
> > > > > > > > > </xs:schema>
> > > > > > > > > v3.xsd:
> > > > > > > > > <xs:schema
> > > > > > > > > <xs:complexContent>
> > > > > > > > > <xs:sequence>
> > > minOccurs="0"/>
> > > > > > > > > </xs:sequence>
> > > > > > > > > </xs:extension>
> > > > > > > > > </xs:complexType>
> > > > > > > > > </xs:schema>
> > > > > > > > > v4.xsd:
> > > > > > > > > <xs:schema
> > > > > > > > > <xs:sequence>
> > > > > > > > > </xs:sequence>
> > > > > > > > > </xs:complexType>
> > > > > > > > > </xs:schema>
> > > > > > > > > Ed Merks wrote:
> > > > > > > > > > James,
> questions
> > > > > without
> > > > > > > clear
> documents,
> > > > > i.e., a
> > > > > accomplished by
> modifying
> > > that
> > > > > copy
> > > touched;
> > > > > it
> > > > > > > may be
> > > containing
> > > > > the
> version
> > > you
> > > > > get
> > > > > > > will
> specific...
> > > > > > > > > > James Taylor wrote:
> > > > > > > > > > > Hello,
> complexType
> > > > > should
> > > > > > > be
> example,
> > > if I
> > > > > use
> > > > > > > the
> > > derived
> > > > > type
> the
> > > > > redefined
> > > When I
> > > > > get
> > > > > > > the
> > > continue
> > > > > to get
> > > References
> > > > > to
> > > > > > > the
> the
> > > new
> > > > > > > redefined
> different
> > > > > > > mechanism to
> > > > > > > > > > > Thanks,
> > > > > > > > > > > James
Re: redefine [message #584509 is a reply to message #39443] |
Ed Merks Messages: 33133 Registered: July 2009 |
James,
James Taylor wrote:
> Hello,
> James
Ed Merks
Re: redefine [message #584530 is a reply to message #39474] |
James Taylor Messages: 21 Registered: July 2009 |
Ed,
James
v1.xsd:
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
v2.xsd:
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:redefine>
</xs:schema>
v3.xsd:
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:schema>
v4.xsd:
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
Ed Merks wrote:
> James,
> James Taylor wrote:
> > Hello,
> > Thanks,
> > James
Re: redefine [message #584543 is a reply to message #39505] |
James,
James Taylor wrote:
> Ed,
> James
> v1.xsd:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> v2.xsd:
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:redefine>
> </xs:schema>
> v3.xsd:
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
> v4.xsd:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Ed Merks wrote:
> > James,
> > James Taylor wrote:
> > > Hello,
> > > Thanks,
> > > James
Ed Merks
Re: redefine [message #584704 is a reply to message #39536] |
Ed,
W3C spec
v4.xsd.
James
Ed Merks wrote:
> James,
of
v1.xsd, as
that
that
that
nothing
> James Taylor wrote:
> > Ed,
> > Thanks,
> > James
> > v1.xsd:
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > v2.xsd:
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:redefine>
> > </xs:schema>
> > v3.xsd:
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:schema>
> > v4.xsd:
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > Ed Merks wrote:
> > > James,
clear
may be
will
> > > James Taylor wrote:
> > > > Hello,
be
the
the
the
redefined
mechanism to
> > > > Thanks,
> > > > James
Re: redefine [message #584719 is a reply to message #39780] |
James,
directly.
James Taylor wrote:
> Ed,
> W3C spec
> v4.xsd.
> James
> Ed Merks wrote:
> > James,
> of
> v1.xsd, as
> that
> that
> that
> nothing
> > James Taylor wrote:
> > > Ed,
> > > Thanks,
> > > James
> > > v1.xsd:
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > v2.xsd:
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > </xs:schema>
> > > v3.xsd:
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:schema>
> > > v4.xsd:
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > Ed Merks wrote:
> > > > James,
> clear
> may be
> will
> > > > James Taylor wrote:
> > > > > Hello,
> be
> the
> the
> the
> redefined
> mechanism to
> > > > > Thanks,
> > > > > James
Ed Merks
Re: redefine [message #584784 is a reply to message #39811] |
Ed,
type
James
Employee.xsd:
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
Department.xsd:
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
Company.xsd:
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:redefine>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
Ed Merks wrote:
> James,
(i.e.,
in that
it may
in a
clone is
redefinition
referenced
> directly.
> James Taylor wrote:
> > Ed,
> > W3C spec
> > v4.xsd.
> > James
> > Ed Merks wrote:
> > > James,
version
> > of
> > v1.xsd, as
include of
needs to
is
> > that
sees
> > that
see
> > that
knows
> > nothing
> > > James Taylor wrote:
> > > > Ed,
"generation"
expected.
> > > > Thanks,
> > > > James
> > > > v1.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > v2.xsd:
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > </xs:schema>
> > > > v3.xsd:
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > v4.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Ed Merks wrote:
> > > > > James,
without
> > clear
i.e., a
accomplished by
copy
it
> > may be
the
get
> > will
> > > > > James Taylor wrote:
> > > > > > Hello,
should
> > be
use
> > the
type
redefined
get
> > the
to get
to
> > the
> > redefined
> > mechanism to
> > > > > > Thanks,
> > > > > > James
Re: redefine [message #584820 is a reply to message #39904] |
James,
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:redefine>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
what you intended.
namespace:
<xs:schema
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:redefine>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
[Image]
James Taylor wrote:
> Ed,
> type
> James
> Employee.xsd:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Department.xsd:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Company.xsd:
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:redefine>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Ed Merks wrote:
> > James,
> (i.e.,
> in that
> it may
> in a
> clone is
> redefinition
> referenced
> > directly.
> > James Taylor wrote:
> > > Ed,
> > > W3C spec
> > > v4.xsd.
> > > James
> > > Ed Merks wrote:
> > > > James,
> version
> > > of
> > > v1.xsd, as
> include of
> needs to
> is
> > > that
> sees
> > > that
> see
> > > that
> knows
> > > nothing
> > > > James Taylor wrote:
> > > > > Ed,
> "generation"
> expected.
> > > > > Thanks,
> > > > > James
> > > > > v1.xsd:
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > v2.xsd:
> > > > > <xs:complexContent>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:extension>
> > > > > </xs:complexType>
> > > > > </xs:redefine>
> > > > > </xs:schema>
> > > > > v3.xsd:
> > > > > <xs:complexContent>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:extension>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > v4.xsd:
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > Ed Merks wrote:
> > > > > > James,
> without
> > > clear
> i.e., a
> accomplished by
> copy
> it
> > > may be
> the
> get
> > > will
> > > > > > James Taylor wrote:
> > > > > > > Hello,
> should
> > > be
> use
> > > the
> type
> redefined
> get
> > > the
> to get
> to
> > > the
> > > redefined
> > > mechanism to
> > > > > > > Thanks,
> > > > > > > James
<html>
James,
<br><font size=-1>
<br><font size=-1>
<br><font size=-1>
has no namespace:
<br><font size=-1>
<br><font size=-1>
<br><font size=-1>
<br>
Company
<br>type
affect the
<p> James
<p>Employee.xsd:
<br> <xs:sequence>
<br> </xs:sequence>
<br></xs:schema>
<p>Department.xsd:
<br> <xs:sequence>
<br> </xs:sequence>
<br></xs:schema>
<p>Company.xsd:
<br> <xs:sequence>
<br>
<br> </xs:sequence>
<br> </xs:redefine>
<br> <xs:sequence>
<br> </xs:sequence>
<p></xs:schema>
<p>Ed Merks wrote:
<p>> James,
<br>(i.e.,
components
<br>in that
namespace,
<br>it may
and each
<br>in a
of the
<br>clone is
other
<br>redefinition
schema remains
when
<br>referenced
<br>> directly.
<p>> > Ed,
<br>> >
the
<br>> > W3C spec
meant
<br>> >
or not.
<br>> >
of the
the
of
<br>> > v4.xsd.
<br>> >
<br>> > James
<br>> >
<br>> >
<br>> > > James,
<br>> >
<br>version
<br>> > of
of
<br>> > v1.xsd, as
its
<br>include of
schema
<br>needs to
The bottom line
<br>is
<br>> > that
v2.xsd
<br>sees
<br>> > that
will
<br>see
<br>> > that
and
<br>knows
<br>> > nothing
<br>> >
<br>> >
<br>> > > > Ed,
<br>> > > >
I would have
<br>"generation"
The
as
<br>expected.
<br>> > > >
<br>> > > > Thanks,
<br>> > > >
<br>> > > > James
<br>> > > >
<br>> > > > v1.xsd:
minOccurs="0"/>
minOccurs="0"
<br>> > > >
<br>> > > >
<br>> > > > v2.xsd:
<br>> > > >
<br>> > > >
<br>> > > > v3.xsd:
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > > v4.xsd:
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > >
<br>without
<br>> > clear
<br>i.e., a
is
<br>accomplished by
that
<br>copy
is not touched;
<br>it
<br>> > may be
<br>the
version you
<br>get
<br>> > will
<br>> > > >
<br>> > > >
<br>should
<br>> > be
example, if I
<br>use
<br>> > the
the derived
<br>type
the
<br>redefined
XSD. When I
<br>get
<br>> > the
continue
<br>to get
References
<br>to
<br>> > the
the new
<br>> > redefined
use a different
<br>> > > > > >
<br>> > > > > >
</html>
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NT
Ed Merks
Re: redefine [message #584855 is a reply to message #39976] |
Ed,
anonymous type.
James
Ed Merks wrote:
> James,
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:redefine>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
particular
express
> what you intended.
> namespace:
> <xs:schema
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:redefine>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
except
> [Image]
I
any more
> James Taylor wrote:
> > Ed,
> > type
> > James
> > Employee.xsd:
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > Department.xsd:
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > Company.xsd:
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:redefine>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > Ed Merks wrote:
> > > James,
incorporated
> > (i.e.,
components
> > in that
namespace,
> > it may
each
> > in a
> > clone is
> > redefinition
remains
> > referenced
> > > directly.
> > > James Taylor wrote:
> > > > Ed,
the
> > > > W3C spec
meant
redefined
> > > > v4.xsd.
> > > > James
> > > > Ed Merks wrote:
> > > > > James,
> > version
> > > > of
> > > > v1.xsd, as
> > include of
> > needs to
line
> > is
> > > > that
v2.xsd
> > sees
> > > > that
will
> > see
> > > > that
> > knows
> > > > nothing
> > > > > James Taylor wrote:
> > > > > > Ed,
> > "generation"
> > expected.
> > > > > > Thanks,
> > > > > > James
> > > > > > v1.xsd:
> > > > > > <xs:schema
> > > > > > <xs:sequence>
> > > > > > </xs:sequence>
> > > > > > </xs:complexType>
> > > > > > </xs:schema>
> > > > > > v2.xsd:
> > > > > > <xs:schema
> > > > > > <xs:complexContent>
> > > > > > <xs:sequence>
minOccurs="0"/>
> > > > > > </xs:sequence>
> > > > > > </xs:extension>
> > > > > > </xs:complexType>
> > > > > > </xs:redefine>
> > > > > > </xs:schema>
> > > > > > v3.xsd:
> > > > > > <xs:schema
> > > > > > <xs:complexContent>
> > > > > > <xs:sequence>
minOccurs="0"/>
> > > > > > </xs:sequence>
> > > > > > </xs:extension>
> > > > > > </xs:complexType>
> > > > > > </xs:schema>
> > > > > > v4.xsd:
> > > > > > <xs:schema
> > > > > > <xs:sequence>
> > > > > > </xs:sequence>
> > > > > > </xs:complexType>
> > > > > > </xs:schema>
> > > > > > Ed Merks wrote:
> > > > > > > James,
> > without
> > > > clear
> > i.e., a
> > accomplished by
that
> > copy
touched;
> > it
> > > > may be
containing
> > the
you
> > get
> > > > will
> > > > > > > James Taylor wrote:
> > > > > > > > Hello,
> > should
> > > > be
> > > > > > > > used everywhere in place of the original type. For example,
if I
> > use
> > > > the
> > > > > > > > redefined complexType as a base type for another type, the
derived
> > type
> > > > > > > > should now include the additional elements introduced by the
> > redefined
> > > > > > > > type. This is not the behavior I'm seeing in Eclipse XSD.
When I
> > get
> > > > the
continue
> > to get
References
> > to
> > > > the
> > > > > > > > type within the schema that has the redefine do point to the
new
> > > > redefined
> > > > > > > > type, though. Is this intentional? Should I use a different
> > > > mechanism to
> > > > > > > > Thanks,
> > > > > > > > James
Re: redefine [message #584887 is a reply to message #40038] |
James,
James Taylor wrote:
> Ed,
> anonymous type.
> James
> Ed Merks wrote:
> > James,
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:redefine>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> particular
> express
> > what you intended.
> > namespace:
> > <xs:schema
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:redefine>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > </xs:schema>
> except
> > [Image]
> I
> any more
> > James Taylor wrote:
> > > Ed,
> > > type
> > > James
> > > Employee.xsd:
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > Department.xsd:
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > Company.xsd:
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > > Ed Merks wrote:
> > > > James,
> incorporated
> > > (i.e.,
> components
> > > in that
> namespace,
> > > it may
> each
> > > in a
> > > clone is
> > > redefinition
> remains
> > > referenced
> > > > directly.
> > > > James Taylor wrote:
> > > > > Ed,
> the
> > > > > W3C spec
> meant
> redefined
> > > > > v4.xsd.
> > > > > James
> > > > > Ed Merks wrote:
> > > > > > James,
> > > version
> > > > > of
> > > > > v1.xsd, as
> > > include of
> > > needs to
> line
> > > is
> > > > > that
> v2.xsd
> > > sees
> > > > > that
> will
> > > see
> > > > > that
> > > knows
> > > > > nothing
> > > > > > James Taylor wrote:
> > > > > > > Ed,
> > > > > > > Thanks for the reply. My sample is below. In v4.xsd, I would have
> > > "generation"
> > > > > > > element since it is redefined to include this in v2.xsd. The
> > > > > > > "singlePeople" element does include the "generation" element as
> > > expected.
> > > > > > > Thanks,
> > > > > > > James
> > > > > > > v1.xsd:
> > > > > > > <xs:schema
> targetNamespace="http://namespaces.nextance.com/nex/test"
> > > > > > > xmlns:test="http://namespaces.nextance.com/nex/test"
> > > > > > > xmlns:xs="http://www.w3.org/2001/XMLSchema"
> > > > > > > <xs:sequence>
> > > > > > > <xs:element name="title" type="xs:string" minOccurs="0"/>
> > > > > > > <xs:element name="forename" type="xs:string" minOccurs="0"
> > > > > > > </xs:sequence>
> > > > > > > </xs:complexType>
> > > > > > > </xs:schema>
> > > > > > > v2.xsd:
> > > > > > > <xs:schema
> > > > > > > <xs:complexContent>
> > > > > > > <xs:sequence>
> > > > > > > <xs:element name="generation" type="xs:string"
> minOccurs="0"/>
> > > > > > > </xs:sequence>
> > > > > > > </xs:extension>
> > > > > > > </xs:complexType>
> > > > > > > </xs:redefine>
> > > > > > > </xs:schema>
> > > > > > > v3.xsd:
> > > > > > > <xs:schema
> > > > > > > <xs:complexContent>
> > > > > > > <xs:sequence>
> > > > > > > <xs:element name="maidenName" type="xs:string"
> minOccurs="0"/>
> > > > > > > </xs:sequence>
> > > > > > > </xs:extension>
> > > > > > > </xs:complexType>
> > > > > > > </xs:schema>
> > > > > > > v4.xsd:
> > > > > > > <xs:schema
> > > > > > > <xs:sequence>
> > > > > > > </xs:sequence>
> > > > > > > </xs:complexType>
> > > > > > > </xs:schema>
> > > > > > > Ed Merks wrote:
> > > > > > > > James,
> > > without
> > > > > clear
> > > i.e., a
> > > > > > > > sample. Perhaps it helps to explain that redefinition is
> > > accomplished by
> that
> > > copy
> > > > > > > > according to the redefinition. The original schema is not
> touched;
> > > it
> > > > > may be
> containing
> > > the
> > > > > > > > redefine will see only the copy, not the original. Which version
> you
> > > get
> > > > > will
> > > > > > > > James Taylor wrote:
> > > > > > > > > Hello,
> > > should
> > > > > be
> if I
> > > use
> > > > > the
> derived
> > > type
> > > redefined
> When I
> > > get
> > > > > the
> continue
> > > to get
> References
> > > to
> > > > > the
> new
> > > > > redefined
> > > > > mechanism to
> > > > > > > > > Thanks,
> > > > > > > > > James
<html>
James,
<br>
because I
this is
every
and
prevents
with an
<br>anonymous type.
<p> James
<p>Ed Merks wrote:
<br>> James,
name="Employee">
<br>>
<xs:complexContent>
<br>>
<br>>
<xs:sequence>
<br>>
<br>>
</xs:sequence>
<br>>
</xs:extension>
<br>>
<br>> <xs:sequence>
<br>>
<br>>
<p>> </xs:schema>
and have fixed that
<br>particular
way to
<br>express
has no
<br>> namespace:
<p>> <xs:schema
<br>> <xs:sequence>
<br>>
<br>> </xs:schema>
the null
<br>> <xs:sequence>
<br>>
<br>>
<br>> </xs:schema>
of
name="Employee">
<br>>
<xs:complexContent>
<br>>
<br>>
<xs:sequence>
<br>>
<br>>
</xs:sequence>
<br>>
</xs:extension>
<br>>
<br>> <xs:sequence>
<br>>
<br>>
<br>>
<p>> </xs:schema>
type,
<br>except
<p>> [Image]
(and
<br>I
have
<br>any more
<p>> > Ed,
<br>> >
<br>> >
Company
<br>> > type
<br>> >
include
not affect the
type
the
<br>> >
<br>> >
<br>> > James
<br>> >
type="xs:string"/>
<br>> >
<br>> >
<br>> >
<br>> >
<br>> >
<br>> >
<br>> >
<br>> >
maxOccurs="500"/>
<br>> >
<br>> >
<br>> >
<br>> > > James,
<br>> >
<br>incorporated
<br>> > (i.e.,
the
<br>components
<br>> > in that
target
<br>namespace,
<br>> > it may
namespace and
<br>each
<br>> > in a
of the
<br>> > clone is
the other
schema
<br>remains
when
<br>> > referenced
<br>> > > directly.
<br>> >
<br>> >
<br>> > > > Ed,
<br>> > > >
"pervasive"
<br>the
<br>meant
<br>> > > >
<br>redefined
or not.
<br>> > > >
of the
that the
example of
<br>> > > > v4.xsd.
<br>> > > >
<br>> > > > James
<br>> > > >
<br>> > > >
<br>> > > >
redefined
<br>> > version
<br>> > > > of
of
via its
<br>> > include of
v3.xsd schema
<br>> > needs to
The bottom
<br>line
<br>> > is
<br>> > > > that
only
<br>v2.xsd
<br>> > sees
<br>> > > > that
v2.xsd
<br>will
<br>> > see
<br>> > > > that
v1.xsd and
<br>> > knows
<br>> > > > nothing
collision.
<br>> > > >
<br>> > > >
<br>> > > > > > Ed,
<br>> > > > > >
the
The
as
<br>> > expected.
<br>> > > > > >
<br>> > > > > >
<br>> > > > > >
<br>targetNamespace="<a href="http://namespaces.nextance.com/nex/test">http://namespaces.nextance.com/nex/test</a>"
<br>> > >
Ed Merks
Re: redefine [message #584972 is a reply to message #40108] |
Ed,
fine.
James
Ed Merks wrote:
> James,
the
different
someone
spec that
consider the
the
(and
> James Taylor wrote:
> > Ed,
> > anonymous type.
> > James
> > Ed Merks wrote:
> > > James,
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > particular
to
> > express
> > > what you intended.
no
> > > namespace:
> > > <xs:schema
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
null
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
of
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
type,
> > except
> > > [Image]
(and
> > I
have
> > any more
> > > James Taylor wrote:
> > > > Ed,
Company
> > > > type
include
the
> > > > James
> > > > Employee.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Department.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Company.xsd:
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Ed Merks wrote:
> > > > > James,
> > incorporated
> > > > (i.e.,
> > components
> > > > in that
> > namespace,
> > > > it may
> > > > > be redefined in multiple schemas each with a different namespace and
> > each
> > > > in a
> > > > > different way; in this case, during incorporation, the namespace of
the
> > > > clone is
other
> > > > redefinition
> > > > > modifications are applied as well. In any event, the original schema
> > remains
> > > > > untouched so that it can and will be reused in its pristine form when
> > > > referenced
> > > > > directly.
> > > > > James Taylor wrote:
> > > > > > Ed,
"pervasive"
> > the
> > > > > > W3C spec
> > > > > > ( http://www.w3.org/TR/2001/REC-xmlschema-1-20010502/#modify-s chema)
> > meant
> > > > > > The modifications have a pervasive impact, that is, only the
> > redefined
> > > > > > components are used, even when referenced from other
incorporated
> > > > > > components, whether redefined themselves or not.
> > > > > > Given that later in the spec they imply that multiple redefines of
the
> > > > > > same type that conflict are not legal, I assume they meant that the
example of
> > > > > > v4.xsd.
> > > > > > James
> > > > > > Ed Merks wrote:
> > > > > > > James,
redefined
> > > > version
> > > > > > of
redefinition of
> > > > > > v1.xsd, as
> > > > > > > well as the original version of personName and addressee, via its
> > > > include of
schema
> > > > needs to
> > > > > > > include v2.xsd not v1.xsd for this example to be valid. The
bottom
> > line
> > > > is
> > > > > > that
> > v2.xsd
> > > > sees
> > > > > > that
v2.xsd
> > will
> > > > see
> > > > > > that
v1.xsd and
> > > > knows
> > > > > > nothing
> > > > > > > James Taylor wrote:
> > > > > > > > Ed,
have
> > > > "generation"
> > > > expected.
> > > > > > > > Thanks,
> > > > > > > > James
> > > > > > > > v1.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:sequence>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > v2.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:complexContent>
> > > > > > > > <xs:sequence>
> > minOccurs="0"/>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:extension>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:redefine>
> > > > > > > > </xs:schema>
> > > > > > > > v3.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:complexContent>
> > > > > > > > <xs:sequence>
> > minOccurs="0"/>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:extension>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > v4.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:sequence>
> > > > > > > > <xs:element name="singlePeople" type="test:personName"
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > Ed Merks wrote:
> > > > > > > > > James,
questions
> > > > without
> > > > > > clear
documents,
> > > > i.e., a
> > > > accomplished by
modifying
> > that
> > > > copy
> > touched;
> > > > it
> > > > > > may be
> > containing
> > > > the
version
> > you
> > > > get
> > > > > > will
specific...
> > > > > > > > > James Taylor wrote:
> > > > > > > > > > Hello,
complexType
> > > > should
> > > > > > be
example,
> > if I
> > > > use
> > > > > > the
> > derived
> > > > type
the
> > > > redefined
> > When I
> > > > get
> > > > > > the
> > continue
> > > > to get
> > References
> > > > to
> > > > > > the
the
> > new
> > > > > > redefined
different
> > > > > > mechanism to
> > > > > > > > > > Thanks,
> > > > > > > > > > James
Re: redefine [message #585234 is a reply to message #40108] |
Ed,
James
Ed Merks wrote:
> James,
the
different
someone
spec that
consider the
the
(and
> James Taylor wrote:
> > Ed,
> > anonymous type.
> > James
> > Ed Merks wrote:
> > > James,
> > > <xs:schema targetNamespace="http://namespaces.nextance.com/test"
> > > xmlns:test="http://namespaces.nextance.com/test"
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
> > particular
to
> > express
> > > what you intended.
no
> > > namespace:
> > > <xs:schema
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
null
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
of
> > > <xs:complexContent>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:extension>
> > > </xs:complexType>
> > > </xs:redefine>
> > > <xs:sequence>
> > > </xs:sequence>
> > > </xs:complexType>
> > > </xs:schema>
type,
> > except
> > > [Image]
(and
> > I
have
> > any more
> > > James Taylor wrote:
> > > > Ed,
Company
> > > > type
include
> > > > needs to be redefined. With Eclipse XSD, the redefine does not affect
the
> > > > James
> > > > Employee.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Department.xsd:
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Company.xsd:
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > Ed Merks wrote:
> > > > > James,
> > incorporated
> > > > (i.e.,
> > components
> > > > in that
> > namespace,
> > > > it may
> > each
> > > > in a
the
> > > > clone is
other
> > > > redefinition
> > remains
> > > > referenced
> > > > > directly.
> > > > > James Taylor wrote:
> > > > > > Ed,
"pervasive"
> > the
> > > > > > W3C spec
> > meant
> > redefined
incorporated
the
example of
> > > > > > v4.xsd.
> > > > > > James
> > > > > > Ed Merks wrote:
> > > > > > > James,
redefined
> > > > version
> > > > > > of
redefinition of
> > > > > > v1.xsd, as
> > > > include of
schema
> > > > needs to
bottom
> > line
> > > > is
> > > > > > that
> > v2.xsd
> > > > sees
> > > > > > that
v2.xsd
> > will
> > > > see
> > > > > > that
v1.xsd and
> > > > knows
> > > > > > nothing
> > > > > > > James Taylor wrote:
> > > > > > > > Ed,
have
> > > > "generation"
> > > > expected.
> > > > > > > > Thanks,
> > > > > > > > James
> > > > > > > > v1.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:sequence>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > v2.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:complexContent>
> > > > > > > > <xs:sequence>
> > minOccurs="0"/>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:extension>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:redefine>
> > > > > > > > </xs:schema>
> > > > > > > > v3.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:complexContent>
> > > > > > > > <xs:sequence>
> > minOccurs="0"/>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:extension>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > v4.xsd:
> > > > > > > > <xs:schema
> > > > > > > > <xs:sequence>
> > > > > > > > </xs:sequence>
> > > > > > > > </xs:complexType>
> > > > > > > > </xs:schema>
> > > > > > > > Ed Merks wrote:
> > > > > > > > > James,
questions
> > > > without
> > > > > > clear
documents,
> > > > i.e., a
> > > > accomplished by
modifying
> > that
> > > > copy
> > touched;
> > > > it
> > > > > > may be
> > containing
> > > > the
version
> > you
> > > > get
> > > > > > will
specific...
> > > > > > > > > James Taylor wrote:
> > > > > > > > > > Hello,
complexType
> > > > should
> > > > > > be
example,
> > if I
> > > > use
> > > > > > the
> > derived
> > > > type
the
> > > > redefined
> > When I
> > > > get
> > > > > > the
> > continue
> > > > to get
> > References
> > > > to
> > > > > > the
the
> > new
> > > > > > redefined
different
> > > > > > mechanism to
> > > > > > > > > > Thanks,
> > > > > > > > > > James
Re: redefine [message #585325 is a reply to message #40755] |
James,
James Taylor wrote:
> Ed,
> James
> Ed Merks wrote:
> > James,
> the
> different
> someone
> spec that
> consider the
> the
> (and
> > James Taylor wrote:
> > > Ed,
> > > anonymous type.
> > > James
> > > Ed Merks wrote:
> > > > James,
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > https://bugs.eclipse.org/bugs/show_bug.cgi?id=56328 and have fixed that
> > > particular
> > > > problem. So, to my way of thinking, the above sample is the correct way
> to
> > > express
> > > > what you intended.
> > > > Consider the following slightly modified example where Employee.xsd has
> no
> > > > namespace:
> > > > <xs:schema
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> > > > and Department.xsd is still the same (but the include is changing the
> null
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> of
> > > > <xs:complexContent>
> > > > <xs:sequence>
> > > > </xs:sequence>
> > > > </xs:extension>
> > > > </xs:complexType>
> > > > </xs:redefine>
> > > > <xs:sequence>
> > > > <xs:element name="dummy" type="Employee"/>
> > > > </xs:sequence>
> > > > </xs:complexType>
> > > > </xs:schema>
> type,
> > > except
> > > > [Image]
> (and
> > > I
> have
> > > any more
> > > > James Taylor wrote:
> > > > > Ed,
> Company
> > > > > type
> include
> the
> > > > > James
> > > > > Employee.xsd:
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > Department.xsd:
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > Company.xsd:
> > > > > <xs:complexContent>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:extension>
> > > > > </xs:complexType>
> > > > > </xs:redefine>
> > > > > <xs:sequence>
> > > > > </xs:sequence>
> > > > > </xs:complexType>
> > > > > </xs:schema>
> > > > > Ed Merks wrote:
> > > > > > James,
> > > incorporated
> > > > > (i.e.,
> > > components
> > > > > in that
> > > namespace,
> > > > > it may
> > > each
> > > > > in a
> the
> > > > > clone is
> other
> > > > > redefinition
> > > remains
> > > > > referenced
> > > > > > directly.
> > > > > > James Taylor wrote:
> > > > > > > Ed,
> "pervasive"
> > > the
> > > > > > > W3C spec
> > > meant
> > > redefined
> incorporated
> the
> example of
> > > > > > > v4.xsd.
> > > > > > > James
> > > > > > > Ed Merks wrote:
> > > > > > > > James,
> redefined
> > > > > version
> > > > > > > of
> redefinition of
> > > > > > > v1.xsd, as
> > > > > include of
> schema
> > > > > needs to
> bottom
> > > line
> > > > > is
> > > > > > > that
> > > v2.xsd
> > > > > sees
> > > > > > > that
> v2.xsd
> > > will
> > > > > see
> > > > > > > that
> v1.xsd and
> > > > > knows
> > > > > > > nothing
> > > > > > > > James Taylor wrote:
> > > > > > > > > Ed,
> have
> > > > > "generation"
> > > > > expected.
> > > > > > > > > Thanks,
> > > > > > > > > James
> > > > > > > > > v1.xsd:
> > > > > > > > > <xs:schema
> > > > > > > > > <xs:sequence>
> > > > > > > > > </xs:sequence>
> > > > > > > > > </xs:complexType>
> > > > > > > > > </xs:schema>
> > > > > > > > > v2.xsd:
> > > > > > > > > <xs:schema
> > > > > > > > > <xs:complexContent>
> > > > > > > > > <xs:sequence>
> > > minOccurs="0"/>
> > > > > > > > > </xs:sequence>
> > > > > > > > > </xs:extension>
> > > > > > > > > </xs:complexType>
> > > > > > > > > </xs:redefine>
> > > > > > > > > </xs:schema>
> > > > > > > > > v3.xsd:
> > > > > > > > > <xs:schema
> > > > > > > > > <xs:complexContent>
> > > > > > > > > <xs:sequence>
> > > minOccurs="0"/>
> > > > > > > > > </xs:sequence>
> > > > > > > > > </xs:extension>
> > > > > > > > > </xs:complexType>
> > > > > > > > > </xs:schema>
> > > > > > > > > v4.xsd:
> > > > > > > > > <xs:schema
> > > > > > > > > <xs:sequence>
> > > > > > > > > </xs:sequence>
> > > > > > > > > </xs:complexType>
> > > > > > > > > </xs:schema>
> > > > > > > > > Ed Merks wrote:
> > > > > > > > > > James,
> questions
> > > > > without
> > > > > > > clear
> documents,
> > > > > i.e., a
> > > > > accomplished by
> modifying
> > > that
> > > > > copy
> > > touched;
> > > > > it
> > > > > > > may be
> > > containing
> > > > > the
> version
> > > you
> > > > > get
> > > > > > > will
> specific...
> > > > > > > > > > James Taylor wrote:
> > > > > > > > > > > Hello,
> complexType
> > > > > should
> > > > > > > be
> example,
> > > if I
> > > > > use
> > > > > > > the
> > > derived
> > > > > type
> the
> > > > > redefined
> > > When I
> > > > > get
> > > > > > > the
> > > continue
> > > > > to get
> > > References
> > > > > to
> > > > > > > the
> the
> > > new
> > > > > > > redefined
> different
> > > > > > > mechanism to
> > > > > > > > > > > Thanks,
> > > > > > > > > > > James
Ed Merks
Current Time: Wed Apr 17 00:34:51 GMT 2024
Powered by FUDForum. Page generated in 1.23887 seconds
