Re: Disable icon generation [message #386879 is a reply to message #386875] |
Thu, 05 August 2004 11:11 |
Ed Merks Messages: 33141 Registered: July 2009 |
Achim,
You can turn off the image for any GenClass by setting the "Image"
property to false. The child creation images can be turned off by
turning off Edit "Creation" for the whole model or by turning off
"Create Child" for a particular feature, but you no doubt you want the
creation commands just not the creation images, and we don't have flags
that will let you do just that.
Achim Oehlenschlaeger wrote:
> Hello,
> I've got a pretty big model which causes the generator to create more
> than 20,000 icons which unnecessarily slows down some processes (CVS,
> plugin export, distribution etc.).
> I was able to use only Item.gif and CreateChild.gif by modifying
> ItemProvider.javajet which works fine so far. However the generator
> still creates all the icons and even just deleting them from the
> project takes more than 10 minutes on my machine.
> So my question is, can I completely disable generation of the icons?
> Achim
Ed Merks
FUDForum. Page generated in 0.02670 seconds
