Home » Eclipse Projects » EclipseLink » hsqldb
hsqldb [message #386565] Tue, 31 March 2009 14:21 Go to next message
Tom Eugelink is currently offline Tom EugelinkFriend
I love writing unit tests against an in-memory database, so I usually pull out HSQLDB for that. But I get the impression that the support for HSQLDB in Eclipselink is very minimal. The GeneratedValue is converted to a identify column, but the generated DDL code is incorrect (syntax error) when letting EclipseLink generate the database.
Time for me to get the 1.1 source distribution and work on the HSQLDB implementation?
Re: hsqldb [message #386567 is a reply to message #386565] Tue, 31 March 2009 14:26 Go to previous messageGo to next message
Hmmm, HSQLDB only supports IDENTITY on integers (Eclipselink mirror that from a Java Integer class) or bigints (no idea what Java class Eclipselink will mirror to that). So sequences would be very welcome.
Re: hsqldb [message #386570 is a reply to message #386565] Wed, 01 April 2009 13:21 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
What DDL and error do you get?
For database independent sequencing you can use TABLE sequencing. It is
also more efficient than IDENTITY sequencing.
You might also consider Derby/JavaDB as a test database.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog : Twitter
Re: hsqldb [message #386578 is a reply to message #386570] Thu, 02 April 2009 09:15 Go to previous message
HSQLDB only allows IDENTITY on columns of type Integer or BigInt. EclipseLink generates a column of type Decimal-something. I can get you the exact error tomorrow.
Is that so? Hm. It sure it more portable, but I intended to enable sequences in the HSQLDB database platform. Table or sequence? Hm, table is more portable and that is the goal here, so I think I'll be using table.
Those do not work in memory; this is unittesting, so I need a new clean database everytime. In memory is very practical.
Tom
Previous Topic:Eclipselink 1.1: java.lang.ClassCast,Exception: org.eclipse.persistence.internal.helper.IdentityWeak
Next Topic:[MOXy] Plugin to build mapping against a schema like DALI for JPA
Current Time: Sat May 30 18:43:21 GMT 2020
Powered by FUDForum. Page generated in 0.02327 seconds
