Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] pre/post condition in EWL
[Epsilon] pre/post condition in EWL [message #385270] Thu, 28 August 2008 12:37 Go to next message
Patry Olivier is currently offline Patry OlivierFriend
Member
I see that EOL implements pre/post conditions.
I test this feature on EWL:
$pre elt > 1
operation Elt test(elt: Integer) {
'success'.println();
I get syntax highlighting on $pre..., so I think it should work (EWL is
based on EOL, am I right?)
But, I get an error:
Method 'test' not found (...\file.ewl@66:13)
If I suppress "$pre..." it works.
If EWL can't now implement pre/post condition, is it possible to get it
in a close future?
Olivier
Re: [Epsilon] pre/post condition in EWL [message #385276 is a reply to message #385270] Thu, 28 August 2008 15:57 Go to previous messageGo to next message
Louis Rose is currently offline Louis RoseFriend
Hi Olivier,
That's correct, EWL is based on EOL. Your syntax looks to be correct.
I've been able to reproduce the error. We have recently ported EOL to a
new version of ANTLR, and I suspect that this regression has been
introduced during that process.
We'll investigate further, and either Dimitrios or I will prepare a fix
in the next week or so.
Many thanks,
Louis.
Olivier PATRY wrote:
> $pre elt > 1
> in a close future?
> Olivier
Re: [Epsilon] pre/post condition in EWL [message #385279 is a reply to message #385276] Fri, 29 August 2008 09:13 Go to previous messageGo to next message
Member
Louis Rose a écrit :
> Hi Olivier,
> Many thanks,
> Louis.
>> Hi,
>> $pre elt > 1
>> is based on EOL, am I right?)
>> it in a close future?
>> Thanks,
>> Olivier
Thanks for your reply and investigation Louis.
What will I check to get informed for changes and get a new version?
(automatic update I think)
Olivier
Re: [Epsilon] pre/post condition in EWL [message #385280 is a reply to message #385279] Fri, 29 August 2008 09:51 Go to previous messageGo to next message
No problem.
Either Dimitrios or I will reply to your post here, once a fix is
available. We'll provide instructions on how to obtain it either via
automatic update; from our source code repository; or with an overlay for
your installation.
Many thanks,
Louis.
Re: [Epsilon] pre/post condition in EWL [message #385286 is a reply to message #385280] Sat, 30 August 2008 07:42 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Olivier,
As Louis mentioned this is a known result of the Antlr2->3 migration.
I'll look into this shortly. Thanks for reporting this - it had almost
skipped my mind :)
Dimitrios
Louis Rose wrote:
> No problem.
> for your installation.
> Many thanks,
> Louis.
Re: [Epsilon] pre/post condition in EWL [message #385302 is a reply to message #385286] Sat, 30 August 2008 07:53 Go to previous messageGo to next message
In the meantime could you please open a new bug to keep track of the
progress?
Dimitrios
Dimitrios Kolovos wrote:
> Hi Olivier,
> skipped my mind :)
> Cheers,
> Dimitrios
> Louis Rose wrote:
>> No problem.
>> Many thanks,
>> Louis.
Re: [Epsilon] pre/post condition in EWL [message #385313 is a reply to message #385302] Mon, 01 September 2008 08:17 Go to previous messageGo to next message
Member
> progress?
> Cheers,
> Dimitrios
>> Hi Olivier,
>> skipped my mind :)
>> Cheers,
>> Dimitrios
>> Louis Rose wrote:
>>> No problem.
>>> Many thanks,
>>> Louis.
I report it on eclipse bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245824
Thanks for involving on it.
Olivier
Re: [Epsilon] pre/post condition in EWL [message #385316 is a reply to message #385313] Mon, 01 September 2008 14:49 Go to previous messageGo to next message
Hi Olivier,
Thanks for reporting this. I've fixed it and committed the changes to
the CVS. A minor glitch is that because pre and post are reserved words
in EWL, pre and post in executable annotations should be placed between
"" i.e.
$"pre" elt > 1
I'll close the bug when we make the next binary version (0.8.1) available.
Dimitrios
>> progress?
>> Cheers,
>> Dimitrios
>>> Hi Olivier,
>>> almost skipped my mind :)
>>> Cheers,
>>> Dimitrios
>>> Louis Rose wrote:
>>>> No problem.
>>>> overlay for your installation.
>>>> Many thanks,
>>>> Louis.
> Hello,
> Olivier
Re: [Epsilon] pre/post condition in EWL [message #385317 is a reply to message #385316] Mon, 01 September 2008 15:13 Go to previous message
Member
> Hi Olivier,
> "" i.e.
> $"pre" elt > 1
> Cheers,
> Dimitrios
Ok, thanks a lot.
It works well now.
Olivier
Re: [Epsilon] pre/post condition in EWL [message #621666 is a reply to message #385270] Thu, 28 August 2008 15:57 Go to previous message
Hi Olivier,
Many thanks,
Louis.
> $pre elt > 1
> in a close future?
> Olivier
Re: [Epsilon] pre/post condition in EWL [message #621671 is a reply to message #385276] Fri, 29 August 2008 09:13 Go to previous message
Member
> Hi Olivier,
> Many thanks,
> Louis.
>> Hi,
>> $pre elt > 1
>> Thanks,
>> Olivier
Olivier
Re: [Epsilon] pre/post condition in EWL [message #621673 is a reply to message #385279] Fri, 29 August 2008 09:51 Go to previous message
No problem.
your installation.
Many thanks,
Louis.
Re: [Epsilon] pre/post condition in EWL [message #621686 is a reply to message #385280] Sat, 30 August 2008 07:42 Go to previous message
Hi Olivier,
skipped my mind :)
Dimitrios
Louis Rose wrote:
> No problem.
> Many thanks,
> Louis.
Re: [Epsilon] pre/post condition in EWL [message #621689 is a reply to message #385286] Sat, 30 August 2008 07:53 Go to previous message
progress?
Dimitrios
> Hi Olivier,
> skipped my mind :)
> Cheers,
> Dimitrios
> Louis Rose wrote:
>> No problem.
>> Many thanks,
>> Louis.
Re: [Epsilon] pre/post condition in EWL [message #621698 is a reply to message #385302] Mon, 01 September 2008 08:17 Go to previous message
Member
> progress?
> Cheers,
> Dimitrios
>> Hi Olivier,
>> skipped my mind :)
>> Cheers,
>> Dimitrios
>> Louis Rose wrote:
>>> No problem.
>>> Many thanks,
>>> Louis.
Olivier
Re: [Epsilon] pre/post condition in EWL [message #621745 is a reply to message #385313] Mon, 01 September 2008 14:49 Go to previous message
Hi Olivier,
"" i.e.
$"pre" elt > 1
Dimitrios
>> progress?
>> Cheers,
>> Dimitrios
>>> Hi Olivier,
>>> Cheers,
>>> Dimitrios
>>> Louis Rose wrote:
>>>> No problem.
>>>> Many thanks,
>>>> Louis.
> Hello,
> Olivier
Re: [Epsilon] pre/post condition in EWL [message #621747 is a reply to message #385316] Mon, 01 September 2008 15:13 Go to previous message
Member
> Hi Olivier,
> "" i.e.
> $"pre" elt > 1
> Cheers,
> Dimitrios
Ok, thanks a lot.
It works well now.
Olivier
Previous Topic:[MOFScript]i+=1 acturally add by two
Next Topic:[Epsilon]EWL finding EClass
Current Time: Wed Aug 04 19:33:44 GMT 2021
Powered by FUDForum. Page generated in 0.02900 seconds
