cdo - unimplemented methods and missing repositories [message #385161] |
Mon, 27 July 2009 18:07 |
Originally posted by: hamak.email.cz
Hi.
For the past couple of days I've been trying to learn cdo and to get it
to work with hibernate and mysql but unsuccessfully. I use Eclipse
Galileo on linux and I have followed these guides:
http://wiki.eclipse.org/CDO_Source_Installation and
http://wiki.eclipse.org/Getting_started_with_CDO_Galileo.
The first problem I have is that there is an error in CDOIDHibernateImpl
because methods isExternal(), isNull() etc. are not implemented. These
methods are commented out in its primitive class AbstractCDOID. Is it right
to uncomment them or is there another way to solve it?
The second problem concerns repositories. When I run CDO server(it
starts without any errors) and try
to connect to it in the CDO Sessions view I get an error that says
Repository /repo1 not found
org.eclipse.emf.cdo.util.ServerException: Repository /repo1 not found
at
org.eclipse.emf.internal.cdo.net4j.protocol.OpenSessionReque st.confirming(OpenSessionRequest.java:79)
at
org.eclipse.emf.internal.cdo.net4j.protocol.OpenSessionReque st.confirming(OpenSessionRequest.java:1)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientRequest .confirming(CDOClientRequest.java:77)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestWithConfirmation.java:123)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:103)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:66)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
at
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:423)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doSend(Requ estWithConfirmation.java:87)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtoco l.send(CDOClientProtocol.java:286)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtoco l.openSession(CDOClientProtocol.java:78)
at
org.eclipse.emf.internal.cdo.session.CDOSessionImpl$Delegati ngSessionProtocol.openSession(CDOSessionImpl.java:1572)
at
org.eclipse.emf.internal.cdo.session.CDOSessionImpl.doActiva te(CDOSessionImpl.java:716)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:65)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:94)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:84)
at
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:285)
at
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:265)
at
org.eclipse.emf.cdo.internal.ui.actions.OpenSessionAction.do Run(OpenSessionAction.java:67)
at
org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo ngRunningAction.java:185)
and the console of the CDO sever says:
[ERROR] Factory not found: org.eclipse.emf.cdo.server.repositories[default]
org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not
at
org.eclipse.net4j.util.container.ManagedContainer.getFactory (ManagedContainer.java:193)
at
org.eclipse.net4j.util.container.ManagedContainer.createElem ent(ManagedContainer.java:490)
at
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:281)
at
at
org.eclipse.emf.cdo.spi.server.RepositoryFactory.get(Reposit oryFactory.java:43)
at
org.eclipse.emf.cdo.spi.server.ContainerRepositoryProvider.g etRepository(ContainerRepositoryProvider.java:41)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.OpenSessi onIndication.responding(OpenSessionIndication.java:85)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServer Indication.responding(CDOServerIndication.java:112)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOu tput(IndicationWithResponse.java:96)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:282)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:65)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Thanks for your help
Ondrej Hamak
Re: cdo - unimplemented methods and missing repositories [message #385164 is a reply to message #385161] |
Tue, 28 July 2009 09:10 |
Ondrej,
Comments below...
Ondrej Hamak schrieb:
> Hi.
> right
As Martin said, we completely reworked the HibernateStore. Now the
org.eclipse.emf.cdo.server.hibernate.id bundle is no longer needed (in
HEAD!). Please just delete it from your workspace. I've also removed it
from the PSF files now.
I also bet that the leading slash must be removed.
And I think that latest HEAD now throws a RepositoryNotFoundException
instead of just a FactoryNotFoundException if the named repository can
not be found in the managed container (and no factory is present to
create it).
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Cheers
/Eike
http://www.esc-net.de
Re: cdo - unimplemented methods and missing repositories [message #385165 is a reply to message #385161] |
Tue, 28 July 2009 09:18 |
Ondrej,
Please do not cross-post the same question to multiple newsgroups. CDO
is supported in the EMF newsgroup.
Cheers
/Eike
> Hi.
> right
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Cheers
/Eike
Re: cdo - unimplemented methods and missing repositories [message #617538 is a reply to message #385161] |
Ondrej,
Comments below...
> Hi.
> right
create it).
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Cheers
/Eike
Re: cdo - unimplemented methods and missing repositories [message #617541 is a reply to message #385161] |
Ondrej,
Cheers
/Eike
> Hi.
> right
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Cheers
/Eike
FUDForum. Page generated in 0.04164 seconds
