Home » Modeling » Modeling (top-level project) » Problem opening ecore_diagram file/dynamic diagram generation
Problem opening ecore_diagram file/dynamic diagram generation [message #384803] |
Fri, 19 June 2009 17:54 |
Originally posted by: watertext.hotmail.it
Greetings, i'm creating an eclipse plugin, it has a view that make some
calculations and then create a diagram that is displayed on the editor, my
actual solution is that the view creates an .ecore and an ecore_diagram file
using dom, save them locally and then calls the editor (very ugly), the
problem is that I cant open the ecore_diagram because the file do not
belongs to any project.
As far as I know eclipse is not able (at the moment) to open diagram files
outside the workspace as is described on this thread:
http://dev.eclipse.org/newslists/news.eclipse.modeling.mdt.u ml2tools/msg00724.html
(my plugin doesn't use any project or workspace files, the data is passed
directly inside the view)
So i made a temporary solution, is to take any project using
ResourcesPlugin.getWorkspace().getRoot().getProjects()[0] and create
temporary links by file.createLink and then load the diagram (very ugly too)
It would be nice to get rid of the serialized models, I just don't need
them, so my questions are:
- How can i extend the editor and set by myself the correct iPath ,
IEditorinput or something else to make it able to open the ecore_diagram?
- Or how can i extend the ecore diagram editor to directly create the
model -> diagram and display it?
- there is another way to get a solution?
Sorry for my long post, I hope that I'm asking on the right thread and
thanks in advance
Max Shell
Re: Problem opening ecore_diagram file/dynamic diagram generation [message #384806 is a reply to message #384803] |
Sat, 20 June 2009 09:21 |
Ed Merks Messages: 33140 Registered: July 2009 |
Max,
This sounds like a GMF question, so best to ask there. I've added that
newsgroup to the "to" list of the reply, so no need to repost.
> thanks in advance
> Max Shell
Ed Merks
Re: Problem opening ecore_diagram file/dynamic diagram generation [message #616724 is a reply to message #384803] |
Max,
> thanks in advance
> Max Shell
Ed Merks
Current Time: Thu Apr 25 00:45:32 GMT 2024
Powered by FUDForum. Page generated in 0.03110 seconds
