Home » Modeling » Modeling (top-level project) » UML Class Diagram
Re: UML Class Diagram [message #384798 is a reply to message #384796] |
Tue, 09 June 2009 10:31 |
Ed Merks Messages: 33140 Registered: July 2009 |
Gilod,
I'm not quite sure what you're asking but probably asking on the UML2
Tools newsgroup, which I've added to the "to" list of this reply, is a
better starting point. Copying a project and modifying it doesn't sound
like an ideal approach...
Gilod wrote:
> Hello
> I want to use a class diagram in my application.
> I want to modify the ecore of the Class Diagram exists in EMF
> environmet, so it will be adjust to my needs.
> Where can I download the UML class diagram model files from?
> (ecore, gmfgraph, gmftool, gmfmap, genmodel, gmfgen)
> Thanks in advance
> Gilod
Ed Merks
Re: UML Class Diagram [message #384800 is a reply to message #384798] |
Wed, 10 June 2009 18:12 |
Tatiana Fesenko Messages: 530 Registered: July 2009 |
Hello Gilod,
You can use this PSF to download GMF artifacts for UML2 Tools diagram --
http://wiki.eclipse.org/images/6/62/UML2Tools_Diagrams.psf
The referenced code contains GMF sources ( gmfgraph, gmftool, gmfmap, gmfgen
files) as well as code of the generated diagrams.
More details about re-generating UML2Tools diagram you can find here --
http://wiki.eclipse.org/MDT-UML2Tools_How_To_Regenerage_Diag rams#Checkout_diagram_plug-ins_of_UML2_Tools
Best wishes,
Tanya.
> Gilod,
> sound like an ideal approach...
> Gilod wrote:
>> Hello
>> Thanks in advance
>> Gilod
Re: UML Class Diagram [message #616721 is a reply to message #384796] |
Gilod,
Gilod wrote:
> Hello
> Thanks in advance
> Gilod
Ed Merks
Re: UML Class Diagram [message #616722 is a reply to message #384798] |
Hello Gilod,
Best wishes,
Tanya.
> Gilod,
> Gilod wrote:
>> Hello
>> Thanks in advance
>> Gilod
Current Time: Tue Apr 23 14:54:10 GMT 2024
Powered by FUDForum. Page generated in 0.04454 seconds
