Home » Archived » GMT (Generative Modeling Technologies) » [xtext] Error in the generated PartitionScanner
[xtext] Error in the generated PartitionScanner [message #384445] |
Wed, 06 August 2008 15:24 |
by taking a look at the generated antlr grammar, the STRING token takes
care of escaping character \ (which is a really good thing :-)
RULE_STRING :
'"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'\"'|'\''|'\\') | ~('\\'|'"') )* '"' |
'\'' ( '\\' ('b'|'t'|'n'|'f'|'r'|'\"'|'\''|'\\') | ~('\\'|'\'') )* '\''
However, the generated GeneratedPartitionScanner.java in the .editor
plugin, does not consider the escape character:
public class GeneratedPartitionScanner extends AbstractPartitionScanner {
public List<IPredicateRule> getRules() {
List<IPredicateRule> rules = new ArrayList<IPredicateRule>();
rules.add(new MultiLineRule("\"","\"", string));
rules.add(new MultiLineRule("'","'", string));
return rules;
in fact, in the generated editor the highlighting of a string of the shape
"this is \"a test\""
does not generate an error (right!) but it is not highlighted correctly.
The generated partition scanner should consider the escape character:
rules.add(new MultiLineRule("\"","\"", string, '\\'));
rules.add(new MultiLineRule("'","'", string, '\\'));
return rules;
where should I fix this?
if I modify the generated partition scanner directly I assume it will be
overwritten...
thanks
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: [xtext] Error in the generated PartitionScanner [message #384650 is a reply to message #384445] |
Fri, 08 August 2008 06:27 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Hi Lorenzo,
it would be best if you could provide a patch and file it in bugzilla,
so that the issue is fixed for everybody :-)
In general if you want to configure a special partition scanner you
should subclass the generated [LanguageName]Utilities.java class in the
editor project. The subclass should of course go into the src/ folder.
Then change the [LanguageName]EditorPlugin class so that it instantiates
the new subclass instead of the generated class.
In the manually created utility class you can overwrite the method:
public IPartitionTokenScanner getPartitionScanner() {
// TODO Auto-generated method stub
return super.getPartitionScanner();
Note, that this is how you can replace other built-in functionality as
well (e.g. content assist).
hope that helps,
Sven
> RULE_STRING :
> @Override
> return rules;
> @Override
> return rules;
> overwritten...
> thanks
> Lorenzo
Re: [xtext] Error in the generated PartitionScanner [message #384659 is a reply to message #384650] |
Fri, 08 August 2008 09:29 |
Sven Efftinge wrote:
> Hi Lorenzo,
I'll try to do this, but it might not be easy for someone external to
the development of xtext code itself to try to figure out where to patch ;-)
anyway, I'm trying to download the sources; I assume the right procedure
is the one described in the wiki am I right?
> @Override
OK, I managed to figure this out and already did that :-)
Note that if you override a standard rule, as for instance the single
comment rule, the generated partition scanner is not updated
accordingly... so you end up with an highlighting scheme that is not
consistent with the parser... was that intentional or is it a bug?
> hope that helps,
> Sven
>> RULE_STRING :
>> @Override
>> return rules;
>> shape
>> @Override
>> return rules;
>> overwritten...
>> thanks
>> Lorenzo
Re: [xtext] Error in the generated PartitionScanner [message #384663 is a reply to message #384650] |
Fri, 08 August 2008 16:47 |
--------------070706060603020106050406
> Hi Lorenzo,
there seem to be problems with bugzilla, so for the moment I'm posting
the patch here
hope this helps
Lorenzo
Content-Type: text/x-diff;
name="scanner_with_escape_chars_for_strings.patch"
Content-Disposition: inline;
filename="scanner_with_escape_chars_for_strings.patch"
### Eclipse Workspace Patch 1.0
#P xtext.generator
Index: main/src/org/openarchitectureware/xtext/editor/Utilities.xpt
RCS file: /cvsroot/architecturware/oaw_v4/xtext/xtext.generator/main/s rc/org/openarchitectureware/xtext/editor/Utilities.xpt,v
retrieving revision 1.6.2.3.2.1
diff -u -r1.6.2.3.2.1 Utilities.xpt
--- main/src/org/openarchitectureware/xtext/editor/Utilities.xpt 31 May 2008 12:57:18 -0000 1.6.2.3.2.1
+++ main/src/org/openarchitectureware/xtext/editor/Utilities.xpt 8 Aug 2008 16:16:50 -0000
@@ -103,8 +103,8 @@
rules.add(new MultiLineRule("/*","*/", comment));
rules.add(new SingleLineRule("//", "", comment));
�ENDIF-�
- rules.add(new MultiLineRule("\"","\"", string));
- rules.add(new MultiLineRule("'","'", string));
+ rules.add(new MultiLineRule("\"","\"", string, '\\'));
+ rules.add(new MultiLineRule("'","'", string, '\\'));
return rules;
--------------070706060603020106050406--
Re: [xtext] Error in the generated PartitionScanner [message #384664 is a reply to message #384650] |
--------------030806020307050809080108
> Hi Lorenzo,
the patch here
hope this helps
Lorenzo
#P xtext.generator
@@ -103,8 +103,8 @@
�ENDIF-�
return rules;
--------------030806020307050809080108--
Re: [xtext] Error in the generated PartitionScanner [message #384901 is a reply to message #384880] |
Sat, 23 August 2008 17:10 |
Scott wrote:
> It seems to me that the problem is that the STRING definition is
> incorrect. See this thread for my explanation of why I think this:
> http://www.openarchitectureware.org/forum/viewtopic.php?show topic=9640
> Also, should I be posting on this newsgroup or that one?
As I also answered to that thread:
Actually, concerning the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243608, which
now should be fixed in the CVS, the strings with backslashed quotes used
to work correctly as before (the parser used to parse it correctly), it
was the highlighter that was wrong...
Re: [xtext] Error in the generated PartitionScanner [message #618902 is a reply to message #384445] |
Hi Lorenzo,
hope that helps,
Sven
> RULE_STRING :
> @Override
> return rules;
> @Override
> return rules;
> overwritten...
> thanks
> Lorenzo
Re: [xtext] Error in the generated PartitionScanner [message #619450 is a reply to message #384650] |
> Hi Lorenzo,
> @Override
> hope that helps,
> Sven
>> RULE_STRING :
>> @Override
>> return rules;
>> shape
>> @Override
>> return rules;
>> overwritten...
>> thanks
>> Lorenzo
Re: [xtext] Error in the generated PartitionScanner [message #619459 is a reply to message #384650] |
> Hi Lorenzo,
the patch here
hope this helps
Lorenzo
#P xtext.generator
@@ -103,8 +103,8 @@
�ENDIF-�
return rules;
Re: [xtext] Error in the generated PartitionScanner [message #619460 is a reply to message #384650] |
> Hi Lorenzo,
the patch here
hope this helps
Lorenzo
#P xtext.generator
@@ -103,8 +103,8 @@
�ENDIF-�
return rules;
Re: [xtext] Error in the generated PartitionScanner [message #620047 is a reply to message #384880] |
Current Time: Tue Apr 23 08:27:53 GMT 2024
Powered by FUDForum. Page generated in 0.06102 seconds
