Home » Modeling » Modeling (top-level project) » Problem with CDO/Teneo/Hibernate on Derby
Problem with CDO/Teneo/Hibernate on Derby [message #383233] Fri, 19 September 2008 08:22 Go to next message
Roger Stocker is currently offline Roger StockerFriend
I ran into a problem when I use the TeneoHibernateMapping for CDO on
Apache Derby Embedded:
org.hibernate.exception.GenericJDBCException: could not insert:
[org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl]
Caused by: org.apache.derby.iapi.services.io.DerbyIOException: A
truncation error was encountered trying to shrink CLOB 'XXXX' to length
255.
(below is a Stacktrace)
It happens when I commit the CDOTransaction after adding one eClass:
CDOSession session = configuration.openSession();
session.getPackageRegistry().putEPackage(PeoplePackage.eINST ANCE);
// Open transaction
CDOTransaction transaction = session.openTransaction();
transaction.setChangeSubscriptionPolicy(CDOChangeSubscriptio nPolicy.ALL);
CDOResource resource = transaction.createResource("/Test");
Person person = PeopleFactory.eINSTANCE.createPerson();
person.setFirstName("Hallo");
person.setLastName("Velo");
resource.getContents().add(person);
transaction.commit();
This is only happening with Derby Embedded, but not with Postgres. Also
using the storeType="db" is working with Derby.
My model is just a simple test model with 3 features (no relations).
Used Versions:
Eclipse SDK 3.4.1RC3
CDO 2.0.0-I200809110653
Net4j 2.0.0-I200809110620
Teneo 1.0.1-M200809150739
Derby 10.4.2
cdo-server.xml:
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<!-- negotiator type="challenge" description="/temp/users.db"/ -->
</acceptor>
<repository name="HPROTO">
<property name="overrideUUID"
value="1ff5d226-b1f3-45fb-afa2-0c30b38c764f" />
<property name="supportingAudits" value="false" />
<property name="verifyingRevisions" value="false" />
<property name="currentLRUCapacity" value="10000" />
<property name="revisedLRUCapacity" value="100" />
<property name="hibernate.hbm2ddl.auto" value="update" />
<property name="hibernate.show_sql" value="true" />
<property name="hibernate.connection.pool_size" value="10" />
<property name="hibernate.dialect"
value="org.hibernate.dialect.DerbyDialect" />
<property name="hibernate.connection.driver_class"
value="org.apache.derby.jdbc.EmbeddedDriver" />
<property name="hibernate.connection.url"
value="jdbc:derby:ProtoDB;create=true" />
<property name="hibernate.connection.autocommit" value="true" />
<property name="hibernate.cache.provider_class"
value="org.hibernate.cache.HashtableCacheProvider" />
<property name="teneo.mapping.inheritance" value="TABLE_PER_CLASS" />
<property name="teneo.naming.id_feature_as_primary_key" value="id" />
<store type="hibernate">
<mappingProvider type="teneo" />
</store>
</repository>
</cdoServer>
And the stacktrace:
2008-09-19 10:03:56 DEBUG org.hibernate.util.JDBCExceptionReporter could
not insert: [org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl]
[insert into cdo_packages (uri, ecore, dynamic, parentUri, metaIDStart,
metaIDSize, CDOPackageImpl) values (?, ?, ?, ?, ?, ?, ?)]
java.sql.SQLException: An unexpected exception was thrown
at
org.apache.derby.impl.jdbc.SQLExceptionFactory40.getSQLExcep tion(Unknown
Source)
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.Util.seeNextException(Unknown Source)
at
org.apache.derby.impl.jdbc.TransactionResourceImpl.wrapInSQL Exception(Unknown
Source)
at
org.apache.derby.impl.jdbc.TransactionResourceImpl.handleExc eption(Unknown
Source)
at org.apache.derby.impl.jdbc.EmbedConnection.handleException(U nknown
Source)
at org.apache.derby.impl.jdbc.ConnectionChild.handleException(U nknown
Source)
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(U nknown
Source)
at
org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeSta tement(Unknown
Source)
at
org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpd ate(Unknown
Source)
at
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2278)
at
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2688)
at
org.hibernate.action.EntityInsertAction.execute(EntityInsert Action.java:79)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:27 9)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:263)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:167)
at
org.hibernate.event.def.AbstractFlushingEventListener.perfor mExecutions(AbstractFlushingEventListener.java:321)
at
org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:50)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1027)
at org.hibernate.impl.SessionImpl.managedFlush(SessionImpl.java :365)
at
org.hibernate.transaction.JDBCTransaction.commit(JDBCTransac tion.java:137)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernatePacka geHandler.writePackages(HibernatePackageHandler.java:145)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Writer.writePackages(HibernateStoreWriter.java:197)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Writer.write(HibernateStoreWriter.java:60)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext Impl.write(TransactionCommitContextImpl.java:227)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicatingCommit(CommitTransactionIndication.ja va:167)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:68)
at
org.eclipse.emf.cdo.internal.server.protocol.CDOServerIndica tion.indicating(CDOServerIndication.java:116)
at org.eclipse.net4j.signal.Indication.execute(Indication.java: 48)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:38)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:186)
at org.eclipse.net4j.signal.Signal.run(Signal.java:167)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: java.sql.SQLException: An unexpected exception was thrown
at org.apache.derby.impl.jdbc.SQLExceptionFactory.getSQLExcepti on(Unknown
Source)
at
org.apache.derby.impl.jdbc.SQLExceptionFactory40.wrapArgsFor TransportAcrossDRDA(Unknown
Source)
... 35 more
Caused by: java.sql.SQLException: Java exception: 'A truncation error was
encountered trying to shrink CLOB 'XXXX' to length 255.:
org.apache.derby.iapi.services.io.DerbyIOException'.
Source)
at
Source)
at
Source)
at org.apache.derby.impl.jdbc.Util.javaException(Unknown Source)
at
Source)
... 32 more
255.
at org.apache.derby.iapi.types.ReaderToUTF8Stream.truncate(Unkn own Source)
at
org.apache.derby.iapi.types.ReaderToUTF8Stream.checkSufficie ntData(Unknown
Source)
at org.apache.derby.iapi.types.ReaderToUTF8Stream.fillBuffer(Un known
Source)
at org.apache.derby.iapi.types.ReaderToUTF8Stream.read(Unknown Source)
at org.apache.derby.impl.store.raw.data.MemByteHolder.write(Unk nown
Source)
at
org.apache.derby.impl.store.raw.data.RememberBytesInputStrea m.fillBuf(Unknown
Source)
at org.apache.derby.impl.store.raw.data.StoredPage.logColumn(Un known
Source)
at org.apache.derby.impl.store.raw.data.StoredPage.logRow(Unkno wn Source)
at
org.apache.derby.impl.store.raw.data.InsertOperation.writeOp tionalDataToBuffer(Unknown
Source)
at org.apache.derby.impl.store.raw.data.InsertOperation.<init>(Unknown
Source)
at
org.apache.derby.impl.store.raw.data.LoggableActions.actionI nsert(Unknown
Source)
at org.apache.derby.impl.store.raw.data.BasePage.insertNoOverfl ow(Unknown
Source)
at org.apache.derby.impl.store.raw.data.BasePage.insertAtSlot(U nknown
Source)
at org.apache.derby.impl.store.raw.data.StoredPage.insertAtSlot (Unknown
Source)
at org.apache.derby.impl.store.raw.data.BasePage.insert(Unknown Source)
at
org.apache.derby.impl.store.access.heap.HeapController.doIns ert(Unknown
Source)
at
org.apache.derby.impl.store.access.heap.HeapController.inser tAndFetchLocation(Unknown
Source)
at org.apache.derby.impl.sql.execute.RowChangerImpl.insertRow(U nknown
Source)
at
org.apache.derby.impl.sql.execute.InsertResultSet.normalInse rtCore(Unknown
Source)
at org.apache.derby.impl.sql.execute.InsertResultSet.open(Unkno wn Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(U nknown
Source)
... 28 more
Any clue what could be wrong?
Roger
Re: Problem with CDO/Teneo/Hibernate on Derby [message #383234 is a reply to message #383233] Fri, 19 September 2008 10:18 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Hi Roger,
I added the EMF newsgroup to the list of recipients because CDO is
supported there.
From a first look I don't think that your code is obviously wrong
somewhere.
Can you please open a Bugzilla so that we can discuss and keep track?
Cheers
/Eike
Roger schrieb:
> Hi
> length 255.
> // Open transaction
> Also using the storeType="db" is working with Derby.
> Used Versions:
> Derby 10.4.2
> cdo-server.xml:
> <cdoServer>
> </acceptor>
> value="true" />
> value="id" />
> </store>
> </repository>
> </cdoServer>
> And the stacktrace:
> could not insert:
> [org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl] [insert
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> ... 35 more
> was encountered trying to shrink CLOB 'XXXX' to length 255.:
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> ... 32 more
> length 255.
> Source)
> at
> Source)
> at
> org.apache.derby.iapi.types.ReaderToUTF8Stream.fillBuffer(Un known Source)
> Source)
> at
> org.apache.derby.impl.store.raw.data.MemByteHolder.write(Unk nown Source)
> at
> Source)
> at
> org.apache.derby.impl.store.raw.data.StoredPage.logColumn(Un known Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> ... 28 more
> Regards
> Roger
Re: Problem with CDO/Teneo/Hibernate on Derby [message #383235 is a reply to message #383234] Fri, 19 September 2008 10:26 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Roger, Eike,
My guess is that the default length is 255 for a text/varchar/clob and that derby throws an
exception when a longer string is inserted. While other database just truncate without exception.
You can try to solve this by adding the following annotation to the efeature which has the clob:
@Column(length=1000) (replace 1000 with the length you want to support.
Here is more information on how to set annotations in your model:
http://www.elver.org/hibernate/ejb3_format.html
gr. Martin
Eike Stepper wrote:
> Hi Roger,
> supported there.
> somewhere.
> Cheers
> /Eike
> Roger schrieb:
>> Hi
>> length 255.
>> // Open transaction
>> Used Versions:
>> Derby 10.4.2
>> cdo-server.xml:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cdoServer>
>> </acceptor>
>> value="true" />
>> value="id" />
>> </store>
>> </repository>
>> </cdoServer>
>> And the stacktrace:
>> could not insert:
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> ... 35 more
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> ... 32 more
>> length 255.
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> ... 28 more
>> Regards
>> Roger
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Problem with CDO/Teneo/Hibernate on Derby [message #383236 is a reply to message #383235] Fri, 19 September 2008 12:24 Go to previous messageGo to next message
I am sorry, but I don't see where to put an annotation.
Since it happens at the insert of the CDOPackageImpl, I assume this must
be inside org.eclipse.emf.cdo.server.hibernate/mappings/meta.hbm.xml.
I can see this here (in meta.hbm.xml):
<joined-subclass name="CDOPackageImpl" table="cdo_packages" lazy="false"
extends="CDOModelElementImpl">
<key />
<property name="ecore" type="text" not-null="false" />
I guess, it must be the ecore property, which is of type text and
obviously gets mapped to a CLOB with size 255 in Derby.
After putting a length="32767" there, I get a different exception:
Thread-6 [debug] Persisted new Object Person id: HBM-Person-32'768
2008-09-19 14:20:06 DEBUG
org.hibernate.event.def.AbstractFlushingEventListener processing
flush-time cascades
org.hibernate.event.def.AbstractFlushingEventListener dirty checking
collections
2008-09-19 14:20:06 DEBUG org.hibernate.engine.Collections
Collection found: [CDOResource.contents#1], was: [<unreferenced>]
(initialized)
org.hibernate.event.def.AbstractFlushingEventListener Flushed: 2
insertions, 0 updates, 0 deletions to 2 objects
org.hibernate.event.def.AbstractFlushingEventListener Flushed: 1
(re)creations, 0 updates, 0 removals to 1 collections
2008-09-19 14:20:06 DEBUG org.hibernate.pretty.Printer
listing entities:
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl
2008-09-19 14:20:06 DEBUG org.hibernate.jdbc.AbstractBatcher about
to open PreparedStatement (open PreparedStatements: 0, globally: 0)
2008-09-19 14:20:06 DEBUG org.hibernate.jdbc.util.SQLStatementLogger
insert into "cdo_resources" (e_version, path, "dtype", e_id) values (?, ?,
'cdoresource', ?)
Hibernate: insert into "cdo_resources" (e_version, path, "dtype", e_id)
values (?, ?, 'cdoresource', ?)
to close PreparedStatement (open PreparedStatements: 1, globally: 1)
insert into "person" (e_version, _resID_Entity, _resID_ID, _resID_class,
_contID_Entity, _contID_ID, _contID_class, _contFeatureID, "firstname",
"lastname", e_id) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
Hibernate: insert into "person" (e_version, _resID_Entity, _resID_ID,
_resID_class, _contID_Entity, _contID_ID, _contID_class, _contFeatureID,
"firstname", "lastname", e_id) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
2008-09-19 14:20:06 DEBUG org.hibernate.util.JDBCExceptionReporter could
not insert: [Person] [insert into "person" (e_version, _resID_Entity,
_resID_ID, _resID_class, _contID_Entity, _contID_ID, _contID_class,
_contFeatureID, "firstname", "lastname", e_id) values (?, ?, ?, ?, ?, ?,
java.sql.SQLSyntaxErrorException: Syntax error: Encountered "_" at line 1,
column 34.
at
Source)
at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unkno wn Source)
at
Source)
at
Source)
Source)
Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.<init>(Unknown
Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement20.<init>(Unknown
Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement30.<init>(Unknown
Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement40.<init>(Unknown
Source)
at org.apache.derby.jdbc.Driver40.newEmbedPreparedStatement(Unk nown
Source)
at org.apache.derby.impl.jdbc.EmbedConnection.prepareStatement( Unknown
Source)
Source)
at
org.hibernate.jdbc.AbstractBatcher.getPreparedStatement(Abst ractBatcher.java:534)
at
org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:116)
at
org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:109)
at
org.hibernate.jdbc.AbstractBatcher.prepareBatchStatement(Abs tractBatcher.java:244)
at
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2252)
at
at
at
at
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Writer.write(HibernateStoreWriter.java:110)
at
at
at
at
at
Caused by: java.sql.SQLException: Syntax error: Encountered "_" at line 1,
column 34.
Source)
at
Source)
... 38 more
Caused by: ERROR 42X01: Syntax error: Encountered "_" at line 1, column 34.
at org.apache.derby.iapi.error.StandardException.newException(U nknown
Source)
at org.apache.derby.impl.sql.compile.ParserImpl.parseStatement( Unknown
Source)
at org.apache.derby.impl.sql.GenericStatement.prepMinion(Unknow n Source)
at org.apache.derby.impl.sql.GenericStatement.prepare(Unknown Source)
at
org.apache.derby.impl.sql.conn.GenericLanguageConnectionCont ext.prepareInternalStatement(Unknown
Source)
... 32 more
I'll open a Bugzilla...
Roger
Re: Problem with CDO/Teneo/Hibernate on Derby [message #383237 is a reply to message #383236] Fri, 19 September 2008 15:41 Go to previous message
Hi Roger,
I will change the mapping for the epackage. The stack trace you mention below is related to the fact
that derby does not support _ as the first character of a column/table name. If you can enter a
bugzilla for that one to then I can change that to.
gr. Martin
Roger wrote:
> Hi
> <key />
> flush-time cascades
> collections
> (initialized)
> listing entities:
> about to open PreparedStatement (open PreparedStatements: 0, globally: 0)
> about to close PreparedStatement (open PreparedStatements: 1, globally: 1)
> could not insert: [Person] [insert into "person" (e_version,
> _resID_Entity, _resID_ID, _resID_class, _contID_Entity, _contID_ID,
> _contID_class, _contFeatureID, "firstname", "lastname", e_id) values (?,
> 1, column 34.
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedConnection.handleException(U nknown Source)
> at
> org.apache.derby.impl.jdbc.ConnectionChild.handleException(U nknown Source)
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedPreparedStatement20.<init>(Unknown Source)
> at
> org.apache.derby.impl.jdbc.EmbedPreparedStatement30.<init>(Unknown Source)
> at
> org.apache.derby.impl.jdbc.EmbedPreparedStatement40.<init>(Unknown Source)
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedConnection.prepareStatement( Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> 1, column 34.
> at
> Source)
> at
> Source)
> ... 38 more
> at
> org.apache.derby.iapi.error.StandardException.newException(U nknown Source)
> at
> org.apache.derby.impl.sql.compile.ParserImpl.parseStatement( Unknown Source)
> Source)
> at
> Source)
> ... 32 more
> Thanks
> Roger
The Netherlands
Re: Problem with CDO/Teneo/Hibernate on Derby [message #611007 is a reply to message #383233] Fri, 19 September 2008 10:18 Go to previous message
Hi Roger,
supported there.
somewhere.
Cheers
/Eike
Roger schrieb:
> Hi
> length 255.
> // Open transaction
> Used Versions:
> Derby 10.4.2
> cdo-server.xml:
> <cdoServer>
> </acceptor>
> value="true" />
> value="id" />
> </store>
> </repository>
> </cdoServer>
> And the stacktrace:
> could not insert:
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> ... 35 more
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> ... 32 more
> length 255.
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> ... 28 more
> Regards
> Roger
Re: Problem with CDO/Teneo/Hibernate on Derby [message #611010 is a reply to message #383234] Fri, 19 September 2008 10:26 Go to previous message
Hi Roger, Eike,
gr. Martin
Eike Stepper wrote:
> Hi Roger,
> supported there.
> somewhere.
> Cheers
> /Eike
> Roger schrieb:
>> Hi
>> length 255.
>> // Open transaction
>> Used Versions:
>> Derby 10.4.2
>> cdo-server.xml:
>> <cdoServer>
>> </acceptor>
>> value="true" />
>> value="id" />
>> </store>
>> </repository>
>> </cdoServer>
>> And the stacktrace:
>> could not insert:
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> ... 35 more
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> ... 32 more
>> length 255.
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> ... 28 more
>> Regards
>> Roger
The Netherlands
Re: Problem with CDO/Teneo/Hibernate on Derby [message #611012 is a reply to message #383235] Fri, 19 September 2008 12:24 Go to previous message
<key />
flush-time cascades
collections
(initialized)
listing entities:
'cdoresource', ?)
column 34.
at
Source)
at
Source)
at
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
column 34.
Source)
at
Source)
... 38 more
Source)
Source)
at
Source)
... 32 more
Roger
Re: Problem with CDO/Teneo/Hibernate on Derby [message #611014 is a reply to message #383236] Fri, 19 September 2008 15:41 Go to previous message
Hi Roger,
gr. Martin
Roger wrote:
> Hi
> <key />
> flush-time cascades
> collections
> (initialized)
> listing entities:
> 1, column 34.
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> 1, column 34.
> at
> Source)
> at
> Source)
> ... 38 more
> at
> at
> Source)
> at
> Source)
> ... 32 more
> Thanks
> Roger
The Netherlands
Previous Topic:Problem with CDO/Teneo/Hibernate on Derby
Next Topic:Anyone still use UML 1.4? Anyone have a UML 1.4 to UML 2.1 XMI file converter?
Current Time: Tue Apr 16 09:35:43 GMT 2024
Powered by FUDForum. Page generated in 0.19767 seconds
