How to get Element Content rather than Attribute [message #383195] |
Mon, 01 September 2008 20:20 |
I am trying to find a way to coerce EMF to model some text as Element
content rather than as an Attribute. To make this explicit, how EMF
normally serialises at String field is as such:
<epo:PurchaseOrder xmlns:epo="http://www.example.com/ExtendedPO">
<details description="This could potentially be a very long string."/>
</epo:PurchaseOrder>
The value of "description" could be any length, f.i. it could be stored
as a CLOB.
What I would like EMF to produce is:
<details>
<description>This could potentially be a very long string.</description >
</details>
Is it possible to get EMF to co-operate in this way?
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme
|) ::: (| The Open Requirements Management Too
====w=w==== [https://useme.dev.java.net]
Re: How to get Element Content rather than Attribute [message #383201 is a reply to message #383195] |
Fri, 05 September 2008 20:15 |
I have added eclipse.tools.emf to the list as per Ed's advice on another post.
Thanks Ed,
Joel
On 2008-09-01 21:20:58 +0100, Joel Rosi-Schwartz
<Joel.Rosi-Schwartz@Etish.org> said:
> as a CLOB.
> <details>
> </details>
> Joel
Joel Rosi-Schwartz
Re: How to get Element Content rather than Attribute [message #383208 is a reply to message #383203] |
Mon, 08 September 2008 10:18 |
Works like a charm, thanks Ed. One small correction is that it is
XMLResource.OPTION_EXTENDED_META_DATA rather than
XMLResource.OPTION_EXTENDED_METADATA
Btw, for others who may use this thread for assistance in the future, I
found that Chapter 9 "XML Schema" of the "EMF: Eclipse Modeling
Framework, Second Edition" fills in a lot of the details about this. It
is currently on Safari Rough Cuts at
http://safari.oreilly.com/9780321331885
All the best,
Joel
Joel Rosi-Schwartz
Re: How to get Element Content rather than Attribute [message #610547 is a reply to message #383195] |
Thanks Ed,
Joel
> as a CLOB.
> <details>
> </details>
> Joel
Joel Rosi-Schwartz
Re: How to get Element Content rather than Attribute [message #610548 is a reply to message #383201] |
Fri, 05 September 2008 20:27 |
Ed Merks Messages: 33140 Registered: July 2009 |
Joel,
Sorry I missed your original post. :-(
Comments below.
> another post.
> Thanks Ed,
> Joel
>> Hi,
>> <?xml version="1.0" encoding="UTF-8"?>
>> stored as a CLOB.
>> <details>
>> </details>
Yes. You could include a annotation like this on the "description"
EAttribute.
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="element"/>
</eAnnotations>
Then you need to ensure that you use
XMLResource.OPTION_EXTENDED_METADATA when serializing. If you have a
generated resource factory the option should be generated for you. If
you don't, you can use the GenPackage Resource Type property to ensure
one gets generated. Keep in mind that plugin.xml isn't regenerated so
the registration won't get added if there already is one.
>> Thanks,
>> Joel
Ed Merks
Re: How to get Element Content rather than Attribute [message #610551 is a reply to message #383203] |
All the best,
Joel
Joel Rosi-Schwartz
FUDForum. Page generated in 0.04543 seconds
