Home » Archived » XML Schema Definition (XSD) » Schema Validation Problem
Schema Validation Problem [message #39105] |
Sat, 20 March 2004 00:08 |
Originally posted by: cipher8000.yahoo.com
I am using 20040127_1738SL build. I have two schemas 1.boo.xsd 2. foo.xsd.
boo.xsd imports "foo" schema. foo.xsd is invalid because i used
type="xsd:aaaa". When i validate boo.xsd, the validate() doesn't populate
any diagnostic error messages. But if i validate foo.xsd seperately, i get
diagnostic error messages for unresolved type "xsd:aaaa"
this combination used to work in previous build.
here is the boo.xsd:
<schema attributeFormDefault="qualified" elementFormDefault="qualified"
targetNamespace="http://schemas.xmlsoap.org/wsdl/"
xmlns="http://www.w3.org/2001/XMLSchema" xmlns:foo="http://foo.com">
<import namespace="http://foo.com" schemaLocation="foo.xsd"/>
<element name="fooElement" type="foo:fooElementType"/>
</schema>
here is the foo.xsd
<xsd:schema targetNamespace="http://foo.com"
xmlns="http://foo.com"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified">
<xsd:complexType name="fooElementType">
<xsd:sequence>
<xsd:element name="end" type="xsd:aaaa"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
thanks
-muruga
Re: Schema Validation Problem [message #39136 is a reply to message #39105] |
Sat, 20 March 2004 00:28 |
I tried the latest build Build I20040308163 also. It behaves same.
thanks
-muruga
"Muruga Chinnananchi" <cipher8000@yahoo.com> wrote in message
news:c3g1oj$5i6$1@eclipse.org...
> </schema>
> here is the foo.xsd
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> thanks
> -muruga
Re: Schema Validation Problem [message #39167 is a reply to message #39105] |
Mon, 22 March 2004 11:43 |
Muruga,
You have to collect diagnostics from each schema resource; it's always worked
this way. Have a look at how the XSDMainTest supports -validate by walking
each resource.
> </schema>
> here is the foo.xsd
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> thanks
> -muruga
Re: Schema Validation Problem [message #39198 is a reply to message #39167] |
Tue, 23 March 2004 00:07 |
Hi Ed,
Thanks very much. It works now. I traverse all the imports and try to
validate them seperately.
I have another problem. I have a schema eoli.xsd, XMLSpy validates with no
error. But eclipse xsd throws these error when i tried to validate. I am
attaching this schema (eoli.xsd). Looks like this is valid schema.
Error at line 374, in
"file:////c:/customer/spacebel/HelloWorld/services/eoli.xsd". XSD: The type
of element 'http://earth.esa.int/XML/eoli#geoEle' must derive from
'http://earth.esa.int/XML/eoli#geoEle_._type'
Error at line 401, in
of element 'http://earth.esa.int/XML/eoli#tempEle' must derive from
'http://earth.esa.int/XML/eoli#EX_TemporalExtendType'
Error at line 370, in
restricted content type must accept a subset of the content accepted by the
base type
Error at line 791, in
base type
thanks,
-muruga
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:405ED169.43E4B2DB@ca.ibm.com...
> Muruga,
worked
walking
> each resource.
foo.xsd.
populate
get
> > </schema>
> > here is the foo.xsd
> > <xsd:sequence>
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:schema>
> > thanks
> > -muruga
Re: Schema Validation Problem [message #39228 is a reply to message #39198] |
Tue, 23 March 2004 00:09 |
oops i forgot to attach that schema file.
thanks
-muruga
news:c3nurp$r8$1@eclipse.org...
> Hi Ed,
type
type
the
> base type
the
> base type
> thanks,
> -muruga
> > Muruga,
> worked
> walking
> > each resource.
> foo.xsd.
> populate
> get
> > > </schema>
> > > here is the foo.xsd
> > > <xsd:sequence>
> > > </xsd:sequence>
> > > </xsd:complexType>
> > > </xsd:schema>
> > > thanks
> > > -muruga
Attachment: eoli.xsd
(Size: 46.23KB, Downloaded 344 times)
Re: Schema Validation Problem [message #39259 is a reply to message #39228] |
Tue, 23 March 2004 11:11 |
Muruga,
These all appear to be legitimate errors that XMLSpy overlooked.
> thanks
> -muruga
> > Hi Ed,
> type
> type
> the
> > base type
> the
> > base type
> > thanks,
> > -muruga
> > > Muruga,
> > worked
> > walking
> > > each resource.
> > foo.xsd.
> > populate
> > get
> > > > </schema>
> > > > here is the foo.xsd
> > > > <xsd:sequence>
> > > > </xsd:sequence>
> > > > </xsd:complexType>
> > > > </xsd:schema>
> > > > thanks
> > > > -muruga
> eoli.xsd Type: unspecified type (application/octet-stream)
> Encoding: x-uuencode
Re: Schema Validation Problem [message #584332 is a reply to message #39105] |
thanks
-muruga
> </schema>
> here is the foo.xsd
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> thanks
> -muruga
Re: Schema Validation Problem [message #584348 is a reply to message #39105] |
Ed Merks Messages: 33140 Registered: July 2009 |
Muruga,
each resource.
> </schema>
> here is the foo.xsd
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> thanks
> -muruga
Ed Merks
Re: Schema Validation Problem [message #584366 is a reply to message #39167] |
Hi Ed,
base type
base type
thanks,
-muruga
> Muruga,
worked
walking
> each resource.
foo.xsd.
populate
get
> > </schema>
> > here is the foo.xsd
> > <xsd:sequence>
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:schema>
> > thanks
> > -muruga
Re: Schema Validation Problem [message #584377 is a reply to message #39198] |
thanks
-muruga
> Hi Ed,
type
type
the
> base type
the
> base type
> thanks,
> -muruga
> > Muruga,
> worked
> walking
> > each resource.
> foo.xsd.
> populate
> get
> > > </schema>
> > > here is the foo.xsd
> > > <xsd:sequence>
> > > </xsd:sequence>
> > > </xsd:complexType>
> > > </xsd:schema>
> > > thanks
> > > -muruga
(Size: 46.23KB, Downloaded 269 times)
Re: Schema Validation Problem [message #584394 is a reply to message #39228] |
Muruga,
> thanks
> -muruga
> > Hi Ed,
> type
> type
> the
> > base type
> the
> > base type
> > thanks,
> > -muruga
> > > Muruga,
> > worked
> > walking
> > > each resource.
> > foo.xsd.
> > populate
> > get
> > > > </schema>
> > > > here is the foo.xsd
> > > > <xsd:sequence>
> > > > </xsd:sequence>
> > > > </xsd:complexType>
> > > > </xsd:schema>
> > > > thanks
> > > > -muruga
Ed Merks
Current Time: Thu Apr 25 09:27:55 GMT 2024
Powered by FUDForum. Page generated in 0.04511 seconds
