Home » Modeling » Modeling (top-level project) » Generating code with stereotypes
Re: Generating code with stereotypes [message #381147 is a reply to message #381131] |
Fri, 20 July 2007 11:38 |
Jose Messages: 51 Registered: July 2009 |
Member |
Thanks James-Bruck,
But Omondo's group can generate code using UML2 and EMF, so that I could
not do it?
Excuse me if the question is very stupid.
Thanks.
James Bruck escribió:
> Hi Jose,
> Information from arbitrary stereotypes is not used in the conversion from
> uml to ecore.
> There is some facility to generate code from OCL when it is used in the
> original model but not when it is in an applied stereotype ( check out the
> new and noteworthy section for some details. ).
> UML also now has the means to use static profile definition ( also see new
> and noteworthy ), but this might not be what you are interested in.
> There does seem to be an outstanding defect that might be similar to what
> you are looking for https://bugs.eclipse.org/bugs/show_bug.cgi?id=101404.
> You might want to state your exact needs in a bugzilla or add to the one I
> just mentioned and it will be looked into.
> - James.
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:f785au$g6s$1@build.eclipse.org...
>> Jose,
>> Probably it's best to start with the UML newsgroup with this question,
>> so I've added that to the "to" list of my reply. I'm not sure what it
>> does with arbitrary stereotypes, but I think it throws them away. The
>> closest equivalent concept in Ecore would be an EAnnotation, so you
>> might need to use that.
>> Jose wrote:
>>> Hi,
>>> How can I generate code with EMF from a UML Diagram that uses
>>> stereotypes? With OCL? EAnnotation from EMF?
>>> What have I to do for not lost the stereotypes and generate code
>>> correctly?
>>> Thanks.
>>> (Sorry for my English).
Re: Generating code with stereotypes [message #381151 is a reply to message #381149] |
Fri, 20 July 2007 14:54 |
Member |
Thank you very much, James
James Bruck wrote:
> Hi Jose,
> I'm not sure I'm interpreting your question correctly.
> Are you saying that Omondo can generate code from applied stereotypes from
> some specific profile?
> or are you saying that Omondo can generate code from UML2 in general?
> If it's the first case: I'm not familiar with Omondo but they might be
> extending the uml to ecore converter in some way. The existing
> UML2EcoreConverter does for example take the Ecore profile into account in
> the conversion process. Perhaps Omondo does something special with another
> profile?
> If it's the second case: You can generate code using UML2 by converting to
> ecore and then generating code from the ecore representation.
> By adding a stereotype you are introducing a new item at the meta model
> level. I'm not sure how the general uml to ecore converter can interpret
> this new meta level property. Ultimately, code generation from uml happens
> by first mapping the uml representation to an ecore representation and then
> code generation occurrs from ecore. There would have to be some agreed
> upon mapping from these newly introduced values within the stereotype to an
> - James.
> "Jose" <ja.navarro.a@alumnos.urjc.es> wrote in message
> news:f7q6sj$d5s$1@build.eclipse.org...
>> Thanks James-Bruck,
>> not do it?
>> Thanks.
>> James Bruck wrote:
>>> Hi Jose,
> from
>>> uml to ecore.
> the
> new
> what
>>> you are looking for
> I
>>> - James.
>>>> Jose,
>>>> Jose wrote:
>>>>> Hi,
>>>>> correctly?
>>>>> Thanks.
Re: Generating code with stereotypes [message #596800 is a reply to message #380830] |
Fri, 13 July 2007 15:21 |
Ed Merks Messages: 33141 Registered: July 2009 |
Jose,
Jose wrote:
> correctly?
> Thanks.
Ed Merks
Re: Generating code with stereotypes [message #596945 is a reply to message #381131] |
Member |
Thanks James-Bruck,
not do it?
Thanks.
> Hi Jose,
> uml to ecore.
> - James.
>> Jose,
>> Jose wrote:
>>> Hi,
>>> correctly?
>>> Thanks.
Re: Generating code with stereotypes [message #596979 is a reply to message #381149] |
Member |
James Bruck wrote:
> Hi Jose,
> profile?
> - James.
>> Thanks James-Bruck,
>> not do it?
>> Thanks.
>> James Bruck wrote:
>>> Hi Jose,
> from
>>> uml to ecore.
> the
> new
> what
>>> you are looking for
> I
>>> - James.
>>>> Jose,
>>>> Jose wrote:
>>>>> Hi,
>>>>> correctly?
>>>>> Thanks.
Current Time: Thu Apr 25 16:44:03 GMT 2024
Powered by FUDForum. Page generated in 0.03947 seconds
